- Joined
- Jan 22, 2016
- Messages
- 28
- Reaction score
- 14
- Location
- Netherlands
- VCDS Serial number
- C?ID=122818
Hi there,
I would like some help with a problem I induced myself to my 2015 A3 Etron.
Some months ago I did some trial and error in the adaptations of the Information Electronics, to maybe use some hidden goodies in it. But no success.
Probably due to one or more settings that I messed up my data connection for Audi connect doesn’t work anymore.
I have been trying for a long time now, but I cant find what I did wrong.
So I would be very grateful for some advice on which parameters in Information Electronics (or Telematics or CAN Gateway) could be the cause for the data connection not working anymore.
The menu for settings of Telephone shows the item Connections and in there the item to switch on the Data module. But when I press that nothing happens.
The system does not see the Sim card in the MMI unit. It is a valid card that I normally use daily in my phone. When I insert the card no reaction from the system like asking for the PIN.
Here are the results of my recent scan.
And these are the present settings in adaptations.
I compared the scan to a scan I made shortly after I bought the car and all codes are still the same. Only changes I made are for the anti theft system I have added.
I have no log of the settings in adaptations from when I bought the car so I cannot compare the changes. I know: not very intelligent. That is why I ask for this help.
There are two other things to mention but I don’t think they can be the cause of my problem.
One is that I have added a surround view system from SZDalos on Aliexpress. It is connected in parallel to the Can lines on the MMI system. I could think that in some way this could influence the MMI system, but the MMI works fine. Only problem is with the SIM card. The surround view system is very good, by the way.
The other possibility is that by coincidence in the same period the module in the MMI that reads the SIM card has broken down. If anyone knows how I could test that, I would do that. The measurement readout in the Telematics and in the Information Electronics module shows the external SIM as not available.
Sorry for the long story, but as I said I have been chewing on this for a long time.
I hope that someone can help me solve this.
Groet, Ron
Thursday,25,October,2018,18:51:58:31113
VCDS Version: 18.9.0.2 (x64)
VIN: WAUZZZ8V7GA092145 License Plate:
Mileage: 29659km-18429mi Repair Order:
Chassis Type: 8V-AU37 (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 55 5F
75 8C A5 BB BC C6
VIN: WAUZZZ8V7GA092145 Mileage: 29659km-18429miles
8C-Hybrid Battery -- Status: Malfunction 0010
C6-Batt. Chrg. -- Status: Malfunction 0010
Address 01: Engine (J623-CUKB) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AF HW: 04E 907 309 F
Component: 1.4l TFSI hy H22 2660
Revision: X3H22---
Coding: 021D0012636401083000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM14TFS01104E906023AF 005006
ROD: EV_ECM14TFS_005.rod
VCID: 64CD51DB6F22366A51-8030
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DD 300 045 K HW: 0DD 927 770 B
Component: GSG DQ400E H31 1121
Revision: 00031033 Serial number: TFK01510290350
Shop #: WSC 00099 780 00200
ASAM Dataset: EV_TCMDQ400021 001001
ROD: EV_TCMDQ400021_VW37.rod
VCID: 2F67EEF77664C5327C-807A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 907 379 AK HW: 5Q0 907 379 H
Component: ESC H31 0809
Revision: 00000000 Serial number: 63185000000608
Coding: 12F140A23829326E0378060441C82948021C4CC0608294F5F8A150788608
ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
ROD: EV_Brake1UDSContiMK100OMG_001.rod
VCID: 050B6C5F8458AF62E6-8050
32832 - Switch for Electric Parking Brake
C100C 07 [032] - Mechanical Failure
Revision: 00021000 Serial number: 0386830410
Coding: 030C0C
VCID: 3A71CFA3BD26109ADB-806E
Part No SW: 8V0 820 043 G HW: 8V0 820 043 G
Component: AC Automat H05 0040
Revision: 20010000 Serial number: 00000000785477
Coding: 0300000000000000000000000000100001000000
ASAM Dataset: EV_AirCondiFrontRDWAU37X 001015
ROD: EV_AirCondiFrontRDWAU37X.rod
VCID: 3669DB93893EF4FA3F-8062
Subsystem 1 - Part No SW: 12E 963 231 F HW: 12E 963 231 F
Component: J848 HV-PTC H09 0206
Serial number: LM153223003807000433
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0003
Serial number: 3B1987D7000000000001
Subsystem 3 - Part No SW: 12E 820 803 E HW: 12E 820 803 E
Component: J842 eKK H02 0005
459030 - Invalid Data Received From Electric A/C Compressor
U046C 00 [040] - -
Mileage: 29634 km
Date: 2018.10.21
Time: 18:58:27
Unlearning counter according OBD-OBD Parameter: 40
Compressor shut-off requirement: Shut-off from Engine Control Module (ECM) via CAN
Compressor status: global-A/C compressor release status: transmitted
Compressor status: global-A/C compressor: target speed: 0 /min
Compressor status: global-A/C compressor: actual speed: Measured value not available
Compressor status: global-A/C compressor: function status: Air conditioner compressor off
Compressor status: global-A/C compressor error indicator: not active
Compressor status: global-A/C compressor: veh. elec. syst. volt.: OK
Compressor status: global-A/C compressor: inverter temperature: Measured value not available
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AR HW: 5Q0 937 084 AM
Component: BCM MQBAB M+ H24 0175
Serial number: 01061532000615
Coding: 04051D46C2D506FD438C5004B11407A8081E000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 0815656BB34AB20A9D-805C
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 150808 042 0580
Serial number: 151102160601
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 60971829
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 02 09 2015 00001415
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0312
Serial number: 000000000ZY112370VBD
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000058693429
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39491530000173
Coding: 1030360011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 4797A657FED47D7254-8012
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 P HW: 5Q0 907 567 P
Component: ACC3 H10 0100
Serial number: 25111503032432
Coding: 003E1701FE0309
ASAM Dataset: EV_ACCBoschMQB 001024
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 4895A56BF3CA720A5D-801C
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR01HXTI
Coding: 98FCC0000C2000009C5400CA004800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 50A58D0B0B9ABACA05-8004
Subsystem 1 - Part No SW: ----------- HW: 480 002 011 15
Serial number: 357000000005BC21C71N
Subsystem 2 - Part No SW: ----------- HW: 480 002 011 15
Serial number: 35800000000C9C21C71T
Subsystem 3 - Part No SW: ----------- HW: 480 401 711 15
Serial number: 35100029B1DBD61560DE
Subsystem 4 - Part No SW: ----------- HW: 480 401 711 15
Serial number: 3520002AD1DBD6124213
Subsystem 5 - Part No SW: ----------- HW: 480 400 611 15
Serial number: 3550002AB1D25F01E135
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 810 15
Component: PedP_Sensor_D 001 6149
Serial number: 2280002A11D3F972217%
Subsystem 7 - Part No SW: ----------- HW: 480 402 710 15
Component: PedP_Sensor_P 001 6149
Serial number: 2290002C71D3F972C17I
Subsystem 8 - Part No SW: ----------- HW: 480 002 710 15
Component: PedPSensor_D2 001 0887
Serial number: I0M0000000055A7D7618
Subsystem 9 - Part No SW: ----------- HW: 480 002 710 15
Component: PedPSensor_P2 001 0887
Serial number: I0N0000000057A7D761B
Part No SW: 8V0 953 521 GK HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 31101508491449
Coding: EC18
ASAM Dataset: EV_SMLSKLOMQB 020001
VCID: 0913606FA840CB0282-805C
Part No SW: 8V0 920 872 K HW: 8V0 920 872 K
Component: KOMBI H03 6423
Coding: 078D0C186F9400080D83EE101200000000000000
Shop #: WSC 55783 001 104857
VCID: 458BAC5FC4D86F62A6-8010
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 E HW: 5QE 907 530 A
Component: GW MQB EV 312 3245
Revision: -------- Serial number: 09111510520191
Coding: 0201001726F200005B001218580000000001010100010000000000000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013_VW37.rod
Subsystem 1 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 16 11 2015 F0043938
Subsystem 2 - Part No SW: 5QE 915 181 HW: 5QE 915 181
Component: J367-BDMHella H04 8050
Serial number: 3627298203
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 D HW: 5QE 909 059 B
Component: EBKV H14 0182
Serial number: 085430011005
Coding: 03720100331900030002050500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
ROD: EV_BrakeBoostBoschMQBOMG_003.rod
VCID: 4FA78E7716A4A5321C-801A
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861241115232654
222976 - Brake Booster; Brake Pedal Travel Excessive
C1214 00 [032] - -
Mileage: 28312 km
Date: 2018.08.20
Time: 16:49:00
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000251699007
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 346DE19B9F42E6EA01-8060
Component: TSG FS 020 0041
Serial number: 300915BIT21884
Coding: 001C9F204000040000001003
Shop #: WSC 06385 790 00021
VCID: 438FB247CAEC515288-8016
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: D302
VCID: 448DB15BCFE2566AB1-8010
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 D HW: 5G0 907 080 D
Component: VW370P3815010 H06 4492
Revision: 00H06000
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM09550115G0907080D 001018
ROD: EV_DMCM09550115G0907080D.rod
VCID: 285505EB538A920ABD-807C
Component: TSG BFS 020 0041
Serial number: 081015BJ718517
Coding: 001C97204000040000001003
Shop #: WSC 55783 001 1048576
VCID: 4281B743D5F6585A83-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 011A00002B230200
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
VCID: 3F87BEB7A60435B2EC-806A
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 035 F HW: 8V0 035 035 B
Component: MU-H-LN-EU H45 0401
Serial number: A301K0F7558834
Coding: 01739301FF0A000021110001000A02132F000105010001009E
ROD: EV_MUHig6C3HBAS_AU37.rod
Subsystem 1 - Part No SW: V03 959 800 QA HW: -----------
Component: ECE 2016 --- 0134
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY204FFZ
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000005101500030112
Component: Gracenote --- 1010
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 284 C HW: 5QE 035 284 C
Component: OCULowMQBEU 012 0715
Coding: 0173930110809A0100F800000000
ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5Q0 915 182 C HW: 5Q0 915 182 C
Component: BECM H05 0752
Serial number: T7250045
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006037
ROD: EV_BECM09620115Q0915182.rod
VCID: 336FE2879A4CE1D218-8066
Battery Junction Box:
Subsystem 1 - Part No SW: 5Q0 915 250 D HW: 5Q0 915 250 D
Component: BJB H27 0240
Cell module: control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D1 H14 0472
Serial number: V013C1590320064
Cell module: control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D2 H14 0472
Serial number: V013C1590320075
Cell module: control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D3 H14 0472
Serial number: V013C1590330432
Cell module: control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D4 H14 0472
Serial number: V013C1590330161
Cell module: control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D5 H14 0472
Serial number: V013C1590330431
Cell module: control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D6 H14 0472
Serial number: V013C1590330162
Cell module: control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D7 H14 0472
Serial number: V013C1590330164
Cell module: control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D8 H14 0472
Serial number: V013C1590330429
26717 - Battery Charger Input
P0D80 00 [036] - Open Circuit
Mileage: 28312 km
Date: 2018.08.20
Time: 13:08:57
Pack Voltage: 387.6 V
Pack Current: -0.00 A
Isolation Resistance: 5080 kOhm
Maxumum charge current limit: 3 A
Maximum discharge current limit: 330.0 A
Contactor Voltage: 0 V
OBD unlearned counter: 40
Crash status: 00
Pilot Line Status: 00
Fuse Status: 00
(Minus) Contactor Status: 00
(Plus) Contactor Status: 00
Terminal 15 status: 00
Max Cell Temperature: 24 °C
Min Cell Temperature: 24 °C
Air inlet temperature: 24 °C
Air outlet temperature: 24 °C
LV Battery Voltage: 12.1 V
Min.cell voltage: 4.038 V
Max.cell Voltage: 4.042 V
Max.cell SOC: 94 %
Min.cell SOC: 94 %
Hybrid Battery Pack Remaining Life: 94.9 %
Max Charge Pack Current(10s duration): 0 A
Max Discharge Pack Current(10s duration): 0.0 A
Max Pack Voltage(10s duration): 386 V
Min Pack Voltage(10s duration): 386 V
Max.cell Voltage(10s duration): 4.043 V
Min.cell Voltage(10s duration): 4.038 V
Accelerator Pedal Position D: 14.1 %
Calculated LOAD Value: 0.0 %
Engine coolant temperature: 23 °C
Engine RPM: 0.00 /min
Vehicle Speed Sensor: 0 km/h
Ambient Air Temperature: 215 °C
Hybrid Battery Pack Remaining Life: 94.90 %
control module system voltage: 12.100 V
absolute load: 0.0 %
Time After Engine Start: 0 s
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000464374
Coding: 0101010001010303000500000100000100
ROD: EV_MFKBoschAU370.rod
VCID: 3C7DC9BBB7122EAAC9-8068
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 271015BJP11072
Coding: 000C97204000040000001002
Component: TSG HBFS 020 0041
Serial number: 271015BJP11047
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 AA HW: 5QE 915 682 AA
Component: OBC KOSTAL H61 3017
Revision: -------- Serial number: 1411150KD001PA
Coding: 115068203000
ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
VCID: 0C1D597BA732DE2AB9-8058
2097152 - Battery Management
P33EB 00 [008] - Read Event Memory
Reset counter: 204
Mileage: 29634 km
Date: 2018.10.21
Time: 18:58:23
2097696 - Charging Socket A for AC Connection
P31C7 00 [008] - Open Circuit
Fault Frequency: 9
Reset counter: 204
Mileage: 22858 km
Date: 2018.04.30
Time: 09:13:03
End-------------------------(Elapsed Time: 05:39)--------------------------
SW:8V0-035-035-F HW:8V0-035-035-B --- Information Electr.
Component:MU-H-LN-EU H45 0401, Coding:01739301FF0A000021110001000A02102F00010501000100DE
EV_MUHig6C3HBAS,001040,EV_MUHig6C3HBAS_AU37.rod
Thursday,25,October,2018,17:03:33:31113
VCDS Version: Release 18.9.0 (x64) Data version: 20180927 DS296.0
IDE00346-Summertime-automatic,Europe ,1
IDE00768-Country identification: country of sale,DE ,2
IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00845-Wheel circ.,0 mm,2
IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,28 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,85 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,85 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,85 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,85 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,85 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,85 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,85 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,16 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,16 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,28 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,85 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,85 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,85 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,85 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,85 ,49
IDE02502-Confirmation of installation change,5D 66 ,2
IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,OFF ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,On ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,On ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,On ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,Deactivated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,Deactivated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,On ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,Enabled ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,On ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE03580-Country code for mobile network,31 ,2
IDE03581-ENG117690-Vehicle function list CAN-Adaptive_key_msg_bus,Terminal 15 ,8
IDE03581-ENG117691-Vehicle function list CAN-Adaptive_key_school,Available ,8
IDE03581-ENG117688-Vehicle function list CAN-Driving_school,Not available ,8
IDE03581-ENG117689-Vehicle function list CAN-Driving_school_msg_bus,Comfort data bus ,8
IDE03581-ENG107608-Vehicle function list CAN-MFL,Available ,8
IDE03581-ENG117681-Vehicle function list CAN-MFL_msg_bus,Terminal 15 ,8
IDE03581-ENG117683-Vehicle function list CAN-Oil_level,Not available ,8
IDE03581-ENG117684-Vehicle function list CAN-Oil_level_msg_bus,Comfort data bus ,8
IDE03581-ENG117685-Vehicle function list CAN-PDC_audio_lowering,Available ,8
IDE03581-ENG117686-Vehicle function list CAN-PDC_audio_lowering_msg_bus,Terminal 15 ,8
IDE03581-ENG98994-Vehicle function list CAN-Trailer,Not available ,8
IDE03581-ENG117682-Vehicle function list CAN-Trailer_msg_bus,Comfort data bus ,8
IDE03581-ENG99892-Vehicle function list CAN-VIN,Available ,8
IDE03581-ENG117687-Vehicle function list CAN-VIN_msg_bus,Terminal 15 ,8
IDE04292-Roadside assistance mode,Corresponding setting in MMI ,1
IDE04294-Number attempted dialing attempts for roadside assistance,3 ,1
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,40
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,40
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,40
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,40
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,40
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,activated ,40
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,40
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,40
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,activated ,40
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,40
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,40
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,40
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,40
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,40
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,40
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,40
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,40
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,40
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,40
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,40
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,40
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,40
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,40
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,40
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,40
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,40
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,40
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,40
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,40
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,40
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,40
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,40
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,40
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,40
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,40
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,40
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,40
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,40
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,40
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,40
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,40
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,40
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,40
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,40
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,40
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,not activated ,40
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,40
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,40
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,not activated ,40
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,40
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,not activated ,40
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,40
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,40
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,not activated ,40
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,40
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,40
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,40
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,40
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,40
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,40
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,40
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,40
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,40
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,40
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,40
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,40
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,40
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,40
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,40
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,40
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,40
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,40
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,40
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,40
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,40
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,40
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,40
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,40
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,40
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,40
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,40
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,40
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,40
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,40
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,40
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,40
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,40
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,40
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,40
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,40
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,not activated ,40
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,40
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,40
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,not activated ,40
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,40
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,40
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,40
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,40
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,40
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,40
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,40
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,40
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,40
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,40
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,40
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,activated ,40
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,40
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,40
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,activated ,40
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,40
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,40
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,40
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,40
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,40
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,40
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,activated ,40
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,40
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,40
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,activated ,40
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,40
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,40
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,40
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,40
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,40
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,40
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,40
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,40
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,40
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,40
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,40
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,40
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,40
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,40
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,not activated ,40
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,40
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,40
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,40
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,40
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,not activated ,40
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,activated ,40
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,40
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,40
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,40
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,40
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,40
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,activated ,40
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,40
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,40
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,activated ,40
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,40
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,40
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,40
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,40
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,not activated ,40
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,40
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,40
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,40
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,40
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,40
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,40
IDE04300-ENG117511-Vehicle menu operation-menu_display_side_assistant,not activated ,40
IDE04300-ENG117515-Vehicle menu operation-menu_display_side_assistant_after_disclaimer,not activated ,40
IDE04300-ENG117512-Vehicle menu operation-menu_display_side_assistant_clamp_15_off,not activated ,40
IDE04300-ENG117513-Vehicle menu operation-menu_display_side_assistant_over_threshold_high,not activated ,40
IDE04300-ENG117514-Vehicle menu operation-menu_display_side_assistant_standstill,not activated ,40
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,40
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,40
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,40
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,40
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,40
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,40
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,40
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,40
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,40
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,40
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,40
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,40
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,40
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,40
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,40
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,40
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,40
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,40
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,40
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,40
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,40
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,40
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,40
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,40
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,40
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,not activated ,40
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,40
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,40
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,not activated ,40
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,40
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,40
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,40
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,40
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,40
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,40
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,53
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Terminal 15 ,53
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,53
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,Comfort data bus ,53
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,53
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,Comfort data bus ,53
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,53
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,Comfort data bus ,53
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,53
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,53
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,53
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Comfort data bus ,53
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,not activated ,53
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Comfort data bus ,53
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,53
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Terminal 15 ,53
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,53
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Terminal 15 ,53
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,53
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,Comfort data bus ,53
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,53
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,Terminal 15 ,53
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,53
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,Comfort data bus ,53
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,53
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,53
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,53
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,Comfort data bus ,53
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,53
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,53
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,not activated ,53
IDE04307-ENG125040-Vehicle function list BAP-Ecall_msg_bus_0x33,Comfort data bus ,53
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,53
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Terminal 15 ,53
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,53
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,Comfort data bus ,53
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,activated ,53
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Terminal 15 ,53
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,53
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Terminal 15 ,53
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,53
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Terminal 15 ,53
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,53
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Terminal 15 ,53
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,activated ,53
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,53
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,not activated ,53
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,53
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,53
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,Comfort data bus ,53
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,53
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,53
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,53
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,Comfort data bus ,53
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,53
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Comfort data bus ,53
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,53
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Terminal 15 ,53
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,53
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,Comfort data bus ,53
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,53
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,53
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,not activated ,53
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Comfort data bus ,53
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,53
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Terminal 15 ,53
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,activated ,53
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,53
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,53
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,Comfort data bus ,53
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,53
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Terminal 15 ,53
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,not activated ,53
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Comfort data bus ,53
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,53
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Terminal 15 ,53
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,53
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Terminal 15 ,53
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04521-Sporadic ring break detection,none ,1
IDE04549-Telephone data services,On ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE05111-Fee-based traffic information (TMC),32783 ,2
IDE05112-MAS02228-Image position-X coordinate,0 ,2
IDE05112-MAS02229-Image position-Y coordinate,0 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,6
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,6
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,6
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,6
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,6
IDE09570-ENG117700-Vehicle function list BAP: extension-ACC_0x05,activated ,64
IDE09570-ENG117701-Vehicle function list BAP: extension-ACC_0x05_msg_bus,Terminal 15 ,64
IDE09570-ENG117702-Vehicle function list BAP: extension-air_suspension_0x06,not activated ,64
IDE09570-ENG117703-Vehicle function list BAP: extension-air_suspension_0x06_msg_bus,Comfort data bus ,64
IDE09570-ENG117764-Vehicle function list BAP: extension-Amplifier_0x2D,not activated ,64
IDE09570-ENG117765-Vehicle function list BAP: extension-Amplifier_0x2D_msg_bus,Comfort data bus ,64
IDE09570-ENG122334-Vehicle function list BAP: extension-Angle_Of_Slope_0x24,not activated ,64
IDE09570-ENG122335-Vehicle function list BAP: extension-Angle_Of_Slope_0x24_msg_bus,Comfort data bus ,64
IDE09570-ENG117696-Vehicle function list BAP: extension-auxilary_heating_0x03,not activated ,64
IDE09570-ENG117697-Vehicle function list BAP: extension-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
IDE09570-ENG117744-Vehicle function list BAP: extension-AWV_0x1B,activated ,64
IDE09570-ENG117745-Vehicle function list BAP: extension-AWV_0x1B_msg_bus,Terminal 15 ,64
IDE09570-ENG122336-Vehicle function list BAP: extension-Battery_Management_0x25,activated ,64
IDE09570-ENG122337-Vehicle function list BAP: extension-Battery_Management_0x25_msg_bus,Terminal 15 ,64
IDE09570-ENG117758-Vehicle function list BAP: extension-BCmE_0x23,not activated ,64
IDE09570-ENG117759-Vehicle function list BAP: extension-BCmE_0x23_msg_bus,Comfort data bus ,64
IDE09570-ENG117760-Vehicle function list BAP: extension-Brake_0x26,not activated ,64
IDE09570-ENG117761-Vehicle function list BAP: extension-Brake_0x26_msg_bus,Comfort data bus ,64
IDE09570-ENG117717-Vehicle function list BAP: extension-central_locking_0x0D,activated ,64
IDE09570-ENG117716-Vehicle function list BAP: extension-central_locking_0x0D_msg_bus,Terminal 15 ,64
IDE09570-ENG117736-Vehicle function list BAP: extension-charisma_0x17,activated ,64
IDE09570-ENG117737-Vehicle function list BAP: extension-charisma_0x17_msg_bus,Terminal 15 ,64
IDE09570-ENG117734-Vehicle function list BAP: extension-clima_slave_2_0x16,not activated ,64
IDE09570-ENG117735-Vehicle function list BAP: extension-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
IDE09570-ENG117692-Vehicle function list BAP: extension-climatic_master_0x01,activated ,64
IDE09570-ENG117693-Vehicle function list BAP: extension-climatic_master_0x01_msg_bus,Terminal 15 ,64
IDE09570-ENG117694-Vehicle function list BAP: extension-climatic_slave_0x02,not activated ,64
IDE09570-ENG117695-Vehicle function list BAP: extension-climatic_slave_0x02_msg_bus,Comfort data bus ,64
IDE09570-ENG117724-Vehicle function list BAP: extension-clock_0x11,activated ,64
IDE09570-ENG117725-Vehicle function list BAP: extension-clock_0x11_msg_bus,Comfort data bus ,64
IDE09570-ENG117732-Vehicle function list BAP: extension-compass_0x15,not activated ,64
IDE09570-ENG117733-Vehicle function list BAP: extension-compass_0x15_msg_bus,Comfort data bus ,64
IDE09570-ENG117722-Vehicle function list BAP: extension-driver_seat_0x10,not activated ,64
IDE09570-ENG117723-Vehicle function list BAP: extension-driver_seat_0x10_msg_bus,Comfort data bus ,64
IDE09570-ENG117708-Vehicle function list BAP: extension-exterieur_light_0x09,activated ,64
IDE09570-ENG117709-Vehicle function list BAP: extension-exterieur_light_0x09_msg_bus,Terminal 15 ,64
IDE09570-ENG117698-Vehicle function list BAP: extension-headup_displ_0x04,not activated ,64
IDE09570-ENG117699-Vehicle function list BAP: extension-headup_displ_0x04_msg_bus,Comfort data bus ,64
IDE09570-ENG117746-Vehicle function list BAP: extension-Hybrid_0x1D,activated ,64
IDE09570-ENG117747-Vehicle function list BAP: extension-Hybrid_0x1D_msg_bus,Terminal 15 ,64
IDE09570-ENG117706-Vehicle function list BAP: extension-interieur_light_0x08,activated ,64
IDE09570-ENG117707-Vehicle function list BAP: extension-interieur_light_0x08_msg_bus,Terminal 15 ,64
IDE09570-ENG117740-Vehicle function list BAP: extension-LDW_HCA_0x19,activated ,64
IDE09570-ENG117741-Vehicle function list BAP: extension-LDW_HCA_0x19_msg_bus,Terminal 15 ,64
IDE09570-ENG117720-Vehicle function list BAP: extension-MFA_0x0F,activated ,64
IDE09570-ENG117721-Vehicle function list BAP: extension-MFA_0x0F_msg_bus,Terminal 15 ,64
IDE09570-ENG117767-Vehicle function list BAP: extension-MFL_Jocker_0x34,activated ,64
IDE09570-ENG117766-Vehicle function list BAP: extension-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
IDE09570-ENG117719-Vehicle function list BAP: extension-mirror_0x0E,not activated ,64
IDE09570-ENG117718-Vehicle function list BAP: extension-mirror_0x0E_msg_bus,Comfort data bus ,64
IDE09570-ENG117738-Vehicle function list BAP: extension-Night_Vision_0x18,not activated ,64
IDE09570-ENG117739-Vehicle function list BAP: extension-Night_Vision_0x18_msg_bus,Comfort data bus ,64
IDE09570-ENG117710-Vehicle function list BAP: extension-parking_assist_0x0A,activated ,64
IDE09570-ENG117711-Vehicle function list BAP: extension-parking_assist_0x0A_msg_bus,Terminal 15 ,64
IDE09570-ENG117752-Vehicle function list BAP: extension-Passenger_Seat_0x20,not activated ,64
IDE09570-ENG117753-Vehicle function list BAP: extension-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
IDE09570-ENG122333-Vehicle function list BAP: extension-Range_Data_0x39,activated ,64
IDE09570-ENG125827-Vehicle function list BAP: extension-Range_Data_msg_bus_0x39,Terminal 15 ,64
IDE09570-ENG122327-Vehicle function list BAP: extension-RearSeatEntertainment_0x2E,not activated ,64
IDE09570-ENG122328-Vehicle function list BAP: extension-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
IDE09570-ENG117750-Vehicle function list BAP: extension-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
IDE09570-ENG117751-Vehicle function list BAP: extension-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Comfort data bus ,64
IDE09570-ENG117726-Vehicle function list BAP: extension-service_interval_display_0x12,activated ,64
IDE09570-ENG117727-Vehicle function list BAP: extension-service_interval_display_0x12_msg_bus,Terminal 15 ,64
IDE09570-ENG117748-Vehicle function list BAP: extension-SideView_0x1E,not activated ,64
IDE09570-ENG117749-Vehicle function list BAP: extension-SideView_0x1E_msg_bus,Comfort data bus ,64
IDE09570-ENG122329-Vehicle function list BAP: extension-Special_Functions_0x35,not activated ,64
IDE09570-ENG122330-Vehicle function list BAP: extension-Special_Functions_msg_bus_0x35,Comfort data bus ,64
IDE09570-ENG117762-Vehicle function list BAP: extension-Start_Stop_reasons_0x27,not activated ,64
IDE09570-ENG117763-Vehicle function list BAP: extension-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,64
IDE09570-ENG117742-Vehicle function list BAP: extension-SWA_0x1A,not activated ,64
IDE09570-ENG117743-Vehicle function list BAP: extension-SWA_0x1A_msg_bus,Comfort data bus ,64
IDE09570-ENG117704-Vehicle function list BAP: extension-tire_pressure_system_0x07,activated ,64
IDE09570-ENG117705-Vehicle function list BAP: extension-tire_pressure_system_0x07_msg_bus,Terminal 15 ,64
IDE09570-ENG117754-Vehicle function list BAP: extension-traffic_sign_recognition_0x21,activated ,64
IDE09570-ENG117755-Vehicle function list BAP: extension-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,64
IDE09570-ENG122331-Vehicle function list BAP: extension-Trailer_Assistant_0x36,not activated ,64
IDE09570-ENG122332-Vehicle function list BAP: extension-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
IDE09570-ENG122325-Vehicle function list BAP: extension-TV_tuner_0x2C,not activated ,64
IDE09570-ENG122326-Vehicle function list BAP: extension-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
IDE09570-ENG117730-Vehicle function list BAP: extension-UGDO_0x14,not activated ,64
IDE09570-ENG117731-Vehicle function list BAP: extension-UGDO_0x14_msg_bus,Comfort data bus ,64
IDE09570-ENG117728-Vehicle function list BAP: extension-unit_master_0x13,activated ,64
IDE09570-ENG117729-Vehicle function list BAP: extension-unit_master_0x13_msg_bus,Terminal 15 ,64
IDE09570-ENG117712-Vehicle function list BAP: extension-VPS_0x0B,not activated ,64
IDE09570-ENG117713-Vehicle function list BAP: extension-VPS_0x0B_msg_bus,Comfort data bus ,64
IDE09570-ENG117756-Vehicle function list BAP: extension-weariness_rcognition_0x22,activated ,64
IDE09570-ENG117757-Vehicle function list BAP: extension-weariness_rcognition_0x22_msg_bus,Terminal 15 ,64
IDE09570-ENG117714-Vehicle function list BAP: extension-wiper_comfort_0x0C,activated ,64
IDE09570-ENG117715-Vehicle function list BAP: extension-wiper_comfort_0x0C_msg_bus,Terminal 15 ,64
IDE10480-MAS10741-Interface for external media: activation-Connection 1,not activated ,4
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
MAS00951-Bluetooth,On ,1
MAS03690-Telephone,Data & language service active ,1
MAS03782-WLAN,On ,1
ENG117918-ENG117811-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_On_Off,OFF ,4
ENG117918-ENG117813-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_Time,0.00 ms,4
ENG117918-ENG117810-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_On_Off,OFF ,4
ENG117918-ENG117812-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_Time,0.00 ms,4
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1,0 ,12
ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2,10 ,12
ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3,100 ,12
ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4,150 ,12
ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5,220 ,12
ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6,253 ,12
ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1,0 %,12
ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2,6 %,12
ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3,16 %,12
ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4,30 %,12
ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5,60 %,12
ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6,100 %,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,4 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,10 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,30 %,12
ENG117808-p_HMI_Display,10 %,1
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 00:41
I compared the scan to a scan I made shortly after I bought the car and all codes are still the same. Only changes I made are for the anti theft system I have added.
I have no log of the settings in adaptations from when I bought the car so I cannot compare the changes. I know: not very intelligent. That is why I ask for this help.
There are two other things to mention but I don’t think they can be the cause of my problem.
One is that I have added a surround view system from SZDalos on Aliexpress. It is connected in parallel to the Can lines on the MMI system. I could think that in some way this could influence the MMI system, but the MMI works fine. Only problem is with the SIM card. The surround view system is very good, by the way.
The other possibility is that by coincidence in the same period the module in the MMI that reads the SIM card has broken down. If anyone knows how I could test that, I would do that. The measurement readout in the Telematics and in the Information Electronics module shows the external SIM as not available.
Sorry for the long story, but as I said I have been chewing on this for a long time.
I hope that someone can help me solve this.
Groet, Ron
