Messed up data connection on 2015 Audi A3 E-tron
Ronc
C?ID=122818
Hi there,
I would like some help with a problem I induced myself to my 2015 A3 Etron.
Some months ago I did some trial and error in the adaptations of the Information Electronics, to maybe use some hidden goodies in it. But no success.
Probably due to one or more settings that I messed up my data connection for Audi connect doesn’t work anymore.
I have been trying for a long time now, but I cant find what I did wrong.
So I would be very grateful for some advice on which parameters in Information Electronics (or Telematics or CAN Gateway) could be the cause for the data connection not working anymore.
The menu for settings of Telephone shows the item Connections and in there the item to switch on the Data module. But when I press that nothing happens.
The system does not see the Sim card in the MMI unit. It is a valid card that I normally use daily in my phone. When I insert the card no reaction from the system like asking for the PIN.
Here are the results of my recent scan.
Thursday,25,October,2018,18:51:58:31113
VCDS Version: 18.9.0.2 (x64)
VIN: WAUZZZ8V7GA092145   License Plate:
Mileage: 29659km-18429mi   Repair Order:
Chassis Type: 8V-AU37 (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 55 5F
          75 8C A5 BB BC C6
VIN: WAUZZZ8V7GA092145   Mileage: 29659km-18429miles
8C-Hybrid Battery -- Status: Malfunction 0010
C6-Batt. Chrg. -- Status: Malfunction 0010
Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AF    HW: 04E 907 309 F
   Component: 1.4l TFSI hy  H22 2660
   Revision: X3H22---
   Coding: 021D0012636401083000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906023AF 005006
   ROD: EV_ECM14TFS_005.rod
   VCID: 64CD51DB6F22366A51-8030
   Part No SW: 0DD 300 045 K    HW: 0DD 927 770 B
   Component: GSG DQ400E    H31 1121
   Revision: 00031033    Serial number: TFK01510290350
   Shop #: WSC 00099 780 00200
   ROD: EV_TCMDQ400021_VW37.rod
   VCID: 2F67EEF77664C5327C-807A
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
   Component: ESC           H31 0809
   Revision: 00000000    Serial number: 63185000000608
   Coding: 12F140A23829326E0378060441C82948021C4CC0608294F5F8A150788608
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_001.rod
   VCID: 050B6C5F8458AF62E6-8050
32832 - Switch for Electric Parking Brake
          C100C 07 [032] - Mechanical Failure
   Revision: 00021000    Serial number: 0386830410
   Coding: 030C0C
   Shop #: WSC 12345 123 12345
   VCID: 3A71CFA3BD26109ADB-806E
   Part No SW: 8V0 820 043 G    HW: 8V0 820 043 G
   Component: AC Automat    H05 0040
   Revision: 20010000    Serial number: 00000000785477
   Coding: 0300000000000000000000000000100001000000
   ASAM Dataset: EV_AirCondiFrontRDWAU37X 001015
   ROD: EV_AirCondiFrontRDWAU37X.rod
   VCID: 3669DB93893EF4FA3F-8062
   Subsystem 1 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
   Component: J848 HV-PTC  H09 0206
   Serial number: LM153223003807000433
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: 3B1987D7000000000001
   Subsystem 3 - Part No SW: 12E 820 803 E    HW: 12E 820 803 E
   Component: J842 eKK  H02 0005
459030 - Invalid Data Received From Electric A/C Compressor
          U046C 00 [040] - -
                    Mileage: 29634 km
                    Date: 2018.10.21
                    Time: 18:58:27
                    Unlearning counter according OBD-OBD Parameter: 40
                    Compressor shut-off requirement: Shut-off from Engine Control Module (ECM) via CAN
                    Compressor status: global-A/C compressor release status: transmitted
                    Compressor status: global-A/C compressor: target speed: 0 /min
                    Compressor status: global-A/C compressor: actual speed: Measured value not available
                    Compressor status: global-A/C compressor: function status: Air conditioner compressor off
                    Compressor status: global-A/C compressor error indicator: not active
                    Compressor status: global-A/C compressor: veh. elec. syst. volt.: OK
                    Compressor status: global-A/C compressor: inverter temperature: Measured value not available
   Part No SW: 5Q0 937 084 AR    HW: 5Q0 937 084 AM
   Component: BCM MQBAB M+  H24 0175
   Serial number: 01061532000615
   Coding: 04051D46C2D506FD438C5004B11407A8081E000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0815656BB34AB20A9D-805C
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150808  042 0580
   Serial number:         151102160601
   Coding: 0A47F7
   Serial number: 60971829
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 02 09 2015  00001415
   Component: Sensor, DWA  005 0312
   Serial number: 000000000ZY112370VBD
   Serial number: 00000000000058693429
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39491530000173
   Coding: 1030360011
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 4797A657FED47D7254-8012
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 P    HW: 5Q0 907 567 P
   Component: ACC3          H10 0100
   Serial number: 25111503032432
   Coding: 003E1701FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 4895A56BF3CA720A5D-801C
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR01HXTI
   Coding: 98FCC0000C2000009C5400CA004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 50A58D0B0B9ABACA05-8004
   Subsystem 1 - Part No SW: -----------    HW: 480 002 011 15
   Serial number: 357000000005BC21C71N
   Subsystem 2 - Part No SW: -----------    HW: 480 002 011 15
   Serial number: 35800000000C9C21C71T
   Subsystem 3 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 35100029B1DBD61560DE
   Subsystem 4 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3520002AD1DBD6124213
   Subsystem 5 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3550002AB1D25F01E135
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 810 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 2280002A11D3F972217%
   Subsystem 7 - Part No SW: -----------    HW: 480 402 710 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2290002C71D3F972C17I
   Subsystem 8 - Part No SW: -----------    HW: 480 002 710 15
   Serial number: I0M0000000055A7D7618
   Subsystem 9 - Part No SW: -----------    HW: 480 002 710 15
   Serial number: I0N0000000057A7D761B
   Part No SW: 8V0 953 521 GK    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 31101508491449
   Coding: EC18
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 0913606FA840CB0282-805C
   Part No SW: 8V0 920 872 K    HW: 8V0 920 872 K
   Component: KOMBI         H03 6423
   Coding: 078D0C186F9400080D83EE101200000000000000
   Shop #: WSC 55783 001 104857
   VCID: 458BAC5FC4D86F62A6-8010
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 E    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3245
   Revision: --------    Serial number: 09111510520191
   Coding: 0201001726F200005B001218580000000001010100010000000000000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013_VW37.rod
   Subsystem 1 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 16 11 2015  F0043938
   Subsystem 2 - Part No SW: 5QE 915 181     HW: 5QE 915 181
   Serial number: 3627298203
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
   Component: EBKV          H14 0182
   Serial number:   085430011005
   Coding: 03720100331900030002050500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
   ROD: EV_BrakeBoostBoschMQBOMG_003.rod
   VCID: 4FA78E7716A4A5321C-801A
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861241115232654
222976 - Brake Booster; Brake Pedal Travel Excessive
          C1214 00 [032] -  -
                    Mileage: 28312 km
                    Date: 2018.08.20
                    Time: 16:49:00
   Revision: 00000000    Serial number: 15000251699007
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346DE19B9F42E6EA01-8060
   Serial number: 300915BIT21884
   Coding: 001C9F204000040000001003
   Shop #: WSC 06385 790 00021
   VCID: 438FB247CAEC515288-8016
   Component: EPS_MQB_ZFLS  125 1063
   Coding: D302
   VCID: 448DB15BCFE2566AB1-8010
   Part No SW: 5G0 907 080 D    HW: 5G0 907 080 D
   Component: VW370P3815010 H06 4492
   Revision: 00H06000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM09550115G0907080D 001018
   ROD: EV_DMCM09550115G0907080D.rod
   VCID: 285505EB538A920ABD-807C
   Serial number: 081015BJ718517
   Coding: 001C97204000040000001003
   Shop #: WSC 55783 001 1048576
   VCID: 4281B743D5F6585A83-8016
   Coding: 011A00002B230200
   VCID: 3F87BEB7A60435B2EC-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Coding: E00100
   Part No SW: 8V0 035 035 F    HW: 8V0 035 035 B
   Component: MU-H-LN-EU    H45 0401
   Serial number: A301K0F7558834
   Coding: 01739301FF0A000021110001000A02132F000105010001009E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 800 QA    HW: -----------
   Component: ECE 2016  --- 0134
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY204FFZ
   Multimedia Operating Unit:
   Serial number: C1000005101500030112
   Component: Gracenote  --- 1010
   Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
   Component: OCULowMQBEU   012 0715
   Coding: 0173930110809A0100F800000000
   ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 5Q0 915 182 C    HW: 5Q0 915 182 C
   Component: BECM          H05 0752
   Serial number: T7250045
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006037
   ROD: EV_BECM09620115Q0915182.rod
   VCID: 336FE2879A4CE1D218-8066
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
   Component: BJB  H27 0240
   Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D1  H14 0472
   Serial number: V013C1590320064
   Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D2  H14 0472
   Serial number: V013C1590320075
   Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D3  H14 0472
   Serial number: V013C1590330432
   Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D4  H14 0472
   Serial number: V013C1590330161
   Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D5  H14 0472
   Serial number: V013C1590330431
   Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D6  H14 0472
   Serial number: V013C1590330162
   Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D7  H14 0472
   Serial number: V013C1590330164
   Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D8  H14 0472
   Serial number: V013C1590330429
26717 - Battery Charger Input
          P0D80 00 [036] - Open Circuit
                    Mileage: 28312 km
                    Date: 2018.08.20
                    Time: 13:08:57
                    Pack Voltage: 387.6 V
                    Pack Current: -0.00 A
                    Isolation Resistance: 5080 kOhm
                    Maxumum charge current limit: 3 A
                    Maximum discharge current limit: 330.0 A
                    Contactor Voltage: 0 V
                    OBD unlearned counter: 40
                    Crash status: 00
                    Pilot Line Status: 00
                    Fuse Status: 00
                    (Minus) Contactor Status: 00
                    (Plus) Contactor Status: 00
                    Terminal 15 status: 00
                    Max Cell Temperature: 24 °C
                    Min Cell Temperature: 24 °C
                    Air inlet temperature: 24 °C
                    Air outlet temperature: 24 °C
                    LV Battery Voltage: 12.1 V
                    Min.cell voltage: 4.038 V
                    Max.cell Voltage: 4.042 V
                    Max.cell SOC: 94 %
                    Min.cell SOC: 94 %
                    Hybrid Battery Pack Remaining Life: 94.9 %
                    Max Charge Pack Current(10s duration): 0 A
                    Max Discharge Pack Current(10s duration): 0.0 A
                    Max Pack Voltage(10s duration): 386 V
                    Min Pack Voltage(10s duration): 386 V
                    Max.cell Voltage(10s duration): 4.043 V
                    Min.cell Voltage(10s duration): 4.038 V
                    Accelerator Pedal Position D: 14.1 %
                    Calculated LOAD Value: 0.0 %
                    Engine coolant temperature: 23 °C
                    Engine RPM: 0.00 /min
                    Vehicle Speed Sensor: 0 km/h
                    Ambient Air Temperature: 215 °C
                    Hybrid Battery Pack Remaining Life: 94.90 %
                    control module system voltage: 12.100 V
                    absolute load: 0.0 %
                    Time After Engine Start: 0 s
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000464374
   Coding: 0101010001010303000500000100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C7DC9BBB7122EAAC9-8068
   Serial number: 271015BJP11072
   Coding: 000C97204000040000001002
   Serial number: 271015BJP11047
Address C6: Batt. Chrg. (J1050)       Labels:* None
   Part No SW: 5QE 915 682 AA    HW: 5QE 915 682 AA
   Component: OBC KOSTAL    H61 3017
   Revision: --------    Serial number: 1411150KD001PA
   Coding: 115068203000
   ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
   ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
   VCID: 0C1D597BA732DE2AB9-8058
2097152 - Battery Management
          P33EB 00 [008] - Read Event Memory
                    Reset counter: 204
                    Mileage: 29634 km
                    Date: 2018.10.21
                    Time: 18:58:23
2097696 - Charging Socket A for AC Connection
          P31C7 00 [008] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 204
                    Mileage: 22858 km
                    Date: 2018.04.30
                    Time: 09:13:03
End-------------------------(Elapsed Time: 05:39)--------------------------
And these are the present settings in adaptations.
	SW:8V0-035-035-F   HW:8V0-035-035-B ---  Information Electr.
	Component:MU-H-LN-EU    H45 0401, Coding:01739301FF0A000021110001000A02102F00010501000100DE
	EV_MUHig6C3HBAS,001040,EV_MUHig6C3HBAS_AU37.rod
	Thursday,25,October,2018,17:03:33:31113
	VCDS Version: Release 18.9.0 (x64)  Data version: 20180927 DS296.0
IDE00346-Summertime-automatic,Europe ,1
IDE00768-Country identification: country of sale,DE ,2
IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00845-Wheel circ.,0 mm,2
IDE02121-CD eject button,Enabled ,1
IDE02122-Developer mode,not activated ,1
IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,28 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,85 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,85 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,85 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,85 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,85 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,85 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,85 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,16 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,16 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,28 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,85 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,85 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,85 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,85 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,85 ,49
IDE02502-Confirmation of installation change,5D 66 ,2
IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,OFF ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,On ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present ,30
IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,On ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,On ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,On ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,Deactivated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,Deactivated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,On ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,Enabled ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,On ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE03580-Country code for mobile network,31 ,2
IDE03581-ENG117690-Vehicle function list CAN-Adaptive_key_msg_bus,Terminal 15 ,8
IDE03581-ENG117691-Vehicle function list CAN-Adaptive_key_school,Available ,8
IDE03581-ENG117688-Vehicle function list CAN-Driving_school,Not available ,8
IDE03581-ENG117689-Vehicle function list CAN-Driving_school_msg_bus,Comfort data bus ,8
IDE03581-ENG107608-Vehicle function list CAN-MFL,Available ,8
IDE03581-ENG117681-Vehicle function list CAN-MFL_msg_bus,Terminal 15 ,8
IDE03581-ENG117683-Vehicle function list CAN-Oil_level,Not available ,8
IDE03581-ENG117684-Vehicle function list CAN-Oil_level_msg_bus,Comfort data bus ,8
IDE03581-ENG117685-Vehicle function list CAN-PDC_audio_lowering,Available ,8
IDE03581-ENG117686-Vehicle function list CAN-PDC_audio_lowering_msg_bus,Terminal 15 ,8
IDE03581-ENG98994-Vehicle function list CAN-Trailer,Not available ,8
IDE03581-ENG117682-Vehicle function list CAN-Trailer_msg_bus,Comfort data bus ,8
IDE03581-ENG99892-Vehicle function list CAN-VIN,Available ,8
IDE03581-ENG117687-Vehicle function list CAN-VIN_msg_bus,Terminal 15 ,8
IDE03902-Automatic ring break diagnostic,No automatic start ,1
IDE04292-Roadside assistance mode,Corresponding setting in MMI ,1
IDE04294-Number attempted dialing attempts for roadside assistance,3 ,1
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,40
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,40
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,40
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,40
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,40
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,activated ,40
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,40
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,40
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,activated ,40
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,40
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,40
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,40
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,40
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,40
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,40
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,40
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,40
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,40
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,40
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,40
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,40
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,40
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,40
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,40
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,40
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,40
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,40
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,40
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,40
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,40
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,40
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,40
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,40
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,40
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,40
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,40
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,40
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,40
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,40
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,40
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,40
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,40
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,40
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,40
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,40
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,not activated ,40
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,40
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,40
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,not activated ,40
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,40
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,not activated ,40
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,40
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,40
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,not activated ,40
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,40
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,40
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,40
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,40
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,40
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,40
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,40
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,40
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,40
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,40
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,40
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,40
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,40
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,40
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,40
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,40
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,40
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,40
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,40
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,40
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,40
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,40
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,40
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,40
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,40
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,40
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,40
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,40
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,40
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,40
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,40
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,40
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,40
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,40
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,40
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,40
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,not activated ,40
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,40
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,40
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,not activated ,40
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,40
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,40
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,40
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,40
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,40
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,40
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,40
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,40
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,40
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,40
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,40
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,activated ,40
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,40
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,40
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,activated ,40
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,40
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,40
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,40
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,40
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,40
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,40
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,activated ,40
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,40
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,40
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,activated ,40
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,40
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,40
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,40
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,40
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,40
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,40
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,40
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,40
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,40
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,40
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,40
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,40
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,40
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,40
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,not activated ,40
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,40
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,40
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,40
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,40
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,not activated ,40
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,activated ,40
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,40
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,40
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,40
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,40
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,40
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,activated ,40
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,40
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,40
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,activated ,40
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,40
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,40
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,40
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,40
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,not activated ,40
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,40
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,40
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,40
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,40
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,40
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,40
IDE04300-ENG117511-Vehicle menu operation-menu_display_side_assistant,not activated ,40
IDE04300-ENG117515-Vehicle menu operation-menu_display_side_assistant_after_disclaimer,not activated ,40
IDE04300-ENG117512-Vehicle menu operation-menu_display_side_assistant_clamp_15_off,not activated ,40
IDE04300-ENG117513-Vehicle menu operation-menu_display_side_assistant_over_threshold_high,not activated ,40
IDE04300-ENG117514-Vehicle menu operation-menu_display_side_assistant_standstill,not activated ,40
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,40
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,40
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,40
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,40
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,40
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,40
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,40
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,40
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,40
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,40
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,40
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,40
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,40
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,40
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,40
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,40
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,40
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,40
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,40
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,40
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,40
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,40
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,40
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,40
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,40
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,not activated ,40
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,40
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,40
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,not activated ,40
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,40
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,40
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,40
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,40
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,40
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,40
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,53
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Terminal 15 ,53
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,53
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,Comfort data bus ,53
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,53
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,Comfort data bus ,53
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,53
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,Comfort data bus ,53
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,53
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,53
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,53
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Comfort data bus ,53
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,not activated ,53
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Comfort data bus ,53
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,53
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Terminal 15 ,53
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,53
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Terminal 15 ,53
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,53
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,Comfort data bus ,53
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,53
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,Terminal 15 ,53
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,53
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,Comfort data bus ,53
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,53
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,53
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,53
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,Comfort data bus ,53
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,53
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,53
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,not activated ,53
IDE04307-ENG125040-Vehicle function list BAP-Ecall_msg_bus_0x33,Comfort data bus ,53
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,53
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Terminal 15 ,53
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,53
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,Comfort data bus ,53
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,activated ,53
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Terminal 15 ,53
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,53
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Terminal 15 ,53
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,53
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Terminal 15 ,53
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,53
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Terminal 15 ,53
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,activated ,53
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,53
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,not activated ,53
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,53
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,53
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,Comfort data bus ,53
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,53
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,53
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,53
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,Comfort data bus ,53
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,53
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Comfort data bus ,53
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,53
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Terminal 15 ,53
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,53
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,Comfort data bus ,53
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,53
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,53
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,not activated ,53
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Comfort data bus ,53
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,53
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Terminal 15 ,53
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,activated ,53
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,53
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,53
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,Comfort data bus ,53
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,53
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Terminal 15 ,53
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,not activated ,53
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Comfort data bus ,53
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,53
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Terminal 15 ,53
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,53
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Terminal 15 ,53
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04521-Sporadic ring break detection,none ,1
IDE04549-Telephone data services,On ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE05111-Fee-based traffic information (TMC),32783 ,2
IDE05112-MAS02228-Image position-X coordinate,0 ,2
IDE05112-MAS02229-Image position-Y coordinate,0 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,6
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,6
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,6
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,6
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,6
IDE09570-ENG117700-Vehicle function list BAP: extension-ACC_0x05,activated ,64
IDE09570-ENG117701-Vehicle function list BAP: extension-ACC_0x05_msg_bus,Terminal 15 ,64
IDE09570-ENG117702-Vehicle function list BAP: extension-air_suspension_0x06,not activated ,64
IDE09570-ENG117703-Vehicle function list BAP: extension-air_suspension_0x06_msg_bus,Comfort data bus ,64
IDE09570-ENG117764-Vehicle function list BAP: extension-Amplifier_0x2D,not activated ,64
IDE09570-ENG117765-Vehicle function list BAP: extension-Amplifier_0x2D_msg_bus,Comfort data bus ,64
IDE09570-ENG122334-Vehicle function list BAP: extension-Angle_Of_Slope_0x24,not activated ,64
IDE09570-ENG122335-Vehicle function list BAP: extension-Angle_Of_Slope_0x24_msg_bus,Comfort data bus ,64
IDE09570-ENG117696-Vehicle function list BAP: extension-auxilary_heating_0x03,not activated ,64
IDE09570-ENG117697-Vehicle function list BAP: extension-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
IDE09570-ENG117744-Vehicle function list BAP: extension-AWV_0x1B,activated ,64
IDE09570-ENG117745-Vehicle function list BAP: extension-AWV_0x1B_msg_bus,Terminal 15 ,64
IDE09570-ENG122336-Vehicle function list BAP: extension-Battery_Management_0x25,activated ,64
IDE09570-ENG122337-Vehicle function list BAP: extension-Battery_Management_0x25_msg_bus,Terminal 15 ,64
IDE09570-ENG117758-Vehicle function list BAP: extension-BCmE_0x23,not activated ,64
IDE09570-ENG117759-Vehicle function list BAP: extension-BCmE_0x23_msg_bus,Comfort data bus ,64
IDE09570-ENG117760-Vehicle function list BAP: extension-Brake_0x26,not activated ,64
IDE09570-ENG117761-Vehicle function list BAP: extension-Brake_0x26_msg_bus,Comfort data bus ,64
IDE09570-ENG117717-Vehicle function list BAP: extension-central_locking_0x0D,activated ,64
IDE09570-ENG117716-Vehicle function list BAP: extension-central_locking_0x0D_msg_bus,Terminal 15 ,64
IDE09570-ENG117736-Vehicle function list BAP: extension-charisma_0x17,activated ,64
IDE09570-ENG117737-Vehicle function list BAP: extension-charisma_0x17_msg_bus,Terminal 15 ,64
IDE09570-ENG117734-Vehicle function list BAP: extension-clima_slave_2_0x16,not activated ,64
IDE09570-ENG117735-Vehicle function list BAP: extension-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
IDE09570-ENG117692-Vehicle function list BAP: extension-climatic_master_0x01,activated ,64
IDE09570-ENG117693-Vehicle function list BAP: extension-climatic_master_0x01_msg_bus,Terminal 15 ,64
IDE09570-ENG117694-Vehicle function list BAP: extension-climatic_slave_0x02,not activated ,64
IDE09570-ENG117695-Vehicle function list BAP: extension-climatic_slave_0x02_msg_bus,Comfort data bus ,64
IDE09570-ENG117724-Vehicle function list BAP: extension-clock_0x11,activated ,64
IDE09570-ENG117725-Vehicle function list BAP: extension-clock_0x11_msg_bus,Comfort data bus ,64
IDE09570-ENG117732-Vehicle function list BAP: extension-compass_0x15,not activated ,64
IDE09570-ENG117733-Vehicle function list BAP: extension-compass_0x15_msg_bus,Comfort data bus ,64
IDE09570-ENG117722-Vehicle function list BAP: extension-driver_seat_0x10,not activated ,64
IDE09570-ENG117723-Vehicle function list BAP: extension-driver_seat_0x10_msg_bus,Comfort data bus ,64
IDE09570-ENG117708-Vehicle function list BAP: extension-exterieur_light_0x09,activated ,64
IDE09570-ENG117709-Vehicle function list BAP: extension-exterieur_light_0x09_msg_bus,Terminal 15 ,64
IDE09570-ENG117698-Vehicle function list BAP: extension-headup_displ_0x04,not activated ,64
IDE09570-ENG117699-Vehicle function list BAP: extension-headup_displ_0x04_msg_bus,Comfort data bus ,64
IDE09570-ENG117746-Vehicle function list BAP: extension-Hybrid_0x1D,activated ,64
IDE09570-ENG117747-Vehicle function list BAP: extension-Hybrid_0x1D_msg_bus,Terminal 15 ,64
IDE09570-ENG117706-Vehicle function list BAP: extension-interieur_light_0x08,activated ,64
IDE09570-ENG117707-Vehicle function list BAP: extension-interieur_light_0x08_msg_bus,Terminal 15 ,64
IDE09570-ENG117740-Vehicle function list BAP: extension-LDW_HCA_0x19,activated ,64
IDE09570-ENG117741-Vehicle function list BAP: extension-LDW_HCA_0x19_msg_bus,Terminal 15 ,64
IDE09570-ENG117720-Vehicle function list BAP: extension-MFA_0x0F,activated ,64
IDE09570-ENG117721-Vehicle function list BAP: extension-MFA_0x0F_msg_bus,Terminal 15 ,64
IDE09570-ENG117767-Vehicle function list BAP: extension-MFL_Jocker_0x34,activated ,64
IDE09570-ENG117766-Vehicle function list BAP: extension-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
IDE09570-ENG117719-Vehicle function list BAP: extension-mirror_0x0E,not activated ,64
IDE09570-ENG117718-Vehicle function list BAP: extension-mirror_0x0E_msg_bus,Comfort data bus ,64
IDE09570-ENG117738-Vehicle function list BAP: extension-Night_Vision_0x18,not activated ,64
IDE09570-ENG117739-Vehicle function list BAP: extension-Night_Vision_0x18_msg_bus,Comfort data bus ,64
IDE09570-ENG117710-Vehicle function list BAP: extension-parking_assist_0x0A,activated ,64
IDE09570-ENG117711-Vehicle function list BAP: extension-parking_assist_0x0A_msg_bus,Terminal 15 ,64
IDE09570-ENG117752-Vehicle function list BAP: extension-Passenger_Seat_0x20,not activated ,64
IDE09570-ENG117753-Vehicle function list BAP: extension-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
IDE09570-ENG122333-Vehicle function list BAP: extension-Range_Data_0x39,activated ,64
IDE09570-ENG125827-Vehicle function list BAP: extension-Range_Data_msg_bus_0x39,Terminal 15 ,64
IDE09570-ENG122327-Vehicle function list BAP: extension-RearSeatEntertainment_0x2E,not activated ,64
IDE09570-ENG122328-Vehicle function list BAP: extension-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
IDE09570-ENG117750-Vehicle function list BAP: extension-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
IDE09570-ENG117751-Vehicle function list BAP: extension-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Comfort data bus ,64
IDE09570-ENG117726-Vehicle function list BAP: extension-service_interval_display_0x12,activated ,64
IDE09570-ENG117727-Vehicle function list BAP: extension-service_interval_display_0x12_msg_bus,Terminal 15 ,64
IDE09570-ENG117748-Vehicle function list BAP: extension-SideView_0x1E,not activated ,64
IDE09570-ENG117749-Vehicle function list BAP: extension-SideView_0x1E_msg_bus,Comfort data bus ,64
IDE09570-ENG122329-Vehicle function list BAP: extension-Special_Functions_0x35,not activated ,64
IDE09570-ENG122330-Vehicle function list BAP: extension-Special_Functions_msg_bus_0x35,Comfort data bus ,64
IDE09570-ENG117762-Vehicle function list BAP: extension-Start_Stop_reasons_0x27,not activated ,64
IDE09570-ENG117763-Vehicle function list BAP: extension-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,64
IDE09570-ENG117742-Vehicle function list BAP: extension-SWA_0x1A,not activated ,64
IDE09570-ENG117743-Vehicle function list BAP: extension-SWA_0x1A_msg_bus,Comfort data bus ,64
IDE09570-ENG117704-Vehicle function list BAP: extension-tire_pressure_system_0x07,activated ,64
IDE09570-ENG117705-Vehicle function list BAP: extension-tire_pressure_system_0x07_msg_bus,Terminal 15 ,64
IDE09570-ENG117754-Vehicle function list BAP: extension-traffic_sign_recognition_0x21,activated ,64
IDE09570-ENG117755-Vehicle function list BAP: extension-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,64
IDE09570-ENG122331-Vehicle function list BAP: extension-Trailer_Assistant_0x36,not activated ,64
IDE09570-ENG122332-Vehicle function list BAP: extension-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
IDE09570-ENG122325-Vehicle function list BAP: extension-TV_tuner_0x2C,not activated ,64
IDE09570-ENG122326-Vehicle function list BAP: extension-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
IDE09570-ENG117730-Vehicle function list BAP: extension-UGDO_0x14,not activated ,64
IDE09570-ENG117731-Vehicle function list BAP: extension-UGDO_0x14_msg_bus,Comfort data bus ,64
IDE09570-ENG117728-Vehicle function list BAP: extension-unit_master_0x13,activated ,64
IDE09570-ENG117729-Vehicle function list BAP: extension-unit_master_0x13_msg_bus,Terminal 15 ,64
IDE09570-ENG117712-Vehicle function list BAP: extension-VPS_0x0B,not activated ,64
IDE09570-ENG117713-Vehicle function list BAP: extension-VPS_0x0B_msg_bus,Comfort data bus ,64
IDE09570-ENG117756-Vehicle function list BAP: extension-weariness_rcognition_0x22,activated ,64
IDE09570-ENG117757-Vehicle function list BAP: extension-weariness_rcognition_0x22_msg_bus,Terminal 15 ,64
IDE09570-ENG117714-Vehicle function list BAP: extension-wiper_comfort_0x0C,activated ,64
IDE09570-ENG117715-Vehicle function list BAP: extension-wiper_comfort_0x0C_msg_bus,Terminal 15 ,64
IDE10480-MAS10741-Interface for external media: activation-Connection 1,not activated ,4
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
MAS00951-Bluetooth,On ,1
MAS03690-Telephone,Data & language service active ,1
MAS03782-WLAN,On ,1
ENG117918-ENG117811-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_On_Off,OFF ,4
ENG117918-ENG117813-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_Time,0.00 ms,4
ENG117918-ENG117810-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_On_Off,OFF ,4
ENG117918-ENG117812-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_Time,0.00 ms,4
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0 ,6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50 ,6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100 ,6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0 ,6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50 ,6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100 ,6
ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1,0 ,12
ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2,10 ,12
ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3,100 ,12
ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4,150 ,12
ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5,220 ,12
ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6,253 ,12
ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1,0 %,12
ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2,6 %,12
ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3,16 %,12
ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4,30 %,12
ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5,60 %,12
ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6,100 %,12
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,4 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,10 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,30 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %,12
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,10 %,1
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 00:41
I compared the scan to a scan I made shortly after I bought the car and all codes are still the same. Only changes I made are for the anti theft system I have added.
I have no log of the settings in adaptations from when I bought the car so I cannot compare the changes. I know: not very intelligent. That is why I ask for this help.
There are two other things to mention but I don’t think they can be the cause of my problem.
One is that I have added a surround view system from SZDalos on Aliexpress. It is connected in parallel to the Can lines on the MMI system. I could think that in some way this could influence the MMI system, but the MMI works fine. Only problem is with the SIM card. The surround view system is very good, by the way.
The other possibility is that by coincidence in the same period the module in the MMI that reads the SIM card has broken down. If anyone knows how I could test that, I would do that. The measurement readout in the Telematics and in the Information Electronics module shows the external SIM as not available.
Sorry for the long story, but as I said I have been chewing on this for a long time.
I hope that someone can help me solve this.
Groet, Ron
Andy
Sector 7G
HC424490
Even if you didn't map the Adp, VCDS should still have a record of the changes in AdpLog.CSV found here on your PC:
C:\Ross-Tech\VCDS\Debug
Ronc
C?ID=122818
Thank you very much. I did not know that.
I actually can see the whole history of my messing around since february last year.
Also found the history of my changes in coding. Apears i did some things even before the date of the first coding log i have.
I will try to undo all of my steps and then i hope that it works again.
Will keep you posted.
Thanks again!
Groet, Ron
Ronc
C?ID=122818
So i checked and i found out that the problem is not in my codings or adaptations.
Instead i found in several posts in other forums that the sim unit (or the LTE unit) in the MMI is one of the typical problems of the A3 Etron of my generation. Probably other Audi's to.
Many people had the MMI unit repaced by Audi under warranty. If no warranty then the costs are 4000 euro!
Is this problem with MMI known to any of the forum members?
I would like to know what the real problem in sim unit is. It could very well be something as simple as loose contact fingers to the sim card.
Anyone know about this? (guess this question is different category?)
