Results 1 to 5 of 5
Thread: BRAKING GUARD off??
    Exclamation BRAKING GUARD off??
    Trying to fix this car... 2012 Audi A7 stealership is quoting like $7500.00 new camera, new cable, new module... (everything under the hood kind of estimate)
    I am getting "Braking guard off" on instrument cluster, and when i scan with my Hex+can I get these fault codes...
    I do know of a leaking tire, so that explains the tire pressure fault... but the
    "0784 - Function Restriction due to Implausible Message(s)
    U1112 00 [009] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]"
    and other un explainable UDS faults cant find anything in my repair information as to how to even attack/diagnose this...
    suggestions & help would be greatly appreciated...
    VIN: WAU2GAFC3CN064663
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 28 36 3B 3C 42 44 46
              47 52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90
    VIN: WAU2GAFC3CN064663   Mileage: 136507km-84821miles
    Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0010
       Revision: --H07---
       Coding: 1A2A0034056600060000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
       ROD: EV_ECM30TFS0214G0907551A_003.rod
       VCID: 2757F4DD5ED2A872B4-8072
    9662 - EVAP System
              P0456 00 [096] - Very Small Leak Detected
                        Mileage: 136149 km
                        Date: 2018.10.30
                        Time: 09:05:12
                        Engine speed: 1311.00 /min
                        Normed load value: 13.3 %
                        Coolant temperature: 27 °C
                        Intake air temperature: 28 °C
                        Voltage terminal 30: 13.202 V
                        Unlearning counter according OBD: 26
                        CTR_NR_DIAG_SMALL_LEAK_NVLD: 1
                        CTR_NR_DIAG_TGT_NVLD: 149
                        CTR_NR_RESP_REP_COMC_NVLD_ENVD: 0
                        Ambient temperature: 23.25 °C
                        AMP_ENVD: 1013.5684 hPa
                        FTL_CAN: 64 l
    Readiness: 0010 0001
       Part No SW: 4G0 927 158 P    HW: 0BK 927 156 R
       Component: 0BK 30TFSIUSA H08 1006
       Revision: --H08---
       Coding: 000002
       ASAM Dataset: EV_TCMAL551211 002018
       VCID: 3B7F38ADB25A1C92C0-806E
       Part No SW: 4G0 907 379 G    HW: 4G0 907 379 G
       Component: ESP PREMIUM   H09 0250
       Coding: 44A70F0322E5F0C05B00
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: 356B2E95947ECAE236-8060
    0607 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 50
                        Mileage: 135652 km
                        Date: 2018.10.20
                        Time: 23:14:40
                        VzRef: 5B
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 28
                        Uz: B4
              U1112 00 [009] - -
                        Reset counter: 27
                        Mileage: 136507 km
                        Date: 2018.11.07
                        Time: 11:56:28
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: DF
                        Uz: B5
       Part No SW: 4H0 907 064 BR    HW: 4H0 907 064 BR
       Component: BCM2 2.0      H31 0330
       Coding: 0D8A2000000000000000
       VCID: 7AF1FDA9F5E0E59A9B-802E
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000216700011
    00956 - Key 2
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 5
                        Mileage: 136061 km
                        Date: 2018.10.28
                        Time: 09:26:37
       Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
       Component: KLIMA 4 ZONEN H11 0062
       Serial number: 06101100040297
       Coding: 6603207A4C
       ASAM Dataset: EV_AirCondiComfoUDS 002033
       VCID: 2855F7E153CCA70ABD-807C
    0518 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Fault Frequency: 36
                        Reset counter: 67
                        Mileage: 131933 km
                        Date: 2018.08.10
                        Time: 11:51:44
                        Voltage terminal 30: 11.65 V
                        Outside air temperature: 34.0 °C
                        Engine speed: 1321 /min
       Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0100
       Revision: 11012002    Serial number: 00000001073412
       Coding: 02002091163C9FE0C1008884A0003928CF9CD208A2080125800008402000
       VCID: 6ED9C1F9B9A8B93A37-803A
       Component: WWS57X 110805  H35 0051
       Serial number:         110809225533
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11706940
       Coding: 02562B
       Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
       Component: E1 - LDS  H07 0044
       Serial number: 21 09 2011  00000774
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R0NK402
       Subsystem 5 - Part No SW: 8K0 959 772 C    HW: 8K0 959 772
       Component: SLR-B8  H05 0006
       Serial number:           0014653152
       Coding: 853000
       Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA102281000000488969
       Coding: 020300
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 1A288DC5000000000001
    03188 - Bulb for Side Marker Light; Front Left
                        Fault Status: 00101100
                        Reset counter: 33
                        Mileage: 135273 km
                        Date: 2018.10.14
                        Time: 21:01:00
    03608 - Humidity Sensor in Fresh Air Intake Duct
                        Fault Status: 00101110
                        Fault Frequency: 37
                        Reset counter: 67
                        Mileage: 131933 km
                        Date: 2018.08.10
                        Time: 11:51:00
    Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
       Part No SW: 8X0 035 110 C    HW: 8X0 035 110
       Component: CDC-MP3-Pana  H41 0490
       Revision: 00000007
       VCID: 2D5B06F5742E82224E-8078
       Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0050
       Revision: 11001001    Serial number: 55901126901706
       Coding: 280904
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3D7B36B5AC4E12A2FE-8068
       Part No SW: 4G0 907 561     HW: 4G0 907 561
       Component: ACC3          H15 0160
       Coding: 3601010201
       ASAM Dataset: EV_AdaptCruisContrAU57X 001003
       ROD: EV_AdaptCruisContrAU57X_001.rod
       VCID: 67D7B4DD9E52687274-8032
    93440 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 27
                        Mileage: 133628 km
                        Date: 2018.09.05
                        Time: 11:46:02
                        Control Module temperature: 31 °C
                        Voltage terminal 15: 13.009 V
                        Velocity_vehicle_reference: -0.01 m/s
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H31 0032
       Revision: --------    Serial number: 003D8001E6MO
       Coding: 303145313131303030324A55304C34473853
       VCID: 336F108D9A0AD4D218-8066
       Serial number: 6940000Y150001FH2C0K
       Serial number: 3575HRB405D0U20SA0PK
       Serial number: 3585HRB405V0Q4PG4GD5
       Serial number: 3515JRB405L0Q8K4K88N
       Serial number: 3525JRB40650OPMMCOVW
       Serial number: 3554VRB405H0P4N0G8P+
       Serial number: 3564VRB405H0P4N02P1L
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372KIU001E9
       Coding: 00003C
       VCID: 3777249D867238F224-8062
       Component: E221 - MFL  H08 0009
       Serial number: 16 09 2011  B0056880
       Part No SW: 4G8 920 982 F    HW: 4G8 920 982 F
       Component: TBenUsaAcc    H79 0375
       Revision: 26181120    Serial number: 658240911593040
       Coding: 0BCF01060F03D705020100
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K.rod
       VCID: 3777249D8E7238F224-8062
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000264156
       Coding: 00C1033000
       ROD: EV_GatewUDS_AU57.rod
       VCID: 326115896510DDDA13-8066
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650617360
       Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
       Component: KLIMA FOND    H07 0062
       Serial number: 28091100040373
       Coding: 00
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
       VCID: 2F671CFD7622F0327C-807A
       Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
       Revision: AA000000    Serial number: 00000014818392
       Coding: C0581B008F002001000001010101102030303232203232
       VCID: 387527A18B6C378A2D-806C
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA42024MTE0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D5B06F57C2E82224E-8078
       Part No SW: 4G0 907 566 J    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0030
       Revision: 00H02000    Serial number: 6PZ 010 287-08
       Coding: 0000007
       VCID: 366929994178C1FA3F-8062
       Subsystem 1 - Part No: 4G0 907 568 J
       Component: J770  SWA Slave H02 0030
       Subsystem 2 - Serial number: 6PZ 010 287-28
       Subsystem 3 - Serial number: 5F05.10.1100H020003CZ20606˙
       Subsystem 4 - Serial number: Z20606˙
       Part No SW: 4G8 959 793 D    HW: 4G8 959 793
       Component: TSG FA        H05 0212
       Coding: 011F57225E00628002000413
       Shop #: WSC 02312 785 00200
       VCID: 41834A45D8B676429A-8014
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0015168719
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0160303618
       Coding: 0126063A20FAF48580B00A80020100000000000000000000000000000000
       Component: GTO BF  H01 0070
       Serial number: 00000000000000051168
       Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
       Component: J245 PS40.033  H07 0006
       Serial number:     WOO1361239%
       Coding: 101F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00000421854
       Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H09 0027
       Serial number: WA102898000000511377
    03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
                000 -  -  - Intermittent
                        Fault Frequency: 63
                        Reset counter: 67
                        Mileage: 132028 km
                        Date: 2018.08.13
                        Time: 13:52:03
    01134 - Alarm Horn (H12)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 131
                        Mileage: 132450 km
                        Date: 2018.08.17
                        Time: 00:01:12
    03128 - Switch 1 for Sunroof
                        Reset counter: 51
                        Mileage: 136153 km
                        Date: 2018.10.30
                        Time: 09:10:40
    00204 - Sunroof Button (E325)
                        Reset counter: 51
                        Mileage: 136153 km
                        Date: 2018.10.30
                        Time: 09:10:40
       Revision: CJ007000    Serial number: 00000000028313
       Coding: 030000
       Shop #: WSC 56617 000 1048576
       VCID: 1D3BD635048E72A2DE-8048
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       Coding: 011F57225E00628002000402
       Revision: --------    Serial number: 00000000150701
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A510DE94DC0951AAB-807E
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
       Component: ....AFS13.... H01 0012
       Serial number: 110927-0004-124
       Coding: 1223A633701AA400
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
       VCID: 30651F816B1CEFCA65-8064
    H01 0031
       Coding: 3A0000
    H01 0031
       Coding: 3A0000
    572427 - Stationary Cornering Lamp Right
              C1084 13 [008] - Open Circuit
                        Reset counter: 67
                        Mileage: 131933 km
                        Date: 2018.08.09
                        Time: 18:08:12
       Component: Radio U SIRIU H51 0133
       Revision: AB001007    Serial number: 471C 0B7563277
       Coding: 020007010000000001
       VCID: 244DE3D127E4436A91-8070
       Part No SW: 4G0 035 746 E    HW: 4G0 035 746
       Component: H-BNT-NA      H48 0735
       Revision: --------    Serial number: 031J 0B7516198
       Coding: 090200040003E9EF75128B3E00000003100001000000000000
       VCID: 2953F2E540C69E02A2-807C
       Component: NAR 2011  0505
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDB1301NPYE
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 A
       Component: E380 BDT C7  H08 0204
       Serial number: 90349KIT0006E
       Component: CD-Database  3371
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F17224000628002000002
       VCID: 448D4351C7A4636AB1-8010
       Revision: --H04---    Serial number: 525 PA8J19G11B
       Coding: 1080013
       VCID: 2649F9D991D8B17A8F-8072
       Part No SW: 4G8 959 107 P    HW: 4G8 959 107 G
       Component: HDSG-Modul    H13 0039
       Revision: 12013001    Serial number: 237100211
       Coding: 0A3305C102
       ASAM Dataset: EV_HDSGAu573 001014
       ROD: EV_HDSGAu571.rod
       VCID: 42814549D5B06D5A83-8016
       Component: TSG HR        H04 0212
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Component: DPC-SG        H24 0036
       Coding: 6A060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 65CBBED5645E7A6246-8030
       Part No SW: 4G0 907 541     HW: 4G0 907 541
       Coding: 3601010201
       ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
       ROD: EV_AdaptCruisContr2AU57X_001.rod
       Part No SW: 4G0 907 107 C    HW: 4H0 907 107
       Component: BV-SG         H29 0036
       Serial number: 000040222609117
       Coding: 038198180111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 2649F9D959D8B17A8F-8072
    0080 - Video Cable for Image Processing
              C1107 02 [024] - Signal Failure
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Fault Frequency: 145
                        Reset counter: 14
                        Mileage: 134173 km
                        Date: 2018.09.16
                        Time: 12:08:32
                        Outside air temperature: 35.5 °C
                        Voltage terminal 15: 14.0 V
                        Control Module temperature: 38.0 °C
    0161 - Video Cable for Image Processing
              C1107 02 [009] - Signal Failure
                        Reset counter: 27
                        Mileage: 133628 km
                        Date: 2018.09.05
                        Time: 11:46:02
                        Outside air temperature: 36.5 °C
                        Voltage terminal 15: 13.1 V
                        Control Module temperature: 31.0 °C
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       Coding: 0066E608031F037E070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 31631A856016E6C26A-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
    I believe the 03-ABS is upset about the faults in 55-Headlight Range, while 13-Auto Dist. Reg is upset about the faults in 8E-Image Processing.
    If it were me, I'd fix the camera or camera connection first.
    Well, for the 55-headlight range, i replaced the cornering light for the passenger side... cleared faults... and these came up...
    A little more help with camera OR camera connection... as my VCDS..." [New feature! Extended UDS fault detail is only supported by current gen." DOES NOT HELP!
    And I cant find anything in my repair information...
       Revision: --H07---
    Readiness: 1110 1101
       Revision: --H08---
       Coding: 000002
              U1112 00 [009] - -
    interfaces]
                        Reset counter: 27
                        Mileage: 136507 km
                        Date: 2018.11.08
                        Time: 18:35:01
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: DF
                        Uz: 97
    00956 - Key 2
                        Reset counter: 27
                        Mileage: 136507 km
                        Date: 2018.11.08
                        Time: 18:35:44
       Coding: 6603207A4C
    119.CLB
       Coding: 0045F7
    559.CLB
       Coding: 02562B
       Coding: 853000
       Coding: 020300
       Revision: 00000007
       Coding: 280904
       Coding: 3601010201
              U1113 00 [009] - -
    interfaces]
                        Reset counter: 27
                        Mileage: 136507 km
                        Date: 2018.11.08
                        Time: 18:35:32
                        Control Module temperature: 33 °C
                        Voltage terminal 15: 11.869 V
       Coding: 00003C
       ROD: EV_RBD4K.rod
       Coding: 00C1033000
       Coding: 00
       Coding: 0000007
       Coding: 101F00
                014 - Defective
                        Reset counter: 27
                        Mileage: 136507 km
                        Date: 2018.11.08
                        Time: 18:34:04
       Coding: 030000
    H01 0031
       Coding: 3A0000
    H01 0031
       Coding: 3A0000
       Coding: 1080013
       Coding: 0A3305C102
       Coding: 6A060000
       Coding: 3601010201
       ROD: EV_BC7.rod
    interfaces]
                        Reset counter: 27
                        Mileage: 136507 km
                        Date: 2018.11.08
                        Time: 18:34:28
                        Outside air temperature: 30.0 °C
                        Voltage terminal 15: 11.9 V
                        Control Module temperature: 33.0 °C
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
    I believe the 161/C1107 code in 8E: Image Processing would read something to the effect of: "No camera found" if you were using an interface compatible with that feature.
    Front bumper camera, windshield camera, or which other camera is this pointing to?
