Tuesday,06,November,2018,09:58:03:47213
VCDS Version: 18.9.0.2 HEX-V2 CB: 0.4436.4
VIN: WVGZZZ7PZHD034472 License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 11 31 13 15 16 17 19 28 34 36 3C 42
46 47 52 53 55 56 5F 62 65 69 6C 6D 72 85 8B 8E 8F 90
VIN: WVGZZZ7PZHD034472 Mileage: 25823km-16045miles
Address 01: Engine (J623-CKDA) Labels:. 057-907-409-CKD.clb
Part No SW: 7P1 907 409 A HW: 7P0 907 409
Component: 4.2TDI EDC17 H21 0001
Revision: 52H21---
Coding: 292A4012437E00020000
Shop #: WSC 25979 002 1048576
ASAM Dataset: EV_ECM42TDI1117P1907409A 001001
ROD: EV_ECM42TDI111_VW52.rod
VCID: 3635DA0C68CCFB67749-8062
10380 - Engine Control Module
P166D 00 [032] - Incorrect Installation
Address 02: Auto Trans (J217) Labels: 0C8-927-755.clb
Part No SW: 0C8 927 755 A HW: 0C8 927 755
Component: 64C05G0M.MOT 130 3066
Coding: 010100000C008400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 2F3BEF689796CAAF37F-807A
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 40627398303864
Coding: 5B6B53C34B276F57DAF8CA9AD2D4F660F701
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC198E4064091B732D-8018
Part No SW: 4H0 907 064 JM HW: 4H0 907 064 JM
Component: BCM2 2.0 H44 0582
Coding: 05960016000000000000
VCID: 7DA705200DFAE83FF53-8028
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 3217000049541016
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000253900314
Coding: 0038330000004201000001010101202020202121202020
VCID: 3431E0047E30E9774AD-8060
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CR HW: 7P6 907 040 CR
Component: Klima 4 Zonen H23 1608
Coding: 38A620BEC0
VCID: 06556ACC58ACABE7A49-8052
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 2202007S Serial number: 00001655000401
Coding: 26000014D0345D010029400780005D4C431D670823014241800000000040110000000000000000
VCID: 6A8D3E7C6C746F87201-803E
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 170405 033 0021
Serial number: 90243401170426064759
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 81051716
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AB HW: 7P6 941 431 AB
Component: E1 - LDS H02 0040
Serial number: 00000000002804170370
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA127501000032668175
Coding: 020300
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28231712200100
Coding: 518D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44D1B0C42E1059F7FAD-8010
Address 11: Engine II (J624) Labels: None
Revision: 52H21---
ASAM Dataset: EV_ECM42TDI2117P1907409A 001001
ROD: EV_ECM42TDI_VW52.rod
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Coding: 3704010101
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C21C82456E0213782D-8068
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 G HW: 7P0 959 655 G
Component: VW10Airbag00T H11 0048
Revision: -------- Serial number: 003TU002N27A
Coding: 000000000000000000000000000000003054
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
VCID: 45D7ADC0252A60FFED3-8010
Serial number: 3575LRB40674AN7Q8H9S
Serial number: 3585LRB401857HGCAGAE
Serial number: 3517ARB40694N63GAGB0
Serial number: 3527ARB40694N63GFOKN
Serial number: 3557BRB401057J24TS95
Serial number: 3567BRB401057J24NS7+
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0010
Revision: -------- Serial number: 01374QE5000J3
Coding: 000CFD
VCID: 3D27C5204D7A283FB53-8068
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0157806 TRW 20170405
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 883 S HW: 7P6 920 883 S
Component: Kombi H15 0607
Revision: 15240314 Serial number: 658060517592030
Coding: 331733003F08000800000C
ASAM Dataset: EV_KombiUDSRBVW526 001030
ROD: EV_KombiUDSRBVW526.rod
VCID: 4EC592ECF05CA3A75C9-801A
Part No SW: 7P6 907 530 R HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H15 6055
Revision: -------- Serial number: 00000002603198
Coding: 0001037D00
ASAM Dataset: EV_GatewVW526UDS 001008
ROD: EV_GatewUDS_VW52.rod
VCID: 47CBA7C81F2672EF1FF-8012
Subsystem 1 - Part No SW: 7P0 915 181 C HW: 7P0 915 181 C
Component: Batt_Sensor H07 0270
Serial number: 34109006055811382710
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 7P6 907 049 S HW: 7P6 907 049 S
Component: Klima Fond H16 1406
Coding: 0000000000
ASAM Dataset: EV_AirCondiHeck 001007
ROD: EV_AirCondiHeck_VW52.rod
VCID: 4DC795E0FD5A98BF253-8018
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 AH HW: 7P0 907 553 AH
Component: PASM H05 0960
Revision: 00000000 Serial number: 00000171150318
Coding: 15210001
ASAM Dataset: EV_PASMConti 001005
ROD: EV_PASMConti.rod
VCID: 7DA705200D7AE83FF53-8028
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000253900583
Coding: 00383B0000004201000001010101202020202121202020
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H08 0030
Serial number: 0437276552
Coding: 030322
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3FDBBF2847F63A2FA7F-806A
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H08 0030
Serial number: 0440338026
Coding: 030322
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H03 0306
Revision: -------- Serial number: 0000254858862
Coding: 011D1620DE01459205080003
VCID: 7AAD0E3C1CD4DF07D01-802E
Revision: 00002001 Serial number: 0441255609
Coding: 019B1E20A8B91095832006202F0000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 172
Component: Sensor, DWA 005 0502
Subsystem 2 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 3 - Part No SW: 7P0 959 591 D HW: 6R0 959 591 D
Component: J245 PS30.408 H03 0004
Serial number: 0000FST001KNZEL00000
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 E HW: 8V3 959 591 A
Component: J394 PS30.408 H03 0004
Serial number: 0000FST001KYYJ000000
Coding: 191100
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H02 0090
Revision: 00002001 Serial number: 10813003795603
VCID: 75B71D0035CAB07FBD3-8020
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H03 0306
Revision: -------- Serial number: 0000254748823
Coding: 011D1620DE01459205080000
VCID: 48C9A4F412B87D97165-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 G HW: 7P0 907 801 G
Component: EPB H51 1201
Revision: 00000000 Serial number: C1741400611
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: 372BD7086FC6026F6FF-8062
Slave 3:
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 012602000B000200
ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0006
Coding: B00000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0006
Coding: B00000
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227D.0H5032496
Coding: 040005010000000003
VCID: 26150A4CB8EC8BE7C49-8072
Part No SW: 7P6 035 764 N HW: 7P6 035 764 A
Component: H-BNT-RW H42 1047
Revision: -------- Serial number: 605DO0H5001514
Coding: 020A01050040E9EF71102B0E00000003F00001030000000000
VCID: 44D1B0C42E9059F7FAD-8010
Subsystem 1 - Part No: 8R0 060 884 EG
Component: ROW 2017 0905
Subsystem 2 - Part No SW: 7P6 919 603 J HW: 7P6 919 603 J
Component: DU8 SV Touch H56 0046
Serial number: VWZ8Z9TGF01FR1
Subsystem 3 - Part No SW: 7P6 919 603 J HW: 7P6 919 603 J
Component: CD-Database 9040
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H04 0306
Revision: -------- Serial number: 0000255022066
Coding: 011814200001259005080000
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 L HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 40000000065089
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H20 0160
Revision: 7C001003 Serial number: 0429912452
Coding: 0300000202000000
ROD: EV_TrailFunctGener2Hella_VW52.rod
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 G HW: 7P6 907 441 G
Component: TopView H09 0115
Revision: 11001001 Serial number: 82330JG0400084
Coding: 0100000001000000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
VCID: 3D27C5204DFA283FB53-8068
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 111700675
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Component: TSG HR H04 0306
Revision: -------- Serial number: 0000254910351
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H27 0035
Revision: -------- Serial number: 262130025421000
Coding: E8030000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 392FD13059D2141F99B-806C
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007069605_3641
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3704010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526_002.rod
VCID: 3A2DCE3C5CD41F07901-806E
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H34 0035
Serial number: 005002471504177
Coding: 0A809E040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H16 0080
Coding: 00660600031F037F00033810594097000000
Shop #: WSC 00001 790 00001
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313FE91081A2DC5F21B-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H16 0080
Coding: 006606000317037F00033810594097000000
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323DE61C84A4E747581-8066
End----------(Elapsed Time: 02:28, VBatt start/end: 12.3V/12.2V)-----------
