Results 1 to 6 of 6
Thread: Failed to start DPF Regeneration / audi S8 / 4.2 TDI
    Feb 2018
    Poland
    Hi guys,
    Im trying to force the ECU to start the DPF Regeneration,
    Ive tried it with the security code 12233 and 27971, but without any success.|
    Below the Error msg:
    Monday,29,October,2018,15:21:53:00332
    VCDS Version: Release 18.9.0 Running on Windows XP x86
                    Address 01: Engine       Labels: None
    Control Module Part Number: 4H0 907 409 K    HW: 4H0 907 409 K
      Component and/or Version: 4.2TDI EDC17  H10 0003
               Software Coding: 0A2A4032056601030800
                Work Shop Code: WSC 77777 777 00000
                  ASAM Dataset: EV_ECM42TDI1114H0907409K 001010 (AU64)
                           ROD: EV_ECM42TDI1114H0907409K.rod
                          VCID: 3424F0AC9F3A23EA01-8060
    5188 - Diesel Particle Filter
              P2463 00 [175] - Excessive Soot Accumulation
                        Mileage: 57497 km
                        Date: 2018.10.27
                        Time: 12:13:20
                        Engine speed: 1576.00 /min
                        Normed load value: 76.1 %
                        Vehicle speed: 50 km/h
                        Coolant temperature: 60 °C
                        Intake air temperature: 24 °C
                        Voltage terminal 30: 13.760 V
                        Particle filter: soot mass measured: 11.65 g
                        Particle filter: kilometers since last regeneration: 1268516 m
                        Exhaust gas jet volume in particle filter: 173.5 m³/h
                        Exh.gas temp.sen 3: 349.2 °C
    5453 - Starter Relay
              P3088 00 [096] - Electrical Malfunction
    5177 - Fuel Pressure Regulator Valve (N276)
              P2294 00 [032] - Open Circuit
                        Mileage: 57255 km
                        Date: 2018.10.19
                        Time: 15:16:52
                        Coolant temperature: 31 °C
                        Intake air temperature: 30 °C
                        Voltage terminal 30: 10.720 V
                        Unlearning counter according OBD: 33
                        Engine status: COENG_READY
    25780 - Catalyst System; Bank 2
              P0430 00 [237] - Efficiency Below Threshold
                        Mileage: 55490 km
                        Date: 2018.09.27
                        Time: 02:23:50
                        Engine speed: 1812.50 /min
                        Normed load value: 81.2 %
                        Vehicle speed: 146 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 22 °C
                        Voltage terminal 30: 13.680 V
                        Shut-off timer: last engine shut-off time: 37233 s
                        Exhaust temperature sensor 1: bank 2: 527.6 °C
                        Exhaust temperature sensor 3: bank 2: 412.5 °C
                        Exhaust temperature sensor 4: bank 2: 586.4 °C
                        Outside air temperature: 13.0 °C
    5189 - Particulate Trap Bank 1
              P2002 00 [047] - Efficiency Below Threshold
                        Mileage: 57497 km
                        Date: 2018.10.27
                        Time: 12:13:20
                        Particle filter: soot mass calculated: 24.90 g
                        Particle filter bank 2: soot mass calculated: 20.52 g
                        Particul.filter diff.pressure: 69 hPa
    Readiness: 1 2 0 0 0
    Monday,29,October,2018,16:18:17:00332
    VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
    VIN: WAUZZZ4H8EN016262   License Plate:
                    Address 01: Engine  (4H0 907 409 K)
    16:18:10
      IDE00433   Particle filter: oil ash volume 0.01 l
      IDE00434   Particle filter: soot mass calculated 26.89 g
      IDE00435   Particle filter: soot mass measured 17.88 g
      IDE00436   Particle filter: kilometers since last regeneration 1420186 m
    Can you please help me out with this S8, thanks in advance for any help.
    Apr 2016
    United Kingdom
    No such car, an Audi S8 with a diesel. Can you post the full VCDS scan.
  3. Likes Uwe, Jack@European_Parts liked this post
    Feb 2018
    Poland
    Monday,29,October,2018,17:52:32:00332
    Chassis Type: 4H-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 18 19 22 28 30
              34 36 3B 3C 42 44 46 47 48 52 53 55 56 57 5B 5F 62 69 6C 6D
              6F 72 7F 81 82 84 85 88 89 8A 8B 8D 8E 8F 90 AC
    VIN: WAUZZZ4H8EN016262   Mileage: 57681km-35841miles
    48-Seat, Rear, DS -- Status: Malfunction 0010
    5B-Seat,Rear,PS -- Status: Malfunction 0010
    7F-Inform. Electr. II -- Status: Malfunction 0010
    84-Night Vision -- Status: OK 0000
    88-Multicont. Seat Driver -- Status: Malfunction 0010
    89-Multicont. Seat Pass. -- Status: Malfunction 0010
    8A-Multicont. Seat Rear,DS -- Status: Malfunction 0010
    8D-Multicont. Seat Rear,PS -- Status: Malfunction 0010
    8F-Pretens. Frt Left -- Status: Cannot be reached 0100
    90-Pretens. Frt Right -- Status: Malfunction 0010
    Address 01: Engine (J623-CTEC)       Labels: None
       Part No SW: 4H0 907 409 K    HW: 4H0 907 409 K
       Component: 4.2TDI EDC17  H10 0003
       Revision: 5AH10---
       Shop #: WSC 77777 777 00000
              P2463 00 [167] - Excessive Soot Accumulation
                        Mileage: 57681 km
                        Date: 2018.10.29
                        Time: 17:44:46
                        Engine speed: 748.00 /min
                        Normed load value: 20.0 %
                        Coolant temperature: 88 °C
                        Intake air temperature: 14 °C
                        Voltage terminal 30: 14.160 V
                        Particle filter: soot mass measured: 7.42 g
                        Particle filter: kilometers since last regeneration: 32339 m
                        Exhaust gas jet volume in particle filter: 61.5 m³/h
                        Exh.gas temp.sen 3: 169.1 °C
              P2002 00 [039] - Efficiency Below Threshold
                        Mileage: 57681 km
                        Date: 2018.10.29
                        Time: 17:44:46
                        Particle filter: soot mass calculated: 25.14 g
                        Particle filter bank 2: soot mass calculated: 25.14 g
                        Particul.filter diff.pressure: 14 hPa
       Part No SW: 4H1 927 158 CM    HW: 0BL 927 156 J
       Component: 0BL 42 TDIRdW H18 1007
       Revision: --H18---
       Coding: 000001
       ASAM Dataset: EV_TCMALX51011 002022
       ROD: EV_TCMALX51011.rod
       VCID: 7DB21588ECF022A2BE-8028
       Part No SW: 4H0 907 379 AC    HW: 4H0 907 379 AC
       Component: ESP PREMIUM   H10 0930
       Coding: E4EDAB8027B7D501E300
       ASAM Dataset: EV_ESPPremi 005025
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 73A633B0DAB464D2D8-8026
       Part No SW: 4H0 907 064 EB    HW: 4H0 907 064 EB
       Component: BCM2 2.0      H36 0521
       Coding: 05A76F4E000000000000
       VCID: 6D9225C8B490B2220E-8038
       Serial number: 0214000078797014
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Component: MEM-BFS       H08 0156
       Revision: AA000000    Serial number: 00000069411154
       Coding: C018B60085047201010001010101112131313333283333
       Shop #: WSC 02729 823 28888
       VCID: 3522CDA89C403AE236-8060
    03725 - Control Module for Seat Belt Tensioner; Left Front
                        Reset counter: 54
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:57:22
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
       Component: Klima 4 Zonen H20 0210
       Coding: 381101FE340000
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_AirCondiFront 003001
       ROD: EV_AirCondiFront_002.rod
       VCID: 2D12E5C87C1072224E-8078
    0378 - Coolant Circulation Pump
              B10D0 04 [009] - Internal System Fault
                        Reset counter: 122
                        Mileage: 57650 km
                        Date: 2018.10.29
                        Time: 17:12:13
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 AB    HW: 4H0 907 063 AB
       Component: BCM1 2.0      H20 0242
       Revision: 19020001    Serial number: 00000809839501
       Coding: 0105001440349FE2E9014084A0001800009CE308AE0802218000089461011700004000000B0000
       VCID: 689C54DC9B72970A7D-803C
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 150411  H36 0090
       Serial number:         150415141308
       Coding: 0045F7
       Serial number: 21401924
       Coding: 0200FF
       Subsystem 3 - Part No SW: 4H0 941 531 G    HW: 4H0 941 531 G
       Component: E1 - LDS  H01 0044
       Serial number: 24 04 2015  00000652
       Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
       Component: EHL2 V07.03  H30 0030
       Serial number: 0000000094CE01E78BF4
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA108140000007185914
       Coding: 020300
       Serial number: B7398B86000000000001
                        Reset counter: 54
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:57:26
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 F    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0200
       Revision: AA001001
       Coding: 020000
       VCID: 230603F022D4B452E8-8076
       Part No SW: 4H0 919 475 AC    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0091
       Revision: 11001001    Serial number: 61061308001908
       Coding: 2AC905
       Shop #: WSC 77777 777 00007
    Address 11: Engine II (J624)       Labels: None
       Revision: 5AH10---
       ASAM Dataset: EV_ECM42TDI2114H0907409K 001010
       ROD: EV_ECM42TDI2114H0907409K.rod
       Part No SW: 4H0 907 561 C    HW: 4H0 907 561
       Component: ACC3          H21 0032
       Coding: 7F04010101
       ASAM Dataset: EV_AdaptCruisContrAU64X 002024
       ROD: EV_AdaptCruisContrAU64X_002.rod
       VCID: 2B16EBD042047C1250-807E
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P1001DV5-
       Coding: 30333045313430303038554A305234483053
       VCID: 3B36DB90B264EC92C0-806E
       Serial number: 3575HRB400S50PASG8M6
       Serial number: 3585HRB400Q50PASHHUN
       Serial number: 3515JRB4016510A0P0MG
       Serial number: 3525JRB400K510A0J9V%
       Serial number: 3554VRB405D36K465HDA
       Serial number: 3564VRB405B36K46KGT$
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 01335OK10019S
       Coding: 0000FC
       Shop #: WSC 24460 823 28888
       VCID: 373EC7A0864CC8F224-8062
       Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
       Serial number: 04 05 2013  C0251012
       Part No SW: 4H0 920 830 R    HW: 4H0 920 830 R
       Component: TDieRDWACCNV- H53 0621
       Revision: 34081090    Serial number: 658240113592013
       Coding: 138F08009F550008000100
       Shop #: WSC 77777 777 12345
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K.rod
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 P    HW: 4H0 919 204 P
       Component: Analoguhr D4  H05 0225
       Serial number: 2150323000273
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
       Component: Standheizung  H24 0260
       Revision: 66006006    Serial number: 20140302223905
       Coding: 551F01
       VCID: 26001AE451E6417A8F-8072
       Part No SW: 4H0 907 468 AE    HW: 4H0 907 468 AC
       Revision: --------    Serial number: 00000001378001
       Coding: 80CD077D00
       VCID: 74A430ACDFBA63EAC1-8020
       Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
       Component: J367-BDM  H08 0181
       Serial number: 51113C36221911038286
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
       Serial number: 14129000768011200410
    5080 - Front Left belt tensioner control module
              U107C 00 [009] - No communication
              [Steuergerät für RGS Links Keine Kommunikation]
                        Reset counter: 54
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:58:36
                        Voltage terminal 30: 14.7 V
                        Voltage terminal 15: 14.7 V
                        Control Module temperature: 34 °C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
              U1101 00 [009] - Active
                        Fault Frequency: 216
                        Reset counter: 122
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:58:36
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    12290 - Quiescent Current
              U1406 00 [009] - Too High
                        Reset counter: 56
                        Mileage: 55552 km
                        Date: 2018.09.28
                        Time: 01:33:57
                        Voltage terminal 30: 12.5 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 16 °C
                        System status: LIN_active
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
              U140B 00 [008] - -
              [Powermanagement active]
                        Fault Frequency: 27
                        Reset counter: 161
                        Mileage: 55462 km
                        Date: 2018.09.27
                        Time: 00:17:38
                        Voltage terminal 30: 12.6 V
                        Control Module temperature: 14 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 1
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H16 0200
       Serial number: 002504140001010
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       VCID: 281C14DC53F2570ABD-807C
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 L    HW: 4H0 919 158 L
       Component: Klima Fond    H16 0200
       Coding: 2700000000
       ASAM Dataset: EV_AirCondiHeck 002001
       ROD: EV_AirCondiHeck.rod
       VCID: 393AC198B858DE82D2-806C
    0089 - Voltage supply terminal 30 for actuators
              B10C1 01 [009] - Electrical Failure
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:25:01
    0058 - Temperature Sensor for Rear Left Upper Body Vent
              B10F2 15 [009] - Open or Short to Plus
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:25:05
    0060 - Temperature Sensor for Rear Right Upper Body Vent
              B10F3 15 [009] - Open or Short to Plus
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:25:05
    0062 - Temperature Sensor for Rear Left Footwell Outlet
              B110E 15 [009] - Open or Short to Plus
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:25:05
    0064 - Temperature Sensor for Rear Right Footwell Outlet
              B110F 15 [009] - Open or Short to Plus
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:25:05
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000059602
       Coding: 01010101000000000001000202
       VCID: 648440EC675AF36A51-8030
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H19 0783
       Coding: 008003
       ASAM Dataset: EV_AirSuspe 003025
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F2EFFC0761C00327C-807A
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000069410890
       Coding: C018BF8085857201030001010101112131313333203333
    03766 - Motor for Seat Belt Height Adjustment
                        Fault Status: 01100101
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:25:44
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:25:45
       Part No SW: 4H0 907 637 L    HW: 4H0 907 637 G
       Component: SARA 6D red   H03 0056
       Revision: --------    Serial number: EJ1BPA7100FNFC
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 383CC49C8352C78A2D-806C
       Part No SW: 4H0 907 566 F    HW: 4H0 907 566 F
       Component: SWA Master    H08 0040
       Serial number: 0408649982
       Coding: 040321
       ROD: EV_LaneChangAssis_VW51.rod
       VCID: 3326F3B09A3424D218-8066
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4H0 907 568 F    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0040
       Serial number: 0408713267
       Coding: 040321
       Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
       Component: TSG FA        H07 0280
       Revision: --------    Serial number: 0000144973716
       Coding: 011F1E015E0062C202083017
       VCID: 48DCB45CFBB2B70A5D-801C
                        Fault Frequency: 7
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:26:02
       Component: RCEPS         H40 0010
       Revision: 00001000    Serial number: 0015215632
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 3228F6B4652E2DDA13-8066
       Revision: 00002001    Serial number: 0335161371
       Coding: 011B0E2280B97981F320C7842C0316470000000000000000000000000000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0081
       Serial number: 00000000000000265223
       Subsystem 2 - Part No: 4H0 951 177
       Subsystem 4 - Part No SW: 4H0 947 135 D    HW: 4H0 947 135 D
       Component: Dachelektroni  H13 0080
       Serial number: A2015000000000835161
       Subsystem 5 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
       Component: GEB.F.Heckoef  H16 0815
       Serial number: 94015820
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:27:14
       Part No SW: 4H1 035 465 B    HW: 4H1 035 465
       Component: BO G3 D4 ANC  H03 0150
       Revision: 11000000    Serial number: 0015855
       Coding: 010101
       Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
       Component: BO D4 SLAVE  H51 0180
       Serial number: 02503150029374
    6 Faults Found:
    00529 - Engine Speed Signal Missing
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:27:40
                        Voltage: 14.70 V
                        Temperature: 26.0°C
                        Bin. Bits: 00000100
                        Voltage: 11.00 V
                        Temperature: 17.0°C
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
    03994 - Noise reduction function limitation
                        Fault Frequency: 14
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:27:40
                        Voltage: 14.70 V
                        Temperature: 26.0°C
                        Bin. Bits: 00000100
                        Voltage: 11.00 V
                        Temperature: 17.0°C
                        Bin. Bits: 00000001
                        Bin. Bits: 00000000
    02173 - Rear Right Microphone (R145)
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:27:41
                        Voltage: 14.70 V
                        Temperature: 26.0°C
                        Bin. Bits: 00000100
                        Voltage: 11.00 V
                        Temperature: 17.0°C
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
    02172 - Rear Left Microphone (R144)
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:27:41
                        Voltage: 14.70 V
                        Temperature: 26.0°C
                        Bin. Bits: 00000100
                        Voltage: 11.00 V
                        Temperature: 17.0°C
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
    02171 - Right Center Microphone (R143)
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:27:41
                        Voltage: 14.70 V
                        Temperature: 26.0°C
                        Bin. Bits: 00000100
                        Voltage: 11.00 V
                        Temperature: 17.0°C
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
    02170 - Left Center Microphone (R142)
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:27:41
                        Voltage: 14.70 V
                        Temperature: 26.0°C
                        Bin. Bits: 00000100
                        Voltage: 11.00 V
                        Temperature: 17.0°C
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
    Address 48: Seat, Rear, DS (J876)       Labels: None
       Part No SW: 4H0 959 860 A    HW: 4H0 959 860 A
       Component: MEM-FS-Fond   H06 0158
       Revision: AA000000    Serial number: 00000066689776
       Coding: C01892808500700D0B00392038193A2039203B3B202020
       VCID: 3228F6B46D2E2DDA13-8066
                        Reset counter: 54
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:57:22
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H07 0280
       Revision: --------    Serial number: 0000145082347
       Coding: 011F1E015E0062C202083006
       VCID: 3C34D88CBF6AEBAAC9-8068
                        Reset counter: 122
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:57:22
       Component: EPB-4         H03 0015
       Revision: --------    Serial number: 00000001055140
       ROD: EV_ParkiBrake_VW51.rod
       Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0049
       Coding: 02520220221B0200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
       ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
       VCID: 312AF9B8602816C26A-8064
       Coding: E00300
       Coding: E00300
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E00300
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E00300
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109EY0E7923800
       Coding: 010103010003000001
       VCID: 2B16EBD04A047C1250-807E
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4G0 919 129 C    HW: 4G0 919 129
       Component: NGTV-DVB      H04 0690
       Revision: R0043000    Serial number: 06800800102001
       Coding: 01000400
       VCID: 2D12E5C8741072224E-8078
    Address 5B: Seat,Rear,PS (J877)       Labels: None
       Component: MEM-BFS-Fond  H06 0158
       Revision: AA000000    Serial number: 00000066701142
       Coding: C01896808500700D0B00392038193A2039203B3B382020
                        Reset counter: 54
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:57:22
       Part No SW: 4H0 035 654     HW: 4H0 035 670 P
       Component: H-BNT-EU      H47 0939
       Revision: --------    Serial number: 179E00E7520584
       Coding: 03010000020BFFEFFDF6AB1E00000003000001000000000000
       VCID: 638643F06254F452A8-8036
       Subsystem 1 - Part No: 8R0 060 884 ED
       Component: EUR 2017  2402
       Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
       Component: DU8 D4 SV NB  H63 0060
       Serial number: AUZ8ZDFY900AB50
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000123673
       Component: CD-Database  5571
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:29:13
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 10000000 00000000
                        Bin. Bits: 01000000 00000000
    02612 - Audio Wire Adapter Set
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:29:19
                        Voltage: 14.40 V
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H06 0270
       Revision: --------    Serial number: 0000121325220
       Coding: 010F1E00420062C202083006
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4H0 907 383 N    HW: 4H0 907 383 L
       Component: Anhaenger     H14 0160
       Revision: 7A001001    Serial number: 0356263965
       Coding: 0100010202000000
       Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
       Component: TopView       H05 0220
       Revision: 11001001    Serial number: 82330JF0149179
       Coding: 020E000001010002010102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
       ROD: EV_CamerSysteTopViewAUDI_007.rod
       VCID: 2C14E8CC470A7B2A59-8078
    9617993 - Proximity Camera
              B145C 54 [009] - Missing Calibration / Basic Setting
                        Fault Frequency: 40
                        Reset counter: 122
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:57:21
                        Voltage terminal 30: 14.4 V
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
       Component: HDSG-Modul    H12 0049
       Revision: 10012001    Serial number: 117400553
       Coding: 021004C020
       ASAM Dataset: EV_DeckLidContrUnit 001032
       ROD: EV_DeckLidContrUnit.rod
       VCID: 6FAE3FC0B69C40323C-803A
    0051 - Hall Sensors in Motor 1 for Rear Lid
              B1211 12 [008] - Short to Plus
                        Reset counter: 144
                        Mileage: 57256 km
                        Date: 2018.10.19
                        Time: 15:19:49
                        Voltage terminal 30: 14.57 V
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000149802
       Coding: 200000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 638643F06A54F452A8-8036
    0006 - Front Left Footwell Lighting  Color 2
              B111D 01 [009] - Electrical Failure
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:48:12
                        Control Module temperature: 28 °C
                        Processor load: 34.5 %
                        Color setting Ambient: Red
                        Status terminal 58s: On
    0014 - Rear Left Footwell Lighting  Color 2
              B1121 01 [009] - Electrical Failure
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 16:31:29
                        Control Module temperature: 32 °C
                        Processor load: 37.5 %
                        Status terminal 58s: OFF
    0018 - Rear Right Footwell Lighting  Color 2
              B1123 01 [009] - Electrical Failure
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 16:31:28
                        Processor load: 37.0 %
       Component: TSG HR        H07 0280
       Revision: --------    Serial number: 0000146431913
    Address 7F: Inform. Electr. II (J829)       Labels: None
       Part No SW: 4H0 035 762 N    HW: 4H0 035 762
       Component: H-B-AS        H41 0940
       Revision: --------    Serial number: 020CC0AB000091
       Coding: 03010000020100400100000400001300000000000000000000
       Shop #: WSC 06798 128 28888
       VCID: 312AF9B8682816C26A-8064
       Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
       Component: DU10 RSE  H41 0021
       Serial number: AUZ8ZDC1200WUMF
       Subsystem 2 - Part No SW: 4H0 919 607     HW: 4H0 919 607
       Serial number: AUZ8ZDC1200WUKD
       Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
       Component: E499 BDT 2  H07 0019
       Serial number: 90238KH20000H
       Component: CD-Database  3371
       Subsystem 5 - Part No: 8R0 060 884 ED
    01043 - Control Module; Incorrect Software Version
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:32:13
                        Bin. Bits: 00000000 00011010
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H08 0083
       Revision: 0L0D5015    Serial number: SN130617  0236
       ROD: EV_GSM2x3Mono.rod
       Part No SW: 4H0 919 617     HW: 4H0 919 617
       Component: HeadUpDisplay H17 0023
       Coding: D70000
       ASAM Dataset: EV_HUDContiC7 001025
       ROD: EV_HUDContiC7.rod
       VCID: 6D9225C8BC90B2220E-8038
    Address 84: Night Vision (J853)       Labels:* None
       Part No SW: 4G0 907 547     HW: 4G0 907 547
       Component: NV-ECU-Gen3   H06 0023
       Serial number: 622352400201312
       Coding: 101100
       ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
       ROD: EV_NightVisioGen3AE4AU64X.rod
       VCID: 6B962BD08284BC1210-803E
       Camera For Night Vision System:
       Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
       Component: NV-CAM-Gen3  H03 0006
       Serial number: 623466500F1505000272
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 79160000
       ROD: EV_OnBoardCamerDPC.rod
       Serial number: 00011983066802
       Coding: 766FF2
       ROD: EV_IVBDriveSideFrnt.rod
    0018 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Funktionseinschränkung wegen fehlender CAN-Botschaft]
                        Reset counter: 122
                        Mileage: 57649 km
                        Date: 2018.10.29
                        Time: 15:32:45
       Serial number: 00011983068502
       Coding: 366FF2
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:57:26
    Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
       Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
       Component: IVB           H08 0042
       Serial number: 00011982182302
       Coding: 306F00
       ASAM Dataset: EV_IVBDriveSideRear 001003
       VCID: 2E10E2C47116093A77-807A
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:57:26
       Part No SW: 4H0 907 541 C    HW: 4H0 907 541
       Coding: 7F04010101
       ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
       ROD: EV_AdaptCruisContr2AU64X_002.rod
       VCID: 291A11D848F86E02A2-807C
    Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
       Serial number: 00011982028701
       Coding: 306F00
       ASAM Dataset: EV_IVBPasseSideRear 001003
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 55435 km
                        Date: 2018.09.26
                        Time: 12:57:26
       Part No SW: 4G0 907 107 B    HW: 4H0 907 107
       Component: BV-SG         H29 0038
       Serial number: 000040180205117
       Coding: 01A09B061111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 25021DE824E04A6286-8070
    Address 8F: Pretens. Frt Left
    Address 90: Pretens. Frt Right        Labels:
       VCID: 55E26D28AC001AE2D6-FFFE
       Note: Excessive Comm Errors
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 141070748
       ROD: EV_RDCMA00100_008.rod
    End----------(Elapsed Time: 04:52, VBatt start/end: 14.7V/14.8V)-----------
  5. Likes mattylondon liked this post
  6. #4
    Remove particulate trap for manual chemical remediation of soot and ash accumulation and check PSI sensors, further clean EGR.
    Feb 2018
    Poland
    Thanks a lot for the advice, I was unable to start the regen because the amount of soot was to high. Took the car to a highway and drove around 100 km , the amount of soot dropped. After all I was able to start the Regen with following Access code 27971 .
    Thanks again for your help and advises
  8. Likes Jack@European_Parts, Uwe, mattylondon liked this post
  9. #6
    Glad it worked out for you but keep a close eye on the DPF for becoming cherry red or observe EGT temps with pile up.
