Results 1 to 7 of 7
Thread: Operate VW Beetle Flaps with VCDS?
    Aug 2018
    Does VCDS have the ability to operate/test the flaps on a 2006 VW Beetle without actually operating the top?
    The question would be better phrased: Does the roof module have a provision in it for that to be done using a scan-tool?
    Can you post a scan from this car you can post so we can see what module it has and what we know about it?
  3. Likes DrPeter liked this post
    Aug 2018
    Attached is the output from when I first scanned the car.
    Tuesday,28,August,2018,15:02:55:63037
    VIN: 3VWSF31Y06M324226   License Plate:
    Mileage: 176680km-109783mi   Repair Order:
    Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
    VIN: 3VWSF31Y06M324226   Mileage: 176680km-109783miles
    Address 01: Engine        Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 B    HW: Hardware No
       Component: R5              G   7828
       Revision: --------    Serial number: VWZ5Z0F2298336
       Coding: 0000003
       Shop #: WSC 00066 000 00000
       VCID: 2809FBFC2EEC7897194-513C
    Readiness: 0110 1101
       Part No SW: 09G 927 750 CG    HW: 09G 927 750 CG
       Component: AQ 250 6F           0759
       Revision: 00H27000    Serial number:
       Coding: 0000008
       VCID: 78A9EBBCBECC2817494-513C
    17105 - Transmission Output Speed Sensor (G195)
                P0721 - 008 - Implausible Signal - Intermittent
       Part No: 1C0 907 379 Q
       Coding: 0019978
       VCID: 38292BBCFE4CE817894-5160
       Part No: 6Q0 909 605 AL
       Component: 01 AIRBAG VW71      0811
       Coding: 0012337
       VCID: 015F8658ED1669DF7EA-513C
       Subsystem 1 - Part No: 1C0 959 339 F
       Component: BF-Gewichtsens. 006 0007
       Part No: 1C0 920 501 T
       Component: KOMBI+WEGFAHRS. M73 V01
       Coding: 11234
       Shop #: WSC 00066
       VCID: 290FFEF830E6419F06A-4B00
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V012
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70B9D39CD3BC7057814-4B00
    Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
       Part No SW: 1C0 920 501 T    HW: 1C0 920 501 T
       Component: IMMO                X007
       Revision: xxxxxxxx    Serial number: VWZ5Z0F2298336
       VCID: 290FFEF835E6419F06A-513C
    Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
       Part No: 1Y0 959 255 C
       Component:  VSG  NBC
       VCID: 40D9435CA69CA0D7314-513C
    00532 - Supply Voltage B+
    Address 46: Central Conv.        Labels:
       VCID: 55F782084C0E357F722-FFFE
       Part No: 1C0 035 196 BG
       Component:  RADIO DE2         0006
       Coding: 06031
       Shop #: WSC 00066
       VCID: 6597B2C81C7EA5FFE22-51CE
                00-10 -  -  - Intermittent
    End----------(Elapsed Time: 04:15, VBatt start/end: 14.0V/13.9V)-----------
  5. Likes Dana liked this post
    Doesn't look promising. I see nothing that indicates this module supports Selective Output Tests, which would be the most probable way.
    But some of the folks know these roof systems better than I do....
  7. Likes Dana liked this post
  8. #5
    I'm not aware of any output test support for this Roof Electronics.
    Just what issue are you having with the top other than some voltage issue. Does the Comfort Control Module, address 46, communicate? It isn't there in the Auto-Scan and it needs to talk for the top to operate.
    Jef
  9. Likes Uwe liked this post
  10. #6
    Aug 2018
    I thought that might be the case with the roof electronics.
    The battery is shot and needs to be replaced so I'm pretty sure that's what's causing the low voltage. I was asking about the roof since it wont operate and was seeing if there was a way to test. I'm going to see if I can locate a diagram that shows the location of the fuse for the roof electronics. Unfortunately fuse location card is no longer with the car.
  11. #7
    Quote Originally Posted by Spartan2381 View Post
    erWin is your friend
    https://erwin.vw.com/erwin/showHome.do
  12. Likes Uwe, Dana liked this post
