Results 1 to 9 of 9
Thread: Audi A3 Xenons 8V 2015 - Upgrade
    Sep 2017
    Hi
    Im having some problems with my retrofitted Xenons and need some help with coding.I bought the adaptor lead from Kufatec, I bought the lights ,BCM & light switch from a friend who had it fitted as standard in his.
    The component protection has been removed from the BCM.
    The problem that im having is that im getting warnings that ALL bulbs including rear have a malfunction on the dash and that the Xenons and DRLS are constantly on AND when the light switch is on any Position other than 0 / off i get fog lights and the fog light buttons wont work along with the dash brightness control.
    The confusing bit is when i plug the other BCM in everything works ok / No bulb warnings atall, Light switch works perfect , Fogs switch on etc. The only thing that will not work is the Xenon shutter as it is not supported by the BCM.
    Any help or suggestions would be much appreciated and dont mind paying.
    Current coding
    07041A42C24122FD03844004B31407A8000000000000000000 0000000000
    Old BCM coding
    07041842C24102FD03844004B31407A8000000000000000000 0000000000
    Full scan attached
    Thursday,25,October,2018,21:43:47:26184
    VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
    VIN: WAUZZZ8VXFA******   License Plate:
    Mileage:    Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 52 5F BB BC
    VIN: WAUZZZ8VXFA******   Mileage:
    Address 01: Engine (J623-CJSB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 E    HW: 06K 907 425 A
       Component: 1.8l R4 TFSI  H09 0002
       Revision: --H09---
       Coding: 0A9D00322426010B2000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM18TFS0218V0906264E 001003
       ROD: EV_ECM18TFS0218V0906264E_AU37.rod
       VCID: 3E30C621A111FDBAE7-806A
       Part No SW: 0D9 300 012 J    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4517
       Revision: 05853104    Serial number: TFK01410081510
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 1D7221AD0CD786A2DE-8048
       Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
       Component: ESC           H42 0609
       Revision: 00000000    Serial number: 63094000000076
       Coding: 12F18AA234282A740379070641C82948512C54C0E08294F5024100788208
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
       VCID: 3D32C12DAC17E6A2FE-8068
    25 Faults Found:
    0128 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [undervoltage]
                        Reset counter: 207
                        Mileage: 50490 km
                        Date: 2018.10.23
                        Time: 14:11:54
    0297 - Steering angle sensor
              B1168 16 [008] - Voltage Too Low
                        Fault Frequency: 10
                        Reset counter: 207
                        Mileage: 50076 km
                        Date: 2018.10.13
                        Time: 00:00:12
    8204 - Databus
              [FCAN: Airbag_02 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8212 - Databus
              [FCAN: BEM_05 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8220 - Databus
              [FCAN : Gateway_72 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8222 - Databus
              [FCAN : Getriebe_11 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8226 - Databus
              [FCAN : Getriebe_14 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8228 - Databus
              [FCAN: Klemmen_Status_01 is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8236 - Databus
              [FCAN: Kombi_01 messagei is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8246 - Databus
              [FCAN: Motor_Code_01 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8250 - Databus
              [FCAN: Motor_07 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8252 - Databus
              [FCAN: Motor_11 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8254 - Databus
              [FCAN: Motor_12 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8256 - Databus
              [FCAN: Motor_14 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8258 - Databus
              [FCAN: Motor_20 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8268 - Databus
              [FCAN: VIN_01 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8286 - Databus
              [FCAN: MO_Timeout_ESP signal is invalid]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:06:09
    8343 - Databus
              [FCAN : Gateway_79 message is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8352 - Databus
              [FCAN: TSG_FT_02 is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    8374 - Databus
              [FCAN: Dimmung_01 is not received]
                        Reset counter: 191
                        Mileage: 50076 km
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 188
                        Mileage: 50036 km
                        Date: 2018.10.12
                        Time: 23:27:55
    16412 - Display for Tire Pressure Monitoring
              C1146 02 [008] - Signal Failure
                        Reset counter: 207
                        Mileage: 50076 km
                        Date: 2018.10.13
                        Time: 00:00:22
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 207
                        Mileage: 50076 km
                        Date: 2018.10.13
                        Time: 00:00:22
    32868 - Databus
              [IPB_BUS: Gateway_72 / ZV_02_alt invalid]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:06:07
    32869 - Databus
              [IPB-BUS: Airbag_02 / AB_Gurtschloss_FA invalid]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:06:07
       Component: AC Automat    H13 0060
       Revision: 20027000    Serial number: 00000000657922
       Coding: 03100014000000011000000000001100
       VCID: 3326E7159A5320D218-8066
       Serial number: 0A090957000000000001
    196865 - Temperature Sensor for Footwell Vent
              B1085 11 [008] - Short to Ground
                        Reset counter: 207
                        Mileage: 50501 km
                        Date: 2018.10.23
                        Time: 16:32:10
                        Outside air temperature: 23.5 °C
                        Voltage terminal 30: 14.1 V
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Fault Frequency: 11
                        Reset counter: 173
                        Mileage: 50501 km
                        Date: 2018.10.23
                        Time: 16:32:10
                        Engine speed: 760.00 /min
                        Temperature after evaporator: 40.0 °C
                        Refrigerant pressure: 1.0 bar
    459018 - Databus
                        Fault Frequency: 12
                        Reset counter: 173
                        Mileage: 50501 km
                        Date: 2018.10.23
                        Time: 16:32:15
       Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H34 0236
       Serial number: 02001633802914
       Coding: 07041A42C24122FD03844004B31407A80000000000000000000000000000
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7F4EFB25E69B34B2AC-802A
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 141025  041 0580
       Serial number:         141027075700
       Coding: 0A47F7
       Serial number: 23414961
       Coding: 00006C
       Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY142740NEQ
       Serial number: 00000000000031099075
    24 Faults Found:
    10506 - Bulb for Left Tail Light
              B12BE 15 [009] - Open or Short to Plus
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:15
    10762 - Bulb for Right Tail Light
              B12BF 15 [009] - Open or Short to Plus
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:15
    18698 - Left LED Module for DRL and Parking Lights
              B12EC F2 [024] - Voltage Supply Open or Short to Plus
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:08:01
    65802 - Rear Left Ride-Height Sensor
              C1036 15 [009] - Open or Short to Plus
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:15
    132363 - Voltage Supply; Terminal 30; Left
              B140D 13 [008] - Open Circuit
                        Reset counter: 212
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:08:00
    133131 - Voltage Supply Terminal 30
              B1423 13 [008] - Open Circuit
                        Reset counter: 212
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:08:00
    133899 - Voltage Supply; Terminal 30 for Seat Heaters
              B1411 13 [009] - Open Circuit
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:15
    137217 - Outside temperature sensor
              B103F 1B [008] - Resistance Too High
                        Reset counter: 212
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:08:01
    262664 - Switch for Interior Monitoring / Inclination Sensor
              B131B 29 [009] - Signal Implausible
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:22:51
    267012 - No Communications with Anti-Theft Siren / Alarm Horn
              U10F3 00 [008] - -
              [Sirene-DWA->kein Signal/Kommunikation]
                        Reset counter: 212
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:22:29
    395273 - Control Circuit for Signal Horn
              B1344 14 [008] - Open or Short to Ground
                        Reset counter: 212
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:08:01
    460041 - Heated Rear Window
              B1265 14 [008] - Open or Short to Ground
                        Reset counter: 212
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:07:59
    529173 - Databus
              [Anhaenger_01 Datenbus fehlende Botschaft]
                        Fault Frequency: 6
                        Reset counter: 173
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:19
    533013 - Databus
              [ELV_01 Datenbus fehlende Botschaft]
                        Fault Frequency: 6
                        Reset counter: 173
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:33
    536853 - Databus
              [HDSG_01 Datenbus fehlende Botschaft]
                        Fault Frequency: 6
                        Reset counter: 173
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:19
    538389 - Databus
              [Kessy_04 Datenbus fehlende Botschaftz]
                        Fault Frequency: 6
                        Reset counter: 173
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:19
    540693 - Databus
              [LWR_AFS_01 Datenbus fehlende Botschaft]
                        Fault Frequency: 6
                        Reset counter: 173
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:19
    560149 - Databus
              [SAD_01 Datenbus fehlende Botschaft]
                        Fault Frequency: 6
                        Reset counter: 173
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:32
    568086 - Databus
              [LCM links - Blinker defekt]
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:06:28
    568342 - Databus
              [LCM rechts - Blinker defekt]
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:06:29
    568836 - Databus
              [LWR AFS - Kein Signal/Kommunikation]
                        Fault Frequency: 6
                        Reset counter: 173
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:19
    919560 - Light Switch
              B126A 29 [009] - Signal Implausible
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:15
    1053188 - Lamp 1 for Contour Lighting of Roof
              U119A 00 [009] - No Communications
              [PSD - Slave 1->kein Signal/Kommunikation]
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:19
    1054468 - Lamp 2 for Contour Lighting of Roof
              U119C 00 [009] - No Communications
              [PSD - Slave 2->kein Signal/Kommunikation]
                        Reset counter: 172
                        Mileage: 50561 km
                        Date: 2018.10.25
                        Time: 16:05:20
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39331431403638
       Coding: 0010050011
       VCID: 42C8B2D1D5E9995A83-8016
    1111828 - Front Left Parking Aid Sensor
              B10F7 14 [008] - Open or Short to Ground
                        Reset counter: 206
                        Mileage: 50025 km
                        Date: 2018.10.12
                        Time: 23:02:00
    1112596 - Front Right Parking Aid Sensor
              B10FA 14 [008] - Open or Short to Ground
                        Reset counter: 206
                        Mileage: 50025 km
                        Date: 2018.10.12
                        Time: 23:02:00
    1111812 - Front Left Parking Aid Sensor
              B10F7 04 [008] - Internal System Fault
                        Reset counter: 206
                        Mileage: 50490 km
                        Date: 2018.10.23
                        Time: 13:20:03
              U1400 00 [008] - -
              [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                        Reset counter: 206
                        Mileage: 50490 km
                        Date: 2018.10.23
                        Time: 14:11:38
    13637426 - Databus
                        Reset counter: 207
                        Mileage: 50076 km
                        Date: 2018.10.13
                        Time: 00:00:14
    12665088 - Databus
              [Bodycomputer 2 / Zentralmodul Komfortsystem / ZKE - Klemmen_Status_01 - kein Signal/keine Kommunikation]
                        Reset counter: 191
       Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
       Serial number: 003M2R097C40
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4BD69FF5E2A3581270-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 000 611 14
       Serial number: 3576700000094C98811.
       Subsystem 2 - Part No SW: -----------    HW: 480 000 611 14
       Serial number: 3586700000004C98811T
       Subsystem 3 - Part No SW: -----------    HW: 480 402 810 14
       Serial number: 3516502AF1860BC471CN
       Subsystem 4 - Part No SW: -----------    HW: 480 403 010 14
       Serial number: 3526502AB1860BA60268
       Subsystem 5 - Part No SW: -----------    HW: 480 400 409 14
       Serial number: 3556502B3175A8D23047
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 005 15
       Component: PedP_Sensor_D  001 6149
       Serial number: 22865029D1A2DCD5B2F2
       Subsystem 7 - Part No SW: -----------    HW: 480 402 005 15
       Component: PedP_Sensor_P  001 6149
       Serial number: 22965029F1A2DCD4733W
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 402 005 15
       Component: PedP_Sensor_C  001 6149
       Serial number: 23065029D1A2DCD4623K
    9445397 - Key switch for deactivation of passenger-side airbag
              B1020 15 [137] - Open or Short to Plus
                        Mileage: 50501 km
                        Date: 2018.10.23
                        Time: 16:02:27
    9446677 - Redundant signal path for airbag shut-off; passenger side
              B1025 15 [137] - Open or Short to Plus
                        Mileage: 50501 km
                        Date: 2018.10.23
                        Time: 16:02:28
       Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 09111404220693
       Coding: A418
       VCID: 095A65FDA85F0A0282-805C
    131108 - Databus
              U1121 00 [024] - Missing Message
              [Time-Out Gateway_71: Time-Out BSG]
                        Date: 2127.15.00
                        Time: 31:63:63
                        Operating time: 80673 min
                        Supply voltage: Terminal 30: 11.7 V
                        Voltage at switch: 4.98 V
                        Terminal 15 status: active
                        System status: 30
       Part No SW: 8V0 920 971 C    HW: 8V0 920 971 C
       Coding: 27A40808238026000100E8001000000000000000
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 E
       Component: GW MQB Mid    127 1204
       Revision: --------    Serial number: 0002638100
       Coding: 030100043F085A005B0002481C0B00000001010000000000000000000000
       ASAM Dataset: EV_GatewLear 011020
       ROD: EV_GatewLear_011_VW37.rod
       VCID: 71AA2D1DA0CF52C22A-8024
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 23 05 2015  E0054472
       Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
       Component: J367-BDMConti  H02 1011
       Serial number: 74185703001410210570
       Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7082
       Serial number: HA1-00001.10.14
       Coding: 0001
       ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
       VCID: 46C0AEC1F9C1A57AAF-8012
    9 Faults Found:
    16652 - Databus
              [Getriebe - TO -- Get_11]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.16
                        Time: 16:05:35
    16654 - Databus
              [Kombi - TO -- Kombi_01]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.16
                        Time: 16:05:35
    17466 - Databus
              [Kombi - TO -- Kombi_02]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.16
                        Time: 16:05:35
    17473 - Databus
              [Motorsteuergerät - TO -- Mot_11]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.16
                        Time: 16:05:35
    16657 - Databus
              [Motorsteuergerät - TO -- Mot_12]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.16
                        Time: 16:05:35
    17474 - Databus
              [Motorsteuergerät - TO -- Mot_14]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.16
                        Time: 16:05:35
    16727 - Databus
              [Motorsteuergerät - TO -- Mot_20]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.16
                        Time: 16:05:35
    17475 - Databus
              [Motorsteuergerät - TO -- Mot_Code]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.16
                        Time: 16:05:35
    16659 - Databus
              [Gateway - TO -- Sys_01]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.16
                        Time: 16:05:35
       Serial number: 17101402090737
       Coding: 00108E205C01040000001002
    458752 - Databus
              [Airbag_01 Datenbus fehlende Botschaft]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:02:42
    458809 - Databus
              [Systeminfo_01 Datenbus fehlende Botschaft]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:02:42
    458803 - Databus
              [Motor_14 Datenbus fehlende Botschaft]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:02:42
    458857 - Databus
              [RGS_VL_01 Datenbus fehlende Botschaft]
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:02:42
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 8103
       VCID: 43C6B7D5CAF3905288-8016
    7 Faults Found:
    22272 - Databus
              [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                        Reset counter: 191
                        Motor status: 03
                        System status: Driving mode
                        Supply voltage: 11.50 V
                        Temperature: 14.0 °C
                        KFC: 57
                        KFA: 00 00
                        Environmental conditions: 20
                        uioUdNotFilt_xdu16: 11.75 V
                        uAdSensI_SwitchedKl30_xdu16: 11.74 V
    22528 - Databus
              [MOTOR_12 Botschaft - CAN-Timeout]
                        Reset counter: 191
                        Motor status: 03
                        KFC: 58
                        KFA: 00 00
    23040 - Databus
              [MOTOR_20 Botschaft - CAN-Timeout]
                        Reset counter: 191
                        Motor status: 03
                        KFC: 5A
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 11.63 V
                        uAdSensI_SwitchedKl30_xdu16: 11.62 V
    18944 - Databus
              [BEM_05 Botschaft - CAN-Timeout]
                        Reset counter: 191
                        Motor status: 03
                        KFC: 4A
                        KFA: 00 00
    26624 - Databus
              [KLSTAT_01 Botschaft - CAN-Timeout]
                        Reset counter: 191
                        Motor status: 03
                        KFC: 68
                        KFA: 00 00
    22784 - Databus
              [MOTOR_14-Botschaft - CAN-Timeout]
                        Reset counter: 191
                        Motor status: 03
                        KFC: 59
                        KFA: 00 00
    24576 - Databus
              [GATEWAY_72 Botschaft - CAN-Timeout]
                        Reset counter: 191
                        Motor status: 03
                        KFC: 60
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 11.59 V
       Serial number: 30101403110643
       Coding: 001086205E01040000001002
       VCID: 41CABDDDD0EF82429A-8014
    458752 - Databus
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:02:42
    458809 - Databus
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:02:42
    458803 - Databus
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:02:42
    458857 - Databus
                        Reset counter: 191
                        Mileage: 50076 km
                        Date: 2018.10.17
                        Time: 20:02:42
    Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
       Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
       Component: MU-S-ND-ER    041 0420
       Serial number: A7F00311141493
       Coding: 01730301FF00000021111101000A00002F0004060100010006
       ASAM Dataset: EV_MUStd4CPASE 002018
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 3B36CF35B203E892C0-806E
       Subsystem 1 - Part No SW: 8V0 919 866 C    HW: -----------
       Component:  ECE 2015  --- 0045
       Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9EY307BH9
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Component: ControlUnit_B  H41 0054
       Serial number: C1000020101400030147
       Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
       Component: TSG HFS       020 0028
       Serial number: 25101402090616
       Coding: 000086204001040000001002
       VCID: 44C4B4C9CFFD976AB1-8010
       Component: TSG HBFS      020 0028
       Serial number: 25101401100230
    End----------(Elapsed Time: 01:28, VBatt start/end: 12.3V/12.4V)-----------
    Apr 2018
    ITALY
    there's plenty of faults everywhere, how about clearing all DTCs and checking what stays?
    also you cannot just swap BCMs all around because CP kicks in at every swap.
    Sep 2017
    Hi Faults has been cleared.The BCM was replaced and the component protection was removed and still remains in place now. There's a few such Faults with airbag as glove box is unplugged , Parking sensor is faulty , As for AWD not sure as its in german
    Sep 2015
    You have changed the coding of BCM, but how about adaptation channels? They contain LOTS of stuff that needs to match the actual hardware of car. Including all exterior lighting.
    Adaptation maps of old BCM and new BCM would be helpful, I guess.
  5. Likes downtime, Dana liked this post
    Oct 2014
    Did you check the Kufatec adaptor against the factory wiring diagrams?
    I can't see a xenon range module fitted either?
  7. Likes downtime liked this post
    Apr 2018
    ITALY
    all the errors like "open circuit", "short to ground", "resistance too high" make me think about wiring issues. also the BCM is complaining about Terminal 30, it means it lacks power supply.
    I don't envy you, you got a big mess to troubleshoot.
  9. Likes Uwe liked this post
  10. #7
    May 2017
    Like both Mika_M and langers2k already wrote.
    First do you have range control module? You won't get anything out of the lights without that. Second, adaptation channels are where the magic is done. Coding is minimal part in BCM nowadays.
  11. Likes Dana liked this post
  12. #8
    Sep 2017
    Thanks for the help,I do have to hand the range control module 5Q0 907 357 , However as it was halogen lights I don't believe it has this module, Currently all the lights are working and performing ok from outside , The issue im having is that im getting errors saying bulbs are blown on the dash and the headlight switch is not operating correctly as no matter what position the switch is on the lights remain on. As for wiring issues, when the old BCM is connected everything works perfect I don't get no errors , Headlight switch works perfect etc. Its just that you cant code the xenon shutter to work that's why I cant use the original BCM
  13. #9
    Oct 2014
    Factory xenons have range control modules and level sensors for a reason...
    I'd suggest you fit the range control module and level sensors then check your wiring matches the factory spec for xenons. Once that's done, we can move on to coding and adaptions. If you don't know where to get a wiring diagram, try here: https://erwin.audi.com/erwin/showHome.do
    Probably worth adding a full autoscan and adaption map for 09 with your original BCM fitted to show where you started from.
    Once you fit the xenon range module, add another full autoscan and adaption map for 09 to compare with.
  14. Likes downtime, Andy, Uwe, Dana liked this post
