Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Problems wih interface drivers after updating version 18.9.0
    Quote Originally Posted by -Jake- View Post
    After update the interface status is still "questionable". Is this normal?
    When it's not plugged into a car that's normal.
  2. #12
    I did try your instruction and it turned my laptop a completely brick. Grey screen, nothing worked.
    That's rather strange.
    By using the task manager managed to enable all services and brick turned to a working computer.
    OK.
    I did try only disable all programs from the startup tab and this worked. I was able to connect to interface via VCDS and I manged to update the firmware.
    Cool! Now your mission is to figure out which of the programs in your Startup tab is ill-behaved enough to grab/block access to the interface and report back.
    Yes, if it sees no power at all from the car side, that is normal.
