Results 1 to 2 of 2
Thread: Help needed to a R32 swap
    Pirate
    Nov 2018
    Hi Guys
    I need a bit of help with my build. I'm building a Golf mk1 with a R32 engine from a Golf mk5. The engine is from a car with DSG but i'm running manual, so I tried to code the ECU in VCDS to a manual gearbox, but it keeps telling me "Out of Range" ? Do any of you know if it is possible to code a ECU from DSG to manual ?
    The engine is currently running fine in the car, but only in Idle, there is no respons when i hit the throttle, the pedal is brand new but maybe the ECU needs a pedal from a specific DSG car ?
    I know you guys needs an Autoscan, but thats is really not possible, since I dont have a working Can-Bus system in the car, I only connect Via K-line. But here are a scan of the fault I'm currently working with, I hope all of them can be coded out of the ECU, but i'm not sure..
    Any input is appriciated.
    Removed.   Data from a clone/pirate copy of VCDS is not welcome here.
    Getting help on this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#dk
    Let us know via PM if/when you get one so we can adjust your forum status.
  3. Likes Fredrick Awuor liked this post
