Results 1 to 3 of 3
Thread: Stock coding for byte 18 in central electronics for a 2016 VW GLI
    New User
    Feb 2015
    I'm looking for the original coding for a 2016 NAr GLI with xenon headlights and LED DRLs. The auto scan shows "00", which apparently is not the true value.
    Trying to go back to original coding.
    The DRLs are not turning on under any circumstances, and there's a bulb out warning for the front side lights on both sides. Seems as if it's currently set up for non-xenon models.
    Saturday,27,October,2018,10:31:52:27490
    VCDS Version: 18.9.0.2
    VIN: 3VW4T7AJ0GM235687   License Plate:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52
              55 5F 62 72 75
    VIN: 3VW4T7AJ0GM235687   Mileage: 49700km-30882miles
    Address 01: Engine (J623-CPPA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 071 AT    HW: 06K 907 425 C
       Component: R4 2.0l TFS   H13 4876
       Revision: --H13---
       Coding: 001D0012242400171000
       Shop #: WSC 00066 000 00293
       ASAM Dataset: EV_ECM20TFS02006K906071AT 001005
       ROD: EV_ECM20TFS02006K906071AT.rod
       VCID: 7DDF2BB2EC9A0CA2BE-8028
       Part No SW: 02E 300 063 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4907
       Revision: 06253104    Serial number: 00001506140334
       VCID: 236B3DCAE2BE9A52E8-8076
       Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
       Component: ESP MK60EC1   H46 0174
       Revision: 00H46001
       Coding: A14B600C492500FF851106EC922000412118F06A
       Shop #: WSC 00066 123 12345
       VCID: 74C90E96D7D04DEAC1-8020
       Revision: 00092000    Serial number: 0374256810
       Coding: 030C0C
       Shop #: WSC 00066 000 00018
       ROD: EV_KESSYPQ35G_A02_VW36.rod
       VCID: 3753F99A8E26E6F224-8062
       Part No SW: 1K8 907 044 AR    HW: 1K8 907 044 AR
       Component: Climatronic   H05 0304
       Revision: 00001K02
       Coding: 0050019002
       Shop #: WSC 00066 790 00318
       VCID: 7F23D1BAE6961EB2AC-802A
       Part No SW: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
       Component: BCM PQ35 H+   122 0183
       Revision: BL122001
       Coding: E7200A3E902B06D44188008024000DCC0174000845A08DB2E4842000A040
       VCID: 7DDF2BB2E49A0CA2BE-8028
       Component: RLS 070715 05  54  0403
       Coding: 02300A
                000 -  -  - Intermittent
                        Reset counter: 230
                        Mileage: 48842 km
                        Date: 2018.10.16
                        Time: 14:00:12
                            Term 15 Off
                        Voltage: 12.00 V
       Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0479
       Revision: --------    Serial number: 39331519700470
       Coding: 0071155011
       ASAM Dataset: EV_EPHVA18VW364GP00 001006
       VCID: 364DF49E892C1FFA3F-8062
    Address 15: Airbags (J234)       Labels:* 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    001 0207
       Serial number: 003RXM00PA3.
       Coding: 8CCCF000000000005000001AC20800000065
       Shop #: WSC 00066 790 00016
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411_VW32.rod
       VCID: 63EB7DCA6A3EDA52A8-8036
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH000000000003BO7X
       Coding: 30314C
       Subsystem 2 - Part No SW: -----------    HW: 480 002 506 15
       Serial number: 3570000000039729841F
       Subsystem 3 - Part No SW: -----------    HW: 480 002 506 15
       Serial number: 35800000000DAB19841U
       Subsystem 4 - Part No SW: -----------    HW: 480 021 407 15
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001C51BB2F13631
       Subsystem 5 - Part No SW: -----------    HW: 480 021 407 15
       Component: SideSensor_Pr  000 0148
       Serial number: 3520001C51BB2F1421E4
       Subsystem 6 - Part No SW: -----------    HW: 480 020 807 15
       Component: FrontSensor_D  000 0189
       Serial number: 3550001B11B2C52542A.
       Subsystem 7 - Part No SW: -----------    HW: 480 020 807 15
       Component: FrontSensor_P  000 0189
       Serial number: 3560001B11B2C525172W
       Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20150702101815
       Coding: 0012440008
       ROD: EV_SMLSNGVOLWSR8C.rod
       Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H03 0102
       Serial number: 29150001070060065212
       Coding: B1FFFF
       Part No SW: 5C6 920 985 C    HW: 5C6 920 985 C
       Component: KOMBI         H04 1009
       Coding: 271C010000
       VCID: 3245C88E654403DA13-8066
       Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1663
       Revision:   H56       Serial number: 29071503000204
       Coding: 351032
       VCID: 72C5088EADC443DAD3-8026
       Component: IMMO          H04 1009
       Coding: 000007
       VCID: 6AF510EE8D148B1A6B-803E
       Revision: 00000000    Serial number: 15000155339002
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 3041C2866B4831CA65-8064
       Component: HRE_Master    H11 0071
       Serial number: 0372939727
       Coding: 02011102
       Shop #: WSC 00066 790 00018
       ROD: EV_HREntryHella_VW32.rod
       VCID: 3C59E6B6B700C5AAC9-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H11 0071
       Serial number: 0372995197
       Coding: 020111
       Revision: 13110009    Serial number: 0009900850
       Coding: 0404BD
       Shop #: WSC 00066 790 00083
       VCID: 5B9B452A524EE292E0-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Serial number: 14102587150801175139
       Coding: 800000
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 306    3501
       Revision: 00H22000
       VCID: 3957FFA27032F082D2-806C
       Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
       Component: KonzernAmp10K H08 6831
       Revision: --------    Serial number: EAA098C0063981
       VCID: 28712AE65398790ABD-807C
       Component: EZE_2         H56 1663
       Coding: 01030100
       VCID: 6FC301FABEF66E323C-803A
       Subsystem 1 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
       Component: J245 PS41.402  H03 0004
       Serial number: 0000FST000ANA8F00000
       Coding: 180000
       Revision: 15110009    Serial number: 0009911938
       Coding: 0404BC
       VCID: 5C9946365740E5AAE9-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14102586150724085220
       Coding: 800000
       Component: AFS-ECU       H05 0111
       Coding: 081200010B000200
       Shop #: WSC 01383 790 50316
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
       Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
       Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0156
       Serial number: 000003554140540
       Coding: 02630102C24232107F1606000000
       ASAM Dataset: EV_OCULow 002009
       ROD: EV_OCULow_002.rod
       VCID: 14096E16FF10EDEA61-8040
    9458451 - Cellular Antenna
              B1053 13 [008] - Open Circuit
                        Reset counter: 244
                        Time: 00:00:00
    End-------------------------(Elapsed Time: 03:17)--------------------------
    Nov 2018
    Resurecting an old thread. I have the same issue. Does any with 2012-2014 GLI Autobahn or Edition 30 have the correct code for byte 18? Note: an autoscan will not show the correct value. "00" in byte 18 is a place holder, the value everyone is searching for is shown in the drop down tab below byte 18.
    OP: were you able to solve your issue?
    Dec 2016
    Amsterdam
    00 means the light configuration is not equal to any of the available 'presets' selectable by picking a value for that byte. Rather it is a light configuration loaded directly into the BCM. There is no way to return to stock by selecting one of the presets (if lucky you can get close to what it was regarding functionality, maybe even fault-code-free). If you want to revert to stock, have a dealer or someone else with ODIS restore the control unit, or get a tool that can directly write to the BCM EEPROM, that last case provided you saved the original EEPROM values.
    Current:
