I have an early 2010 RHD Mk6 Golf 1.6TDI S (105PS) 5 speed manual UK spec. It already has the Highline Computer operated by the wiper stalk. Presently it does not have a MFSW and has the midline steering control module 1K0-953-549-CQ with a Type 2 Slip ring, SW 0111, no Steering Angle Sensor and no info re LIN according to Ross tech Wiki..
Initially I am trying to determine the most suitable Highline steering control module to get for the vehicle (before getting into the correct coding). The new Steering wheel I have to fit is from a 2012 Mk6 Golf GTD it is the 3 spoke round (not flat bottom). I think the part number is 3C8 419 091 BE E74 or 3C8 959 537D according to the stickers. (see attached pics for these and airbag below).
I have been looking at the 1K0-953-549-CD as this doesn't have a steering angle sensor or the 1K0-953-549-CH which does have the steering angle sensor. Do I need one with or without the sensor?? Both of these are similar part numbers to my midline version. Or would I need a newer one that matches the 2012 new wheel? Is it important what LIN version it supports re the wheel as I presently haven't the specs on the new wheel.
Both of these (1K0-953-549-CD/CH) have support for LIN versions 1.3 & 2.0. Again I am not sure which of these I would need for the new MFSW. I would want the wheel to interface with the MDI media unit (connected to a RCD310 EU Radio and USB SSD for Music). Originally the car was fitted with the VW badged Bury bluetooth hands free tel. unit which was stripped out and replaced with the full Bury equivalent Bury CC9068. This presently interfaces with the MDI. I wonder whether it will work with the wheel buttons?
I have had a full auto scan done here below and any help to begin with here would be greatly appreciated:
VCDS Version: 18.9.0.2
VIN: WVWZZZ1KZAW2*****
Mileage: 54040km-33578mi
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56
VIN: WVWZZZ1KZAW2***** Mileage: 54040km-33578miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 B HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 9971
Revision: --H23--- Serial number: 00000000000000
Coding: 00114014030500080000
ASAM Dataset: EV_ECM16TDI02103L906023B 003011
ROD: EV_ECM16TDI02103L906023PA.rod
VCID: 254A63F224ADCF6286-8070
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 133B200D09290003C81104E890210080300000
VCID: 78F47A86CB9F828AED-802C
Part No SW: 3C8 907 336 AB HW: 3C8 907 336 AB
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
ROD: EV_ClimaBasis_VW36.rod
VCID: 6DDA5BD2BCDD37220E-8038
Part No SW: 1K0 937 086 D HW: 1K0 937 086 D
Component: BCM PQ35 M+ 103 0575
Revision: 00103 AG
Coding: 48180A3E9025F19044080080100081E443010088524D8160648000200000
VCID: 316287A2686593C26A-8064
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 09011 21 0512
Coding: 009795
Subsystem 2 - Part No: 1K8 951 171
Subsystem 3 - Part No: 1K8 951 605
Component: LIN BACKUP HO H10 9003
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA2JEAY
Coding: 00003133
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B7EA58AB2296992C0-806E
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME7C0A234DZZZ1
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME3212524EZZZR
Serial number: 3512QSME10064635ZZZG
Serial number: 3522QSME0E0A4616ZZZX
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000004
VCID: 030E1D6A4259D152C8-8056
Part No SW: 5K0 920 970 N HW: 5K0 920 970 N
Component: KOMBI H03 0305
Coding: 770B00
VCID: 3972BF82B8155B82D2-806C
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 120110F1000526
Coding: E9801F06000212000003
Shop #: WSC 00246 210 64224
VCID: 69D22FC240352B0262-803C
Component: IMMO H03 0305
VCID: 6AD050CE8D33201A6B-803E
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667763649
VCID: 264864FE51ABC47A8F-8072
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2114
Coding: 0000564
VCID: 316287A2A86593C26A-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2140
Coding: 0000564
VCID: 346C8EB65777A6EA01-8060
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: RCD310 EU H11 5032
Revision: -----01S Serial number: VWZ4Z2K1102548
Coding: 0500040004
VCID: 65CA23F26C2D0F6246-8030
End---------------------(Elapsed Time: 02:22, udsna)-----------------------
