Hi all,
Please help retrofit Sensor for Rear Lid/Hatch Opening (open the luggage compartment with flap)
I can not do the calibration (Missing Calibration / Basic Setting)
Scan:
Scan:
Friday,02,November,2018,18:37:37:60022
VIN: VSSZZZ5FZH6505219 License Plate: NWW992
Mileage: 71779km-44601mi Repair Order: 20181102total
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 6D A5
CA
VIN: VSSZZZ5FZH6505219 Mileage: 71779km-44601miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CZEA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 JT HW: 04E 907 309 BJ
Component: R4 1.4l TFS H23 3139
Revision: R6H23---
Coding: 0125003223641D083000
Shop #: WSC 33361 790 00063
ASAM Dataset: EV_ECM14TFS01104E906027JT 001004
ROD: EV_ECM14TFS01104E906027JT_AU37.rod
VCID: 7F5BFFEA4773DB9FE7F-802A
CAN Converter 01:
Part No SW: 0CW 300 049 R HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0903
Revision: 00005026 Serial number: CU501607146531
ROD: EV_TCMDQ200021_VW31.rod
VCID: 4CC198264645B00732D-8018
Part No SW: 5Q0 614 517 BH HW: 5Q0 614 517 AD
Component: ESC H25 0507
Revision: 00000000 Serial number: 61676000000466
Coding: 21EE6A92342014718779660141CC2584562C28E16682A4733822F074C62203
ROD: EV_Brake1UDSContiMK100IPB_035_VW41.rod
VCID: 78A914F6625DECA7A65-802C
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0412007821
Coding: 032C0C0F03
Shop #: WSC 73430 790 00063
VCID: 3C21C8E616E5008782D-8068
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98328917
221445 - Sensor for Rear Lid/Hatch Opening
B1303 54 [137] - Missing Calibration / Basic Setting
Reset counter: 24
Mileage: 71657 km
Date: 2018.11.02
Time: 07:37:34
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
ZAT_pressed: OFF
Park selector lever position: Not engaged and not locked
Enabling immobilizer: Condition not met
Control Module Voltage: 13.402 V
Vehicle speed: 35.5 km/h
Engine speed: 1480.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID sensor 1 authentication: status: No response
ID sensor 2 authentication: status: No response
ID sensor 3 authentication: status: No response
ID sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Part No SW: 5F0 907 044 AE HW: 5F0 907 044 AE
Component: Climatronic H05 1601
Revision: 00001K09
Coding: 02000024200110011105004001101020
ROD: EV_ACClimaBHBVW37X_006_SE37.rod
VCID: 698F41B229F7452F29B-803C
Air quality sensor:
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001619701330
ROD: EV_BCMBOSCH_017.rod
Component: RLHS 042 0105
Serial number: S4Y16M07D27H12M29S06
Coding: 06996E
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616202
Coding: 0271063051
ASAM Dataset: EV_EPHVA2CAU3700000 009017
VCID: 0D4755227DDFF90FE53-8058
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 J HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0156
Coding: 3200474310FF8728749C8065804081
ASAM Dataset: EV_ACCMRRCONTIVW376 001011
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 3B23CBFA13EB07BF8B7-806E
Part No SW: 3Q0 959 655 AK HW: 3Q0 959 655 AK
Component: Airbag VW21 004 0305
Revision: -------- Serial number: 003R6PDW7RP-
Coding: 98CCC0C0000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 074B670A1FA3935FDFF-8052
Subsystem 1 - Part No SW: ----------- HW: 454 001 806 16
Serial number: 35700000000C3439AB1P
Subsystem 2 - Part No SW: ----------- HW: 454 000 707 16
Serial number: 358000000009E274DB1Y
Subsystem 3 - Part No SW: ----------- HW: 454 801 406 16
Serial number: 351003485C90B000000I
Subsystem 4 - Part No SW: ----------- HW: 454 801 906 16
Serial number: 35200DB96C90B000000
Subsystem 5 - Part No SW: ----------- HW: 454 802 805 16
Serial number: 355005837470B000000F
Part No SW: 3Q0 953 521 EE HW: 5Q0 953 569 A
Revision: FF036036 Serial number: 20160721400799
Coding: 6C14
ROD: EV_SMLSVALEOMQB.rod
VCID: 77AB17CA6F43E3DFAFF-8022
Part No SW: 5F0 920 740 D HW: 5F0 920 740 D
Component: KOMBI 205 8311
Coding: 07A5221A6F84000800883A031001000000000000
VCID: 25170D82856FA14FCD3-8070
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 23071610800742
Coding: 030100F42F085700EA000250140F00010001050000000000000000000000
Shop #: WSC 33361 790 00114
ROD: EV_GatewConti_013_VW37.rod
VCID: 7CA108E65665C087C2D-8028
Subsystem 2 - Part No SW: 5F0 959 537 A HW: 5F0 959 537 A
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B0649050416
Coding: 012000
Serial number: 75410803001607270054
Component: ELV-MQBB H05 0032
Serial number: 16000154551001
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BF29D20127BDEF61B-8024
Component: TSG FS 010 0031
Serial number: 0000211224110
Coding: 00311320D000040000001000
VCID: 47CBA70A5F23535F1FF-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000010835108
Coding: 210000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000934230
Coding: 01010011004000
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3D27C5E20DFF098FB53-8068
Component: TSG BFS 010 0031
Serial number: 0000211032019
Coding: 00311320DC00040000001000
VCID: 46D5AA0E58294A57E49-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000010887931
Coding: 390000
Component: LWR-ECU 005 0080
Coding: 068A000009000000
VCID: 75B71DC2754F91CFBD3-8020
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 824 A HW: 5QA 035 824 A
Component: MU-S--ER H30 0351
Serial number: SEZAZ2S0121586
Coding: 04230600D70A000011110001000808002F0100C40120010002
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SK25.rod
VCID: 3E25C2EE00F91297AC9-806A
Subsystem 1 - Part No SW: 575 919 606 A HW: 575 919 606 A
Component: ABT_High-2_R H41 1041
Serial number: SEZ8Z9SCC001A9
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30845819900000
Coding: 1908
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 3FDBBFEA07F31B9FA7F-806A
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H04 0220
Serial number: 22071611P21068
Coding: 030307060000040000220044C040A10094000E200020
ROD: EV_MFKBoschMQBB_001_SE37.rod
VCID: 3A2DCEFE1CD13EB7901-806E
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 408040532602
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_004.rod
VCID: 372BD7CA2FC323DF6FF-8062
End----------(Elapsed Time: 01:53, VBatt start/end: 12.3V/12.3V)-----------
;SW:3Q0-959-435-E HW:3Q0-959-435-E --- Acc/Start Auth. --- SA: 20103
;Component:VWKESSYMQB 036 0811, Coding:032C0C0F03
;EV_KessyHellaMQBAB,004039,EV_KessyHellaMQBAB_004_VW37.rod
;Friday,02,November,2018,18:40:06:60022
;VCDS Version: Release 18.9.0 (x64) Data version: 20180927 DS296.0
;VCID: 3C21C8E616E5008782D-8068
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE09735-CU tailgate opener: sensor 1: threshold value 1,69 ,1
IDE09736-CU tailgate opener: sensor 1: threshold value 2,16 ,1
IDE09737-CU tailgate opener: sensor 1: threshold value 3,16 ,1
IDE09738-CU tailgate opener: sensor 1: threshold value 4,16 ,1
IDE09739-CU tailgate opener: sensor 1: threshold value 5,16 ,1
IDE09740-CU tailgate opener: sensor 2: threshold value 1,2 ,1
IDE09741-CU tailgate opener: sensor 2: threshold value 2,31 ,1
IDE09742-CU tailgate opener: sensor 2: threshold value 3,2 ,1
IDE09743-CU tailgate opener: sensor 2: threshold value 4,31 ,1
IDE09744-CU tailgate opener: sensor 2: threshold value 5,224 ,1
IDE09745-CU tailgate opener: sensor 1: timer value 1,170 ,1
IDE09746-CU tailgate opener: sensor 1: timer value 2,0 ,1
IDE09747-CU tailgate opener: sensor 1: timer value 3,9 ,1
IDE09748-CU tailgate opener: sensor 1: timer value 4,241 ,1
IDE09749-CU tailgate opener: sensor 1: timer value 5,40 ,1
IDE09750-CU tailgate opener: sensor 2: timer value 1,11 ,1
IDE09751-CU tailgate opener: sensor 2: timer value 2,165 ,1
IDE09752-CU tailgate opener: sensor 2: timer value 3,138 ,1
IDE09753-CU tailgate opener: sensor 2: timer value 4,204 ,1
IDE09754-CU tailgate opener: sensor 2: timer value 5,228 ,1
IDE09755-CU tailgate opener: sensor 1: burst length,16 ,1
IDE09756-CU tailgate opener: sensor 1: active screening,16 ,1
IDE09757-CU tailgate opener: sensor 2: burst length,2 ,1
IDE09758-CU tailgate opener: sensor 2: active screening,31 ,1
IDE09759-CU for tailgate opener: reset all counters,Default ,1
IDE09760-CU for tailgate opener: check sum,170 ,1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,2 ,1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,31 ,1
IDE09831-CU for tailgate opener: play protection increments,6 ,1
IDE09832-CU for tailgate opener: play protection decrements,25 ,1
IDE09833-CU for tailgate opener: play protection threshold active,255 ,1
IDE09834-CU for tailgate opener: play protection threshold inactive,5 ,1
IDE09835-CU for tailgate opener: play protection decrement interval,60 ,1
IDE09836-CU tailgate opener: sensor 1: control parameter,16 ,1
IDE09837-CU tailgate opener: sensor 2: control parameter,16 ,1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation,0 ,1
IDE09839-CU for tailgate opener: parameter set version,30 ,2
IDE10844-Control module rear lid opening: duration status query,4960 ms,1
IDE10845-Control module rear lid opening: vehicle type,28 ,1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,not activated ,1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,not activated ,1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
ENG126956-ENG126976-Byte9_VIP-active_vip,activated ,1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG126961-deactivation_time_vip_slidingdoor,15 s,1
ENG126960-Debounce_time_detection,500 ms,2
ENG126959-Debounce_time_driver_presence,200 ms,1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,120.00 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,not activated ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",not activated ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,activated ,1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
ENG105825-Diagnostic: wait time after power on,500 ms,1
ENG126943-Display_duration_emergency_off,3000 ms,1
ENG126944-Display_duration_error_mode_2_SPN,10 s,1
ENG126941-Display_duration_please_engage_P,10 s,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,1000 ms,1
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
ENG126950-duration_ZAT_debounce,50 ms,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,30 %,9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,5.00 s,9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,150 ,9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,70 %,9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,500 ms,9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,01 ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,05 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,70 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,65 mV/m,5
ENG126966-environment_scan_cyclic_step1,700 ms,1
ENG126967-environment_scan_cyclic_step2,2000 ms,1
ENG126965-environment_scan_duration_step1,300 min,1
ENG126971-environment_scan_duration_step2,24 H,1
ENG126969-environment_scan_level_bem,2 ,1
ENG126968-environment_scan_responselevel_reduction,500 ,1
ENG126970-environment_scan_startdelay_time,5 s,1
ENG126958-Ignition_For_Immobilizer,Default ,1
ENG129016-Initialization_diagnostics_switching_terminal,not activated ,4
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,activated ,1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,not activated ,1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,not activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,activated ,1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,14 B,1
ENG107595-MCTX settling phase,10 B,1
ENG129013-min_receptiontime_vit,0 ms,1
ENG126945-min_time_for_Terminal_50_request,200 ms,1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,210 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG126939-rpm_threshold_engine_runnning,100 /min,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG126963-settime_trigger_entry_vehicle,500 ms,1
ENG126962-settime_trigger_exit_vehicle,500 ms,1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
ENG129025-ENG142122-sonstiges_byte2-sad_existing,not activated ,1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,activated ,1
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG126938-Terminal_15_adaption_body_control_module,Default ,1
ENG126946-Terminal_S_Timeout,30 min,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG129027-Time_frame_VIP_kick_forecast,5 ,1
ENG126942-time_to_drive_cycle_detection,1.00 s,1
ENG126947-time_to_ignore_ignition_trigger,35 s,1
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
ENG126949-time_ZAT_actuation_detection,3000 ms,1
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
ENG129019-timeout_convenience_coverage_limiting,75 s,1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.100 ,1
ENG153751-ZAT_clamp58xt_signal_offset,2.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,500 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,2500 ms,1
ENG153755-ZAT_motor_signal_timer_2,2000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,0 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,0 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,80 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,1600 ms,1
Elapsed Time: 00:55
