Ricunique
New Member
hi guys i am almost ready to threw in the towel. If you can pls help me...
I bought an Seat Leon FR '09 model with vin# VSSZZZ1PZ9R004186 on auction.
The car was starting and running with clocks from the gti.
while it was in our store, someone stole the ECU and ABS pump out.
I got a ECU from a SEAt Cupra with coded key and ignition. tho code # on ECU 1P0 907 116 C
Also from another Cupra the ABS pump with code # 1K0 614 517 AF also the clocks from this same car.
I have a guy coding it with Vcds and Autel Maxisys elite..
It have excepted the codes for the clocks with the ECU but giving us not picking up the ABS pump...
Should the car start without not picking up ABS pump or not. There is spark on the coils but only swinging..
ANY help will be appreciated and if there is more you need to know i will get all info immediately.
Thank you in advance
