Hello Audi folks,
My AudiQ7 (2012) has misfire with cylinders 4,5,6 (only the left one) only (1,2,3 perfect without any error). The Engine light was randomly popped up and sometimes automatically off, especially when I drove more than 100km/h. The misfile usually happened at cold weather but not always true.
I am in Canada so I am using the super premium gasoline (91%) - the highest quality gasoline.
Here are what I have done so far:
1. I have changed all the spark plugs but did not not help.
2. I bought an ignition cold pack and changed it circularly among 4,5,6 but misfire is still there with 4,5,6.
Since we don't have Audi dealer at our town (VW only but I don't think they are good), I bought the car to an very experienced mechanical guy. He use his diagnosis tool (similar to our VCDS) to examine it and thought that it could be something with the software update. He advised to talk with the Audi dealer about software update but I couldn't find any information about software update for misfire on Internet. Moreover, the closest Audi deader is more than 300km away from our town so I would like to fix this issue ourselves if possible.
Please find the Auto Scan report below and kindly advise me possibilities and how to check up. Note that, this report was about 3-4 months since I did not clear the DTCs.
My deep appreciation to your advice!
Friday,26,October,2018,01:12:04:38100
VCDS Version: 18.9.0.2 HEX-V2 CB: 0.4436.4
VIN: WA1DGCFE4CD004190 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
56 5F 62 69 6C 6D 6F 72 76
VIN: WA1DGCFE4CD004190 Mileage: 122270km-75975miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CJW) Labels: None
Part No SW: 4L0 910 551 K HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0040
Revision: --H08--- Serial number:
Coding: 0121000A290F0928
Shop #: WSC 23095 001 1048576
VCID: 3039EC96E62A1EC72E5-8064
8 Faults Found:
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - Intermittent
Fault Frequency: 43
Mileage: 115244 km
Date: 2018.06.04
Time: 13:05:02
RPM: 2272 /min
Mass Air / Rev.: 201.7 mg/str
Temperature: 22.5∞C
Bin. Bits: 00000100
Time: 25.6 s
000773 - Cylinder 5
P0305 - 000 - Misfire Detected - Intermittent
Fault Frequency: 40
Mileage: 115244 km
Date: 2018.06.04
Time: 13:05:02
RPM: 2272 /min
Temperature: 22.5∞C
Bin. Bits: 00000100
Time: 25.6 s
P0300 - 000 - - Intermittent
Fault Status: 00100001
Fault Frequency: 39
Mileage: 115244 km
Date: 2018.06.04
Time: 13:05:32
RPM: 672 /min
Mass Air / Rev.: 179.9 mg/str
Temperature: 30.0∞C
Bin. Bits: 00000010
Time: 51.2 s
000774 - Cylinder 6
P0306 - 000 - Misfire Detected - Intermittent
Fault Frequency: 33
Mileage: 115278 km
Date: 2018.06.05
Time: 13:11:40
RPM: 2272 /min
Temperature: 22.5∞C
Bin. Bits: 00000100
Time: 25.6 s
004874 - Cylinder Disabling
P130A - 000 - - Intermittent
Mileage: 120595 km
Date: 2018.08.23
Time: 10:40:48
RPM: 160 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 96.0∞C
Bin. Bits: 00000001
Time: 0.0 s
U1017 - 000 - - Intermittent
Mileage: 120595 km
Date: 2018.08.23
Time: 10:40:48
RPM: 4256 /min
Mass Air / Rev.: 877.5 mg/str
Temperature: 97.5∞C
Bin. Bits: 00000011
Load: 73.7 %
Speed: 110.0 km/h
008768 - Oxygen (Lambda) Sensor B2 S1
P2240 - 000 - Pump Current Open Circuit - Intermittent
Mileage: 121104 km
Date: 2018.09.08
Time: 16:22:07
RPM: 1184 /min
Mass Air / Rev.: 70.9 mg/str
Temperature: 94.5∞C
Bin. Bits: 00000101
Bin. Bits: 00000100
004393 - Fuel Trim; Bank 2 (Mult)
P1129 - 000 - System too Rich - Intermittent - MIL ON
Fault Status: 10100010
Mileage: 121581 km
Date: 2018.10.07
Time: 13:29:18
RPM: 1472 /min
Mass Air / Rev.: 316.1 mg/str
Temperature: 96.0∞C
Bin. Bits: 00000011
Time: 1664.0 s
Bin. Bits: 00000010
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 001 2090
Coding: 001378
ROD: EV_TCMAL991031_002.rod
VCID: 3A2DCEBE3CD6D497901-806E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099409
Shop #: WSC 31414 790 00001
VCID: 3431E086123222E74AD-8060
Fault Status: 00101101
Reset counter: 52
Mileage: 120595 km
Date: 2018.08.23
Time: 10:40:47
Count: 27392
Count: 8193
Count: 8196
Count: 51968
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10603401905722
Coding: 0000135
VCID: 25170DC2A9E84B6FCD3-8070
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 112
Mileage: 114919 km
Date: 2018.06.04
Time: 07:09:24
Reset counter: 112
Mileage: 114919 km
Date: 2018.06.04
Time: 07:09:24
00956 - Key 2
Fault Status: 00110010
Reset counter: 78
Mileage: 121227 km
Date: 2018.09.29
Time: 10:12:33
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AJ
Revision: 00---026 Serial number: 00000030214020
Coding: 000CC026
VCID: 25170DC2A5E84B6FCD3-8070
Subsystem 1 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 0015396664
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Serial number: 0015396025
Coding: 070000
01273 - Fresh Air Blower (V2)
Reset counter: 77
Mileage: 121274 km
Date: 2018.10.04
Time: 15:59:54
Temperature: 26.0∞C
Speed: 47.0 km/h
(no units): 122.0
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0133114
VCID: 6E8532EE3C9E48377C9-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Fault Status: 00100111
Reset counter: 85
Mileage: 122232 km
Date: 2018.10.12
Time: 17:10:00
Reset counter: 85
Mileage: 122232 km
Date: 2018.10.12
Time: 17:10:00
Fault Status: 00101010
Fault Frequency: 14
Reset counter: 85
Mileage: 121264 km
Date: 2018.10.04
Time: 13:44:00
Reset counter: 85
Mileage: 122232 km
Date: 2018.10.12
Time: 17:10:00
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 75 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09WGZD
Coding: 0014133
VCID: 2B03FBFACF0C7D1F1B7-807E
Subsystem 1 - Serial number: 6332QSME69603E48P
Subsystem 2 - Serial number: 6342QSME6860314AE
Subsystem 3 - Serial number: 6352QSME6760545AK
Subsystem 4 - Serial number: 6362QSME1D5F4F6E8
Subsystem 5 - Serial number: 63734SME6066184C1
Subsystem 6 - Serial number: 63834SME63662E725
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H07000 Serial number: 90025112660077
Coding: 0012142
VCID: 280904F6DEFA5607F65-807C
Component: E0221 H03 0030
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 932 Q HW: 4L0 920 932 Q
Component: KOMBIINSTR. H22 0411
Revision: 00000000 Serial number: LMY00UCAC
Coding: 8BD6630409000008020304
VCID: 3A2DCEBE3C56D497901-806E
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0057
Revision: MB600036 Serial number: 3600M11926004B
Coding: 00C303
VCID: 3FDBBFAA2774F1BFA7F-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790684988
02256 - Quiescent Current
Reset counter: 80
Mileage: 121900 km
Date: 2018.10.08
Time: 21:53:00
Reset counter: 80
Mileage: 121900 km
Date: 2018.10.09
Time: 01:53:00
Bin. Bits: 00000
Voltage: 12.50 V
Count: 18
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Revision: 00---010 Serial number: 00000030213844
Coding: 0000006
VCID: 688944F61E7A9607365-803C
00003 - Control Module
Fault Status: 00100011
Fault Frequency: 10
Mileage: 115247 km
Date: 2018.06.04
Time: 13:24:33
Fault Status: 01101101
Reset counter: 2
Mileage: 120244 km
Date: 2018.08.16
Time: 18:46:44
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000014366995
Coding: 00581B00000011110000
VCID: 323DE69EE4262CD7581-8066
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E05F2EEFC1E08373C9-807A
Component: J0770_SWA_Slave_H01 0050
Subsystem 3 - Serial number: 5F19.09.1100H010003C911410ˇ
Subsystem 4 - Serial number: 911410ˇ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000015162620
Coding: 011F57205E40440004
VCID: 48C9A47672BAB607165-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H11 0120
Revision: 0120 --- Serial number: 01582991030000
Coding: 3569693
VCID: 3829D4B60E5AC687665-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0160
Revision: CH003000 Serial number: 00000000016199
Coding: 030000
Shop #: WSC 95863 999 13635
VCID: 290F01F2C9F06F0FE9B-807C
Fault Status: 00111011
Reset counter: 85
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190128838
Coding: 0693961
VCID: 231313DAA7DCB55FA37-8076
Reset counter: 52
Mileage: 120595 km
Date: 2018.08.23
Time: 10:40:48
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.30 V
Temperature: 21.0∞C
(no units): 112.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000096927
Coding: 0012001
VCID: 5EE5622ECC3ED8B7CC9-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000015452788
VCID: 47CBA74A7FA4B97F1FF-8012
Reset counter: 28
Mileage: 114919 km
Date: 2018.06.04
Time: 06:41:47
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
Component: AFS-Modul links H07 0004
Component: AFS-Modul rechtsH07 0004
02071 - Local Databus
Reset counter: 45
Mileage: 122234 km
Date: 2018.10.12
Time: 17:10:02
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H53 0112
Revision: AB001007 Serial number: 156J/0B7559140
Coding: 020007010000000000
VCID: 211F19D2B1C0A74FB1B-8074
Part No SW: 4L2 035 664 A HW: 4L2 035 664
Component: H-BN-NA H42 0552
Revision: -------- Serial number: 078HW0B7501081
Coding: 180200060004E1EF51002345EF632003F40000020100000000
VCID: 2B03FBFAC30C7D1F1B7-807E
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130JB0BS036079
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000001923896
Component: CD-Database 3371
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000015269175
Coding: 010E57204040230004
VCID: 46D5AA4E78AEA077E49-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000159165285
Coding: 0200000000000000
VCID: 313FE992E12017CF21B-8064
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H05--- Serial number: 525PA8-J1940I2
Coding: 1021201
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C8138E60A82BA2752D-8038
Subsystem 3 - Serial number: RD11.10.11--H57001001B0323ˇ
Subsystem 4 - Serial number: 1B0323ˇ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H07 0080
Revision: AAH07080 Serial number: 120651932-----
Coding: 0003595
VCID: 26150ACED4EE4077C49-8072
Component: J_245_EE16_SKB10H11 0220
Component: J_394_EE16_SKB10H11 0220
Component: J_392_EE16_SKB10H11 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000015269178
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H03 0100
Revision: 00H03000 Serial number: 37361124103530
Coding: 0231266
VCID: 2C01F8E6CA027A2712D-8078
End----------(Elapsed Time: 02:24, VBatt start/end: 12.1V/12.1V)-----------
