Results 1 to 10 of 16
Thread: Audi S3 8L (2002) - Internal Control Module Memory Error.
    Nov 2018
    Question Audi S3 8L (2002) - Internal Control Module Memory Error.
    Hi All,
    Brief story: Iím in the process of upgrading my stereo to an aftermarket one. I have ended up removing all interior accept the dashboard; laid down some RCA cables from the front to the rear and have put everything back together. No standard Audi wires were cut, and all connectors are connected.
    Having not driven the car for a while, ABS, ESP and Red Brake symbol appeared with three audio beeps when engine was started. Iíve replaced the old battery with a new one and all faults were cleared. However, I keep getting the following faults appearing which I'm unable to resolve Ė the faults in question are Engine, ABS Brakes and AWD.
    Can anyone shed some light, on how to resolved this please?
    Sunday,04,November,2018,12:46:01:06092
    VCDS Version: 18.9.0.2 (x64)
    VIN: WAUZZZ8L931204596   License Plate: GK52KZZ
    Mileage: 141359   Repair Order:
    Chassis Type: 8L (8L - Audi A3/S3 (1997 > 2005))
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    Address 01: Engine        Labels: 06A-906-032-BAM.lbl
       Part No: 8N0 906 018 BH
       Component: 1.8L R4/5VT     G   0001
       Coding: 10710
       Shop #: WSC 02629
       VCID: 78FFC92B58C4878AED-5140
       WAUZZZ8L931204596     AUZ7Z0B2120938
    18057 - Powertrain Data Bus
                P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
    Readiness: 0000 0001
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
       Part No: 8N0 907 379 E
       Component: ESP     20    CAN  V005
       Coding: 18448
       Shop #: WSC 01236
       VCID: 3E731F333A6079BAE7-4B04
    65535 - Internal Control Module Memory Error
                00-00 -  -
    Address 08: Auto HVAC        Labels: Redir Fail!
       Part No: 8L0 820 043 L
       Component: A3  KLIMAAUTOMAT   0105
       Coding: 00041
       Shop #: WSC 01236
       VCID: 3169340FFB3E96C26A-2582
    Address 15: Airbags        Labels: 8L0-959-655-AI8.lbl
       Part No: 8L0 959 655 L
       Component: Airbag Front+Seite 7008
       Coding: 01104
       Shop #: WSC 01236
       VCID: 479D7AD765BA387254-5140
    Address 17: Instruments        Labels: 8L0-920-xxx-17.lbl
       Part No: 8L0 920 980 R
       Component: KOMBI+WEGFAHRS. VDO D10
       Coding: 01444
       Shop #: WSC 00285
       VCID: 428B6BC34E981D5A83-5140
    01304 - Radio
                49-00 - No Communications
    Address 22: AWD        Labels: 02D-900-554.lbl
       Part No: 02D 900 554 C
       Component: HALDEX LSC  ECC     0010
       VCID: 204FC14BA0D42F4AF5-4B04
    Address 35: Centr. Locks        Labels:. 8D0-862-257.lbl
       Part No: 8D0 862 257 E
       Component: CV-Pump, Alarm, RC  D17
       Coding: 15214
       Shop #: WSC 00151
       VCID: 2F6D3277ED0A80327C-4F3E
    01134 - Alarm Horn (H12)
    Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
       Part No: 4B0 951 173
       Component: Innenraumueberw.    D03
       Coding: 00001
       VCID: 60CF814BE0546F4AB5-4B36
    01377 - Ultra Sonic Sensor for Alarm System; Left (G170)
                31-10 - Open or Short to Ground - Intermittent
    01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D004
       Coding: 00014
       Shop #: WSC 01236
       VCID: 65C1905FFF760A6246-515C
    Address 76: Park Assist        Labels: 4B0-919-283.lbl
       Part No: 4B0 919 283
       Component: Parkingsystem A3 RDW D18
       Coding: 00103
       Shop #: WSC 01236
       VCID: 66C397530270017A4F-51D4
    No Faults Found
    End-------------------------(Elapsed Time: 04:05)--------------------------
    United States
    I believe you fall into category #2: https://forums.ross-tech.com/showthr...o-get-Verified
    If you purchased that HEX-USB+CAN directly from a distributor (rather than 2nd hand) please fill out this form including "Please check my forum status" in the 'Notes or Special Instructions' field of the form. After doing so we can flip you status to Verified and move this to the Car Repair Support section.
    Next, it is possible the 03-ABS module is failing but I'd re-check the battery connections, connections at the Golf Mk4 style fuse panel on top of the battery and inspect the wiring near the ABS module itself to rule out a flaky connection or rodent damage (wire chewing) that may explain a voltage drop causing 65535.
  3. Likes Uwe, Jack@European_Parts liked this post
    Nov 2018
    Hi Dana,
    I've now registered and waiting confirmation from ross-tech.com.
    The fuse panel on top of the battery is fine, as well as the terminals, clean and free from corrosion. Also, the ABS module cable has not been tampered with, but I will check again.
    There does not seem to be much information regarding fault 65535 - Internal Control Module Memory Error and how to resolve it. I really hope my ABS module is not on the verge of dying!
    Thanks.
  5. Likes Dana liked this post
  6. #4
    OP is now Verified. Moving to Car Repair Support.
  7. Likes Dana liked this post
  8. #5
    Nov 2018
    If it's any help, here's the original scan before the battery was replaced. Please ignore faults with Airbags, Instruments, Centr. Locks, Inter. Monitor as these were relating to me removing the interior headlining.
    Sunday,21,October,2018,15:51:55:06092
    VCDS Version: 18.2.1.5 (x64)
       Coding: 10710
       Shop #: WSC 02629
       VCID: 78FFC92B58C487841C-5140
    18010 - Power Supply Terminal 30
                P1602 - 35-00 - Voltage too Low
       Coding: 18448
       Shop #: WSC 01236
       VCID: 3E731F333A6079B416-4B04
    8 Faults Found:
                00-00 -  -
                16-10 - Signal Outside Specifications - Intermittent
    01130 - ABS Operation
    00538 - Reference Voltage
                57-10 - Electric Circuit Failure - Intermittent
    00814 - Solenoid for Brake Pressure (N247)
                35-10 -  -  - Intermittent
    00812 - Brake Pressure Release Solenoid (F84)
                37-10 - Faulty - Intermittent
       Coding: 00041
       Shop #: WSC 01236
       VCID: 3169340FFB3E96CC9B-2582
       Coding: 01104
       Shop #: WSC 01236
       VCID: 479D7AD765BA387CA5-5122
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
                30-00 - Open or Short to Plus
       Coding: 01444
       Shop #: WSC 00285
       VCID: 428B6BC34E981D5472-5140
    01304 - Radio
       VCID: 204FC14BA0D42F4404-4B1C
       Coding: 15214
       Shop #: WSC 00151
       VCID: 2F6D3277ED0A803C8D-4F22
                35-00 -  -
    01370 - Alarm triggered by Interior Monitoring
                35-00 -  -
       Coding: 00001
       VCID: 60CF814BE0546F4444-4B36
       Coding: 00014
       Shop #: WSC 01236
       VCID: 65C1905FFF760A6CB7-517A
       Coding: 00103
       Shop #: WSC 01236
       VCID: 66C3975302700174BE-51D4
    End-------------------------(Elapsed Time: 03:55)--------------------------
  9. #6
    Sep 2019
    Bournemouth, UK
    Please excuse me for jumping on the end of this thread, - especially as my first post.
    As the thread has been dead for nearly a year, i thought it might be ok.
    Did you find the cause of this issue with the car?
    I`ve been having the same issue intermittently - most notably when the car has been sat over night or for a few hours. Having driven the car for about 1/2 hour, the ABS light goes out and all appears normal.
    Ive replaced all fuses associated with the ABS, replaced the battery as this was suspect and cleaned up the earth points under the battery and the one on the scuttle in front of the ECU.
    Im beginning to think there`s a wiring issue in the loom feeding the module, (a lot of responses to 63353 fault code suggest this) especially as my rear washer jet pipe has been leaking.
    Did you find the problem in the end?
  10. #7
    Welcome to the VCDS forum.........
    Isn't this most likely a faulty terminal 15 reset & either from back feed, relay related, poor ground or ignition switch?
    Please JPPSG & post an auto scan ..........
  11. Likes Uwe liked this post
  12. #8
    Sep 2019
    Bournemouth, UK
    Thank you for your reply. I didnt realise i had had a response to this until yesterday evening.
    I`ll post a scan later today when im back on my laptop.
    Having done some inspection on the wiring loom this weekend, I have got solid 12v + on both permanent power feeds and good grounds too to the area under the battery.
    Ive looked at the wiring diagram and believe PIN 4 is the ignition feed into the plug. I`ll check this later today and report back along with the code scan.
  13. #9
    Sep 2019
    Bournemouth, UK
    Today I have had the day off to try and get to the bottom of this issue,or at least a process of elimination
    Here is a fresh scan from today after clearing old DTCS
     VIN: WAUZZZ8L831202175   License Plate:
       Component: 1.8L R4/5VT         0001
       Coding: 10710
       Shop #: WSC 33278
       VCID: 78A9E9F99BC1D077F29-5160
       WAUZZZ8L831202175     AUZ7Z0B2114192
                P1649 - 35-00 - Missing Message from ABS Controller
    Readiness: 0110 0100
       Coding: 18448
       Shop #: WSC 01236
       VCID: 3E253FE1F9652E47F85-4B1E
                00-00 - -
    00813 - Sensor 2 for Brake Pressure (G214)
                57-00 - Electric Circuit Failure
       Part No: 8L0 820 043 K
       Coding: 00041
       Shop #: WSC 01236
       VCID: 303911D93331C8377A9-2596
       Coding: 01104
       Shop #: WSC 01236
       VCID: 47CB5A05A6BF6F8F4B3-5160
       Coding: 01444
       Shop #: WSC 00001
       VCID: 42DD4B118D9D4AA79CD-5160
       VCID: 2019E19963D178B7EA9-4B1E
    No Faults Found
    Address 35: Centr. Locks        Labels:. 8D0-862-257.clb
       Coding: 15211
       Shop #: WSC 27925
       VCID: 2F3B12A52E0FD7CF633-4F2E
       Coding: 00001
       VCID: 6099A199235138B7AA9-4AA4
       Coding: 00014
       Shop #: WSC 01236
       VCID: 6597B08D3C735D9F59F-5184
       Part No: 8L0 035 195 H
       Component: symphony II NP2    0151
       Coding: 00201
       Shop #: WSC 24929
       VCID: 33331ED5C227F32F07B-4E62
    End----------(Elapsed Time: 03:17, VBatt start/end: 12.2V/12.2V)-----------
    So far i have:
    Replaced all fuses- 2x 30amp on top of the battery and the 5amp interior fuse
    I have checked and have 2 good 12v+ permanent power feeds
    I have good earth points having cleaned up both the stud and the terminal ends
    I found my Haldex earth strap like so many had come apart so i have replaced this today
    Where im slightly confused is that i have 2 12v+ terminal 15 feeds with the ignition on. Both of these drop with either the ignition off or with the interior fuse removed.
    The only wiring diagram i could find that related to the car (A3 8L was as close as i could find) was one with a 25 Pin J104 module plug. Mine appears to have 44 pins, so i`m not 100% sure i should have two ignition feeds?
    Any ideas. Im now wondering if it is an internal module issue.
  14. #10
    Quote Originally Posted by AntonS38l View Post
    Sounds like you need to create an account on the EU Audi erWin website, buy 1 hour access and download all the documents for your car (enter the VIN to get the correct ones) which will include the wiring diagrams.
  15. Likes Uwe, Jack@European_Parts liked this post
