We had changed the engine due to the original engine having dropped valve with a second hand engine from a running car.
This was all supplied by the owner of the car
The car had a misfire on cylinder 3 but the owner could not source a replacement under warranty since its quite a rare and expensive engine.
The owner of the car tried to change over a ECU, Body control module, instrument panel and steering lock due to a perceived misfire issue he believed was a ECU problem.
The car was running OK without a engine light or engine fault code but the ABS light traction control TPMS light is on.
We checked it on the VCDS and the ABS unit has lost its coding.
Also secondarily less importantly the radio has lost is code also
We did some research and this seems to be a common problem and any of the available ways to work out the ABS coding have not been effective.
I have searched through the forums and have seen you guys have helped some people.
So if possible we would love if someone helps us out or points us in the right direction.
In regard to the autoscan we have put all the original equipment back on the car so the running engines ECU, Body control module, instrument panel and steering lock are part of the scan
Thanks for you time
John
Thanks for you time
John
Tuesday,30,October,2018,09:31:02:50316
VCDS Version: 18.9.0.2 (x64)
VIN: WVWZZZ6RZAU033280 License Plate: FV10ULR
Mileage: 74200km-46105mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 09 15 17 19 25 44 56
VIN: WVWZZZ6RZAU033280 Mileage: 74200km-46105miles
Address 01: Engine (CGP) Labels: 03E-906-033-AZQ.lbl
Part No SW: 03E 906 023 AL HW: 03E 906 023 L
Component: SIMOS91 1.2l 4V 4523
Revision: --H04--- Serial number:
Coding: 0000031
Shop #: WSC 31414 790 31414
VCID: 69D9C13B43BD6E0262-5140
16687 - Cylinder 3
P0303 - 009 - Misfire Detected - Intermittent
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
VCID: 4D9115AB101592226E-8018
Fault Frequency: 18
Reset counter: 195
Mileage: 74201 km
Date: 2013.03.17
Time: 00:10:27
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x3213
Hex Value: 0x1490
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
Fault Status: 01100101
Reset counter: 195
Mileage: 74201 km
Date: 2013.03.21
Time: 23:33:33
Hex Value: 0x4007
Hex Value: 0x0002
Hex Value: 0x3251
Hex Value: 0x1B90
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
00493 - ESP-Sensor Unit (G419)
Fault Frequency: 18
Reset counter: 195
Mileage: 74201 km
Date: 2013.03.17
Time: 00:10:27
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x32E1
Hex Value: 0x1A90
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
00532 - Supply Voltage B+
Fault Status: 10100010
Reset counter: 235
Mileage: 74201 km
Date: 2013.03.17
Time: 00:23:44
Hex Value: 0x0003
Hex Value: 0x0001
Hex Value: 0x3224
Hex Value: 0x0370
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7C00
Hex Value: 0x0000
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 085 B HW: 6R0 937 085 B
Component: BCM PQ25 M+ H46 0207
Revision: BB046001 Serial number: 0143 337091283
Coding: 64B02BBF08A10048002000003D2B0C900040410F60060000200000000000
VCID: 3A7B4E77B59B159ADB-806E
Subsystem 1 - Part No SW: 6R0 959 802 R HW: 6R0 959 802 R Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU014.12.0917118
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 T HW: 6R0 959 801 T Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU021.01.1016670
Coding: 08BC30
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00B H09 0018
Revision: -------- Serial number: 003DW00BHY6U
Coding: 003042
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 428B3697D54B5D5A83-8016
Serial number: 3572SRB40000A1D14A0/
Serial number: 3582SRB40000A6D92177
Serial number: 3516GRB401T9DB9KSSEK
Serial number: 3526GRB402BCBBSP2R5-
Part No SW: 6R0 920 960 C HW: 6R0 920 960 C
Component: KOMBI H03 0205
Coding: 440200
Shop #: WSC 31414 790 50316
VCID: 35615D4B9485FAE236-8060
Part No SW: 6N0 909 901 HW: 6R0 937 085 B
Component: GW-K-CAN TP20 0207
Coding: 002300
VCID: 70EFAC5FA3679FCA25-8024
Reset counter: 235
Component: IMMO H03 0205
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
VCID: 6ADBBE378DBB651A6B-803E
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 31414
VCID: 2E537227EDD3C93A77-807A
01288 - Terminal 30; Steering Assist
Part No SW: 5M0 035 156 B HW: 5M0 035 156 B
Component: Radio 510 0521
Revision: R0510002 Serial number: VWZ5Z1I0237180
Coding: 0000020002
Shop #: WSC 00000 000 31414
VCID: 285F843F5B37970ABD-807C
End-------------------------(Elapsed Time: 02:10)--------------------------
