Results 1 to 10 of 13
Thread: DSG faults worldwide
    Tartu, Estonia
    I thought I'd ask, how is your DSG holding up?
    Locally we have some problems with DSG gearboxes and the users with faulty gearboxes seem to coming up.
    Example:
    My friend has a Passat b6 with 3.2L FSI (2007) and DSG. He had a fault, that gearbox doesn't want to stay in gear when releasing brake. When think it as a manual it felt like someone is releasing clutch, pressing it and then releasing it again. It stopped when decent speed was gained. Also uncomfortable gear change for automatic. I don't know the word describing it, but feels like when releasing clutch too quickly.
    Local dealer told that mechatronic needs replacing what got replaced, but that didn't cure it cause after some driving, symptoms came back.
    Currently don't know the exact situation of car, but when i talked to friend, who is a truck driver in Europe, he told he talked to many VR6 and DSG owners.
    They all claim to have problems with their DSG, usually mechatronic change.
    A man who had owned his MKV R32 from new said his car mechatronic is changed at 53k km and 117k km, clutches at 117k km, than gearbox broke 155k km and at the same time DMF got replaced. On the second gearbox the mechtronic got swapped at 240k km and probably will get changed again. Current milage is 350k km.
    How is the situation on others?
    Although i wanna get a newer car sometime and also automatic(too lazy as i am), i don't want to have expensive bills on gearbox repair. Oil change is understandable, but not expensive repair cost. Makes me wanna change to Audi, that some engines have option of tiptronic or BMW that seems to hold up, at least on gearbox side.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
    DSG = Double shitty gearbox........... in comparison to early auto gearboxes fails at double frequency of 01M and
    I say double........... because double the cost..........
    Jul 2014
    Greece
    Jul 2014
    Greece
    Hello , i want to ask about measure block 15 in my dsg 6 gearbox
    i do not have errors and the gearbox Works perfect!!!!
    I have reflash the dsg ecu with stage 2 unitronic program to have quick gear changes and more Protection for the gearbox since 8000 klm .
    in vag com
    the Measured value block 15:
    1. Travel measurement gear actuator 1-3 (0... 1023)
    2. Travel measurement gear actuator 2-4 (0... 1023)
    3. Travel measurement gear actuator 5-N (0... 1023)
    4. Travel measurement gear actuator 6-R (0... 1023)
    in my gearbox the Measured value block 15:
    1. Travel measurement gear actuator 1-3 is 2063
    2. Travel measurement gear actuator 2-4 is 1082
    3. Travel measurement gear actuator 5-N is 2072
    4. Travel measurement gear actuator 6-R is 1224
    the values are above limit because of the dsg ecu reflash??
    Jul 2014
    Greece
    this is a data log from the gearbox
    	SW:02E-300-013-N   HW:02E-927-770-AL ---  Auto Trans
    	Component:GSG DSG AG6     511 2602	 Coding:0000020
    	Saturday	17	January	2015	18:57:08:28322
    	VCDS Version: Release 14,10,0  Data version: 20141022
    	VCID: 1C19182FDFC565C1933-8049
    Group	Field 1	Data type	Field 2	Data type	Field 3	Data type	Field 4	Data type
    1	 	 	 	 	PN Active	 	0,0 km/h	Speed
    2	 P	 	 P	 	1000	Bin, Bits	 P
    3	 P	 	 P	 	Not Oper,	 	Not Oper,
    4	 P	 	Not Recogn,	 	0 /min	RPM	0 /min	RPM
    5	 P	 	Activated	 	13,70 V	Voltage	13,70 V	Voltage
    6	 P	 	0,000 A	Current	19,00%	Duty Cycle	0,846 A	Current
    7	 P	 	0,000 A	Current	22,00%	Duty Cycle	0,846 A	Current
    8	736 /min	RPM	0 /min	RPM	0 /min	RPM	0 /min	RPM
    9	768 /min	RPM	768 /min	RPM	0 /min	RPM	0 /min	RPM
    10	0,00%	Load	 	 	6,0 Nm	Torque	16,0 Nm	Torque
    11	0 /min	RPM	-600,0 Nm	Torque	0,000 A	Current	0,12 bar	Pressure
    12	0 /min	RPM	-600,0 Nm	Torque	0,000 A	Current	0,12 bar	Pressure
    13	0,000 A	Current	19,00%	Duty Cycle	0,00%	Duty Cycle	0,00%	Duty Cycle
    14	0,000 A	Current	22,00%	Duty Cycle	0,00%	Duty Cycle	0,00%	Duty Cycle
    15	2063	Count	1082	Count	2072	Count	1224	Count
    16	-0,1 mm	Distance	-8,3 mm	Distance	0,0 mm	Distance	-8,2 mm	Distance
    17	-2,9 mm	Distance	-3,3 mm	Distance	0,0 mm	Distance	-2,3 mm	Distance
    18	3,5 mm	Distance	2,9 mm	Distance	2,6 mm	Distance	2,7 mm	Distance
    19	39,0C	Temperature	41,0C	Temperature	40,0C	Temperature	Idle
    20	 R	 	2	 	  	 	N/A
    30	0,275 A	Current	0,265 A	Current	0,835 A	Current	0,835 A	Current
    31	0,220 A	Current	0,220 A	Current	0,750 A	Current	0,750 A	Current
    32	0,220 A	Current	1,000 A	Current	0,215 A	Current	1,000 A	Current
    33	243	Count	0	Count	120	Count	0	Count
    34	545	Count	0	Count	556	Count	0	Count
    36	4602	Count	4452	Count	5044	Count	4701	Count
    37	5011	Count	4977	Count	5046	Count	5126	Count
    38	5628	Count	5469	Count	5531	Count	5540	Count
    40	13105	Count	0x3331	Hex Value
    41	v0697q0202ea__getriebe_DSG_Zc7q  	Parameter
    48	F26S	Software
    49	0,20 V	Voltage	9,30 V	Voltage	4,90 V	Voltage	4,90 V	Voltage
    50	8P1 713041 C 0  1 C6	Selector Lever
    51	65535	Count	65535	Count	65535	Count	65535	Count
    52	65535	Count	65535	Count	65535	Count	65535	Count
    53	65535	Count	65535	Count	65535	Count	65535	Count
    54	L45J0062	SV-Parameter
    65	0,65 bar	Pressure	0,65 bar	Pressure	0,75 bar	Pressure	0,50 bar	Pressure
    66	11111	Bin, Bits	11111	Bin, Bits	10101	Bin, Bits	11111	Bin, Bits
    67	0,275 A	Current	0,220 A	Current	N/A		N/A
    68	0,220 A	Current	0,215 A	Current	N/A		N/A
    69	0	Bin, Bits	111	Bin, Bits	0	Bin, Bits	11	Bin, Bits
    70	0	Count	0	Count	N/A		N/A
    71	0000025258  00000 00000 00000 	Count
    72	0000009229  00000 00000 00000 	Count
    79	ON	 	N/A		N/A		N/A
    80	TFK-030 03,11,10 05351112 8503 0213
    81	<> 00001011030213 <>
    82	0003225766565 21,14,23 F10 03 <> <>
    84	006MTX0000196K101125
    90	65535	Count	0	Count	0,00%	Load	0	Count
    91	0 /min	RPM	0 /min	RPM	0 /min	RPM	0 /min	RPM
    93	0,000 A	Current	0,000 A	Current	0,000 A	Current	-60,0C	Temperature
    94	65535	Count	0	Count	0,00%	Load	0	Count
    95	0 /min	RPM	0 /min	RPM	0 /min	RPM	0 /min	RPM
    97	0,000 A	Current	0,000 A	Current	0,000 A	Current	-60,0C	Temperature
    104	0x0000	Hex Value	0x0000	Hex Value	0,00 V	Voltage	-98,0 Nm	Torque
    105	0,00 bar	Pressure	0,000 A	Current	0,00 bar	Pressure	0,000 A	Current
    106	0x0000	Hex Value	0x0000	Hex Value	0,00 V	Voltage	-98,0 Nm	Torque
    107	0,00 bar	Pressure	0,000 A	Current	0,00 bar	Pressure	0,000 A	Current
    109	26760 km	Mileage	92,50%	Duty Cycle	1,00%	Duty Cycle	6,00%	Duty Cycle
    110	0 km	Mileage	N/A		N/A		N/A
    111	0 km	Mileage	N/A		N/A		N/A
    120	100,00%	Load	100,00%	Load	15	Count	1148	Count
    121	100,00%	Load	100,00%	Load	100,00%	Load	100,00%	Load
    122	100,00%	Load	100,00%	Load	100,00%	Load	100,00%	Load
    123	100,00%	Load	100,00%	Load	100,00%	Load	100,00%	Load
    124	100,00%	Load	100,00%	Load	100,00%	Load	100,00%	Load
    125	Engine 1	 	ABS 1	 	Instruments 1	 	Sel,Lev, 1
    126	Gateway 1	 	St, Wheel 1	 	Steer, ang, 1	 	Park Brake 0
    127	Distance 0	 	N/A		N/A		N/A
    130	0 km	Mileage	0	Count	0 km	Mileage	0	Count
    140	455 h	ON Time	85 h	ON Time	0:31	Clock	0,00 s	Time
    141	0,00 s	Time	0,00 s	Time	116,0C	Temperature	N/A
    142	23	Count	425	Count	0	Bin, Bits	5	Count
    210	0	Count	0 km	Mileage	0 00   0	Bin, Bits	N/A
    225	0	(no units)	000 000 000	Raw	 Form, N/A	000 000 000	Raw	 Form, N/A
    226	0	(no units)	000 000 000	Raw	 Form, N/A	000 000 000	Raw	 Form, N/A
    227	000 000 000	Raw	 Form, N/A	N/A		N/A		N/A
    Northern ireland
    Yes, when you remap the dsg box it adjusts the travel paths for the gears. I actually like dsg's but sadly the mechatronics unit is prone to failure. Although saying that the newer versions don't seem to give as much trouble!
  7. #7
    Jul 2014
    Greece
    thank you for the quick response!!
    are you telling me that i am going to have problem in the future??
    the dsg 6 Works perfect with no errors or other problems?
    inlight me please....
  8. #8
    Jul 2014
    Greece
    hello again,
    tell me your opinion please
  9. #9
    Northern ireland
    Nobody can predict the future, but most of the issues I have found with dsg boxes have been from 06-09, I've only ever replaced 1 7 speed mechatronics unit which had an internal short.
  10. Likes Uwe liked this post
  11. #10
    Redwood City, Ca
    It's hard to tell from the various "advice" out there on the Internet, but I'd be willing to bet that many of the DSG problems experienced ae overfill/underfills. It's tough to nail the fill volume just right unless you understand what you're doing (I messed it up the first time and overfilled), but VCDS definitely helped me do it right the second time. '06 A3 with the 3.2l VR6 (PFI).
