Audi A3 Xenons 8V 2015 - Upgrade
remstar
C?ID=124820
Hi
Im having some problems with my retrofitted Xenons and need some help with coding.I bought the adaptor lead from Kufatec, I bought the lights ,BCM & light switch from a friend who had it fitted as standard in his.
The component protection has been removed from the BCM.
The problem that im having is that im getting warnings that ALL bulbs including rear have a malfunction on the dash and that the Xenons and DRLS are constantly on AND when the light switch is on any Position other than 0 / off i get fog lights and the fog light buttons wont work along with the dash brightness control.
The confusing bit is when i plug the other BCM in everything works ok / No bulb warnings atall, Light switch works perfect , Fogs switch on etc. The only thing that will not work is the Xenon shutter as it is not supported by the BCM.
Any help or suggestions would be much appreciated and dont mind paying.
Current coding
07041A42C24122FD03844004B31407A80000000000000000000000000000
Old BCM coding
07041842C24102FD03844004B31407A80000000000000000000000000000
Full scan attached
Thursday,25,October,2018,21:43:47:26184
VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
VIN: WAUZZZ8VXFA******   License Plate:
Mileage:    Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 52 5F BB BC
VIN: WAUZZZ8VXFA******   Mileage:
Address 01: Engine (J623-CJSB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 E    HW: 06K 907 425 A
   Component: 1.8l R4 TFSI  H09 0002
   Revision: --H09---
   Coding: 0A9D00322426010B2000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM18TFS0218V0906264E 001003
   ROD: EV_ECM18TFS0218V0906264E_AU37.rod
   VCID: 3E30C621A111FDBAE7-806A
   Part No SW: 0D9 300 012 J    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4517
   Revision: 05853104    Serial number: TFK01410081510
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1D7221AD0CD786A2DE-8048
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63094000000076
   Coding: 12F18AA234282A740379070641C82948512C54C0E08294F5024100788208
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 3D32C12DAC17E6A2FE-8068
25 Faults Found:
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [undervoltage]
                    Reset counter: 207
                    Mileage: 50490 km
                    Date: 2018.10.23
                    Time: 14:11:54
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Fault Frequency: 10
                    Reset counter: 207
                    Mileage: 50076 km
                    Date: 2018.10.13
                    Time: 00:00:12
8204 - Databus
          [FCAN: Airbag_02 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8212 - Databus
          [FCAN: BEM_05 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8220 - Databus
          [FCAN : Gateway_72 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8222 - Databus
          [FCAN : Getriebe_11 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8226 - Databus
          [FCAN : Getriebe_14 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8228 - Databus
          [FCAN: Klemmen_Status_01 is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8236 - Databus
          [FCAN: Kombi_01 messagei is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8246 - Databus
          [FCAN: Motor_Code_01 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8250 - Databus
          [FCAN: Motor_07 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8252 - Databus
          [FCAN: Motor_11 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8256 - Databus
          [FCAN: Motor_14 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8268 - Databus
          [FCAN: VIN_01 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8286 - Databus
          [FCAN: MO_Timeout_ESP signal is invalid]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:06:09
8343 - Databus
          [FCAN : Gateway_79 message is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8352 - Databus
          [FCAN: TSG_FT_02 is not received]
                    Reset counter: 191
                    Mileage: 50076 km
8374 - Databus
          [FCAN: Dimmung_01 is not received]
                    Reset counter: 191
                    Mileage: 50076 km
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 188
                    Mileage: 50036 km
                    Date: 2018.10.12
                    Time: 23:27:55
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 207
                    Mileage: 50076 km
                    Date: 2018.10.13
                    Time: 00:00:22
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 207
                    Mileage: 50076 km
                    Date: 2018.10.13
                    Time: 00:00:22
32868 - Databus
          [IPB_BUS: Gateway_72 / ZV_02_alt invalid]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:06:07
32869 - Databus
          [IPB-BUS: Airbag_02 / AB_Gurtschloss_FA invalid]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:06:07
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000657922
   Coding: 03100014000000011000000000001100
   VCID: 3326E7159A5320D218-8066
   Serial number: 0A090957000000000001
196865 - Temperature Sensor for Footwell Vent
          B1085 11 [008] - Short to Ground
                    Reset counter: 207
                    Mileage: 50501 km
                    Date: 2018.10.23
                    Time: 16:32:10
                    Outside air temperature: 23.5 °C
                    Voltage terminal 30: 14.1 V
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Fault Frequency: 11
                    Reset counter: 173
                    Mileage: 50501 km
                    Date: 2018.10.23
                    Time: 16:32:10
                    Engine speed: 760.00 /min
                    Temperature after evaporator: 40.0 °C
                    Refrigerant pressure: 1.0 bar
                    System run time-Terminal 15 on: 253 s
459018 - Databus
                    Fault Frequency: 12
                    Reset counter: 173
                    Mileage: 50501 km
                    Date: 2018.10.23
                    Time: 16:32:15
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001633802914
   Coding: 07041A42C24122FD03844004B31407A80000000000000000000000000000
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F4EFB25E69B34B2AC-802A
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 141025  041 0580
   Serial number:         141027075700
   Coding: 0A47F7
   Serial number: 23414961
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY142740NEQ
   Serial number: 00000000000031099075
24 Faults Found:
10506 - Bulb for Left Tail Light
          B12BE 15 [009] - Open or Short to Plus
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:15
10762 - Bulb for Right Tail Light
          B12BF 15 [009] - Open or Short to Plus
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:15
18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [024] - Voltage Supply Open or Short to Plus
          Intermittent - Confirmed - Not Tested Since Memory Clear
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:08:01
65802 - Rear Left Ride-Height Sensor
          C1036 15 [009] - Open or Short to Plus
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:15
132363 - Voltage Supply; Terminal 30; Left
          B140D 13 [008] - Open Circuit
                    Reset counter: 212
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:08:00
133131 - Voltage Supply Terminal 30
          B1423 13 [008] - Open Circuit
                    Reset counter: 212
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:08:00
133899 - Voltage Supply; Terminal 30 for Seat Heaters
          B1411 13 [009] - Open Circuit
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:15
137217 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Reset counter: 212
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:08:01
262664 - Switch for Interior Monitoring / Inclination Sensor
          B131B 29 [009] - Signal Implausible
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:22:51
267012 - No Communications with Anti-Theft Siren / Alarm Horn
          U10F3 00 [008] - -
          [Sirene-DWA->kein Signal/Kommunikation]
                    Reset counter: 212
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:22:29
395273 - Control Circuit for Signal Horn
          B1344 14 [008] - Open or Short to Ground
                    Reset counter: 212
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:08:01
460041 - Heated Rear Window
          B1265 14 [008] - Open or Short to Ground
                    Reset counter: 212
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:07:59
529173 - Databus
          [Anhaenger_01 Datenbus fehlende Botschaft]
                    Reset counter: 173
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:19
533013 - Databus
          [ELV_01 Datenbus fehlende Botschaft]
                    Reset counter: 173
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:33
536853 - Databus
          [HDSG_01 Datenbus fehlende Botschaft]
                    Reset counter: 173
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:19
538389 - Databus
          [Kessy_04 Datenbus fehlende Botschaftz]
                    Reset counter: 173
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:19
540693 - Databus
          [LWR_AFS_01 Datenbus fehlende Botschaft]
                    Reset counter: 173
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:19
560149 - Databus
          [SAD_01 Datenbus fehlende Botschaft]
                    Reset counter: 173
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:32
568086 - Databus
          [LCM links - Blinker defekt]
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:06:28
568342 - Databus
          [LCM rechts - Blinker defekt]
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:06:29
568836 - Databus
          [LWR AFS - Kein Signal/Kommunikation]
                    Reset counter: 173
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:19
919560 - Light Switch
          B126A 29 [009] - Signal Implausible
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:15
1053188 - Lamp 1 for Contour Lighting of Roof
          U119A 00 [009] - No Communications
          [PSD - Slave 1->kein Signal/Kommunikation]
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:19
1054468 - Lamp 2 for Contour Lighting of Roof
          U119C 00 [009] - No Communications
          [PSD - Slave 2->kein Signal/Kommunikation]
                    Reset counter: 172
                    Mileage: 50561 km
                    Date: 2018.10.25
                    Time: 16:05:20
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331431403638
   Coding: 0010050011
   VCID: 42C8B2D1D5E9995A83-8016
6 Faults Found:
1111828 - Front Left Parking Aid Sensor
          B10F7 14 [008] - Open or Short to Ground
                    Reset counter: 206
                    Mileage: 50025 km
                    Date: 2018.10.12
                    Time: 23:02:00
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [008] - Open or Short to Ground
                    Reset counter: 206
                    Mileage: 50025 km
                    Date: 2018.10.12
                    Time: 23:02:00
1111812 - Front Left Parking Aid Sensor
          B10F7 04 [008] - Internal System Fault
                    Reset counter: 206
                    Mileage: 50490 km
                    Date: 2018.10.23
                    Time: 13:20:03
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 206
                    Mileage: 50490 km
                    Date: 2018.10.23
                    Time: 14:11:38
13637426 - Databus
                    Reset counter: 207
                    Mileage: 50076 km
                    Date: 2018.10.13
                    Time: 00:00:14
12665088 - Databus
          [Bodycomputer 2 / Zentralmodul Komfortsystem / ZKE - Klemmen_Status_01 - kein Signal/keine Kommunikation]
                    Reset counter: 191
   Serial number: 003M2R097C40
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4BD69FF5E2A3581270-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 611 14
   Serial number: 3576700000094C98811.
   Subsystem 2 - Part No SW: -----------    HW: 480 000 611 14
   Serial number: 3586700000004C98811T
   Subsystem 3 - Part No SW: -----------    HW: 480 402 810 14
   Serial number: 3516502AF1860BC471CN
   Subsystem 4 - Part No SW: -----------    HW: 480 403 010 14
   Serial number: 3526502AB1860BA60268
   Subsystem 5 - Part No SW: -----------    HW: 480 400 409 14
   Serial number: 3556502B3175A8D23047
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 005 15
   Serial number: 22865029D1A2DCD5B2F2
   Subsystem 7 - Part No SW: -----------    HW: 480 402 005 15
   Serial number: 22965029F1A2DCD4733W
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 005 15
   Serial number: 23065029D1A2DCD4623K
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 50501 km
                    Date: 2018.10.23
                    Time: 16:02:27
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 50501 km
                    Date: 2018.10.23
                    Time: 16:02:28
   Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 09111404220693
   Coding: A418
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 095A65FDA85F0A0282-805C
131108 - Databus
          U1121 00 [024] - Missing Message
          [Time-Out Gateway_71: Time-Out BSG]
                    Date: 2127.15.00
                    Time: 31:63:63
                    Operating time: 80673 min
                    Supply voltage: Terminal 30: 11.7 V
                    Voltage at switch: 4.98 V
                    Terminal 15 status: active
                    System status: 30
   Part No SW: 8V0 920 971 C    HW: 8V0 920 971 C
   Component: KOMBI         H02 4291
   Coding: 27A40808238026000100E8001000000000000000
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 E
   Component: GW MQB Mid    127 1204
   Revision: --------    Serial number: 0002638100
   Coding: 030100043F085A005B0002481C0B00000001010000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011_VW37.rod
   VCID: 71AA2D1DA0CF52C22A-8024
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 23 05 2015  E0054472
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001410210570
   Serial number: HA1-00001.10.14
   Coding: 0001
   VCID: 46C0AEC1F9C1A57AAF-8012
9 Faults Found:
16652 - Databus
          [Getriebe - TO -- Get_11]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.16
                    Time: 16:05:35
16654 - Databus
          [Kombi - TO -- Kombi_01]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.16
                    Time: 16:05:35
17466 - Databus
          [Kombi - TO -- Kombi_02]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.16
                    Time: 16:05:35
17473 - Databus
          [Motorsteuergerät - TO -- Mot_11]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.16
                    Time: 16:05:35
16657 - Databus
          [Motorsteuergerät - TO -- Mot_12]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.16
                    Time: 16:05:35
17474 - Databus
          [Motorsteuergerät - TO -- Mot_14]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.16
                    Time: 16:05:35
16727 - Databus
          [Motorsteuergerät - TO -- Mot_20]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.16
                    Time: 16:05:35
17475 - Databus
          [Motorsteuergerät - TO -- Mot_Code]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.16
                    Time: 16:05:35
16659 - Databus
          [Gateway - TO -- Sys_01]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.16
                    Time: 16:05:35
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 17101402090737
   Coding: 00108E205C01040000001002
458752 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:02:42
458809 - Databus
          [Systeminfo_01 Datenbus fehlende Botschaft]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:02:42
458803 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:02:42
458857 - Databus
          [RGS_VL_01 Datenbus fehlende Botschaft]
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:02:42
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8103
   VCID: 43C6B7D5CAF3905288-8016
7 Faults Found:
22272 - Databus
          [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                    Reset counter: 191
                    Motor status: 03
                    System status: Driving mode
                    Supply voltage: 11.50 V
                    Temperature: 14.0 °C
                    KFC: 57
                    KFA: 00 00
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 11.75 V
                    uAdSensI_SwitchedKl30_xdu16: 11.74 V
22528 - Databus
          [MOTOR_12 Botschaft - CAN-Timeout]
                    Reset counter: 191
                    Motor status: 03
                    KFC: 58
                    KFA: 00 00
23040 - Databus
          [MOTOR_20 Botschaft - CAN-Timeout]
                    Reset counter: 191
                    Motor status: 03
                    KFC: 5A
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 11.63 V
                    uAdSensI_SwitchedKl30_xdu16: 11.62 V
18944 - Databus
          [BEM_05 Botschaft - CAN-Timeout]
                    Reset counter: 191
                    Motor status: 03
                    KFC: 4A
                    KFA: 00 00
26624 - Databus
          [KLSTAT_01 Botschaft - CAN-Timeout]
                    Reset counter: 191
                    Motor status: 03
                    KFC: 68
                    KFA: 00 00
22784 - Databus
          [MOTOR_14-Botschaft - CAN-Timeout]
                    Reset counter: 191
                    Motor status: 03
                    KFC: 59
                    KFA: 00 00
24576 - Databus
          [GATEWAY_72 Botschaft - CAN-Timeout]
                    Reset counter: 191
                    Motor status: 03
                    KFC: 60
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 11.59 V
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Serial number: 30101403110643
   Coding: 001086205E01040000001002
   VCID: 41CABDDDD0EF82429A-8014
458752 - Databus
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:02:42
458809 - Databus
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:02:42
458803 - Databus
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:02:42
458857 - Databus
                    Reset counter: 191
                    Mileage: 50076 km
                    Date: 2018.10.17
                    Time: 20:02:42
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    041 0420
   Serial number: A7F00311141493
   Coding: 01730301FF00000021111101000A00002F0004060100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3B36CF35B203E892C0-806E
   Subsystem 1 - Part No SW: 8V0 919 866 C    HW: -----------
   Component:  ECE 2015  --- 0045
   Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY307BH9
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Serial number: C1000020101400030147
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 25101402090616
   Coding: 000086204001040000001002
   VCID: 44C4B4C9CFFD976AB1-8010
   Component: TSG HBFS      020 0028
   Serial number: 25101401100230
End----------(Elapsed Time: 01:28, VBatt start/end: 12.3V/12.4V)-----------
darkchina811
ITALY
C?ID=333184
there's plenty of faults everywhere, how about clearing all DTCs and checking what stays?
also you cannot just swap BCMs all around because CP kicks in at every swap.
remstar
C?ID=124820
Hi Faults has been cleared.The BCM was replaced and the component protection was removed and still remains in place now. There's a few such Faults with airbag as glove box is unplugged , Parking sensor is faulty , As for AWD not sure as its in german
Mika_M
C?ID=183725
You have changed the coding of BCM, but how about adaptation channels? They contain LOTS of stuff that needs to match the actual hardware of car. Including all exterior lighting.
Adaptation maps of old BCM and new BCM would be helpful, I guess.
langers2k
C?ID=224085
Did you check the Kufatec adaptor against the factory wiring diagrams?
I can't see a xenon range module fitted either?
darkchina811
ITALY
C?ID=333184
all the errors like "open circuit", "short to ground", "resistance too high" make me think about wiring issues. also the BCM is complaining about Terminal 30, it means it lacks power supply.
I don't envy you, you got a big mess to troubleshoot.
downtime
C?ID=280813
Like both Mika_M and langers2k already wrote.
First do you have range control module? You won't get anything out of the lights without that. Second, adaptation channels are where the magic is done. Coding is minimal part in BCM nowadays.
remstar
C?ID=124820
Thanks for the help,I do have to hand the range control module 5Q0 907 357 , However as it was halogen lights I don't believe it has this module, Currently all the lights are working and performing ok from outside , The issue im having is that im getting errors saying bulbs are blown on the dash and the headlight switch is not operating correctly as no matter what position the switch is on the lights remain on. As for wiring issues, when the old BCM is connected everything works perfect I don't get no errors , Headlight switch works perfect etc. Its just that you cant code the xenon shutter to work that's why I cant use the original BCM
:banghead:
langers2k
C?ID=224085
Factory xenons have range control modules and level sensors for a reason...
I'd suggest you fit the range control module and level sensors then check your wiring matches the factory spec for xenons. Once that's done, we can move on to coding and adaptions. If you don't know where to get a wiring diagram, try here: https://erwin.audi.com/erwin/showHome.do
Probably worth adding a full autoscan and adaption map for 09 with your original BCM fitted to show where you started from.
Once you fit the xenon range module, add another full autoscan and adaption map for 09 to compare with.
