Retrofit Xenon Headlights Golf MK7
Dick.T
C?ID=350787
Hi all, Sure not the right spot to post, however retrofits is not open for me yet.
Retrofitted Xenons on my 2013 MK7 Golf as per :
attachment.php
As far as I can check the connections are correct but the AFS isn't functioning though there is possibility to read out motors in the headlights:
Sunday,28,October,2018,20:11:02:54550
VCDS Version: 18.9.0.1 (x64)
Workshop Code: 052 82536 013366
VIN: WVWZZZAUZDW146901   License Plate: 2-KJK-16
Mileage: 185481km-115252mi   Repair Order: 1
                Address 55: Headlight Range  (7P6 907 357 D)
20:10:46
  IDE03604   Left rear level control system sensor 29.22 %
  IDE03727   Variable left front lighting specified position 10.00 %
  IDE03728   Variable right front lighting specified position 10.00 %
  ENG107365   Left dynamic cornering light value -31.97 °
  ENG103737   Left headlight leveling control value -1023.0 mm
  ENG107367   Left light distribution value 0.00 %
  ENG108468   Right dynamic cornering light value -31.97 °
  ENG102296   Right headlight leveling control value -1023.0 mm
  ENG108470   Right light distribution value 0.00 %
Made a autoscan :
Sunday,28,October,2018,20:11:46:54550
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 13 15 16 17 19 2B 42 44 52 55 5F 69 A5
VIN: WVWZZZAUZDW146901   Mileage: 185481km-115252miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5514
   Revision: 83H22---
   Coding: 01190012045405083000
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 79F3CD98F80C448291-802C
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Coding: 01FA62A120240A720380060001C42980460450C0608094F3F4685024C0
   ROD: EV_Brake1UDSContiMK100IPB_008.rod
   VCID: 7DFBD988EC2478A2BD-8028
   Part No SW: 5Q0 959 435     HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0500
   Revision: 00021000    Serial number: 0211838523
   Coding: 030C0C
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020104202100011105004000101000
   Shop #: WSC 13366 006 82536
   ROD: EV_ACClimaBHBVW37X_002_VW37.rod
   VCID: 366906A489926BFA3C-8062
327941 - Motor for Left Temperature Flap
          B108C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 144
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:21:03
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011310601956
   Coding: 00030946C2C122FB4FE44080B11C0708180A000000000000000000000000
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46897664F972FB7AAC-8012
   Component: WWS    130409  042 0551
   Serial number:         130412185811
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y13M04D10H14M17S23S1
   Coding: 00A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY1306406DM
   Serial number: 00000000000056282587
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 144
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:40:55
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
   Component: ACC3          H08 0390
   Serial number: 08041303030914
   Coding: 00000D00FE0309
   ASAM Dataset: EV_ACCBoschMQB 001021
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 3F876380A6A8AAB2EF-806A
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Serial number: 003M1R02EXZ8
   Coding: 98FCC0C0000000005C5400CF004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4A914254ED6A1F1A48-801E
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667A15041370013
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668A12041340737
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 304 13
   Serial number: 3576700000088CE8CC0G
   Subsystem 4 - Part No SW: -----------    HW: 480 000 504 13
   Serial number: 358670000008B458CC03
   Subsystem 5 - Part No SW: -----------    HW: 480 400 904 13
   Serial number: 3516502AF0FBDE32B1A+
   Subsystem 6 - Part No SW: -----------    HW: 480 400 904 13
   Serial number: 3526502AD0FBDE31720Q
   Subsystem 7 - Part No SW: -----------    HW: 480 400 304 13
   Serial number: 3556502C30FEA21260CH
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 27031308491370
   Coding: 0C00
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 0201AA7495DA075AC0-8056
   Part No SW: 5G0 920 870 A    HW: 5G0 920 870 A
   Component: KOMBI         336 0580
   Coding: 07A501106F841008008F7E03040000
   Shop #: WSC 82536 052 13366
   VCID: 2757DBE05E380272B7-8072
16777012 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
                    Reset counter: 144
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:22:46
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000282345
   Coding: 030100340B087300EF00065E080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 346D3CAC9FEE79EA02-8060
   Component: E221__MFL-DC1  H14 0035
   Serial number: 23130000438170060291
   Coding: 2C0000
   Serial number: 1898680103
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000027319002
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73EFFFB0DA603ED2DB-8026
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 06041301100132
   Coding: 003B1320D000048000001000
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001185799
   Coding: 11
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D7B1988ACA4B8A2FD-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 28031306070861
   Coding: 003B1120DE00048000801000
   VCID: 3E791E84A1A2A3BAE4-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001168150
   Coding: 090000
   Coding: 029A01000B000200
   VCID: 4085607CDB56D54A96-8014
5276144 - Power Output Module for Left Headlamp
          C1081 F0 [137] - Not Coded
                    Reset counter: 144
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:29:20
5276400 - Power Output Module for Right Headlamp
          C1082 F0 [137] - Not Coded
                    Reset counter: 144
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:29:20
5275220 - Headlight
                    Reset counter: 144
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:29:21
13679104 - Local Data Bus
          U10BA 00 [137] - No Communication
                    Reset counter: 146
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:29:20
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 044 B    HW: 5G0 035 044
   Component: MU-H-TN-EU    H41 0388
   Serial number: A329Z0DB000984
   Coding: 02730001FF00000011110001000800101F0202D401000100FF
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1E39FE040162C3BAC4-804A
   Component: ABT_High  H42 0022
   Serial number: VWZ8Z9N2300PBP
   Subsystem 2 - Part No SW: V03 959 801 QN    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Component: Gracenote  --- 1008
          B201A 00 [009] -  -
                    Reset counter: 146
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:34:12
                    Voltage terminal 30: 11.7 V
                    Status_Software_Version_Management-SW_VersMgtInfo: MDUV101/ABT
3073 - Cellular Antenna
          B1053 13 [009] - Open Circuit
                    Reset counter: 144
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:34:10
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 144
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:34:12
                    BAP-BAP_Function_ID: 02
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 144
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:34:12
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 144
                    Mileage: 185356 km
                    Date: 2018.10.27
                    Time: 12:34:12
   Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Component: Anhaenger     H11 0030
   Revision: 6B001003    Serial number: 00000193339620
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 356B01A8949460E235-8060
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0050
   Serial number: 00000048235
   Coding: 0100010001020304000000000100000101
   ROD: EV_MFKBoschAU370.rod
   VCID: 3A711294BD8A8F9AD8-806E
End-------------------------(Elapsed Time: 04:32)--------------------------
I have not YET upgraded my BCM, current lacks the "Byte 02 - 02 Lighting: Bi-xenon w/o light assist".
What could be the cause of the failure of the AFS?
myounus
Northwest UK
C?ID=321059
You need to get yourself verified then you can post on the right section
PetrolDave
Westbury, UK
C?ID=1423
This doesn't look like it belongs in the Hall of Shame (version 18.9.0.1 being used), so maybe it should be moved to New Users and Dick.T encouraged to get his account Verified by the Benevolent Dictator?
langers2k
C?ID=224085
18.9 has already been cracked by the pirates :/
PetrolDave
Westbury, UK
C?ID=1423
If Uwe recognised the signs of a hacked copy usually he would have deleted the scans and added a post commenting on how to get a legal copy and be supported here :thanks:
BTW Dick.T started this thread in the Hall of Shame (no idea why :confused:)
Scratching head. It's possible it was posted in the HoS and I didn't notice that at the time.
Moved to New Users section.
The OP should Get Verified.
Dick.T
C?ID=350787
Because Dick.T did not use his eyes where they are meant for.:banghead: :banghead:
Dick.T
C?ID=350787
Done that : ORDER NUMBER:20219778
myounus
Northwest UK
C?ID=321059
Which headlights have you fitted? Bi-xenon with dtrl?
What model is your vehicle?
Usually in Golf mk7 you require an AJ BCM
Dick.T
C?ID=350787
Can the almighty Uwe move this thread to the retrofits section and clean it up a little because it became a little off topic.
Or should I start a new thread in that section?
Dick.T
C?ID=350787
I have the units with DRL, static/dynamic cornering cornering lights.
Have the following modules:
8K0 941 597 E Starters
3D0 941 329 G AFS Slave modules
4G0 907 697 F DRL Modules
7P6 907 357 D AFS ECU
As earlier said, the BCM in not yet replaced. Lacking the famous byte 02.
Yeah, sorry, I should have done that earlier. Too many windows open all at once.
Dick.T
C?ID=350787
By the way I have 5Q0937085AC which has phisically the pins 22 and 23 for the xenon shutters. Is it necessary to change the BCM before AFS module is activated?
IMHO the AFS is seperately from the BCM since it is accessible for programming. That is why i did not yet change the BCM, I wanted to install the AFS first then go to a friendly garage to change the BCM.
myounus
Northwest UK
C?ID=321059
It is possible to reverse engineer anything, however, we are advising you as per the official VW wiring diagrams and a format that works. If you encounter other issues then it is easier to diagnose and resolve. I've personally installed Bi-Xenon lights a number of times but never got AFS working properly without the correct BCM. On both the GTD and Golf R in the UK they have the AJ BCM which works.
Dick.T
C?ID=350787
Found myself a AJ on E-Bay, have to wait until arrives. somewhere 19 November it will arrive. Then I will take action to swap it at the friendly shop.
myounus
Northwest UK
C?ID=321059
19th November where's it coming from??
downtime
C?ID=280813
One comment on bcm. Even the pins physically are there, they are not getting power as there physical parts missing from the board.
The pins are not needed for AFS. The AFS modules are controlled via can bus. The bcm pins control the xenon shutters.
darkchina811
ITALY
C?ID=333184
go figure. I sent him a PM cause I have an extra AJ on the shelf but got no answer lol.
