Results 1 to 10 of 19
Thread: 2015 Passat Wolfsburg 1.8T CPRA
    Verified VCDS User Mike0p's Avatar
    Sep 2018
    Murrieta, CA
    Hello wonderful world of irritated VW owners who routinely seem to experience mystery problems with their car due to over engineering. Sure are fun tough arenít they! I have one of those issues at the moment and here it is: Low oil pressure light at start up during warm up phase and at 3200 RPM and when the engine kicks down.(the light always extinguishes when the regulator switches back to low pressure and I donít receive a tone of any kind just the light popping on then back off. Items replaced:
    Both pressure sensors on the filter assembly Oil pressure regulator Oil filter/engine oil
    Items inspected/cleaned: Oil pan(was spotless when removed) Oil pump screen(was clear) All vacuum lines, secure and no leaks Checked N80, works 4.0 Verified oil pressure is within OEM guidelines with a mechanical gauge as per the VW service manual obtained from Erwin Checked wires for signs of corrosion/damage/ground. None.
    Anomalies: In the instrument cluster control module one of the adaptations reads: SID or ESI off/no oil level evaluation/oil thermal sensor not connected to instr panel/static oil pressure. At about the same time that the initial light illuminated I noticed that I could not access the remaining service interval from the instrument cluster keys.
    The light illuminates at the exact moment that the pressure regulator switches from low presssure to high pressure and simultaneously the oil pressure switch for high pressure reads OPEN. I currently have a code in the ECU which reads: 15190 unknown error code A code in the CAN bus: 01044 module incorrectly coded
    I am pretty sure that this is a data transfer issue and not a mechanical issue. But I seriously need some guidance. Iím buying Ross-Tech tomorrow to hopefully solve the problem. Any help is appreciated
    When you get your VCDS cable from Ross-Tech the first thing to do is post a full unedited Auto-Scan so we can see the details of the code and how your car is equipped.
  3. Likes Uwe, Jack@European_Parts liked this post
    Sep 2018
    Murrieta, CA
    Ok, expedited shipping it is.
    Sep 2018
    Murrieta, CA
    Where can I find literature on exactly how the lubrication system works. Step by step?
    Sep 2018
    Murrieta, CA
    Wednesday,07,November,2018,20:53:44:13952
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: 1VWAT7A37FC047902   License Plate: EBD
    Mileage: 168390km-104632mi   Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2B 2E 42 44 46 4C 4F 52 56 62
              72 75 77 A6
    VIN: 1VWAT7A37FC047902   Mileage: 168390km-104632miles
    2B-Steer. Col. Lock -- Status: Cannot be reached 1100
    2E-Media Player 3 -- Status: Not registered 0001
    46-Central Conv. -- Status: Not registered 0001
    4C-Tire Pressure II -- Status: Not registered 0001
    A6-Microphone -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 997 071 G    HW: 06K 907 425 C
       Component: R4 1.8l TFS   H13 9372
       Revision: --H13---
       Coding: 001A0012242400170000
       Shop #: WSC 09003 957 00200
       ASAM Dataset: EV_ECM18TFS02006K997071G 001005
       ROD: EV_ECM18TFS02006K997071E.rod
       VCID: 392F2E0C19DAFACF99B-806C
    15211 - Oile Pressure Regulating Valve
              P164E 00 [039] - Electrical Malfunction
                        Mileage: 168399 km
                        Date: 2018.11.07
                        Time: 04:20:08
                        Coolant temperature: 23 įC
                        Intake air temperature: 26 įC
                        Voltage terminal 30: 9.960 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 96 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                        FAC_TPS_1_SAE: 18.359375 %
                        FUP_H_SAE: 290.0 kPa
    Readiness: 1110 1101
    Address 02: Auto Trans (J217)       Labels:* 09G-927-749-V1.clb
       Part No SW: 09G 927 749 B    HW: 09G 927 749 B
       Component: AISIN AG6 G3  109 2855
       Coding: 000348
       ASAM Dataset: EV_TCMAQ250031 001004
       ROD: EV_TCMAQ250031_001_VW25.rod
       VCID: 38292B0822D0E3C7665-806C
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: C54BC0F549260001A31403E4921B0041A5140012
       VCID: 04518FF82E187727BAD-8050
                        Reset counter: 200
                        Mileage: 168399 km
                        Date: 2018.11.07
                        Time: 04:12:54
                        Count: 2
                        Count: 14
                        Count: 20480
                        Count: 16390
                        Count: 35840
                        Count: 255
       Part No SW: 561 907 426 E    HW: 561 907 426 E
       Component: AC Manuell    H02 0303
       Revision: 00001K02
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1D67DA9CAD32A6EF953-8048
              B10AB F0 [009] - Too Low
                        Reset counter: 200
                        Mileage: 168399 km
                        Date: 2018.11.07
                        Time: 04:12:48
       Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
       Component: BCM PQ35 B+   122 0174
       Revision: BH122001
       Coding: EF290EB8C00904DC40120001230000E047F1A0004480D507008022000C71
       VCID: 73B3DC247BB6409F937-8026
                        Fault Frequency: 11
                        Reset counter: 240
                        Mileage: 168365 km
                        Date: 2018.11.06
                        Time: 19:50:17
                        Voltage: 10.55 V
       Part No SW: 5C0 959 655 AA    HW: 5C0 959 655 AA
       Component: AirbagVW10    500 0975
       Serial number: 003LYD01RTA9
       Coding: 00004832
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 71BFD62C012A728F61B-8024
       Serial number: 6940000Y14000194TV03
       Coding: 303044
       Serial number: 3572MSME352C7848ZZZ%
       Serial number: 3582MSME04601C49ZZZU
       Serial number: 3516KSME65582131ZZZK
       Serial number: 3526KSME253C6931ZZZV
       Serial number: 3556LSME28250F31ZZZU
       Serial number: 3566LSME69624331ZZZT
       Part No SW: 1K5 953 521 BN    HW: 5K0 953 569 AE
       Revision: FF010042    Serial number: 20140818100836
       Coding: 488A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7AADF1005C5C31D7D01-802E
       Subsystem 1 - Part No SW: 561 959 537     HW: 561 959 537
       Component: E221__MFL-8LP  H07 0023
       Coding: 620000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 960 D    HW: 561 920 960 D
       Component: KOMBI         H04 0809
       Coding: 030E01
       VCID: 1A6DD180BC1CD1D7701-804E
       Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1653
       Revision:   H55       Serial number: 26101403000053
       Coding: 461000
       VCID: 005983E83A006B079E5-8054
                        Fault Frequency: 9
                        Mileage: 168365 km
                        Date: 2018.11.06
                        Time: 19:49:06
    02811 - Control Module for Electronic Steering Column Lock (J764)
                        Reset counter: 200
                        Mileage: 168399 km
                        Date: 2018.11.07
                        Time: 04:14:37
    03753 - Control Module for Microphone
                        Reset counter: 200
                        Mileage: 168399 km
                        Date: 2018.11.07
                        Time: 04:14:37
       Component: IMMO          H04 0809
       VCID: 6A8DC1402CFC8157201-803E
    Address 2B: Steer. Col. Lock
    Address 2E: Media Player 3
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0009041441
       Coding: 040495
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5BE39484F3A6E8DFAB7-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630141028191045
       Coding: 800000
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 200
    131584 - Motor for Rear Window Regulator
              B11EE 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 200
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 211    3501
       Revision: 00H22000
       VCID: 392F2E0C155AFACF99B-806C
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 10.1 V
                            PD
                        Temperature: 24.0įC
                        Count: 2
                        Steering Angle: 0.00į
                            SteerAng n.Init
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1653
       Coding: 00000008
       VCID: 6FBBD054179E647F77F-803A
       Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  009 0005
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0009064413
       Coding: 040494
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5CE19798F6A8EFE7A2D-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14202631141110134555
       Coding: 800000
                        Reset counter: 200
                        Reset counter: 200
       Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
       Component: LOW NAR SDARS H05 0006
       Revision: -----09S    Serial number: VWZ4Z6P3850735
       Coding: 0100040002000B
       VCID: 2517F27C85E26E2FCD3-8070
       Part No SW: 561 035 285     HW: 561 035 285
       Component: OCULowUSA     014 0102
       Serial number: 000003554140528
       Coding: 02140102C2161A107F1606000000
       ROD: EV_OCULow_001.rod
       VCID: 53F37CA49B76209F737-8006
              U1400 00 [009] - -
              [restriction due to undervoltage]
                        Reset counter: 200
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 200
                        Mileage: 168399 km
                        Date: 2018.11.07
                        Time: 04:22:38
       Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
       Component: TELEFON       H07 0593
       Revision: 1B001001    Serial number: 00007666616802
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: 323D1920C4AC0997581-8066
    Address A6: Microphone
    End--(Elapsed Time: 01:07, VBatt start/end: 9.8V/9.8V. VIgn 9.8V, udsna)---
    Gateway Installation List:  7N0 907 530 AR
    Sep 2018
    Murrieta, CA
    note that my oil pump is currently removed and my AC compressor. the centr elec is my main concern and the CAN bus
    OP is verified now. Moving to Car Repair Support.
  9. #8
    Seems to me this car has a screwed up Gateway Installation List.
    [Select]
    [19-CAN Gateway]
    [Installation List]
    Uncheck the stuff in the list that says, "Cannot Be Reached", check the stuff that says "Not Registered", then:
    [Save Coding].
    Back out gracefully, cycle the ignition, and post a fresh scan.
  10. Likes PetrolDave liked this post
  11. #9
    Sep 2018
    Murrieta, CA
    that's what I figured I needed to do, just wanted some confirmation since the HEX-V2 has so much more it is able to do than what I was previously using. as for the dynamic vs static oil pressure in the instrument panel adaptations and the SID not being available it took me about 3 minutes to correct both issues. I now just need to install my new oil pump and AC compressor and hopefully the whole situation is solved. the only unknown is the cent elec coding, there are a few items that I'm not familiar with, is there a reference I can look at that describes what each option is? i.e. window regulators, central locking without safe function terminal 75/x on-off etc. ive been trying to find a reference scan from an identical vehicle due to the variety of configurations VW uses and the Wolfsburg is kind of an anomaly but it appears I'm the only one on the planet that owns one.....
  12. Likes Jack@European_Parts liked this post
  13. #10
    Be sure to check why voltages dropped to 9 volts and inspect for fuel in sump for washing oil and conduct oil pressure and volume tests on the proper temp engine because if done cold it may fool your gauge readings.
    Do running tests too.
    Be advised the oil PSI valve is under warranty as a PZEV SULEV for 15/150K & since responsible for mileage and SMOG ratings that would display any P code!
