Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: Audi Q7 (2012) Misfire with cylinder 4,5,6 only, please help to diagnose
    Nov 2018
    Canada
    Quote Originally Posted by Larry Manton View Post
    AUDIQ7CAN, NOTED SENSOR BANK 2, YOU ASKED WHY MISSFIRE ONLY 456, AND IS IN BANK 2. WHICH THAT SENSOR CODED, SO WOULD CERTAINLY TARGET THAR AREA.
    That said Lambda can be skewed by many factors, errant air from intake leaks and also exhaust but those in exhaust usually make the O2 think it is lean as will see unused oxygen there and try and compensate by adding fuel but will never be able to catch up.
    Don't know on your unit but if expensive maybe banks can be swapped with O2 and see if issues moves. A cheese test to see if an 02 is moving is place your finger on positive lead to battery and your finger on oppositen hand and should shown fuel trim change, then do the same thing with the negative side of the battery. To do this of course need to take a pin and access the sensor wire to the 02.This allows your body as a conductor but you should see 02 reacting to this input. I.E. meaning is this car in fuel trim.? , just some thoughts.
    LARIMORE.
    Thanks a lot, LARIMORE!
    008768 - Oxygen (Lambda) Sensor B2 S1
                   P2240 - 000 - Pump Current Open Circuit - Intermittent
                        Fault Status: 00100001
                        Mileage: 121104 km
                        Date: 2018.09.08
                        Time: 16:22:07
    As I shared previously, fault of O2 sensor was only reported once for 5000km so I would like to carefully check all possibilities before touching on O2 sensors. Your idea of swapping O2 sensors are very interesting but it should be complicated to take out O2 sensors, especially from the bank 1.
    Anyway, I am wondering whether we can visually or use VCDS to inspect errant air from intake leaks and also exhaust? If yes, please give me some tips!
  2. #12
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by AUDIQ7CAN View Post
    I have little knowledge about car engine but I a curious with principles and logics of engineering problems. Kindly advise and share your thoughts.
    Your instincts here are good. You definitely want to be looking for something that would only affect 4-5-6 rather than the whole engine.
    Your most recent scan has a series of frequency one faults, ten days before you took your scan. How often is this vehicle driven? How often does the problem happen? Is it severe enough to cause a driveability issue perceptible to the driver? Does the MIL flash indicating excessive misfires, or only come on solid?
    - If the problem is caused by MAF sensor, why do misfire only happen with bank 2 managing cylinder 4,5,6. I thought there is only one MAF sensor so if it is defective, it could equally cause misfire of all the cylinders. If so, could the issue be O2 sensor?
    With only one MAF sensor, it shouldn't cause this only on one side. A problematic O2 sensor very well could.
    - If the problem is caused by O2 sensor, it sounds logical as one of two O2 sensor could be defective or carbon buildup. However, if I look into auto-scan report, the fault frequency of O2 sensor (specifically Oxygen (Lambda) Sensor B2 S1) is only 1 while the fault frequency of Fuel Trim (bank 2) is 6. What is the relation between such numbers?
    You're right to look closely at the fault timestamps and frequencies, that can often be helpful. That said, a marginal or intermittently failing O2 sensor might not always be noticed and recorded by the ECU.
    Leaks in the intake or exhaust path will generally cause a lean condition (too much air or too little fuel) rather than rich (too little air or too much fuel).
    If you can make this problem happen on-demand, here's what I would do: disconnect the wiring to the MAF sensor and both O2 sensors, and go for a test drive. Naturally the MIL will be on, but the car will run and drive on its safe baseline fueling maps, and misfire monitoring will still be enabled. Try to reproduce your misfires under the same conditions you were before, and check back with VCDS to see if misfire DTCs were stored.
    If the misfires DON'T happen: it's probably an issue with the sensors measuring and managing air/fuel ratio, very likely the O2 sensor on that side.
    If the misfires DO happen: possibly carbon buildup in the intake (can be a thing for FSI engines, and it's not unheard of for PCV crap deposits to build up asymmetrically), exhaust or catalytic converter obstruction on that side, or a mechanical issue like a timing slip on that bank.
    Silence gives consent.
  3. #13
    Thanks a lot, Jack@European_Parts.
    I'm learning to understand how to solve this problem completely. To do so, I drove another 100km and scanned the car again. The report is exactly the same as the second scan: misfire with cylinder 4,5,6 (Fuel Trim; Bank 2 (Mult) P1129 - 000 - System too Rich) but no fault with O2 sensor.
    I am going with your suggestion first (also because it is cheaper with the spare part - $37 for N80 vs. $300 for O2 sensor and easier to replace it), then back to O2 sensor if the problem is not solved. However, I have two questions:
    - To my understanding, there is only one N80 on the car. If so, it should cause the issue to all cylinders equally. However, there is only with the bank 2 (cylinder 4,5,6). How should we understand/explain for this case?
    - Can we use VCDS to diagnose whether N80 is defective? If so, how we can do it.
    Thanks,
    Please read this thread link...........
    https://forums.ross-tech.com/showthr...you!-Air-leaks!
    Don't be fooled by N80 or PCV leaks that can be on a predominate bank and show up as speculated even.
    A crimp test and isolation of N80 vapors or crank case gasses diverted if in error will correct the misfire very fast if in error.
    An easy test to achieve and should be done while watching trims and misfires.
    In advance : Don't do stupid things like negating or not giving places for vapors to go safely if doing logged road tests!
    ECU could be plain faulty too but most likely a contaminated probe from over fueling.
    Removing the OXS and cleaning with a sodium hydroxide solution ( oven cleaner ) and distilled water then burned with a propane torch for 5 minutes cherry red results in a clean probe & could save you 300 USD!
    OXS failure or contamination is the result usually & not the cause..........
    NostraJackASS Has Spoken!
  4. Likes Larry Manton, AUDIQ7CAN liked this post
  5. #14
    Aug 2017
    These codes look suspiciously familiar to what happened to my 3.0t at 70K miles. The O2 sensors where starting to fail, I had carbon buildup to the point that the secondary air injection ports were blocked, then one cat went bad.... 3 months later the other cat went bad.
    Knowing what I know now, I would change all 4 oxygen sensors, especially the upstream ones on both sides as they're probably due anyway.
    Once they're changed, clear the codes and see if you can get the engine up to 4K RPM in 3rd gear. If you instantly get the EPC light and a cylinder disabling I'd have them put a bore-scope into the downstream O2 hole to look at the cat. You could swap the O2s, but it's a pain in the $##@ and you mind as well just put new ones in anyway.
    It's unlikely you've lost all 3 injectors on one side, it's also unlikely you have an air sensor issue as they control both sides of the engine. Happen to have a warranty for emissions components in Canada?
  6. Likes Uwe, Jack@European_Parts, Aitrui liked this post
  7. #15
    Did I say MAF?
    NOPE!
  8. #16
    Aug 2017
    @Jack, you didn't say MAF, AudiQ7Can did.
    Anyway, so what happened with the misfires???
    [QUOTE=AUDIQ7CAN;146557]Thanks a lot, Uwe.
    Since I shared the auto-scan on the first post, I cleared all DTCs and drove about 100km to examine what is going on when the weather become cold (5 C_degree) now. The Engine light was on with misfire of cylinder 4,5,6 but no message about O2 sensor or MAF sensor.
    I plan to work on the MAF and O2 sensors tomorrow (weekend) but I am wondering whether MAF and/or O2 sensors are the issues based on the latest auto-scan. Alternatively, I am wondering when fault errors of MAF and O2 sensors should be released?
    Thanks,
  9. #17
    Is this car possibly modified with aftermarket tuner code to rule out FOD?
  10. #18
    Nov 2018
    Canada
    It has been a long while since my last post but I will definitely NOT leave this thread without my conclusion and update about what has been going on with my car and how I did because I greatly appreciate you guys's advice and suggestions.
    In fact, I have been too busy during last months and it has been too cold to do anything (even in a garage) in Canada so I could not do much. Moreover, as you know, it takes time to observe, measure, and test such a issue to find out what are truly the problem.
    Here are things I have done so far and results:
    In January:
    Action1: I took out the O2 sensors, both upstream and downstream of the bank 2. It looks quite bad with carbon built up so I cleaned it up and put back. I also cleaned up the spark plugs.
    Result 1: After I put them back, I started the engine. Quite surprisingly, the RMP was up and down for a long while (5 minutes) after I started the engine. I guessed the engine performed auto-calibration when new sensors were installed. I felt engine a bit smoother but not much (less cracking sound). I drove for a week and the engine light was up again. VCDS report still showed that misfires over cylinder 4,5,6 as usual, which made me think that the O2 sensors was defected so I decided to purchase two new ones (both upstream and downstream).
    In March,
    Action2: I ordered two O2 sensor, both upstream and downstream, of the bank 2 (from partavartar.ca) and changed it recently. Note that the two NKT sensors are identical to the installed ones. In addition, I also changed all the spark plugs (the used ones look absolute bad after less than a year).
    Results: After I installed two new O2 sensors, the engine went very smoothly (almost no cracking sound) and RMP become stable very shortly (20 sec). I did not witness auto-calibration (which I thought only without any knowledge). Note that, the temperate is better now (about -1 compared to -20 in January) so I hope that the problem was solved. In fact, it is only partly solved as I do feel that the engine still goes smoothly but the engine light is still up with the same misfires from cylinder 4,5,6. In fact, when the engine light was up after a couple of days after I changed the O2 sensors and spark-plugs, I thought it may take time to auto-adapt to the new sensors, I read and cleared up the DTCs codes. However, after more than a week, the engine light was up at the second one. Now I believe that the new O2 sensors (+ new spark plugs) could not solve the problem completely. I am thinking of MAF as well as injection as pointed out by SpeedRaceAZ.
    Here are the codes of the latest records. Please share your comments and suggestions as well as what I should do next.
    March 10
    Sunday,10,March,2019,14:32:41:38100
    VCDS Version: 18.9.0.2  HEX-V2 CB: 0.4436.4
    VIN: WA1DGCFE4CD004190   License Plate:
    Chassis Type: FE-AU56 (4F0)
    Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
              56 5F 62 69 6C 6D 6F 72 76
    VIN: WA1DGCFE4CD004190   Mileage: 123630km-76820miles
    Address 01: Engine (CJW)       Labels: None
       Part No SW: 4L0 910 551 K    HW: 4L0 907 551 A
       Component: 3.0l V6 TFSI        0040
       Revision: --H08---    Serial number:
       Coding: 0121000A290F0928
       Shop #: WSC 23095 001 1048576
       VCID: 3039EC96E62A1EC72E5-8064
    000772 - Cylinder 4
                   P0304 - 000 - Misfire Detected - Intermittent - MIL ON
                        Fault Status: 10100010
                        Mileage: 123592 km
                        Date: 2019.03.06
                        Time: 22:08:26
                        RPM: 640 /min
                        Mass Air / Rev.: 174.4 mg/str
                        Temperature: 49.5∞C
                        Bin. Bits: 00000010
                        Time: 25.6 s
    000774 - Cylinder 6
                   P0306 - 000 - Misfire Detected - Intermittent
                        Mileage: 123592 km
                        Date: 2019.03.06
                        Time: 22:08:26
                        RPM: 1248 /min
                        Mass Air / Rev.: 169.0 mg/str
                        Temperature: 48.0∞C
                        Bin. Bits: 00000011
                        Time: 51.2 s
                        Speed: 14.0 km/h
    000773 - Cylinder 5
                   P0305 - 000 - Misfire Detected - Intermittent
                        Mileage: 123592 km
                        Date: 2019.03.06
                        Time: 22:08:26
                        RPM: 640 /min
                        Temperature: 49.5∞C
                        Bin. Bits: 00000010
                        Time: 25.6 s
                   P0300 - 000 -  - Intermittent
                        Mileage: 123592 km
                        Date: 2019.03.06
                        Time: 22:09:27
                        RPM: 1248 /min
                        Temperature: 48.0∞C
                        Bin. Bits: 00000011
                        Time: 51.2 s
                        Speed: 14.0 km/h
    Readiness: 0000 0101
       Part No SW: 0C8 927 750 Q    HW: 0C8 927 750 Q
       Component: AL1000 AISIN  001 2090
       Coding: 001378
       ROD: EV_TCMAL991031_002.rod
       VCID: 3A2DCEBE3CD6D497901-806E
       Revision: 00H02001
       Coding: 0099409
       Shop #: WSC 31414 790 00001
       VCID: 3431E086123222E74AD-8060
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
       Component: FBSAUDIC6 ELV   H05 0130
       Revision: 00H05000    Serial number: 10603401905722
       Coding: 0000135
       VCID: 25170DC2A9E84B6FCD3-8070
       Subsystem 3 - Part No: 4F0 910 220 G
       Component: FBSAUDIC6 IDG   H01 0053
                007 - Short to Ground
                        Fault Status: 01110111
                        Reset counter: 0
    00191 - Passenger's Door Handle Touch Sensor (G416)
                        Reset counter: 120
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AJ
       Revision: 00---026    Serial number: 00000030214020
       Coding: 000CC026
       VCID: 25170DC2A5E84B6FCD3-8070
       Subsystem 1 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
       Component: SLR-B8  H05 0006
       Serial number:           0015396664
       Coding: 070000
       Subsystem 2 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
       Serial number:           0015396025
       Coding: 070000
       Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
       Component: ILM Fahrer      H31 0400
       Coding: 0133114
       VCID: 6E8532EE3C9E48377C9-803A
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
       Component: 75 AIRBAG AUDI8RH43 0230
       Revision: 07H43000    Serial number: 0038QD09WGZD
       Coding: 0014133
       VCID: 2B03FBFACF0C7D1F1B7-807E
       Subsystem 1 - Serial number: 6332QSME69603E48P
       Subsystem 2 - Serial number: 6342QSME6860314AE
       Subsystem 3 - Serial number: 6352QSME6760545AK
       Subsystem 4 - Serial number: 6362QSME1D5F4F6E8
       Subsystem 5 - Serial number: 63734SME6066184C1
       Subsystem 6 - Serial number: 63834SME63662E725
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
       Component: J0527               0830
       Revision: 00H07000    Serial number: 90025112660077
       Coding: 0012142
       VCID: 280904F6DEFA5607F65-807C
       Component: E0221           H03 0030
       Part No SW: 4L0 920 932 Q    HW: 4L0 920 932 Q
       Component: KOMBIINSTR.   H22 0411
       Revision: 00000000    Serial number: LMY00UCAC
       Coding: 8BD6630409000008020304
       VCID: 3A2DCEBE3C56D497901-806E
       Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0057
       Revision: MB600036    Serial number: 3600M11926004B
       Coding: 00C303
       VCID: 3FDBBFAA2774F1BFA7F-806A
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790684988
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
       Revision: 00---010    Serial number: 00000030213844
       Coding: 0000006
       VCID: 688944F61E7A9607365-803C
       Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
       Component: MEM-FS        H08 0064
       Revision: AA000000    Serial number: 00000014366995
       Coding: 00581B00000011110000
       VCID: 323DE69EE4262CD7581-8066
       Component: J0769_SWA_MasterH01 0050
       Revision: 00H01000    Serial number: 6PZ 009 014-10
       Coding: 0010001
       VCID: 2E05F2EEFC1E08373C9-807A
       Component: J0770_SWA_Slave_H01 0050
       Subsystem 3 - Serial number: 5F19.09.1100H010003C911410ˇ
       Subsystem 4 - Serial number: 911410ˇ
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000015162620
       Coding: 011F57205E40440004
       VCID: 48C9A47672BAB607165-801C
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H11 0120
       Revision: 0120 ---    Serial number: 01582991030000
       Coding: 3569693
       VCID: 3829D4B60E5AC687665-806C
       Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H03 0160
       Revision: CH003000    Serial number: 00000000016199
       Coding: 030000
       Shop #: WSC 95863 999 13635
       VCID: 290F01F2C9F06F0FE9B-807C
                        Fault Status: 00111011
                        Reset counter: 160
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005190128838
       Coding: 0693961
       VCID: 231313DAA7DCB55FA37-8076
       Component: ILM Beifahrer   H14 0100
       Revision:             Serial number: 00000000096927
       Coding: 0012001
       VCID: 5EE5622ECC3ED8B7CC9-800A
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000015452788
       VCID: 47CBA74A7FA4B97F1FF-8012
       Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
       Component: AFS 1           H01 0010
       Coding: 0000031
       Component: AFS-Modul links H07 0004
       Component: AFS-Modul rechtsH07 0004
       Part No SW: 4G0 035 082 D    HW: 4G0 035 082
       Component: Radio U SIRIU H53 0112
       Revision: AB001007    Serial number: 156J/0B7559140
       Coding: 020007010000000000
       VCID: 211F19D2B1C0A74FB1B-8074
       Part No SW: 4L2 035 664 A    HW: 4L2 035 664
       Component: H-BN-NA       H42 0552
       Revision: --------    Serial number: 078HW0B7501081
       Coding: 180200060004E1EF51002345EF632003F40000020100000000
       VCID: 2B03FBFAC30C7D1F1B7-807E
       Component: NAR 2011  0505
       Component: DU7 High  H41 0104
       Serial number: A130JB0BS036079
       Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
       Component: E0380 Bedient  H01 0060
       Serial number: 00000001923896
       Component: CD-Database  3371
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000015269175
       Coding: 010E57204040230004
       VCID: 46D5AA4E78AEA077E49-8012
    Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
       Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
       Revision: 2A001001    Serial number: 00000159165285
       Coding: 0200000000000000
       VCID: 313FE992E12017CF21B-8064
       Revision: --H05---    Serial number: 525PA8-J1940I2
       Coding: 1021201
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H57 0500
       Revision: --H57001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C8138E60A82BA2752D-8038
       Subsystem 3 - Serial number: RD11.10.11--H57001001B0323ˇ
       Subsystem 4 - Serial number: 1B0323ˇ
       Component: ILM HINTEN 2    H07 0080
       Revision: AAH07080    Serial number: 120651932-----
       Coding: 0003595
       VCID: 26150ACED4EE4077C49-8072
       Component: J_245_EE16_SKB10H11 0220
       Component: J_394_EE16_SKB10H11 0220
       Component: J_392_EE16_SKB10H11 0220
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000015269178
                        Reset counter: 119
                        Mileage: 123592 km
                        Date: 2019.03.02
                        Time: 09:46:47
       Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
       Component: Parkhilfe 8-Kan H03 0100
       Revision: 00H03000    Serial number: 37361124103530
       Coding: 0231266
       VCID: 2C01F8E6CA027A2712D-8078
    End----(Elapsed Time: 02:27, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    March 23
    Saturday,23,March,2019,15:32:23:38100
    VIN: WA1DGCFE4CD004190   Mileage: 123710km-76869miles
    000772 - Cylinder 4
                        Mileage: 123638 km
                        Date: 2019.03.10
                        Time: 10:14:00
                        RPM: 1280 /min
                        Mass Air / Rev.: 277.9 mg/str
                        Temperature: 31.5∞C
                        Bin. Bits: 00000010
                        Time: 0.0 s
    000774 - Cylinder 6
                        Mileage: 123638 km
                        Date: 2019.03.10
                        Time: 10:14:00
                        RPM: 1472 /min
                        Mass Air / Rev.: 218.0 mg/str
                        Temperature: 31.5∞C
                        Bin. Bits: 00000011
                        Time: 0.0 s
                        Speed: 17.0 km/h
                        Mileage: 123638 km
                        Date: 2019.03.10
                        Time: 10:14:32
                        RPM: 1728 /min
                        Mass Air / Rev.: 397.9 mg/str
                        Temperature: 34.5∞C
                        Bin. Bits: 00000011
                        Time: 25.6 s
                        Speed: 44.0 km/h
    000773 - Cylinder 5
                        Mileage: 123692 km
                        Date: 2019.03.19
                        Time: 14:07:04
                        RPM: 1472 /min
                        Temperature: 31.5∞C
                        Bin. Bits: 00000011
                        Time: 0.0 s
                        Speed: 17.0 km/h
       Coding: 001378
       Revision: 00H02001
       Coding: 0099409
       Coding: 0000135
                        Reset counter: 124
                        Mileage: 123645 km
                        Date: 2019.03.10
                        Time: 10:27:11
                        Reset counter: 124
                        Mileage: 123645 km
                        Date: 2019.03.10
                        Time: 10:27:11
       Coding: 000CC026
       Coding: 070000
       Coding: 070000
       Coding: 0133114
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
       Coding: 0014133
       Coding: 0012142
       Coding: 00C303
       Coding: 0000006
       Coding: 0010001
       Coding: 3569693
       Coding: 030000
                        Reset counter: 167
       Coding: 0693961
       Coding: 0012001
       Coding: 0000031
       Coding: 1021201
       Coding: 0003595
                        Reset counter: 124
                        Mileage: 123638 km
                        Date: 2019.03.10
                        Time: 09:34:39
       Coding: 0231266
    End----(Elapsed Time: 02:25, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  11. #19
  12. #20
    Nov 2018
    Canada
    One thing I can add is that the oil consumption is very high (I needed to fill up more than a little of oil after 2000km). It seems you are right, Jack.
    Anyway, what should I do in this case as I don't truly understand from your post.
    Thanks,
