Audi Q7 (2012) Misfire with cylinder 4,5,6 only, please help to diagnose
AUDIQ7CAN
Canada
C?ID=336119
Hello Audi folks,
My AudiQ7 (2012) has misfire with cylinders 4,5,6 (only the left one) only (1,2,3 perfect without any error). The Engine light was randomly popped up and sometimes automatically off, especially when I drove more than 100km/h. The misfile usually happened at cold weather but not always true.
I am in Canada so I am using the super premium gasoline (91%) - the highest quality gasoline.
Here are what I have done so far:
1. I have changed all the spark plugs but did not not help.
2. I bought an ignition cold pack and changed it circularly among 4,5,6 but misfire is still there with 4,5,6.
Since we don't have Audi dealer at our town (VW only but I don't think they are good), I bought the car to an very experienced mechanical guy. He use his diagnosis tool (similar to our VCDS) to examine it and thought that it could be something with the software update. He advised to talk with the Audi dealer about software update but I couldn't find any information about software update for misfire on Internet. Moreover, the closest Audi deader is more than 300km away from our town so I would like to fix this issue ourselves if possible.
Please find the Auto Scan report below and kindly advise me possibilities and how to check up. Note that, this report was about 3-4 months since I did not clear the DTCs.
My deep appreciation to your advice!
Friday,26,October,2018,01:12:04:38100
VCDS Version: 18.9.0.2  HEX-V2 CB: 0.4436.4
VIN: WA1DGCFE4CD004190   License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
          56 5F 62 69 6C 6D 6F 72 76
VIN: WA1DGCFE4CD004190   Mileage: 122270km-75975miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CJW)       Labels: None
   Part No SW: 4L0 910 551 K    HW: 4L0 907 551 A
   Component: 3.0l V6 TFSI        0040
   Revision: --H08---    Serial number:
   Coding: 0121000A290F0928
   Shop #: WSC 23095 001 1048576
   VCID: 3039EC96E62A1EC72E5-8064
8 Faults Found:
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - Intermittent
                    Fault Frequency: 43
                    Mileage: 115244 km
                    Date: 2018.06.04
                    Time: 13:05:02
                    RPM: 2272 /min
                    Mass Air / Rev.: 201.7 mg/str
                    Temperature: 22.5∞C
                    Bin. Bits: 00000100
                    Time: 25.6 s
000773 - Cylinder 5
               P0305 - 000 - Misfire Detected - Intermittent
                    Fault Frequency: 40
                    Mileage: 115244 km
                    Date: 2018.06.04
                    Time: 13:05:02
                    RPM: 2272 /min
                    Temperature: 22.5∞C
                    Bin. Bits: 00000100
                    Time: 25.6 s
               P0300 - 000 -  - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 39
                    Mileage: 115244 km
                    Date: 2018.06.04
                    Time: 13:05:32
                    RPM: 672 /min
                    Mass Air / Rev.: 179.9 mg/str
                    Temperature: 30.0∞C
                    Bin. Bits: 00000010
                    Time: 51.2 s
000774 - Cylinder 6
               P0306 - 000 - Misfire Detected - Intermittent
                    Fault Frequency: 33
                    Mileage: 115278 km
                    Date: 2018.06.05
                    Time: 13:11:40
                    RPM: 2272 /min
                    Temperature: 22.5∞C
                    Bin. Bits: 00000100
                    Time: 25.6 s
004874 - Cylinder Disabling
               P130A - 000 -  - Intermittent
                    Mileage: 120595 km
                    Date: 2018.08.23
                    Time: 10:40:48
                    RPM: 160 /min
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 96.0∞C
                    Bin. Bits: 00000001
                    Time: 0.0 s
               U1017 - 000 -  - Intermittent
                    Mileage: 120595 km
                    Date: 2018.08.23
                    Time: 10:40:48
                    RPM: 4256 /min
                    Mass Air / Rev.: 877.5 mg/str
                    Temperature: 97.5∞C
                    Bin. Bits: 00000011
                    Load: 73.7 %
                    Speed: 110.0 km/h
008768 - Oxygen (Lambda) Sensor B2 S1
               P2240 - 000 - Pump Current Open Circuit - Intermittent
                    Mileage: 121104 km
                    Date: 2018.09.08
                    Time: 16:22:07
                    RPM: 1184 /min
                    Mass Air / Rev.: 70.9 mg/str
                    Temperature: 94.5∞C
                    Bin. Bits: 00000101
                    Bin. Bits: 00000100
004393 - Fuel Trim; Bank 2 (Mult)
               P1129 - 000 - System too Rich - Intermittent - MIL ON
                    Fault Status: 10100010
                    Mileage: 121581 km
                    Date: 2018.10.07
                    Time: 13:29:18
                    RPM: 1472 /min
                    Mass Air / Rev.: 316.1 mg/str
                    Temperature: 96.0∞C
                    Bin. Bits: 00000011
                    Time: 1664.0 s
                    Bin. Bits: 00000010
   Part No SW: 0C8 927 750 Q    HW: 0C8 927 750 Q
   Component: AL1000 AISIN  001 2090
   Coding: 001378
   ROD: EV_TCMAL991031_002.rod
   VCID: 3A2DCEBE3CD6D497901-806E
   Revision: 00H02001
   Coding: 0099409
   Shop #: WSC 31414 790 00001
   VCID: 3431E086123222E74AD-8060
                    Fault Status: 00101101
                    Reset counter: 52
                    Mileage: 120595 km
                    Date: 2018.08.23
                    Time: 10:40:47
                    Count: 27392
                    Count: 8193
                    Count: 8196
                    Count: 51968
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401905722
   Coding: 0000135
   VCID: 25170DC2A9E84B6FCD3-8070
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0053
00191 - Passenger's Door Handle Touch Sensor (G416)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 112
                    Mileage: 114919 km
                    Date: 2018.06.04
                    Time: 07:09:24
                    Reset counter: 112
                    Mileage: 114919 km
                    Date: 2018.06.04
                    Time: 07:09:24
00956 - Key 2
                    Fault Status: 00110010
                    Reset counter: 78
                    Mileage: 121227 km
                    Date: 2018.09.29
                    Time: 10:12:33
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AJ
   Revision: 00---026    Serial number: 00000030214020
   Coding: 000CC026
   VCID: 25170DC2A5E84B6FCD3-8070
   Subsystem 1 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Component: SLR-B8  H05 0006
   Serial number:           0015396664
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Serial number:           0015396025
   Coding: 070000
01273 - Fresh Air Blower (V2)
                    Reset counter: 77
                    Mileage: 121274 km
                    Date: 2018.10.04
                    Time: 15:59:54
                    Temperature: 26.0∞C
                    Speed: 47.0 km/h
                    (no units): 122.0
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0133114
   VCID: 6E8532EE3C9E48377C9-803A
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Fault Status: 00100111
                    Reset counter: 85
                    Mileage: 122232 km
                    Date: 2018.10.12
                    Time: 17:10:00
                    Reset counter: 85
                    Mileage: 122232 km
                    Date: 2018.10.12
                    Time: 17:10:00
                    Fault Status: 00101010
                    Fault Frequency: 14
                    Reset counter: 85
                    Mileage: 121264 km
                    Date: 2018.10.04
                    Time: 13:44:00
                    Reset counter: 85
                    Mileage: 122232 km
                    Date: 2018.10.12
                    Time: 17:10:00
   Component: 75 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09WGZD
   Coding: 0014133
   VCID: 2B03FBFACF0C7D1F1B7-807E
   Subsystem 1 - Serial number: 6332QSME69603E48P
   Subsystem 2 - Serial number: 6342QSME6860314AE
   Subsystem 3 - Serial number: 6352QSME6760545AK
   Subsystem 4 - Serial number: 6362QSME1D5F4F6E8
   Subsystem 5 - Serial number: 63734SME6066184C1
   Subsystem 6 - Serial number: 63834SME63662E725
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H07000    Serial number: 90025112660077
   Coding: 0012142
   VCID: 280904F6DEFA5607F65-807C
   Component: E0221           H03 0030
   Part No SW: 4L0 920 932 Q    HW: 4L0 920 932 Q
   Component: KOMBIINSTR.   H22 0411
   Revision: 00000000    Serial number: LMY00UCAC
   Coding: 8BD6630409000008020304
   VCID: 3A2DCEBE3C56D497901-806E
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0057
   Revision: MB600036    Serial number: 3600M11926004B
   Coding: 00C303
   VCID: 3FDBBFAA2774F1BFA7F-806A
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790684988
02256 - Quiescent Current
                    Reset counter: 80
                    Mileage: 121900 km
                    Date: 2018.10.08
                    Time: 21:53:00
            000 -  -  - Intermittent
                    Reset counter: 80
                    Mileage: 121900 km
                    Date: 2018.10.09
                    Time: 01:53:00
                    Bin. Bits:    00000
                    Voltage: 12.50 V
                    Count: 18
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000030213844
   Coding: 0000006
   VCID: 688944F61E7A9607365-803C
00003 - Control Module
                    Fault Status: 00100011
                    Fault Frequency: 10
                    Mileage: 115247 km
                    Date: 2018.06.04
                    Time: 13:24:33
                    Fault Status: 01101101
                    Reset counter: 2
                    Mileage: 120244 km
                    Date: 2018.08.16
                    Time: 18:46:44
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000014366995
   Coding: 00581B00000011110000
   VCID: 323DE69EE4262CD7581-8066
   Component: J0769_SWA_MasterH01 0050
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E05F2EEFC1E08373C9-807A
   Component: J0770_SWA_Slave_H01 0050
   Subsystem 3 - Serial number: 5F19.09.1100H010003C911410ˇ
   Subsystem 4 - Serial number: 911410ˇ
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000015162620
   Coding: 011F57205E40440004
   VCID: 48C9A47672BAB607165-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H11 0120
   Revision: 0120 ---    Serial number: 01582991030000
   Coding: 3569693
   VCID: 3829D4B60E5AC687665-806C
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0160
   Revision: CH003000    Serial number: 00000000016199
   Coding: 030000
   Shop #: WSC 95863 999 13635
   VCID: 290F01F2C9F06F0FE9B-807C
                    Fault Status: 00111011
                    Reset counter: 85
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005190128838
   Coding: 0693961
   VCID: 231313DAA7DCB55FA37-8076
                    Reset counter: 52
                    Mileage: 120595 km
                    Date: 2018.08.23
                    Time: 10:40:48
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 14.30 V
                    Temperature: 21.0∞C
                    (no units): 112.0
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000096927
   Coding: 0012001
   VCID: 5EE5622ECC3ED8B7CC9-800A
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000015452788
   VCID: 47CBA74A7FA4B97F1FF-8012
                    Reset counter: 28
                    Mileage: 114919 km
                    Date: 2018.06.04
                    Time: 06:41:47
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Component: AFS 1           H01 0010
   Coding: 0000031
   Component: AFS-Modul links H07 0004
   Component: AFS-Modul rechtsH07 0004
02071 - Local Databus
                    Reset counter: 45
                    Mileage: 122234 km
                    Date: 2018.10.12
                    Time: 17:10:02
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0112
   Revision: AB001007    Serial number: 156J/0B7559140
   Coding: 020007010000000000
   VCID: 211F19D2B1C0A74FB1B-8074
   Part No SW: 4L2 035 664 A    HW: 4L2 035 664
   Component: H-BN-NA       H42 0552
   Revision: --------    Serial number: 078HW0B7501081
   Coding: 180200060004E1EF51002345EF632003F40000020100000000
   VCID: 2B03FBFAC30C7D1F1B7-807E
   Component: NAR 2011  0505
   Component: DU7 High  H41 0104
   Serial number: A130JB0BS036079
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000001923896
   Component: CD-Database  3371
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000015269175
   Coding: 010E57204040230004
   VCID: 46D5AA4E78AEA077E49-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000159165285
   Coding: 0200000000000000
   VCID: 313FE992E12017CF21B-8064
   Revision: --H05---    Serial number: 525PA8-J1940I2
   Coding: 1021201
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H57 0500
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C8138E60A82BA2752D-8038
   Subsystem 3 - Serial number: RD11.10.11--H57001001B0323ˇ
   Subsystem 4 - Serial number: 1B0323ˇ
   Component: ILM HINTEN 2    H07 0080
   Revision: AAH07080    Serial number: 120651932-----
   Coding: 0003595
   VCID: 26150ACED4EE4077C49-8072
   Component: J_245_EE16_SKB10H11 0220
   Component: J_394_EE16_SKB10H11 0220
   Component: J_392_EE16_SKB10H11 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000015269178
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H03 0100
   Revision: 00H03000    Serial number: 37361124103530
   Coding: 0231266
   VCID: 2C01F8E6CA027A2712D-8078
End----------(Elapsed Time: 02:24, VBatt start/end: 12.1V/12.1V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
You got my attention. Although it's not how we do stuff in this forum, we post full autoscan, even when it's not relevant to issue. - It really helps sometimes when googleing it.
Also as You've hidden Your VIN I was not able to search TPI-s to this exact vehicle, but had to rely on on ECU P/N and find another scan from web(See how previously mention full autoscan works IRL). But unfortunately I wasn't able to find anything specific. And no SW update for this P/N.
The fact that only Bank2 gives misfire shows me that only that side is affected. I'm proposing a good visual inspection first. Specially look for O2 sensor, because of this fault code:
Other possibilities are: Carbon buildup, slipped/stretched chain, issues with valve timing and or blocked air intake.
Good luck!
AUDIQ7CAN
Canada
C?ID=336119
Good luck!
Thanks a lot for your advice, Golfi_vend.
First, I don't have any issue to put the full auto scan but my car also has other issues, which I don't want you to be distracted with while I only focused on the misfire issues at the moment. Therefore, I posted the codes for the misfires. If the full auto scan is required and more useful for diagnosis, I will post it on.
Second, I think hiding VIN number is the proper way for privacy in order to avoid unexpected issues. In fact, this is a family car, not for business or anything else, so I don't have any issue to leak the VIN number too.
I will follow your advice with a visual inspection and will share here.
Other advice are appreciated!
Also:
Fuel trim problems can cause misfires.
AUDIQ7CAN
Canada
C?ID=336119
Also:
Thank you very much, Uwe.
Following your and golfi_vend's advice, I will particularly look into MAF and O2 sensors. I think I should check and clean MAF sensor first. If the misfire is still there, I will check with O2 sensors.
Anyway, to improve my knowledge of fuel trim, I would like to share my thought as follows:
- If the problem is caused by MAF sensor, why do misfire only happen with bank 2 managing cylinder 4,5,6. I thought there is only one MAF sensor so if it is defective, it could equally cause misfire of all the cylinders. If so, could the issue be O2 sensor?
- If the problem is caused by O2 sensor, it sounds logical as one of two O2 sensor could be defective or carbon buildup. However, if I look into auto-scan report, the fault frequency of O2 sensor (specifically Oxygen (Lambda) Sensor B2 S1) is only 1 while the fault frequency of Fuel Trim (bank 2) is 6. What is the relation between such numbers?
I have little knowledge about car engine but I a curious with principles and logics of engineering problems. Kindly advise and share your thoughts.
Thanks,
I'm not terribly familiar with the 3.0 TFSI, particularly as installed in the Q7. I would guess it only has one MAF sensor.
However, I'm pretty confident it has separate oxygen sensors for each cylinder bank, and a bad reading from one of them can throw off your fuel trims. Plus the fact that there's a fault code for one of them makes me think that Golfi is on the right track. If it were mine, I would look there first.
AUDIQ7CAN
Canada
C?ID=336119
Thanks a lot, Uwe.
Since I shared the auto-scan on the first post, I cleared all DTCs and drove about 100km to examine what is going on when the weather become cold (5 C_degree) now. The Engine light was on with misfire of cylinder 4,5,6 but no message about O2 sensor or MAF sensor.
I plan to work on the MAF and O2 sensors tomorrow (weekend) but I am wondering whether MAF and/or O2 sensors are the issues based on the latest auto-scan. Alternatively, I am wondering when fault errors of MAF and O2 sensors should be released?
Thanks,
Friday,09,November,2018,04:12:17:38100
VIN: WA1DGCFE4CD004190   Mileage: 122390km-76049miles
                    Mileage: 122363 km
                    Date: 2018.10.26
                    Time: 16:28:47
                    RPM: 1536 /min
                    Mass Air / Rev.: 376.1 mg/str
                    Temperature: 96.0∞C
                    Bin. Bits: 00000011
                    Time: 1408.0 s
                    Bin. Bits: 00000010
000772 - Cylinder 4
                    Mileage: 122379 km
                    Date: 2018.10.31
                    Time: 13:35:54
                    RPM: 800 /min
                    Mass Air / Rev.: 267.1 mg/str
                    Temperature: 16.5∞C
                    Bin. Bits: 00000010
                    Time: 25.6 s
                    Speed: 12.0 km/h
000774 - Cylinder 6
                    Mileage: 122379 km
                    Date: 2018.10.31
                    Time: 13:35:54
                    RPM: 832 /min
                    Mass Air / Rev.: 305.2 mg/str
                    Temperature: 18.0∞C
                    Bin. Bits: 00000010
                    Time: 25.6 s
                    Speed: 1.0 km/h
000773 - Cylinder 5
                    Mileage: 122379 km
                    Date: 2018.10.31
                    Time: 13:35:54
                    RPM: 800 /min
                    Temperature: 16.5∞C
                    Bin. Bits: 00000010
                    Time: 25.6 s
                    Speed: 12.0 km/h
                    Mileage: 122379 km
                    Date: 2018.10.31
                    Time: 13:36:20
                    RPM: 1152 /min
                    Mass Air / Rev.: 245.3 mg/str
                    Temperature: 22.5∞C
                    Bin. Bits: 00000011
                    Time: 25.6 s
                    Speed: 19.0 km/h
   Coding: 001378
   Revision: 00H02001
   Coding: 0099409
   Coding: 0000135
                    Reset counter: 50
                    Reset counter: 50
   Coding: 000CC026
   Coding: 070000
   Coding: 070000
   Coding: 0133114
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0014133
   Coding: 0012142
   Coding: 00C303
   Coding: 0000006
   Coding: 0010001
   Coding: 3569693
   Coding: 030000
                    Reset counter: 92
   Coding: 0693961
   Coding: 0012001
                    Reset counter: 50
                    Mileage: 122326 km
                    Date: 2018.10.26
                    Time: 15:39:03
   Coding: 0000031
   Coding: 1021201
   Coding: 0003595
   Coding: 0231266
End----------(Elapsed Time: 02:20, VBatt start/end: 12.1V/12.1V)-----------
Larry Manton
C?ID=112505
AUDIQ7CAN, NOTED SENSOR BANK 2, YOU ASKED WHY MISSFIRE ONLY 456, AND IS IN BANK 2. WHICH THAT SENSOR CODED, SO WOULD CERTAINLY TARGET THAR AREA.
That said Lambda can be skewed by many factors, errant air from intake leaks and also exhaust but those in exhaust usually make the O2 think it is lean as will see unused oxygen there and try and compensate by adding fuel but will never be able to catch up.
Don't know on your unit but if expensive maybe banks can be swapped with O2 and see if issues moves. A cheese test to see if an 02 is moving is place your finger on positive lead to battery and your finger on oppositen hand and should shown fuel trim change, then do the same thing with the negative side of the battery. To do this of course need to take a pin and access the sensor wire to the 02.This allows your body as a conductor but you should see 02 reacting to this input. I.E. meaning is this car in fuel trim.? , just some thoughts.
LARIMORE.
Sounds like an N80 staying open or injector hanging open to me..........or HPP weep into sump.
Add some marvel mystery oil and MOS2 to gas less than a shot glass and test the N80 for ability to hold mechanically & not just a basic setting test!
AUDIQ7CAN
Canada
C?ID=336119
Thanks a lot, Jack@European_Parts.
I'm learning to understand how to solve this problem completely. To do so, I drove another 100km and scanned the car again. The report is exactly the same as the second scan: misfire with cylinder 4,5,6 (Fuel Trim; Bank 2 (Mult) P1129 - 000 - System too Rich) but no fault with O2 sensor.
I am going with your suggestion first (also because it is cheaper with the spare part - $37 for N80 vs. $300 for O2 sensor and easier to replace it), then back to O2 sensor if the problem is not solved. However, I have two questions:
- To my understanding, there is only one N80 on the car. If so, it should cause the issue to all cylinders equally. However, there is only with the bank 2 (cylinder 4,5,6). How should we understand/explain for this case?
- Can we use VCDS to diagnose whether N80 is defective? If so, how we can do it.
Thanks,
AUDIQ7CAN
Canada
C?ID=336119
LARIMORE.
Thanks a lot, LARIMORE!
                    Mileage: 121104 km
                    Date: 2018.09.08
                    Time: 16:22:07
As I shared previously, fault of O2 sensor was only reported once for 5000km so I would like to carefully check all possibilities before touching on O2 sensors. Your idea of swapping O2 sensors are very interesting but it should be complicated to take out O2 sensors, especially from the bank 1.
Anyway, I am wondering whether we can visually or use VCDS to inspect errant air from intake leaks and also exhaust? If yes, please give me some tips!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Your instincts here are good. You definitely want to be looking for something that would only affect 4-5-6 rather than the whole engine.
Your most recent scan has a series of frequency one faults, ten days before you took your scan. How often is this vehicle driven? How often does the problem happen? Is it severe enough to cause a driveability issue perceptible to the driver? Does the MIL flash indicating excessive misfires, or only come on solid?
With only one MAF sensor, it shouldn't cause this only on one side. A problematic O2 sensor very well could.
You're right to look closely at the fault timestamps and frequencies, that can often be helpful. That said, a marginal or intermittently failing O2 sensor might not always be noticed and recorded by the ECU.
Leaks in the intake or exhaust path will generally cause a lean condition (too much air or too little fuel) rather than rich (too little air or too much fuel).
If you can make this problem happen on-demand, here's what I would do: disconnect the wiring to the MAF sensor and both O2 sensors, and go for a test drive. Naturally the MIL will be on, but the car will run and drive on its safe baseline fueling maps, and misfire monitoring will still be enabled. Try to reproduce your misfires under the same conditions you were before, and check back with VCDS to see if misfire DTCs were stored.
If the misfires DON'T happen: it's probably an issue with the sensors measuring and managing air/fuel ratio, very likely the O2 sensor on that side.
If the misfires DO happen: possibly carbon buildup in the intake (can be a thing for FSI engines, and it's not unheard of for PCV crap deposits to build up asymmetrically), exhaust or catalytic converter obstruction on that side, or a mechanical issue like a timing slip on that bank.
Thanks,
Please read this thread link...........
https://forums.ross-tech.com/showth...gases-and-vacuum-amp-so-should-you!-Air-leaks!
Don't be fooled by N80 or PCV leaks that can be on a predominate bank and show up as speculated even.
A crimp test and isolation of N80 vapors or crank case gasses diverted if in error will correct the misfire very fast if in error.
An easy test to achieve and should be done while watching trims and misfires.
In advance : Don't do stupid things like negating or not giving places for vapors to go safely if doing logged road tests!
ECU could be plain faulty too but most likely a contaminated probe from over fueling.
Removing the OXS and cleaning with a sodium hydroxide solution ( oven cleaner ) and distilled water then burned with a propane torch for 5 minutes cherry red results in a clean probe & could save you 300 USD!
OXS failure or contamination is the result usually & not the cause..........
NostraJackASS Has Spoken!
SpeedRacerAZ
C?ID=312337
These codes look suspiciously familiar to what happened to my 3.0t at 70K miles. The O2 sensors where starting to fail, I had carbon buildup to the point that the secondary air injection ports were blocked, then one cat went bad.... 3 months later the other cat went bad.
Knowing what I know now, I would change all 4 oxygen sensors, especially the upstream ones on both sides as they're probably due anyway.
Once they're changed, clear the codes and see if you can get the engine up to 4K RPM in 3rd gear. If you instantly get the EPC light and a cylinder disabling I'd have them put a bore-scope into the downstream O2 hole to look at the cat. You could swap the O2s, but it's a pain in the $##@ and you mind as well just put new ones in anyway.
It's unlikely you've lost all 3 injectors on one side, it's also unlikely you have an air sensor issue as they control both sides of the engine. Happen to have a warranty for emissions components in Canada?
Did I say MAF? :rolleyes:
NOPE!
SpeedRacerAZ
C?ID=312337
@Jack, you didn't say MAF, AudiQ7Can did.
Anyway, so what happened with the misfires???
Thanks a lot, Uwe.
Thanks,
Is this car possibly modified with aftermarket tuner code to rule out FOD?
AUDIQ7CAN
Canada
C?ID=336119
It has been a long while since my last post but I will definitely NOT leave this thread without my conclusion and update about what has been going on with my car and how I did because I greatly appreciate you guys's advice and suggestions.
In fact, I have been too busy during last months and it has been too cold to do anything (even in a garage) in Canada so I could not do much. Moreover, as you know, it takes time to observe, measure, and test such a issue to find out what are truly the problem.
Here are things I have done so far and results:
In January:
Action1: I took out the O2 sensors, both upstream and downstream of the bank 2. It looks quite bad with carbon built up so I cleaned it up and put back. I also cleaned up the spark plugs.
Result 1: After I put them back, I started the engine. Quite surprisingly, the RMP was up and down for a long while (5 minutes) after I started the engine. I guessed the engine performed auto-calibration when new sensors were installed. I felt engine a bit smoother but not much (less cracking sound). I drove for a week and the engine light was up again. VCDS report still showed that misfires over cylinder 4,5,6 as usual, which made me think that the O2 sensors was defected so I decided to purchase two new ones (both upstream and downstream).
In March,
Action2: I ordered two O2 sensor, both upstream and downstream, of the bank 2 (from partavartar.ca) and changed it recently. Note that the two NKT sensors are identical to the installed ones. In addition, I also changed all the spark plugs (the used ones look absolute bad after less than a year).
Results: After I installed two new O2 sensors, the engine went very smoothly (almost no cracking sound) and RMP become stable very shortly (20 sec). I did not witness auto-calibration (which I thought only without any knowledge). Note that, the temperate is better now (about -1 compared to -20 in January) so I hope that the problem was solved. In fact, it is only partly solved as I do feel that the engine still goes smoothly but the engine light is still up with the same misfires from cylinder 4,5,6. In fact, when the engine light was up after a couple of days after I changed the O2 sensors and spark-plugs, I thought it may take time to auto-adapt to the new sensors, I read and cleared up the DTCs codes. However, after more than a week, the engine light was up at the second one. Now I believe that the new O2 sensors (+ new spark plugs) could not solve the problem completely. I am thinking of MAF as well as injection as pointed out by SpeedRaceAZ.
Here are the codes of the latest records. Please share your comments and suggestions as well as what I should do next.
March 10
Sunday,10,March,2019,14:32:41:38100
VIN: WA1DGCFE4CD004190   Mileage: 123630km-76820miles
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - Intermittent - MIL ON
                    Mileage: 123592 km
                    Date: 2019.03.06
                    Time: 22:08:26
                    RPM: 640 /min
                    Mass Air / Rev.: 174.4 mg/str
                    Temperature: 49.5∞C
                    Bin. Bits: 00000010
                    Time: 25.6 s
000774 - Cylinder 6
                    Mileage: 123592 km
                    Date: 2019.03.06
                    Time: 22:08:26
                    RPM: 1248 /min
                    Mass Air / Rev.: 169.0 mg/str
                    Temperature: 48.0∞C
                    Bin. Bits: 00000011
                    Time: 51.2 s
                    Speed: 14.0 km/h
000773 - Cylinder 5
                    Mileage: 123592 km
                    Date: 2019.03.06
                    Time: 22:08:26
                    RPM: 640 /min
                    Temperature: 49.5∞C
                    Bin. Bits: 00000010
                    Time: 25.6 s
                    Mileage: 123592 km
                    Date: 2019.03.06
                    Time: 22:09:27
                    RPM: 1248 /min
                    Temperature: 48.0∞C
                    Bin. Bits: 00000011
                    Time: 51.2 s
                    Speed: 14.0 km/h
Readiness: 0000 0101
   Coding: 001378
   Revision: 00H02001
   Coding: 0099409
   Coding: 0000135
                    Reset counter: 0
                    Reset counter: 120
   Coding: 000CC026
   Coding: 070000
   Coding: 070000
   Coding: 0133114
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0014133
   Coding: 0012142
   Coding: 00C303
   Coding: 0000006
   Coding: 0010001
   Coding: 3569693
   Coding: 030000
                    Reset counter: 160
   Coding: 0693961
   Coding: 0012001
   Coding: 0000031
   Coding: 1021201
   Coding: 0003595
                    Reset counter: 119
                    Mileage: 123592 km
                    Date: 2019.03.02
                    Time: 09:46:47
   Coding: 0231266
End----(Elapsed Time: 02:27, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
March 23
Saturday,23,March,2019,15:32:23:38100
VIN: WA1DGCFE4CD004190   Mileage: 123710km-76869miles
000772 - Cylinder 4
                    Mileage: 123638 km
                    Date: 2019.03.10
                    Time: 10:14:00
                    RPM: 1280 /min
                    Mass Air / Rev.: 277.9 mg/str
                    Temperature: 31.5∞C
                    Bin. Bits: 00000010
                    Time: 0.0 s
000774 - Cylinder 6
                    Mileage: 123638 km
                    Date: 2019.03.10
                    Time: 10:14:00
                    RPM: 1472 /min
                    Mass Air / Rev.: 218.0 mg/str
                    Temperature: 31.5∞C
                    Bin. Bits: 00000011
                    Time: 0.0 s
                    Speed: 17.0 km/h
                    Mileage: 123638 km
                    Date: 2019.03.10
                    Time: 10:14:32
                    RPM: 1728 /min
                    Mass Air / Rev.: 397.9 mg/str
                    Temperature: 34.5∞C
                    Bin. Bits: 00000011
                    Time: 25.6 s
                    Speed: 44.0 km/h
000773 - Cylinder 5
                    Mileage: 123692 km
                    Date: 2019.03.19
                    Time: 14:07:04
                    RPM: 1472 /min
                    Temperature: 31.5∞C
                    Bin. Bits: 00000011
                    Time: 0.0 s
                    Speed: 17.0 km/h
   Coding: 001378
   Revision: 00H02001
   Coding: 0099409
   Coding: 0000135
                    Reset counter: 124
                    Mileage: 123645 km
                    Date: 2019.03.10
                    Time: 10:27:11
                    Reset counter: 124
                    Mileage: 123645 km
                    Date: 2019.03.10
                    Time: 10:27:11
   Coding: 000CC026
   Coding: 070000
   Coding: 070000
   Coding: 0133114
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0014133
   Coding: 0012142
   Coding: 00C303
   Coding: 0000006
   Coding: 0010001
   Coding: 3569693
   Coding: 030000
                    Reset counter: 167
   Coding: 0693961
   Coding: 0012001
   Coding: 0000031
   Coding: 1021201
   Coding: 0003595
                    Reset counter: 124
                    Mileage: 123638 km
                    Date: 2019.03.10
                    Time: 09:34:39
   Coding: 0231266
End----(Elapsed Time: 02:25, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
AUDIQ7CAN
Canada
C?ID=336119
