- Joined
- Oct 27, 2014
- Messages
- 2,866
- Reaction score
- 2,723
- Location
- Arandjelovac, Serbia
- VCDS Serial number
- C?ID=57300
Hi Team!
Our old user Pedja, HC410055, want to know about:
He ask if buy Hex Net, can he expect fully support about problematic on this car?
Best regards,
B
Wednesday,31,October,2018,13:45:37:04300
VCDS Version: 18.9.0.2
VIN: WVGZZZ5NZJW811721 License Plate: AUTOITALIJA TIGUAN
Mileage: 19402km-12055mi Repair Order:
Chassis Type 5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 4B 52 5F 75 A5 CA
VIN: WVGZZZ5NZJW811721 Mileage: 19402km-12055miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 0100
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EJ HW: 04L 907 309 P
Component: R4 2.0l TDI H25 3661
Revision: B4H25---
Coding: 0125001203661D082000
ASAM Dataset: EV_ECM20TDI01104L906026EJ 004003
ROD: EV_ECM20TDI01104L906026EJ_004.rod
VCID: F6E9A41C49D771FA7F-80A2
6 Faults Found:
17167 - Databus
Mileage: 19402 km
Date: 2018.07.13
Time: 00:00:20
Coolant temperature: 15 °C
Intake air temperature: 16 °C
Voltage terminal 30: 11.420 V
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
20360 - Power Supply Terminal 15
P3325 00 [032] - Implausible
Mileage: 4278 km
Date: 2018.06.20
Time: 00:00:09
Voltage terminal 30: 11.280 V
Immobilizer snapshot A-Sia Error Snap A: 00 00 00
Immobilizer snapshot B-Sia Error Snap B: 00 00 00
12888 - Implausible Data Received from ABS Control Module
U0415 00 [047] - -
Fault Frequency: 10
Mileage: 19402 km
Date: 2018.07.13
Time: 21:33:58
Voltage terminal 30: 11.780 V
Engine status: COENG_READY
U0428 00 [047] - -
Mileage: 19402 km
Date: 2018.07.13
Time: 21:33:58
Cruise Control System (CCS): status-Bits 0-7: 7
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [047] - -
Mileage: 19402 km
Date: 2018.07.13
Time: 21:33:57
4716 - No Communications with Parking Brake Control Module
U0128 00 [047] - -
Mileage: 19402 km
Date: 2018.07.13
Time: 21:33:57
selected gear-Bits 0-7: 0
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 011 N HW: 0GC 927 711 G
Component: GSG DQ500 H06 2014
Revision: 00H06V07
ROD: EV_TCMDQ500021.rod
VCID: B36F5D081A2524D298-80E6
10635 - Gear Shift Lock Solenoid Control Circuit
P0928 00 [044] - Open
Mileage: 19402 km
Date: 2018.07.13
Time: 00:00:37
Engine speed: 1032.00 /min
Coolant temperature: 17 °C
Clutch: primary stat: Neutral
selected gear: GANG_R
Driving position: P
Engine torque: -40 Nm
Control Module temperature: 13 °C
Accelerator position: 15.2 %
DTC memory status: 3
21221 - No Communications with Parking Brake Control Module
U0128 00 [047] - -
Fault Frequency: 13
Mileage: 19402 km
Date: 2018.07.13
Time: 21:33:58
Clutch: primary stat: New
Driving position: P
Engine torque: -100 Nm
Control Module temperature: 14 °C
DTC memory status: 73
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 61607000001222
Coding: 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
VCID: F7F7A9184EDD08F264-80A2
15 Faults Found:
0072 - Rear Left Wheel Speed Sensor
C101C 01 [137] - Electrical Failure
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
0195 - Control module not coded
U1013 00 [137] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
0295 - Steering angle sensor
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
4161 - Coding invalid
U10DA 00 [008] - -
Reset counter: 227
Mileage: 19402 km
Date: 2018.07.13
Time: 21:37:01
4193 - Front Left Wheel Speed Sensor
C101A 14 [137] - Open or Short to Ground
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
8279 - Engine Control Module Incorrectly Coded
P1612 00 [137] - -
Fault Frequency: 11
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
8280 - Engine Control Module Incorrectly Coded
P1612 00 [137] - -
Fault Frequency: 15
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
8292 - Control Module Incorrectly Coded
U1014 00 [137] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
8299 - Databus
Fault Frequency: 15
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
8306 - Databus
U1122 00 [137] - Implausible Message
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:26
8308 - Control Module Incorrectly Coded
U1014 00 [009] - -
Fault Frequency: 13
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:31:24
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 M HW: 5NA 907 044 M
Component: AC Automat H35 4301
Revision: 20K08000 Serial number: 00000B00542073
Coding: 0002012420211001110510000010102A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: C9931FE068A94E02C2-809C
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
459024 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:22
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001716700789
ROD: EV_BCMBOSCH_018.rod
VCID: 8913DFE028290E0202-80DC
Subsystem 1 - Part No SW: 5NB 955 119 HW: 5NB 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 151002 033 0372
Serial number: 00000001509290301271
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y17M03D22H16M44S25
Coding: 00A8DD
7 Faults Found:
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
B131D F7 [008] - No Release by Immobilizer
Reset counter: 227
Mileage: 4278 km
Date: 2018.06.20
Time: 00:00:10
539925 - Databus
Reset counter: 227
Mileage: 19402 km
Date: 2018.07.13
Time: 21:58:44
558100 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:26
568086 - Databus
Reset counter: 187
Mileage: 4278 km
Date: 2018.06.20
Time: 00:00:19
568342 - Databus
Reset counter: 187
Mileage: 4278 km
Date: 2018.06.20
Time: 00:00:20
569092 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:24
576516 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:24
Part No SW: 3QD 919 294 B HW: 3QD 919 294
Component: PDC 8 Kanal H07 0030
Serial number: 000206178877041
Coding: 0071451811
ASAM Dataset: EV_EPHBO18VW481CN00 001008
ROD: EV_EPHBO18VW4810000.rod
VCID: CC9D26F467DB5B2AF9-8098
7 Faults Found:
12658704 - Databus
Fault Frequency: 12
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
13637409 - Databus
Fault Frequency: 10
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
13637411 - Databus
Fault Frequency: 10
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
13637422 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
13637424 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
13637426 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
12727553 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:23
Address 13: Auto Dist. Reg
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 005 0336
Serial number: 003VWR32U2AB
Coding: 98CCC0C00C0000005C5400CF004800000065
ROD: EV_AirbaVW20SMEVW37X.rod
Subsystem 1 - Part No SW: ----------- HW: 480 002 701 16
Serial number: 3570000000011B2DC81L
Subsystem 2 - Part No SW: ----------- HW: 480 000 102 16
Serial number: 35800000000ABA5DE812
Subsystem 3 - Part No SW: ----------- HW: 480 401 406 17
Serial number: 3510001B7260B431764T
Subsystem 4 - Part No SW: ----------- HW: 480 401 406 17
Serial number: 35200019D260B433C82+
Subsystem 5 - Part No SW: ----------- HW: 480 401 710 15
Component: FrontSensor_D 000 6149
Serial number: 3550001C31C1FED5144D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 701 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001AB1E9A6C5847O
Subsystem 7 - Part No SW: ----------- HW: 480 402 701 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001AB1E9A6C6C53R
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 402 701 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001AB1E9A6C134BC
Subsystem 9 - Part No SW: ----------- HW: 480 000 712 15
Component: PedPSensor_D2 001 0887
Serial number: I0M0000000065121771R
Subsystem 10 - Part No SW: ----------- HW: 480 000 712 15
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000C7C317715
6 Faults Found:
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 19402 km
Date: 2018.07.13
Time: 21:35:34
Mileage: 19402 km
Date: 2018.07.13
Time: 21:35:34
B1007 1B [137] - Resistance Too High
Mileage: 19402 km
Date: 2018.07.13
Time: 21:35:34
9447189 - Seat Occupied Sensor; Passenger's Side
B1027 15 [137] - Open or Short to Plus
Mileage: 19402 km
Date: 2018.07.13
Time: 21:35:36
9682162 - Multiple collision brake
B13BC F2 [137] - No function
Mileage: 19402 km
Date: 2018.07.13
Time: 21:35:34
15360768 - Component Protection
U1101 00 [008] - Active
Mileage: 4278 km
Date: 2018.06.20
Time: 00:00:12
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20170614100185
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: C18307C0509986421A-8094
Part No SW: 5NA 920 791 B HW: 5NA 920 791 B
Component: KOMBI 407 3193
Coding: 07A400086F80000801886B031401000800000000
VCID: C28108CC559F9D5A03-8096
9 Faults Found:
10485828 - Internal Control Module Memory Check Sum Error
B2000 41 [009] - General checksum failure
Time: 00:00:00
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [009] - Internal electronic failure
Mileage: 19402 km
Date: 2018.07.13
Time: 00:00:10
16777010 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:25
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:25
16776960 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
16776961 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
16776967 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
16776969 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
16776973 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 02061710800165
Coding: 030500045F087300FB07225A1E0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
Subsystem 2 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 9686684204
6 Faults Found:
131604 - No Communication with Instrument Cluster
U0155 00 [008] - -
Reset counter: 227
Mileage: 19402 km
Date: 2018.07.13
Time: 21:58:44
Supply voltage: Terminal 30: 11.8 V
Terminal 15: OFF
131663 - No Communications with Front Sensor Package for Driver Assist. Systems
U10E0 00 [009] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:13:40
Supply voltage: Terminal 30: 11.6 V
Terminal 15: On
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:13:40
Terminal 15: On
197169 - Controls in Steering Wheel
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 04:04:14
Supply voltage: Terminal 30: 12.6 V
Terminal 15: On
8526361 - LV Energy Management
B1802 F1 [008] - Warning Triggered
Reset counter: 227
Mileage: 19402 km
Date: 2018.07.13
Time: 00:00:19
Supply voltage: Terminal 30: 12.0 V
Terminal 15: On
8526363 - Unknown Error Code
B189C F0 [009] - Unknown Error Elaboration
Fault Frequency: 15
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:13:40
Terminal 15: On
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00003.05.17
Coding: 0101
VCID: CA9120EC6DAF451ACB-809E
16656 - Databus
Fault Frequency: 10
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:20
Component: TSG FS 020 0041
Serial number: 040815BGV0672A
Coding: 001E12208000040000001000
VCID: C38F0DC84A85945208-8096
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0001743388
Coding: 01000011004001
ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
VCID: C08502C45B938F4A15-8094
3158336 - Databus
Fault Frequency: 10
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
Write only channel
3164929 - Databus
Fault Frequency: 20
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
Write only channel
3158536 - Indicator Lamp for Electro-Mechanical Power Steering
C10D5 04 [008] - Internal System Fault
Reset counter: 227
Mileage: 19402 km
Date: 2018.07.13
Time: 00:00:13
Write only channel
5262640 - Steering angle sensor
Reset counter: 187
Write only channel
3164800 - Databus
Fault Frequency: 20
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
Write only channel
Address 4B: Multifunc. Module
Interface not compatible.
Component: TSG BFS 020 0041
Serial number: 070815BH521053
Coding: 001E10208000040000001000
Part No SW: 3Q0 035 864 C HW: 3Q0 035 864 C
Component: MU-S-N-ER 851 0842
Coding: 02730601FF0000005111000100080A001F0500E401200000CE
ROD: EV_MUStd4CDELP_VW26.rod
VCID: B1635700E03916C2EA-80E4
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT1701562
11 Faults Found:
Reset counter: 227
Mileage: 4278 km
Date: 2018.06.20
Time: 00:00:06
Voltage terminal 30: 11.9 V
2564 - GPS Antenna
B1054 11 [009] - Short to Ground
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:22
Voltage terminal 30: 11.3 V
6666 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 227
Mileage: 19402 km
Date: 2018.07.13
Time: 21:58:37
Voltage terminal 30: 11.8 V
System_Temperature_Sensor_6-max.value: -50 °C
System_Temperature_Sensor_6-min.value: 0 °C
System_Temperature_Sensor_6-Current: 34 °C
6698 - Optical data bus
Reset counter: 227
Mileage: 19402 km
Date: 2018.07.13
Time: 21:58:44
6667 - Optical Data Bus for Information Electronics 1
U10CA 00 [008] - Intermittent Disruption
Reset counter: 227
Mileage: 19402 km
Date: 2018.07.13
Time: 00:00:34
Voltage terminal 30: 14.4 V
System_Temperature_Sensor_6-Current: 32 °C
6672 - Optical Data Bus for Display in Instruments
U10CF 00 [008] - Intermittent Disruption
Reset counter: 227
Mileage: 4278 km
Date: 2018.06.20
Time: 00:00:21
System_Temperature_Sensor_6-Current: 33 °C
U1111 00 [009] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:24
BAP-BAP_Function_ID: 02
7175 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:24
7193 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:24
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:24
7206 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:24
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0717
Revision: --------
Coding: 02230601EA42380D3F1CBE020045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW37.rod
VCID: BC7D7634377BEBAA49-80E8
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:26
Voltage terminal 30: 11.5 V
12866049 - Databus
Reset counter: 187
Mileage: 19402 km
Date: 2018.07.13
Time: 21:06:21
Address A5: Frt Sens. Drv. Assist
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:09)--------------------------
Best regards,
B
