Results 11 to 20 of 25
Thread: High Beam Assist retrofit on Golf 7
    Apr 2018
    ITALY
    I was considering the retrofit for the A5 camera, but I would need to replace the windscreen. not gonna happen.
  2. #12
    I have the "lowline" 20 camera and I find the HBA works really well, never been flashed by oncoming drivers and switches back to main beam as soon as they have passed.
    Only change I have done is to lower the speed threshold as 40mph (58kph) was too fast for HBA to work on the narrow single track lanes where I live.
  3. Likes jyoung8607 liked this post
  4. #13
    Oct 2014
    My earlier "lowline" also works pretty well on a PQ35 Octavia. Very occasionally it's slow to react but it's typically tail lights rather than headlights it struggles with.
    I'd check the coding to see if there is anything obvious, ideally checking against another MK7 golf.
    Maybe Italian drivers are just more eager to flash their headlights!
  6. #14
    Apr 2018
    ITALY
    well, we do have a thing for being impatient and just pissed while driving. also, most of the times the code is just a suggestion...
  7. #15
    Apr 2018
    ITALY
    there must be something not properly configured. I tried again and the function is barely usable.
    the HBA never switches off high beams soon enough when a car approaches in the opposite direction. also, it somehow seems to be much more sensitive to street illumination than to car approaching from the front.
    unfortunately there are not a lot of reference scans for taking inspiration.
    guess it will stay off for now
  8. #16
    Apr 2018
    ITALY
    I have permanently disabled the feature, because it just does not kill high beams soon enough when a car approaches me.
    I am considering going back to the non-HBA mirror.
  9. #17
    HBA does seem to work well for some people (including me) but others (like you) find it very slow to return to dipped beam.
    It doesn't seem to have any pattern whether it's good or bad
  10. #18
    Apr 2018
    ITALY
    I would still bet my module 20 is not configured properly, but I don't have other examples to look at. when I reinstall ODIS I will check if it helps.
  11. #19
    Don't know if it helps, but here is the adpmap for my 20 (including coding):
    ;SW:5G0-857-511-D   HW:5G0-857-511 ---  High Beam Assist.
    ;Component:FLA           H04 0002, Coding:01028F6B76765D525220343E01
    ;EV_HighBeamAssisAU37X,001009,EV_HighBeamAssisAU37X.rod
    ;Wednesday,05,October,2016,11:39:15:40444
    ;VCDS Version: Release 16.8.2  Data version: 20160926 DS261.0
    ;VCID: 2B16C7424298CC1A31-807E
    IDE03885-Speed threshold for high beam recommendation off,28 km/h
    IDE03886-Activation speed for high beam assistant,58 km/h
    IDE03887-Location recognition mode,Standard
    IDE03888-Left-/right hand driving,Left
    IDE80016-Analysis 16,3000 ms
    IDE80017-Analysis 17,3000 ms
    IDE80018-Analysis 18,600 ms
    IDE80019-Analysis 19,6000 ms
    IDE80020-Analysis 20,1600 ms
    IDE80021-Analysis 21,2000 ms
    IDE80032-Analysis 32,On
    IDE80033-Analysis 33,On
    IDE80048-Analysis 48,25
    IDE80049-Analysis 49,45
    IDE80050-Analysis 50,13
    IDE80051-Analysis 51,20
    IDE80052-Analysis 52,3
    IDE80053-Analysis 53,9
    IDE80054-Analysis 54,9
    IDE80055-Analysis 55,64
    IDE80056-Analysis 56,28
    IDE80057-Analysis 57,90 km/h
    IDE80058-Analysis 58,64
    IDE80059-Analysis 59,250
    IDE80060-Analysis 60,3
    IDE80061-Analysis 61,2
    IDE80064-Analysis 64,OFF
    IDE80080-Analysis 80,On
    IDE80081-Analysis 81,On
    IDE80096-Analysis 96,100
    IDE80097-Analysis 97,100
    IDE80098-Analysis 98,100
    IDE80099-Analysis 99,On
    IDE80100-Analysis 100,25
    IDE80102-Analysis 102,25
    IDE80128-Analysis 128,On
    IDE80144-Analysis 144,OFF
    IDE80234-ENG110471-Analysis 234-DTC_0x00030E,activated
    IDE80234-ENG110492-Analysis 234-DTC_0x01BE02,activated
    IDE80234-ENG110493-Analysis 234-DTC_0x01BF01 2,activated
    IDE80234-ENG110472-Analysis 234-DTC_0x01C904,activated
    IDE80234-ENG110473-Analysis 234-DTC_0x01D204,activated
    IDE80234-ENG110474-Analysis 234-DTC_0x021401,activated
    IDE80234-ENG110475-Analysis 234-DTC_0x021402 2,activated
    IDE80234-ENG110476-Analysis 234-DTC_0x041200,activated
    IDE80234-ENG110477-Analysis 234-DTC_0x051304,activated
    IDE80234-ENG120023-Analysis 234-DTC_0x05200E,activated
    IDE80234-ENG120034-Analysis 234-DTC_0x052204 3,activated
    IDE80234-ENG120024-Analysis 234-DTC_0x052404 2,activated
    IDE80234-ENG110481-Analysis 234-DTC_0x080400,not active
    IDE80234-ENG110482-Analysis 234-DTC_0x080401 2,activated
    IDE80234-ENG110480-Analysis 234-DTC_0x087303,activated
    IDE80234-ENG120025-Analysis 234-DTC_0x0D7D00 2,activated
    IDE80234-ENG120027-Analysis 234-DTC_0x0D7D01 4,activated
    IDE80234-ENG120028-Analysis 234-DTC_0x0D7D02 5,activated
    IDE80234-ENG120029-Analysis 234-DTC_0x0D7D03 6,activated
    IDE80234-ENG120030-Analysis 234-DTC_0x0D7D04 7,activated
    IDE80234-ENG120031-Analysis 234-DTC_0x0D7D05 8,activated
    IDE80234-ENG120033-Analysis 234-DTC_0x0D7D06 10,activated
    IDE80234-ENG120022-Analysis 234-DTC_0x0D7D07,activated
    IDE80234-ENG120026-Analysis 234-DTC_0x0D7F00 3,activated
    IDE80234-ENG120032-Analysis 234-DTC_0x0D7F01 9,activated
    IDE80234-ENG110485-Analysis 234-DTC_0x0DF800,activated
    IDE80234-ENG110486-Analysis 234-DTC_0x0DF900 2,activated
    IDE80234-ENG110487-Analysis 234-DTC_0x3FD80E,activated
    IDE80234-ENG110488-Analysis 234-DTC_0x3FDB0E 2,activated
    IDE80234-ENG110489-Analysis 234-DTC_0x3FDC0E 3,activated
    IDE80234-ENG110491-Analysis 234-DTC_0x3FE00E 2,activated
    IDE80234-ENG110490-Analysis 234-DTC_0x3FE30E,activated
    Elapsed Time: 00:10
  12. Likes Uwe liked this post
  13. #20
    Apr 2018
    ITALY
    I fu**ed it up, merry christmas
    I connected ODIS (offline) and saw nothing helpful in the coding. So I tried "reset of all adaptations" and now the module says it is not parameterized.
    this will need to be fixed by ODIS ONLINE, if it doesn't get mad because the module was not in my car from the factory.
