Results 1 to 9 of 9
Thread: Discover Media - navigation speech language change
    May 2018
    Czech Republic
    Hi guys,
    I have just retrofitted DM 2017 (to Passat 2015). Everything went OK. Nevertheless the unit was bought in England and it is not possible to change the navigation speech language - now it is in english although all the menu language is in german. I need also navigation voice in german version. How/where should I change this data set? Is it necessary to flash SW, or is this an VCDS coding issue? (In APKs I can see "country of origin" as GB. This was change to DE without any result.
    Thank you,
    Please post an Auto-Scan so people can see exactly what part number you have, how it is coded, etc.
    May 2018
    Czech Republic
    So it may help:
    Address 5F:
    Information Electr. Labels: 5G0-035-MIB-STD2.clb
    Control Module Part Number: 3Q0 035 874 B HW: 3Q0 035 874 B
    Component and/or Version: MU-S-ND-ER 840 0743
    Software Coding: 02840201FF00000091510101008908031F0100C401200100CD
    Work Shop Code: WSC 10000 444 00002
    ASAM Dataset: EV_MUStd4CDELP 001001 (VW48)
    ROD: EV_MUStd4CDELP_VW26.rod
    VCID: 313EE515F1AEA7EF21B-8064
    Thank you for the 5F information, but we still need to see a full Auto-Scan.
    May 2018
    Czech Republic
    Hi, my full scan:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
              69 6C A5 CA CF
    VIN: WVWZZZ3CZFP40xxxx   Mileage: 170391km-105876miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
       Component: R4 2.0l TDI   X21 1990
       Revision: B5X21---
       Coding: 011D001A04741D083000
       Shop #: WSC 10000 444 00002
       ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
       ROD: EV_ECM20TDI01104L906026FL.rod
       VCID: 005870D10A84FE679E5-8054
       Part No SW: 0D9 300 041 A    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4801
       Revision: 05853104    Serial number: TFK01411260629
       Shop #: WSC 00028 028 00024
       ROD: EV_TCMDQ250021.rod
       VCID: 16743689780060D7549-8042
       Part No SW: 3Q0 907 379 H    HW: 3Q0 907 379 H
       Component: ESC           H34 0906
       Revision: 00000000    Serial number: 42904000000356
       Coding: 0FEC6A8F34200B730779060641C849F0562CD0E0608292F11862F078CAA9
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034001
       VCID: 3FDAB32D37FA419FA7F-806A
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0355060936
       Coding: 000F0F0703
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77AA1B0D5F4AB9DFAFF-8022
       Part No SW: 5G0 907 044 CQ    HW: 5G0 907 044 CQ
       Revision: 00001K10
       Coding: 12020124604101012115505001101802
       Shop #: WSC 07790 995 07790
       ROD: EV_ACClimaBHBVW37X_006_VW48.rod
       VCID: 78A818315254B6A7A65-802C
       Air quality sensor:
       Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
       Component: BCM PQ37BOSCH 028 0146
       Revision: --------    Serial number: 86580112141660
       Coding: 00971E46C2410AFF4BE44004001C07081C80000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       VCID: 7DA609257D76938FF53-8028
       Component: WWS    141124  042 0607
       Serial number:         141201070426
       Coding: 0F4DFD
       Component: RLHS  037 0059
       Serial number: S4Y14M12D11H14M52S31
       Coding: 06A8DD
       Serial number: 17 10 2014  00001092
       Sun Roof:
       Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0053
       Revision: --------    Serial number: 39391433501067
       Coding: 0071257111
       ROD: EV_EPHVA18AU3700000_002_VW48.rod
       VCID: 40D8B0D14A043E67DE5-8014
       Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 A
       Component: ACC BOSCH MQB H04 0195
       Coding: B21F7F7915FFFF28949C807D
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3536D10505C68BCF7D3-8060
       Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
       Component: Airbag VW20   012 0195
       Revision: --------    Serial number: 003R1PP7RFCD
       Coding: 98FCC0C0008000005C5400CC000800000065
       Shop #: WSC 00028 028 00012
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 015E75D5018EF76F91B-8054
       Belt Pretensioner left:
       Component: BeltPretRevFL  105 1032
       Serial number: 3G1857705E0328O00083
       Coding: 80000A
       Belt Pretensioner right:
       Component: BeltPretRevFR  105 1032
       Serial number: 3G1857706E0328O00396
       Coding: 80000A
       Subsystem 3 - Part No SW: -----------    HW: 454 000 112 14
       Serial number: 3576U0000001B4691210
       Subsystem 4 - Part No SW: -----------    HW: 454 000 112 14
       Serial number: 3586U000000FA391C11I
       Subsystem 5 - Part No SW: -----------    HW: 454 800 312 14
       Serial number: 3516R73374B05000000$
       Subsystem 6 - Part No SW: -----------    HW: 454 800 312 14
       Serial number: 3526R5F224B050000001
       Subsystem 7 - Part No SW: -----------    HW: 454 800 112 14
       Serial number: 3556V14FC3F05000000J
       Part No SW: 3Q0 953 521 R    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20141127500777
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       Part No SW: 3G0 920 751     HW: 3G0 920 751
       Component: KOMBI         308 4311
       Coding: 0BF512186F8C000808887E2B5002000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009043
       ROD: EV_DashBoardVDDMQBAB_VW48.rod
       VCID: 629C5A59E4C84C77E81-8036
       Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
       Component: STH-MQB       006 0069
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002014
       VCID: 3634D60918C080D7749-8062
       Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000001027933
       Revision: --------    Serial number: 29111410800846
       Coding: 0B0300344F017300EF00025E1C0F00010001070000000000000000000000
       ROD: EV_GatewConti_011_VW48.rod
       VCID: 72BC2A193428DCF7981-8026
       Component: E221__MFL-DC1  H16 0040
       Serial number: 27140003062100094494
       Coding: 2DFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 7498745203
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
       Component: WECHSELRICHTE  H54 0033
       Serial number: 0015860
       Analog clock:
       Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
       Component: Analoguhr  111 1004
       Serial number: 0212201400010310
       Serial number: 14000249651010
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BE2515312EE7EF61B-8024
       Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0510
       Revision: --------
       Coding: 16C000
       VCID: 3A2CC2392CD864B7901-806E
       Part No SW: 5Q4 959 593 D    HW: 5Q4 959 593 B
       Component: TSG FS        009 0016
       Serial number: 0000127482581
       Coding: 00170B205800028000001000
       Shop #: WSC 44444 010 00001
       VCID: 46D4A6C968201057E49-8012
       Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000535055
       Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    203 2033
       Revision: 00000000    Serial number: 0000092408
       Coding: 01000011005000
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
       ROD: EV_SteerAssisVWBSMQBA_008.rod
       VCID: 3B22C73D23E25DBF8B7-806E
       Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0015
       Serial number: 0000128541534
       Coding: 001501205C00028000001100
       VCID: 44D0BCC15E1C2247FAD-8010
       Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000555770
       Coding: 090000
       Coding: 039A00004F210200
       Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 0001
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 0001
       Coding: E02400
       Coding: E02400
       Component: LeiMo rechts  H02 0003
       Coding: E02400
       Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
       Component: MU-S-ND-ER    840 0743
       Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZHT3233946
       Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
    1552 - Expanded Bus Activity Active
              U1104 00 [009] - -
                        Reset counter: 109
                        Mileage: 170391 km
                        Date: 2018.11.07
                        Time: 16:48:14
                        Voltage terminal 30: 14.0 V
       Part No SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
       Component: Anhaenger     H14 0137
       Revision: 8A001001    Serial number: 0354678309
       Coding: 0100000202000000
       VCID: 3828D83112D476A7665-806C
    Address 6C: Back-up Cam. (J123)       Labels:* None
       Part No SW: 5Q0 907 556     HW: 5Q0 907 556
       Component: TopView       H11 0327
       Serial number: C854706JG000070
       Coding: 01840201E30F200000204414
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003011
       ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
       VCID: 76B416095840C0D7B49-8022
       Part No SW: 3Q0 980 653 E    HW: 3Q0 980 653
       Component: MQB_B_MFK     H08 0121
       Serial number: 26111411P10378
       Coding: 01040802050004010022335F814EA5009B00A2200140
       Part No SW: 4M0 907 594 B    HW: 4M0 907 594
       Component: SAD_STG_1     009 0002
       Coding: 208040748202
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
       Revision: --------
       Coding: 16C000
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
       VCID: 372ADB0D1FCA79DF6FF-8062
  6. #6
    Oct 2017
    Northwest UK
    If you've tried to change the language and it hasn't updated the voice, then I don't think it's possible to change the navigation language as this will be set with the maps.
    However, you may be able to do it using another tool by flashing a different dataset but we cannot help you with that.
  7. #7
    May 2018
    Czech Republic
    I am glad to hear any opinion and this one helped to me! I will have to flash..thank you!
  8. #8
    Moved to Retrofits.
  9. #9
    May 2018
    Czech Republic
    thank you.
