No spark on 3-rd cylinder
bane
Unverified
Macedonia
Hi need advice or help with no spark at all on 3rd-cylinder on polo 1.4 16v AFH engine. Alredy Cheked the cable with unimeter changed the rotor arm cleaned the contacts in the dizzy changed the spark plugs but yet no spark. What could tehnicly cause that and whats the best way to diagnose this.
Thanks in advance
Cheers!
PetrolDave
Westbury, UK
C?ID=1423
Must be a pretty old polo to have a distributor?
An Auto-Scan would be useful.
Tried checking the continuity in the distributor cap?
bane
Unverified
Macedonia
yes its 1996. Dont have diagnostics :( to scan with. How to check that ?
bane
Unverified
Macedonia
actualy in the service where i take it there was vcds and they diagnose faulty throttle body which i replaced it and the idle is ok. But they didnt see this thing with no spark in 3rd cyl. I discovered by myself with extra spark plug. Other weird thing i noticed is if card idles 20 min without being driven it shuts off and cant starti it within 20 min i suppose till cool off. This two problems now are my enigmatics
Gremling
Norway, Nordland
C?ID=319714
Problem solved?
If not, how is temp reading, hot engine might cause issues.
Also how is coil, and have you noticed any arcing in coil or distributor cap (erratic sounds from these two areas can be tell tale signs of issues. Also running engine (engine covers removed) in dark room can make it easier to see arces. I assume you have taken distributor cap off and cleaned it with alcohol (some other dissolvents can lay a current leading layer as red methylated spirit), removing any dust and corrosion on "pick-up" pins to plug leads inside distr cap.
