Results 1 to 9 of 9
Thread: VCDS Mobile Autoscan Hangs at 14%
    Since performing the most recent firmware update to my Hex-Net (two days ago), I've had a problem when trying to complete an Auto-Scan with VCDS Mobile. Each time I try, it hangs while "Trying address 08," at 14% complete. It encounters the same issue whether in Access Point Mode or Infrastructure Mode, and I have tested it on two devices with identical results - first an iPhone (which also serves as the hotspot for Infrastructure Mode) and second a laptop running Firefox.
    I have tried clearing the ROD files and the Data Cache, but continue to have the exact same problem. When I cleared the ROD files and try an Auto-Scan in Infrastructure Mode, after I cancel the Auto-Scan after it hangs, I receive a prompt asking if I want to download the ASAM data. When I respond that I do, it appeared to do so successfully. However, when I then go back and select individual modules, some come up as still requiring a download of the ASAM data. In this situation, it appears that those modules listed after Address 08 still require downloading of the ASAM data, while those prior to Address 08 do not. Address 08 itself does not come up as requiring an ASAM data download when I select it. However, the situation makes it seems like the problems I am having relate somehow to a corruption of the ASAM data that was downloaded following the firmware update I performed.
    I am able to complete an Autoscan in VCDS on my laptop. Below is a copy of the Autoscan. Any help would be greatly appreciated.
    Monday,05,November,2018,17:29:06:07492
    VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
    VIN: 3VWH17AU1JM762808   License Plate:
    Mileage: 2954km-1835mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 3C 42 44 47
              4B 52 5F 75 A5 CA D6 D7
    VIN: 3VWH17AU1JM762808   Mileage: 2954km-1835miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 311D00322466002F1000
       Shop #: WSC 00066 790 00235
       ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
       ROD: EV_ECM18TFS0208V0906264M.rod
       VCID: 46C097BDF9BAA97AAF-8012
       Part No SW: 0D9 300 018     HW: 02E 927 770 AS
       Component: DQ250-6A MQB  H54 5201
       Revision: 06454104    Serial number: TFK01711081627
       ROD: EV_TCMDQ250021.rod
       VCID: 59FA4CC158043682F2-800C
              P1734 00 [002] - -
       Revision: 00000000    Serial number: 53227000001314
       Coding: 43FA6AA13426096E807F0300A0CB29C2562C9001C005943C36435050E0A5430000010312121212B435351919323200
       Shop #: WSC 01383 790 50316
       VCID: 77BE2A79CED000F2E4-8022
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0464212546
       Coding: 032C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C34F555B776E3AAC9-8068
       Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
       Component: Climatronic   H04 2001
       Revision: 00001K05
       Coding: 0202002410011800010400001211140A
       ASAM Dataset: EV_ACClimaBHBVW37X 006146
       VCID: 48DC9985F3AEBF0A5D-801C
       Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
       Component: BCM PQ37BOSCH 034 0245
       Revision: --------    Serial number: C86408011800SK
       Shop #: WSC 00066 790 00147
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0B566689A2581412B0-805E
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    171125  043 0551
       Serial number: 97022066171201163457
       Coding: 0E4DFD
       Component: RLHS  047 0105
       Serial number: S4Y17M12D13H18M23S30
       Coding: 00A8DD
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000116644R18002
       Coding: 0271167811
       VCID: 50ECB1E50BFE77CA05-8004
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 350007C141FFC728949C810520401600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: 3E30FF5DA16AF1BAE7-806A
       Serial number: 003GCR08Y7P3
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47DE9AB9FEB0B07254-8012
       Occupant Detection:
       Serial number: IBH0000000000084TMJ%
       Coding: 303137
       Subsystem 2 - Part No SW: -----------    HW: 480 000 112 17
       Serial number: 3570000000002A810924
       Subsystem 3 - Part No SW: -----------    HW: 480 000 112 17
       Serial number: 35800000000EBB81092T
       Subsystem 4 - Part No SW: -----------    HW: 480 402 511 17
       Serial number: 351000199285E68196CD
       Subsystem 5 - Part No SW: -----------    HW: 480 402 511 17
       Serial number: 3520001B7285E68555CD
       Subsystem 6 - Part No SW: -----------    HW: 480 400 311 17
       Serial number: 3550002AD25629A1316/
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 311 17
       Serial number: 3560002A725629A372F8
       Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 16121708490655
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 095A5C81A824060282-805C
       Part No SW: 5G1 920 840 C    HW: 5G1 920 840 C
       Component: KOMBI         242 0310
       Coding: 0BA5101DED88CF0502887B0B5001000080000000
       VCID: 271E3A395EF05072B4-8072
       Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5323
       Serial number: 26111700841943
       Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000
       Shop #: WSC 00066 790 07026
       ROD: EV_GatewNF_VW37.rod
       VCID: 383CE945834ECF8A2D-806C
       Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
       Serial number: 28170002961430041439
       Coding: 35FFFF
       Power Converter DC AC:
       Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
       Component: U13DCAC  H25 0780
       Serial number: 0002519
       Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7084
       Serial number: HA1-00025.09.17
       Coding: 0001
       VCID: 4CD4A595E7D6532A79-8018
    Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
       Revision: 00000000    Serial number: 17000342999006
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3424DD759F262BEA01-8060
    Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
       Component: HRE_Master    H12 0080
       Serial number: 0461929202
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D32F851AC6CEAA2FE-8068
       Component: HRE_Slave  H12 0080
       Serial number: 0460294454
       Coding: 020111
       Component: TSG FS        011 0032
       Serial number: 5038734401652
       Coding: 003F13205000020000000000
       Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F
       Serial number: 00000000000000032996
       Coding: 011000
       Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
       Component: EPS_MQB_ZFLS  172 1081
       Coding: 930A0000
       ROD: EV_SteerAssisMQB_015.rod
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
       Component: MIB2_lite_amp H40 0200
       Revision: 00000001    Serial number: VWZ8Z1HMD01BFHN
       VCID: 2E10CF1D710A013A77-807A
    Address 4B: Multifunc. Module (J745)       Labels:* None
       Part No SW: 3Q0 907 338     HW: 3Q0 907 338
       Component: FCM MQB Low   002 0286
       Serial number: 24111700840400
       Coding: 000000050100211200110F01030000000000000000000000000000000000
       VCID: 72A81B6DA5B265DAD3-8026
       Component: TSG BFS       011 0032
       Serial number: 6038734200142
       Coding: 003F13205C00020000000000
       Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F
       Serial number: 00000000000000093141
       Coding: 091000
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    851 0867
       Coding: 027312020000000051220002001808009F0508F401200505C6
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 3326DE699A282CD218-8066
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZJT3566733
       Subsystem 2 - Part No SW: 3G0 919 866 BH    HW: -----------
       Component: NAR 2017/18  --- 0620
       Component: OCULowMQBUS   009 0570
       Coding: 02730202C2823A017F1E06020000
       ROD: EV_OCULowMQB.rod
       VCID: 43C68EA9CA889C5288-8016
       Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H08 1272
       Serial number: 06101741K21859
       Coding: 000307020002020100221354C150490084000E200120
       VCID: 085C5985B32E7F0A9D-805C
       Coding: 00804073720C
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 393AEC41B844D682D2-806C
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    End----------(Elapsed Time: 02:21, VBatt start/end: 12.4V/12.4V)-----------
    Can you please make a debug log in VCDS-Mobile, [Options] -> debug level = 001F -> [Submit] then go back and do an autoscan. When that finishes, make sure the resulting debug log is synced to the cloud (from [View Saved Files] page) or email it to us.
  3. Likes Uwe liked this post
    Just done. Docid 0000463A (debug) and 0000463F (canceled auto-scan that hanged at address 08).
    Do you have any problems talking to the 05 or 08 individually, outside of an autoscan?
    I put your interface onto the alpha channel, so you should now be able to download a couple of testing updates if you check for updates again. I don't know if any of these will fix your issue, but for debugging purposes it's at least good to be running the latest stuff.
    Can I get you to make two more debug logs of the autoscan, one with level 41F and one with level just 00F
    If you want to get the ASAM data for modules after 08, you can go and talk to each of them manually and then go and check for updates when you're done with all of them, it should be able to get you all the ASAM data at once.
  6. Likes Uwe, Andy liked this post
    pschwa I put your interface on the alpha channel and have a new alpha codeblock for you to test, V0.4444. Please check for updates and once you have that updated, go ahead and try autoscanning again.
  8. Likes jyoung8607, Uwe liked this post
  9. #6
    Mar 2018
    I have exactly the same problem with VCDS Mobile and 08 address (autoscan/individual scan). It was working a few months ago, but it took about a minute to scan 08 address.
    Shaun can you also put my interface on the alpha channel? Do you need more debug logs?
  10. #7
    Sure I put you on alpha, but that may not be the same problem. Feel free to make debug logs if the alpha doesn't help.
  11. Likes Uwe liked this post
  12. #8
    Hey Shaun,
    That new alpha firmware seemed to do the trick for me. Auto scan completed successfully and new ASAM data was downloaded to complete the set for all modules. I am still having an issue with uploading saved files to VCDS Cloud, where the completion of upload is never confirmed from the Saved Files interface, and in many cases the file does not upload at all.
  13. Likes Eric, Uwe liked this post
  14. #9
    Mar 2018
    I also tested the new alpha codeblock and now autoscan completed in my case too. Before I updated, I made three debug logs with the options 001F, 041F and 000F. When I tried to upload them to the cloud, upload never finished. I had to refresh the page to get rid of the ”Uploading” message. I just logged in to the vcds-cloud.com and the files are there. So I share pschwa’s findings about the file upload function.
  15. Likes Eric, Uwe liked this post
