Hi there,
I have a 2014 plate Seat Alhambra LUX (Same as Volkswagen Sharan SEL).
It comes with almost every extra
I have a Micro-CAN usb Dongle for the Scan
basically the element heater works and heat comes from the front
ventilators, however, the rear ventilators are supposed to blow heat
after the main water heater matrix system heats up and supplys
warm air to both the front and rear ventilators.
hoping I got the above statement correct, seems to me the heater
element is not turning off or some sort of valve is not switching to let the
heat from the heater matrix supply heat to the whole car.
could you let me know who to email so I can let them know this problem
please ? my car is also showing no errors on a full scan relating the
heater problem....
Also I do not know what the headlight range fault is....
Here is a Scan I have just done below..
heater problem....
Friday,09,November,2018,11:56:11:02076
VCDS Version: 18.9.0.2
VIN: VSSZZZ7NZEV509772 License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 20 25 2E 37 42 44 46 4C 4F
52 53 55 56 61 62 6C 6D 72 BE BF
VIN: VSSZZZ7NZEV509772 Mileage: 66690km-41439miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFGC) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 RJ HW: 03L 906 018 M
Component: R4 2,0L EDC H28 4827
Revision: 44H28--- Serial number:
Coding: 001D001A042501080000
Shop #: WSC 00000 210 00000
ASAM Dataset: EV_ECM20TDI01103L906018RJ 003003
ROD: EV_ECM20TDI01103L906018F.rod
VCID: 032B5E498A1D0452C8-8056
Part No SW: 02E 300 062 M HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4007
Revision: 05652104 Serial number: 00001310160498
Shop #: WSC 00020 000 90108
VCID: 1F633239CEB5C0B2CC-804A
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 P HW: 7N0 614 109 P
Component: J104 C3 450M VDCC 0030
Revision: --H07--- Serial number: 00000007543888
Coding: 0028295
Shop #: WSC 00020 790 00000
VCID: 3A55E3AD7557859ADB-806E
Part No SW: 7N0 907 044 AA HW: 7N0 907 044 AA
Component: Clima-Sharan H02 0404
Revision: 00001K02
Coding: 021010C549
Shop #: WSC 00020 999 00000
VCID: 6FC302F9B69510323C-803A
Slave 1:
Subsystem 1 - Part No SW: 7N0 907 049 C HW: 7N0 907 049 C
Component: KBT-H 004 0103
Serial number: 20131028000000136258
Part No SW: 5K0 937 086 Q HW: 5K0 937 086 Q
Component: BCM PQ35 M 122 0173
Revision: BC122001
Coding: 40590A3BE925F1C0508800C87400896443559388636D2F626484C72000C1
Shop #: WSC 00020 790 12345
VCID: 42A59B4DDD87CD5A83-8016
Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 130831 31 0032
Serial number: 130902203702
Coding: 004DBD
Component: RLFS 024 0042
Serial number: Y13M10D23H18M54S19S1
Coding: 0728DD
Subsystem 3 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 157
Reset counter: 204
Mileage: 64168 km
Date: 2018.08.23
Time: 02:35:40
Term 15 Off
Voltage: 11.90 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 7N0 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0012
Revision: -------- Serial number: 28231330101259
Coding: 308102
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 3957FCA1B8518E82D2-806C
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag00M H12 0014
Serial number: 003LGPMY81WX
Coding: 00304D
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3FA392B9A675A0B2EC-806A
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60FCC3C318DDG
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS603D30DC18DD
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS6027D6DB189D0
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60150EDC189D.
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS6002DEE1189DQ
Part No SW: 5K0 953 521 BD HW: 5K0 953 569 B
Revision: FF010042 Serial number: 20131025300890
Coding: 189A240000
ROD: EV_SMLSNGVOLWS.rod
Subsystem 1 - Part No SW: 1P0 959 538 B HW: 1P0 959 538 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0103
Coding: E30000
Part No SW: 7N5 920 970 J HW: 7N5 920 970 J
Component: KOMBI H04 0811
Coding: 441F01
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 E
Component: Zuheizer 051 2940
Revision: 00051000 Serial number: 09024297000000
Coding: 0000041
VCID: 364DF79D414F61FA3F-8062
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 151013F1001117
Coding: 468203
VCID: 7BDB26A9FAED7C9280-802E
Part No SW: 7N0 857 511 P HW: 8P0 857 511 C
Component: FLA H04 0012
Revision: AA001002
Coding: 0202816B74745D545420363E01
VCID: 40A19145D38BDF4A95-8014
Component: IMMO H04 0811
VCID: 6AF513ED8D77F51A6B-803E
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7665387944
Coding: 020100
VCID: 2B7BD6E94A0D2C1250-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 5P0 035 192 D HW: 5P0 035 192 D
Component: RNS315-EU H76 0415
Serial number: SEZAZ2N0585055
Coding: 040004010400240000061002
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 2D7FD8F17C1922224E-8078
Component: EUR_W_V5 0055
8 Faults Found:
1048593 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
Reset counter: 63
Mileage: 64168 km
Date: 2018.08.23
Time: 00:50:32
1048594 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
Reset counter: 63
Mileage: 64168 km
Date: 2018.08.23
Time: 00:50:32
1048595 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Reset counter: 63
Mileage: 64168 km
Date: 2018.08.23
Time: 00:50:32
1048596 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
Reset counter: 63
Mileage: 64168 km
Date: 2018.08.23
Time: 00:50:32
1048597 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
Reset counter: 63
Mileage: 64168 km
Date: 2018.08.23
Time: 00:50:34
1048598 - Front Right Treble Speaker
B1064 13 [009] - Open Circuit
Reset counter: 63
Mileage: 64168 km
Date: 2018.08.23
Time: 00:50:34
1048599 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
Reset counter: 63
Mileage: 64168 km
Date: 2018.08.23
Time: 00:50:34
1048600 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Reset counter: 63
Mileage: 64168 km
Date: 2018.08.23
Time: 00:50:34
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 G HW: 7N0 959 793 G
Component: TSG FA H03 0553
Revision: Serial number: 0000077764455
Coding: 01112E209001411011
VCID: 46AD875DF1AFF17AAF-8012
Address 44: Steering Assist Labels: None
Part No: 7N0 909 144 R
Component: EPS_ZFLS Kl. 278 3501
Revision: 00H21000
VCID: 42A59B4D1D87CD5A83-8016
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 050B0500
VCID: 6FC302F9BE9510323C-803A
Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 G HW: 7N0 959 792 G
Component: TSG BF H03 0553
Revision: Serial number: 0000079376892
Coding: 01112C209E01411011
VCID: 45AF8051CCA9FA62A6-8010
Revision: H19 Serial number: 00000001541669
Coding: 0024167
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 068600000B000000
Shop #: WSC 00020 999 39850
VCID: 3753FA998E4598F224-8062
Subsystem 1 - Part No: 1T0 941 329 B Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 1T0 941 329 B Labels: 3D0-941-329.CLB
5275648 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Reset counter: 184
Mileage: 66332 km
Date: 2018.10.30
Time: 11:51:52
Part No SW: 7N0 907 534 HW: 7N0 907 530 AM
Component: Batt.regelung H55 1642
Coding: 030F1859
VCID: 71C70481A8A106C22A-8024
Component: J367-BDM H07 0180
Serial number: 40306749381491323443
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 H HW: 7N0 959 794 H
Component: TSG HL H01 0554
Revision: Serial number: 0000078074546
Coding: 01006C200001411001
VCID: 48B18965FBBBE70A5D-801C
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7N0 907 441 HW: 7N0 907 441
Component: J772__Rearview 0020
Revision: 00H13000 Serial number: 525 PA8J393971
Coding: 0020011
VCID: 6EFD1FFD799F193A37-803A
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 E HW: 7N0 959 107 A
Component: HDSG-Modul H11 0243
Revision: 41011001 Serial number: 284300352
Coding: 0733334002
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H01 0554
Revision: Serial number: 0000078077249
Address BE: Slid. Door Rear Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 A HW: 7N0 959 244 A
Component: Schiebetuer_l 005 2314
Serial number: 13404369
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
Address BF: Slid. Door Rear Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2314
Serial number: 13404108
ROD: EV_AST.rod
End-------------------------(Elapsed Time: 03:36)--------------------------
