Results 1 to 10 of 18
Thread: MK4 ABS ESP coding
    Mar 2018
    Canada
    MK4 ABS ESP coding
    Folks,
    first time posting here - need some help with my ABS coding...
    I've been dealing with a connection issue with my Haldex and fixing up the electrical connections so the latest code that's popped out is for incorrect coding
    The ABS coding that was in the system is 22534 which doesn't make any sense based on the hints that come up unless there is other numbers I am supposed to add to it...here is the sticker decode:
    X4A = National sales program Austria
    B0B = Component parts set, complying with vehicle type for Austria, various parts
    C7Y = Alloy wheels 6.5J x 16
    G0L = 6-speed manual transmission for four-wheel drive vehicle
    H6U = Tires 205/55 R16 91W
    J0L = Battery 340 A (70 Ah)
    MS7 = 4-cyl. turbo diesel eng. 1.9 L/74 kW TDIpump-jet injection system Base engine is T5X/T21/T71
    Q4H = Comfort sports seats, front
    V0G = MICHELIN tires
    1AT = Electronic stabilization program (ESP)
    1G2 = Steel spare wheel with original equipment tires
    2PX = Leather trimmed sports steering wheel
    1NL = Covers for alloy wheels
    5RQ = Right exterior mirror: convex
    5SL = Left exterior mirror: aspherical
    T5X = 4-cylinder diesel engine 1.9 L unit 038.L
    0BL = Rear stabilizer
    3S2 = Black roof rails
    3U2 = Sliding trunk cover
    QG1 = Service interval prolongation
    0G4 = Cable gearshift
    8AQ = Radio "beta" with removable operating panel
    8GL = Alternator 120 A
    8L3 = Roof antenna
    1H0 = Without proportioning valve
    1KE = Disc brakes, rear
    1ZM = Disc brakes, front (Geomet D)
    3YR = Door pockets with insert mats
    G36 = Front shock absorption
    4UE = Air bag for driver and front seat passenger
    4X1 = Side air bag front
    4R4 = Power windows with comfort operation andcircuit breaker
    4K3 = Radio remote controlled central locking operated from inside and safe securing
    N2Z = Seat covering for special editions
    5MA = Decorative inserts
    8RE = 4 speakers (passive)
    2JC = Comfort bumpers
    E50 = "GTI USA" (that must be wrong)
    0AR = Front stabilizer
    0GE = Emission standard EU3
    1JX = Rear shock absorption, basic/sports design, four wheel drive
    L39 = Suspension range 39 installation control only, no requirement forecast
    0YZ = Without determination of weight categoryfor rear axle
    any help is appreciated...all I can come up with is 18432 + 6 for the FS3 caliper = 18438
    is there anything I can post that would help with figuring out the coding?
    Welcome to the VCDS forum OP Post an auto-scan please.........
    Coding: 0023049
  3. Likes Uwe liked this post
    Mar 2018
    Canada
    Thanks for the reply - I`ll post the full scan tonight...
    can you tell me how you got to that number? I take it the 3 options that are listed in the help bubble are not the only things that get added to the number
    Mar 2018
    Canada
    not sure what that means...
    here's the full scan
    Wednesday,31,October,2018,14:41:40:07614
    VCDS Version: 18.9.0.2 (x64)
    VIN: WVWZZZ1JZ3D011841   License Plate:
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: WVWZZZ1JZ3D011841   Mileage: 220970km-137304miles
    Address 01: Engine        Labels: 038-906-019-AXR.lbl
       Part No: 038 906 019 DD
       Component: 1,9l R4 EDC G000SG  1518
       Coding: 00003
       Shop #: WSC 31414
       VCID: 5CB7EAEFCC3639AAE9-4B00
       WVWZZZ1JZ3D011841     VWZ7Z0B5791057
    18261 - Powertrain Data Bus
                P1853 - 35-10 - Implausible Message from ABS Controller - Intermittent
    Readiness: 0 0 X X X
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
       Part No: 1C0 907 379 N
       Component: ESP ALLRAD MK60     0102
       Coding: 0022534
       Shop #: WSC 31414 000 00000
       VCID: 35615F4B5F5CC8E236-5140
    00493 - ESP-Sensor Unit (G419)
                014 - Defective
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 C
       Component: CLIMATRONIC     C 2.0.0
       Coding: 11000
       Shop #: WSC 31414
       VCID: 21499B1BABD45442FA-5198
    00792 - A/C Pressure Switch (F129)
                35-00 -  -
                37-00 - Faulty
       Part No: 1C0 909 605 A
       Component: 27 AIRBAG VW51 01   0004
       Coding: 12855
       Shop #: WSC 31414
       VCID: 224B9417AED24F5AE3-5124
       Part No: 1J5 920 826 C
       Component: KOMBI+WEGFAHRSP VDO V13
       Coding: 01334
       VCID: 2E537027EA0AFB3A77-5124
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 31414
       VCID: 70EFAE5F30BEADCA25-5106
                49-00 - No Communications
    Address 22: AWD        Labels: 02D-900-554.lbl
       Part No: 02D 900 554 C
       Component: HALDEX LSC  ECC     0010
       VCID: 204F9E1FA0DE5D4AF5-4AE8
       Part No: 1C0 959 799 B
       Component: 1A Komfortgerát HLO 0003
       Coding: 00259
       Shop #: WSC 31414
       VCID: 36635847125AC3FA3F-4B00
       Component: 1A Tõrsteuer.FS KLO 0004
       Component: 1A Tõrsteuer.BF KLO 0004
       Component: 1A Tõrsteuer.HL KLO 0004
       Component: 1A Tõrsteuer.HR KLO 0004
    End-------------------------(Elapsed Time: 04:52)--------------------------
  7. Likes Uwe, Jack@European_Parts liked this post
    Mar 2018
    Canada
    I tried coding 0023049 but got error 31: request out of range
    Interesting. A 1.9 TDI with AWD in Canada.
  11. #8
    Mar 2018
    Canada
    I imported it back in February...trying to sort out the Haldex issues with it so I can enjoy it more this winter
  12. Likes Uwe liked this post
  13. #9
    Vehicle Identification No. WVWZZZ1JZ3D011841
    Model Golf TDI Var. 4Motion
    GOLF
    Date of production 10.09.2002
    Year 2003
    Sales type 1J5137
    Engine Code ATD
    Transmission Code ESW
    Axle drive 6S
    Coding: 0019458
    Coding: 0001025
    Special editions E50 "Generation V3"
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0CE Vehicle class differentiation -1J0-
    Emission standard 0GE Emission standard EU3
    Trailer hitch 1D0 without trailer towing
    airbag 4UE driver and front passanger airbags
    Automatic transmission indicator light 9FA Without automatic transmission indicator light
    Aktivkohlebehälter / Ottopartikelfilter 1E0 Without activated charcoal canister
    Storage compartment 7N0 Without overhead storage compartment
    Aerials 8L3 roof antenna
    Exterior mirror setting 6XD Exterior mirrors, power-adjustable/ heated
    Left exterior mirror 5SL Left exterior mirror, aspherical
    Right exterior mirror 5RQ Right exterior mirror: convex
    Drive type 1X1 Four-wheel drive
    Outside temperature display 9Y0 Without outdoor temperature gage
    Equipment levels A8M higher comfort-version
    Brake type in rear 1KE Disc brakes in rear
    batteries J0L Battery 340 A (70 Ah)
    Brake type, front 1ZM Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Controls (steering wheel/steering column) 4LA Without control element
    Beverage holders 4M5 Beverage holders
    Special color trim 0UA Without special color trim
    Component part sets with country-specific design requirements B0B Component parts set, complying with vehicle type for Austria, various parts
    floor covering 3MH Dilours floor covering without scuff guard
    vehicle tools and jack 1S7 Tool kit and aluminum jack
    brake pressure regulator 1H0 without brake pressure regulator
    Brake systems 1AT electronic satbility programme -ESP-
    Owner's manuals 0XY Information kit in German (for Austria)
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A3 CD player
    Chrome package QJ1 Chrome package
    General operating permit, alterations C25 Operating permit, alteration
    Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
    Roof rails/roof load rack 3S2 Black roof rails
    Roof insert/convertible top 3FA roof without cut out
    Suspension system in rear 1JX Rear shock absorption, four-wheel drive Basic/Sport
    Suspension system in front G36 Shock absorption in front
    Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
    Installation differentiation for components 0EN Installation differentiation for transmission MQ 350 -- vehicle components --
    Theft protection system 7AB Electronic immobilizer with anti-theft alarm system (for ROW)
    Inserts 5MA Decorative inserts
    Park distance control 7X0 Without park distance control
    Manufacturing sequence differentiation 0FK Bratislava manufacturing sequence
    Vehicle type AZ0 Vehicle with production equipment
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Headlight activation 8K0 Without special driving light switching
    Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake with activated charcoal filter
    Antifreeze 1C1 Antifreeze up to -25 degree Celsius tolerance up to -30 degree C
    throttle control 0L2 accelerator pedal with electronic modul
    Alternators 8GL Alternator 120 A
    Transmission types/gearshift mechanisms 0G4 Cable gearshift
    Weight category rear axle 0YZ Without determination of weight category for rear axle
    Weight category front axle L39 Suspension range 39 installation control only, no requirement forecast
    Base engine T5X 4-cylinder diesel engine 1.9 l unit 038.L
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U2 Sliding trunk cover
    cruise control system 8T0 Without cruise control system (CCS)
    Exterior noise suppression measures 2B1 additional noise dampener
    Luggage compartment trim 5A7 Comfort luggage compartment lining with service flap
    Transmission specifications G0L Six-speed manual transmission for four-wheel drive vehicle
    Brackets 3P1 Bracket for first aid kit and warning triangle
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Grab handles at roof frame 5N6 Folding grab handles on roof frame soft fold-away
    Rear axle 0N5 Standard rear axle
    Rear seats 3NE Rear seat bench/backrest, split folding with center armrest
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8JS Twin headlight for driving on the right with clear lens
    Instrument clusters U0C Instrument cluster with tachometer, clock and km/h speedometer
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KZ Decals for special editions
    Body style K8D Wagon/Avant
    Luggage compartment floor covering 6SL Luggage compartment floor covering in needle-punched nonwoven (velour)
    Cassette and CD storage unit 4W0 without cassette / CD tray
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    headrest for seat, rear 3Q1 headrest for seat, rear
    Head restraints 3J7 Tilt- and height-adjustable head restraints for front seats
    Fuel tank treatment 2LB Fuel tank with special material treatment (fluorination)
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 0F9 Cooled fuel system for diesel engine
    Body measures 5C0 Without special body measures
    Radiator grille 6KG Radiator grille
    Rear license plate bracket 6P1 Rear license plate carrier (ECE)
    Front license plate bracket 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K1 Transit coating (wax)
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S2 One reading light in front, two reading lights in rear
    steering 1N1 Power steering
    Backrest release 3H0 Without backrest release for front seats
    Air duct, front area VK0 Air duct, standard
    Lumbar support 7P0 Without lumbar support in seat backrests
    steering wheels 2PX Leather-wrapped sports steering wheel
    Speaker installation 8RE 4 speakers (passive)
    Steering column systems 2C5 Steering column, adjusted axially and vertically
    Headlight range control 8Q1 Headlight range control
    Center armrest 6E0 Without center armrest in front
    Multi-function display/trip computer 9Q1 Multi-function display/trip computer
    Engine cooling 8Z5 not hot country
    Engine specifications MS7 4-cyl. turbo diesel eng. 1.9 l/74 kW TDI unit-injector system base engine is T5X/T21/T71/TG0
    engine compartment lighting 9L0 without engine compartment lighting
    Left vanity mirror 4SD Vanity mirror, left, illuminated
    Right vanity mirror 4TD Vanity mirror, right, illuminated
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TC Rear fog light for driving on the right
    Front fog lamp/additional headlamp 8WA Without fog lights
    Rear of platform module base 4P3 Rear floor panel module, type 4
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels C7Y Alloy wheels 6 1/2J x 16 Design: Montreal, ET 42
    Radios 8AQ Radio "beta" with removable control panel
    Smoker's/non-smoker's package 9JB Smoker's package, ashtrays in front and rear
    tire H6U 205/55 R16 91W tyres
    Tire suppliers V0G MICHELIN tires
    Spare wheel/breakdown kit 1G2 Spare wheel with full tyre, steel
    Restraint systems, front 3QT 3-point seat belts in front, with tensioner and height adjustment
    PH4 air conditioning system "Climatronic"
    RBH radio system "beta" removable operating panel
    W27 Golf "25 Years" II and ESP for Austria with C7Y and chrome package
    W99 "Rabbit" for Austria with W27
    WE1 technical equipment package
    Side airbag 4X1 Side airbag in front
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SB Labels in German
    Tail lamp assemblies 8SA Rear combination lamp, standard design
    Locking mechanism for boot lid/cover rear 4E0 Tailgate/trunk lid unlocking from outside
    Nameplates for sales name QD1 Nameplates for sales name
    Seat belt check 9P0 without press button buckle with warning contact
    Outer rear seat belts 3ZG 3-point seat belts, outer rear with height adjustment
    Center rear seat belts 3C1 Static lap belt, center rear
    Gearshift boot/cover 6R1 Gearshift boot in leatherette
    seat covers N2Z Seat trim covers for special editions
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A0 without seat heater
    Side lights 7R3 Side turn signal lights (white)
    Horns 8Y1 Two-tone horn
    Control number (no PR family) SP9 Control of calendar week 36/00
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B2 Body-colored protective side molding
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JC Comfort bumpers
    Rear stabilizer 0BL Rear stabilizer
    Front stabilizer bar 0AR Front stabilizer bar
    Heavy-duty/sports version 2UA Standard design
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Special approval measures 3M0 Without special measures
    Nameplate set 1DN Nameplate set "TDI 4MOTION", "I" with special color trim
    Special alarm systems 9A0 Without taxi alarm system
    Door storage compartments in front 3YR Door pockets with insert mats
    Fuel filler cap/door, locking option 2W0 filler cap for fuel tank
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B12 Type approval country Austria
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
    doors 0A2 4 doors
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Identification plates 1EX Special identification plate for EU
    First aid kit / warning triangle 1T2 warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Front seats Q4H Sports comfort seats in front
    Rear seat catch 6QA Rear seat catch
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TB Additional warning lights (door area)
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E3 Sheathed type glow plug heater
    Windshield Glass 4GC Windshield in heat-insulating glass with colourstripe
    Washer fluid level indicator 8W0 without washer water level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Additional body panels, side 6EP Additional stone guard body covers
    Additional child seat anchors 3B0 Without additional child seat anchors
    Zündanlaß/Schloß-Sperrsystem/ Elektrische Lenksäulenverriegelung 0RA Without ignition/safety ignition lock
    Additional dust seals 6U0 Without additional seals outside
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  14. Likes Uwe, nitec liked this post
  15. #10
    Mar 2018
    Canada
    thanks Jack! So 19458 is what I should use for the ABS correct? and what is the 1025 coding for?
    can you give me some background on these numbers for my own information? Are you pulling them out of a database or are you able to generate them based on the VIN and the vehicle equipment? It seems your equipment list is a little more inclusive than mine - where do you get that from?
