Results 1 to 4 of 4
Thread: Wanted: 2015 Passat Wolfsburg 1.8T CPRA complete scan
    Verified VCDS User Mike0p's Avatar
    Sep 2018
    Murrieta, CA
    ISO 2015 Passat Wolfsburg Edition 1.8T CPRA, 09, RCD-310, no fog lights, no multi function steering wheel(buttons on left side for volume/phone/seek), complete scan without errors or mods. I need the complete coding as well as full control module map. If you need further details please let me know. Ill post its current scan on a reply, note that the oil pump and AC compressor are removed hence the ridiculous error codes.
    Sep 2018
    Murrieta, CA
    Wednesday,07,November,2018,20:53:44:13952
    VIN: 1VWAT7A37FC047902 License Plate: EBD
    Mileage: 168390km-104632mi Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2B 2E 42 44 46 4C 4F 52 56 62
    72 75 77 A6
    VIN: 1VWAT7A37FC047902 Mileage: 168390km-104632miles
    2B-Steer. Col. Lock -- Status: Cannot be reached 1100
    2E-Media Player 3 -- Status: Not registered 0001
    46-Central Conv. -- Status: Not registered 0001
    4C-Tire Pressure II -- Status: Not registered 0001
    A6-Microphone -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
    Part No SW: 06K 997 071 G HW: 06K 907 425 C
    Component: R4 1.8l TFS H13 9372
    Revision: --H13---
    Coding: 001A0012242400170000
    Shop #: WSC 09003 957 00200
    ASAM Dataset: EV_ECM18TFS02006K997071G 001005
    ROD: EV_ECM18TFS02006K997071E.rod
    VCID: 392F2E0C19DAFACF99B-806C
    15211 - Oile Pressure Regulating Valve
    P164E 00 [039] - Electrical Malfunction
    Mileage: 168399 km
    Date: 2018.11.07
    Time: 04:20:08
    Coolant temperature: 23 C
    Intake air temperature: 26 C
    Voltage terminal 30: 9.960 V
    Engine: operating status: ES
    STATE_LS_SAE[1]: INI
    T_AST_SAE: 0 s
    MAP_MES_SAE: 96 kPa
    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
    FAC_TPS_1_SAE: 18.359375 %
    FUP_H_SAE: 290.0 kPa
    Readiness: 1110 1101
    Address 02: Auto Trans (J217) Labels:* 09G-927-749-V1.clb
    Part No SW: 09G 927 749 B HW: 09G 927 749 B
    Component: AISIN AG6 G3 109 2855
    Coding: 000348
    ASAM Dataset: EV_TCMAQ250031 001004
    ROD: EV_TCMAQ250031_001_VW25.rod
    VCID: 38292B0822D0E3C7665-806C
    Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
    Component: ESP MK60EC1 H46 0166
    Revision: 00H46001
    Coding: C54BC0F549260001A31403E4921B0041A5140012
    VCID: 04518FF82E187727BAD-8050
    Reset counter: 200
    Mileage: 168399 km
    Date: 2018.11.07
    Time: 04:12:54
    Count: 2
    Count: 14
    Count: 20480
    Count: 16390
    Count: 35840
    Count: 255
    Part No SW: 561 907 426 E HW: 561 907 426 E
    Component: AC Manuell H02 0303
    Revision: 00001K02
    Coding: 0010001002
    ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
    ROD: EV_ACManuaElectGen2BHTC_VW36.rod
    VCID: 1D67DA9CAD32A6EF953-8048
    B10AB F0 [009] - Too Low
    Reset counter: 200
    Mileage: 168399 km
    Date: 2018.11.07
    Time: 04:12:48
    Part No SW: 5K0 937 085 AB HW: 5K0 937 085 AB
    Component: BCM PQ35 B+ 122 0174
    Revision: BH122001
    Coding: EF290EB8C00904DC40120001230000E047F1A0004480D50700 8022000C71
    VCID: 73B3DC247BB6409F937-8026
    Fault Frequency: 11
    Reset counter: 240
    Mileage: 168365 km
    Date: 2018.11.06
    Time: 19:50:17
    Term 15 On
    Voltage: 10.55 V
    Part No SW: 5C0 959 655 AA HW: 5C0 959 655 AA
    Component: AirbagVW10 500 0975
    Serial number: 003LYD01RTA9
    Coding: 00004832
    ASAM Dataset: EV_AirbaVW10SMEVW360 001030
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 71BFD62C012A728F61B-8024
    Serial number: 6940000Y14000194TV03
    Coding: 303044
    Serial number: 3572MSME352C7848ZZZ%
    Serial number: 3582MSME04601C49ZZZU
    Serial number: 3516KSME65582131ZZZK
    Serial number: 3526KSME253C6931ZZZV
    Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Serial number: 3556LSME28250F31ZZZU
    Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Serial number: 3566LSME69624331ZZZT
    Part No SW: 1K5 953 521 BN HW: 5K0 953 569 AE
    Revision: FF010042 Serial number: 20140818100836
    Coding: 488A140000
    ROD: EV_SMLSNGVOLWS.rod
    VCID: 7AADF1005C5C31D7D01-802E
    Subsystem 1 - Part No SW: 561 959 537 HW: 561 959 537
    Component: E221__MFL-8LP H07 0023
    Coding: 620000
    Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
    Part No SW: 561 920 960 D HW: 561 920 960 D
    Component: KOMBI H04 0809
    Coding: 030E01
    VCID: 1A6DD180BC1CD1D7701-804E
    Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
    Component: J533 Gateway H55 1653
    Revision: H55 Serial number: 26101403000053
    Coding: 461000
    VCID: 005983E83A006B079E5-8054
    Fault Frequency: 9
    Mileage: 168365 km
    Date: 2018.11.06
    Time: 19:49:06
    02811 - Control Module for Electronic Steering Column Lock (J764)
    Reset counter: 200
    Mileage: 168399 km
    Date: 2018.11.07
    Time: 04:14:37
    03753 - Control Module for Microphone
    Reset counter: 200
    Mileage: 168399 km
    Date: 2018.11.07
    Time: 04:14:37
    Component: IMMO H04 0809
    VCID: 6A8DC1402CFC8157201-803E
    Address 2B: Steer. Col. Lock
    Address 2E: Media Player 3
    Part No SW: 561 959 701 HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0525
    Revision: 13110009 Serial number: 0009041441
    Coding: 040495
    ROD: EV_TSGFPQ25BRFVW46X.rod
    VCID: 5BE39484F3A6E8DFAB7-800E
    Slave Driver:
    Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG_HL 006 5470
    Serial number: 14102630141028191045
    Coding: 800000
    B11EC 54 [009] - Missing Calibration / Basic Setting
    Reset counter: 200
    B11EE 54 [009] - Missing Calibration / Basic Setting
    Reset counter: 200
    Part No: 1K0 909 144 R
    Component: EPS_ZFLS Kl. 211 3501
    Revision: 00H22000
    VCID: 392F2E0C155AFACF99B-806C
    000 - - - MIL ON
    Fault Status: 11100000
    Battery Volts: 10.1 V
    PD
    Temperature: 24.0C
    Count: 2
    Steering Angle: 0.00
    SteerAng n.Init
    Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
    Component: EZE_2 H55 1653
    Coding: 00000008
    VCID: 6FBBD054179E647F77F-803A
    Subsystem 1 - Part No SW: 561 919 204 B HW: 561 919 204 B
    Component: Analoguhr 009 0005
    Part No SW: 561 959 702 HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0525
    Revision: 15110009 Serial number: 0009064413
    Coding: 040494
    ROD: EV_TSGBPQ25BRFVW46X.rod
    VCID: 5CE19798F6A8EFE7A2D-8008
    Slave Passenger:
    Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG_HR 006 5470
    Serial number: 14202631141110134555
    Coding: 800000
    Reset counter: 200
    Reset counter: 200
    Part No SW: 1K0 035 164 F HW: 1K0 035 164 F
    Component: LOW NAR SDARS H05 0006
    Revision: -----09S Serial number: VWZ4Z6P3850735
    Coding: 0100040002000B
    VCID: 2517F27C85E26E2FCD3-8070
    Address 75: Telematics (J949) Labels:| 12E-035-284.clb
    Part No SW: 561 035 285 HW: 561 035 285
    Component: OCULowUSA 014 0102
    Serial number: 000003554140528
    Coding: 02140102C2161A107F1606000000
    ROD: EV_OCULow_001.rod
    VCID: 53F37CA49B76209F737-8006
    U1400 00 [009] - -
    [restriction due to undervoltage]
    Reset counter: 200
    2103041 - Control Module
    Fault Priority: 8
    Reset counter: 200
    Mileage: 168399 km
    Date: 2018.11.07
    Time: 04:22:38
    Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
    Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
    Component: TELEFON H07 0593
    Revision: 1B001001 Serial number: 00007666616802
    Coding: 0A10030080010110
    ROD: EV_UHVUMI.rod
    VCID: 323D1920C4AC0997581-8066
    Address A6: Microphone
    End--(Elapsed Time: 01:07, VBatt start/end: 9.8V/9.8V. VIgn 9.8V, udsna)---
    Gateway Installation List: 7N0 907 530 AR
    Sep 2018
    Murrieta, CA
    Hello cruel world
  4. Likes RUZDO.O liked this post
    Sep 2018
    Murrieta, CA
    The above scan is my current control module. Looking for the stock codes.
  6. Likes RUZDO.O liked this post
