High Beam Assist retrofit on Golf 7
darkchina811
ITALY
C?ID=333184
I found a bargain for an almost new frameless interior mirror with auto-dimming and HBA support. I could not help but starting another retrofit project.
Now I have a simple auto-dimming mirror, so the wiring needs to be slightly modified. The current mirror uses four wires: switched +12V, GND, reverse signal and roof light signal.
The new mirror, part number 3G0 857 511 AE, has 7 populated positions into the 8pin connector. I know that four wires are: +12V, GND and Extended CAN.
(reverse signal is read from CAN, no need for wire).
What are the other 3 pins for? Does anybody have a WD for the mirror, from any MQB car? I downloaded Golf 2018 WDs from erwin but High Beam Assist (PR Code 8G1) is documented only with the bigger camera on the windshield, the camera used for other traffic-assist features.
the mirror does basic HBA and will show up at address 20 into the Gateway install list. also, since it is now a module on the network, shouldn't it be powered by permanent +12V instead of switched?
darkchina811
ITALY
C?ID=333184
apologies, I found the WD by looking harder into what I got from erwin lol.
it's five wires: +12V (switched, this is confirmed), GND, Extended CAN and the wire from the roof light.
I'll report back after I pull the CAN twisted pair. I need a leap of faith cause I already put A-Pillars back with their nasty clips. goddamnit.
BTW the feature is called MBA Main Beam Assist into the WD.
darkchina811
ITALY
C?ID=333184
I installed the mirror today. boy, I hate those A-pillar clips. it took me longer to remove the A-pillar than to pull the pair and terminate it.
the mirror came with all the coding bits at 0. with the experimental coding I was able to set BYTE 0 and 1 to 01, which mean halogen low and high beams.
I don't know how to set BYTE 3, which is apparently the car type; regular coding does not include Golf 7 and experimental coding is... in german.
I don't know how to change all remaining bytes but I doubt they all stay at zero.
I enabled what's needed in the BCM and got the menu in the radio, and I get the high beam symbol with the "A" (AUTO) when pushing the lights stalk. however, on a small test drive high beams never auto-engaged.
does anybody have further info, or a more complete coding label for the mirror?
here is actual scan. ignore the error on the gateway.
Saturday,03,November,2018,17:40:48:06888
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Workshop Code: 011 01357 000000
VIN: WVWZZZAUZHW0xxxxx   License Plate:
Mileage: 24196km-15034mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 18 19 20 42 44 52 5F 65
VIN: WVWZZZAUZHW0xxxxx   Mileage: 24196km-15034miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2833
   Revision: R7H25---
   Coding: 0119003223241D082000
   Shop #: WSC 21385 002 1048576
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B833BBF03045EDF5B7-803F
   CAN Converter 01:
Readiness: 0110 0001
   Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
   Component: ESC           H62 0637
   Revision: 00000000    Serial number: 91596000011507
   Coding: 01FA6AA1242219704779060841C62980562498E2608294730020500A400203
   Shop #: WSC 131071 102 209715
   VCID: 74B120C35E3A81278AD-8021
   Part No SW: 5G0 907 044 BM    HW: 5G0 907 044 BM
   Revision: 00001K08
   Coding: 00020004104111011005004000101022
   Shop #: WSC 00028 028 00068
   VCID: 73B323DF5B34861F937-8027
   Serial number: 01061633700891
   Coding: 00000946C20102FB0B244080B11407281400000000000000000000000000
   Shop #: WSC 01357 011 00000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 045170030E9AB1A7BAD-8051
   Component: WWS    160522  043 0551
   Serial number:         160601172917
   Coding: 0E4DFD
   Component: RLHS  042 0105
   Serial number: S5Y17M06D01H13M38S50
   Coding: 06A8DD
   Serial number: 000000000ZY15028208R
   Serial number: 00000000000030139763
   Part No SW: 5Q0 919 298 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0042
   Revision: --------    Serial number: 61131402901978
   Coding: 0031161041
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 40D9BC135A026D87DE5-8015
   Serial number: 003F6R1V1W4Y
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41DFB9175108648FD1B-8015
   Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 35767000000432B44C1Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 358670000008B4C4DB17
   Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3516502BB205729313D3
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3526502AF2076340F201
   Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
   Serial number: 35565029B21160C1025X
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 13061608490829
   Coding: 0400
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0D4755275DD0F0EFE53-8059
   Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
   Component: KOMBI         303 8311
   Coding: 03A501802290000D02083B041400000000000000
   VCID: 26150A8BD866A3B7C49-8073
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
   Component: STH-MQB       006 0069
   Coding: 1309
   VCID: 3537DDC715C0D82F7D3-8061
   Component: R64 D208L  004 0401
   Serial number: 00000000000000180382
   Revision: --------    Serial number: 0004271482
   Coding: 030100043F085700FB000248080F00010001050000000000000000000000
   Shop #: WSC 12345 123 28888
   VCID: 7CA108E3766AC967C2D-8029
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001142480026234
   Coding: 28FFFF
   Serial number: 8442320304
1541 - Data Set Implausible
          B2012 00 [009] -  -
          [unplausibler Datensatz: Funktion "erweiterte Anzeige StartStopp"]
                    Reset counter: 21
                    Mileage: 24194 km
                    Date: 2018.11.03
                    Time: 00:10:53
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 AE    HW: 3G0 857 511 AE
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0101000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   Serial number: 300516EEU02971
   Coding: 003B0220D000040100001000
   VCID: 43D3B31F4B14769FC37-8017
   Coding: 8307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCEFB3CDE3757901-806F
   Serial number: 280516EER24731
   Coding: 003B0020DE00040100801000
   VCID: 42DDB61B540E7F97C81-8017
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      710 0744
   Coding: 02730000AA0000005111000100080A001F0200D40120010003
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2C01F8A3C68A99E712D-8079
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJT00QNA
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 40000000018766
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E0C31EBAC1274AD-8061
End----------(Elapsed Time: 01:47, VBatt start/end: 12.4V/12.3V)-----------
PetrolDave
Westbury, UK
C?ID=1423
Did you go fast enough for the HBA to engage? Check the speed settings in the adaptation channels of the #20 module.
darkchina811
ITALY
C?ID=333184
ah, that might be. I'll tweak and test drive again.
darkchina811
ITALY
C?ID=333184
it works, although I don't fully understand the assistant's logic.
it appears like it has to be completely dark, I mean not even street illumination. for who has the module A5 camera there are two light-intensity adaptations to be tweaked that I do not find in the list of my module 20.
guess it is what it is.
there are some examples of cars with HBA by module 20 but they use the older mirror (with frame) and it has different HW/SW and coding lenght...
siLc
Tallinn, Estonia
C?ID=330192
Your guess is correct. HBA is a function to be used on extra-urban roads, which are unlit by street lights. No reason to use the main beams if the road is already lit up. Even A5 doesn't switch to main beams when driving on an unlit road if there are visible street lights far away, which actually is a hindrance.
darkchina811
ITALY
C?ID=333184
a couple of days ago I drove one hour on the highway. I ended up deactivating this stupid assistant like after ten minutes.
whenever a car approaches in front of me, the high beams never switch back to lows soon enough, and people flashes me all the time.
I am kind of disappointed. pretty useless.
golfi_vend
Tartu, Estonia
C?ID=195131
I'm very happy with my car HBA. Although my car has A5 camera for assistant, which by many feedbacks works better than mirror mounted one. It has drawback like pedestrian road light intervenes, but You have to be aware of these "features" and it will work fantastically. I also have SEAT LED lights and no car has ever flashed me during using this feature. And during dark time(Autumn, Winter and Spring), like now, I drive a lot in the dark.
darkchina811
ITALY
C?ID=333184
I was considering the retrofit for the A5 camera, but I would need to replace the windscreen. not gonna happen.
PetrolDave
Westbury, UK
C?ID=1423
I have the "lowline" 20 camera and I find the HBA works really well, never been flashed by oncoming drivers and switches back to main beam as soon as they have passed.
Only change I have done is to lower the speed threshold as 40mph (58kph) was too fast for HBA to work on the narrow single track lanes where I live.
langers2k
C?ID=224085
My earlier "lowline" also works pretty well on a PQ35 Octavia. Very occasionally it's slow to react but it's typically tail lights rather than headlights it struggles with.
I'd check the coding to see if there is anything obvious, ideally checking against another MK7 golf.
Maybe Italian drivers are just more eager to flash their headlights!
darkchina811
ITALY
C?ID=333184
well, we do have a thing for being impatient and just pissed while driving. also, most of the times the code is just a suggestion...
darkchina811
ITALY
C?ID=333184
there must be something not properly configured. I tried again and the function is barely usable.
the HBA never switches off high beams soon enough when a car approaches in the opposite direction. also, it somehow seems to be much more sensitive to street illumination than to car approaching from the front.
unfortunately there are not a lot of reference scans for taking inspiration.
guess it will stay off for now :banghead:
darkchina811
ITALY
C?ID=333184
I have permanently disabled the feature, because it just does not kill high beams soon enough when a car approaches me.
I am considering going back to the non-HBA mirror.
PetrolDave
Westbury, UK
C?ID=1423
HBA does seem to work well for some people (including me) but others (like you) find it very slow to return to dipped beam.
It doesn't seem to have any pattern whether it's good or bad :confused:
darkchina811
ITALY
C?ID=333184
I would still bet my module 20 is not configured properly, but I don't have other examples to look at. when I reinstall ODIS I will check if it helps.
PetrolDave
Westbury, UK
C?ID=1423
Don't know if it helps, but here is the adpmap for my 20 (including coding):
;SW:5G0-857-511-D   HW:5G0-857-511 ---  High Beam Assist.
;Component:FLA           H04 0002, Coding:01028F6B76765D525220343E01
;EV_HighBeamAssisAU37X,001009,EV_HighBeamAssisAU37X.rod
;Wednesday,05,October,2016,11:39:15:40444
;VCDS Version: Release 16.8.2  Data version: 20160926 DS261.0
;VCID: 2B16C7424298CC1A31-807E
IDE03885-Speed threshold for high beam recommendation off,28 km/h
IDE03886-Activation speed for high beam assistant,58 km/h
IDE03887-Location recognition mode,Standard
IDE03888-Left-/right hand driving,Left
IDE80016-Analysis 16,3000 ms
IDE80017-Analysis 17,3000 ms
IDE80018-Analysis 18,600 ms
IDE80019-Analysis 19,6000 ms
IDE80020-Analysis 20,1600 ms
IDE80021-Analysis 21,2000 ms
IDE80032-Analysis 32,On
IDE80033-Analysis 33,On
IDE80048-Analysis 48,25
IDE80049-Analysis 49,45
IDE80050-Analysis 50,13
IDE80051-Analysis 51,20
IDE80052-Analysis 52,3
IDE80053-Analysis 53,9
IDE80054-Analysis 54,9
IDE80055-Analysis 55,64
IDE80056-Analysis 56,28
IDE80057-Analysis 57,90 km/h
IDE80058-Analysis 58,64
IDE80059-Analysis 59,250
IDE80060-Analysis 60,3
IDE80061-Analysis 61,2
IDE80064-Analysis 64,OFF
IDE80080-Analysis 80,On
IDE80081-Analysis 81,On
IDE80096-Analysis 96,100
IDE80097-Analysis 97,100
IDE80098-Analysis 98,100
IDE80099-Analysis 99,On
IDE80100-Analysis 100,25
IDE80102-Analysis 102,25
IDE80128-Analysis 128,On
IDE80144-Analysis 144,OFF
IDE80234-ENG110471-Analysis 234-DTC_0x00030E,activated
IDE80234-ENG110492-Analysis 234-DTC_0x01BE02,activated
IDE80234-ENG110493-Analysis 234-DTC_0x01BF01 2,activated
IDE80234-ENG110472-Analysis 234-DTC_0x01C904,activated
IDE80234-ENG110473-Analysis 234-DTC_0x01D204,activated
IDE80234-ENG110474-Analysis 234-DTC_0x021401,activated
IDE80234-ENG110475-Analysis 234-DTC_0x021402 2,activated
IDE80234-ENG110476-Analysis 234-DTC_0x041200,activated
IDE80234-ENG110477-Analysis 234-DTC_0x051304,activated
IDE80234-ENG120023-Analysis 234-DTC_0x05200E,activated
IDE80234-ENG120034-Analysis 234-DTC_0x052204 3,activated
IDE80234-ENG120024-Analysis 234-DTC_0x052404 2,activated
IDE80234-ENG110481-Analysis 234-DTC_0x080400,not active
IDE80234-ENG110482-Analysis 234-DTC_0x080401 2,activated
IDE80234-ENG110480-Analysis 234-DTC_0x087303,activated
IDE80234-ENG120025-Analysis 234-DTC_0x0D7D00 2,activated
IDE80234-ENG120027-Analysis 234-DTC_0x0D7D01 4,activated
IDE80234-ENG120028-Analysis 234-DTC_0x0D7D02 5,activated
IDE80234-ENG120029-Analysis 234-DTC_0x0D7D03 6,activated
IDE80234-ENG120030-Analysis 234-DTC_0x0D7D04 7,activated
IDE80234-ENG120031-Analysis 234-DTC_0x0D7D05 8,activated
IDE80234-ENG120033-Analysis 234-DTC_0x0D7D06 10,activated
IDE80234-ENG120022-Analysis 234-DTC_0x0D7D07,activated
IDE80234-ENG120026-Analysis 234-DTC_0x0D7F00 3,activated
IDE80234-ENG120032-Analysis 234-DTC_0x0D7F01 9,activated
IDE80234-ENG110485-Analysis 234-DTC_0x0DF800,activated
IDE80234-ENG110486-Analysis 234-DTC_0x0DF900 2,activated
IDE80234-ENG110487-Analysis 234-DTC_0x3FD80E,activated
IDE80234-ENG110488-Analysis 234-DTC_0x3FDB0E 2,activated
IDE80234-ENG110489-Analysis 234-DTC_0x3FDC0E 3,activated
IDE80234-ENG110491-Analysis 234-DTC_0x3FE00E 2,activated
IDE80234-ENG110490-Analysis 234-DTC_0x3FE30E,activated
Elapsed Time: 00:10
darkchina811
ITALY
C?ID=333184
I fu**ed it up, merry christmas :banghead:
I connected ODIS (offline) and saw nothing helpful in the coding. So I tried "reset of all adaptations" and now the module says it is not parameterized.
this will need to be fixed by ODIS ONLINE, if it doesn't get mad because the module was not in my car from the factory.
