Since performing the most recent firmware update to my Hex-Net (two days ago), I've had a problem when trying to complete an Auto-Scan with VCDS Mobile. Each time I try, it hangs while "Trying address 08," at 14% complete. It encounters the same issue whether in Access Point Mode or Infrastructure Mode, and I have tested it on two devices with identical results - first an iPhone (which also serves as the hotspot for Infrastructure Mode) and second a laptop running Firefox.
I have tried clearing the ROD files and the Data Cache, but continue to have the exact same problem. When I cleared the ROD files and try an Auto-Scan in Infrastructure Mode, after I cancel the Auto-Scan after it hangs, I receive a prompt asking if I want to download the ASAM data. When I respond that I do, it appeared to do so successfully. However, when I then go back and select individual modules, some come up as still requiring a download of the ASAM data. In this situation, it appears that those modules listed after Address 08 still require downloading of the ASAM data, while those prior to Address 08 do not. Address 08 itself does not come up as requiring an ASAM data download when I select it. However, the situation makes it seems like the problems I am having relate somehow to a corruption of the ASAM data that was downloaded following the firmware update I performed.
I am able to complete an Autoscan in VCDS on my laptop. Below is a copy of the Autoscan. Any help would be greatly appreciated.
Monday,05,November,2018,17:29:06:07492
VCDS Version: 18.9.0.2 HEX-NET CB: 0.4436.4
VIN: 3VWH17AU1JM762808 License Plate:
Mileage: 2954km-1835mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 3C 42 44 47
4B 52 5F 75 A5 CA D6 D7
VIN: 3VWH17AU1JM762808 Mileage: 2954km-1835miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311D00322466002F1000
Shop #: WSC 00066 790 00235
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: 46C097BDF9BAA97AAF-8012
Part No SW: 0D9 300 018 HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01711081627
ROD: EV_TCMDQ250021.rod
VCID: 59FA4CC158043682F2-800C
P1734 00 [002] - -
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 53227000001314
Coding: 43FA6AA13426096E807F0300A0CB29C2562C9001C005943C36435050E0A5430000010312121212B435351919323200
Shop #: WSC 01383 790 50316
VCID: 77BE2A79CED000F2E4-8022
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0464212546
Coding: 032C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C34F555B776E3AAC9-8068
Part No SW: 5GM 907 044 G HW: 5GM 907 044 G
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 0202002410011800010400001211140A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
VCID: 48DC9985F3AEBF0A5D-801C
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0245
Revision: -------- Serial number: C86408011800SK
Shop #: WSC 00066 790 00147
ROD: EV_BCMBOSCH_018.rod
VCID: 0B566689A2581412B0-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 171125 043 0551
Serial number: 97022066171201163457
Coding: 0E4DFD
Component: RLHS 047 0105
Serial number: S4Y17M12D13H18M23S30
Coding: 00A8DD
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Serial number: 000116644R18002
Coding: 0271167811
VCID: 50ECB1E50BFE77CA05-8004
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 350007C141FFC728949C810520401600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E30FF5DA16AF1BAE7-806A
Serial number: 003GCR08Y7P3
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47DE9AB9FEB0B07254-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH0000000000084TMJ%
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 000 112 17
Serial number: 3570000000002A810924
Subsystem 3 - Part No SW: ----------- HW: 480 000 112 17
Serial number: 35800000000EBB81092T
Subsystem 4 - Part No SW: ----------- HW: 480 402 511 17
Serial number: 351000199285E68196CD
Subsystem 5 - Part No SW: ----------- HW: 480 402 511 17
Serial number: 3520001B7285E68555CD
Subsystem 6 - Part No SW: ----------- HW: 480 400 311 17
Serial number: 3550002AD25629A1316/
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 311 17
Serial number: 3560002A725629A372F8
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 16121708490655
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 095A5C81A824060282-805C
Part No SW: 5G1 920 840 C HW: 5G1 920 840 C
Component: KOMBI 242 0310
Coding: 0BA5101DED88CF0502887B0B5001000080000000
VCID: 271E3A395EF05072B4-8072
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 26111700841943
Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000
Shop #: WSC 00066 790 07026
ROD: EV_GatewNF_VW37.rod
VCID: 383CE945834ECF8A2D-806C
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Serial number: 28170002961430041439
Coding: 35FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: U13DCAC H25 0780
Serial number: 0002519
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Serial number: HA1-00025.09.17
Coding: 0001
VCID: 4CD4A595E7D6532A79-8018
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000342999006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3424DD759F262BEA01-8060
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0461929202
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D32F851AC6CEAA2FE-8068
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0460294454
Coding: 020111
Component: TSG FS 011 0032
Serial number: 5038734401652
Coding: 003F13205000020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000032996
Coding: 011000
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 172 1081
Coding: 930A0000
ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1HMD01BFHN
VCID: 2E10CF1D710A013A77-807A
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 24111700840400
Coding: 000000050100211200110F01030000000000000000000000000000000000
VCID: 72A81B6DA5B265DAD3-8026
Component: TSG BFS 011 0032
Serial number: 6038734200142
Coding: 003F13205C00020000000000
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000093141
Coding: 091000
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0867
Coding: 027312020000000051220002001808009F0508F401200505C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3326DE699A282CD218-8066
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT3566733
Subsystem 2 - Part No SW: 3G0 919 866 BH HW: -----------
Component: NAR 2017/18 --- 0620
Component: OCULowMQBUS 009 0570
Coding: 02730202C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
VCID: 43C68EA9CA889C5288-8016
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 06101741K21859
Coding: 000307020002020100221354C150490084000E200120
VCID: 085C5985B32E7F0A9D-805C
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 00804073720C
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 393AEC41B844D682D2-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 02:21, VBatt start/end: 12.4V/12.4V)-----------
