Hi All,
I have a Q2 that has the rear parking sensors fitted.
On the A3's you had the option used coding to turn on the visual parking onto the screen.
I do the same process but cant seem to do this on the Q2, has anyone managed to figure out the coding?
Many thanks!!
Scan is below
Many thanks!!
Scan is below
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V8EA015023 Mileage: 40326km-25057miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5514
Revision: 83H22---
Coding: 02190012030501082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79F983BAF8F4DE8C60-802C
18115 - Oxygen (Lambda) Sensor B1 S1
P0132 00 [032] - Signal too High
21125 - Invalid Data Received from Airbag Control Module
U0452 00 [032] - -
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 61603000000176
Coding: 12F18AA224210A710177060241C6294851245080608294F2006100040508
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 7BF599B2F2C8EC9C72-802E
Part No SW: 8V0 820 043 HW: 8V0 820 043
Component: AC Automat H13 0031
Revision: 20021000 Serial number: 00000000098454
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
VCID: 6FEDBDE2B6B0803CCE-803A
Serial number: 9D19CFA6000000000001
329988 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Reset counter: 25
Mileage: 39465 km
Date: 2018.05.26
Time: 11:10:13
Voltage terminal 30: 14.5 V
Interior temperature: 16.0 °C
Outside air temperature: 16 °C
Defroster flap: specified value: 70
Defroster flap: actual value: 0
Defroster flap: actual value: 0.0 %
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011316201669
Coding: 07000A42C24120DD03844004B31C07A80000000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 77FD8582CEE0C8FC16-8022
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130521 041 0580
Serial number: 130601090809
Coding: 0A47F7
Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Serial number: 13 04 2013 00000986
Subsystem 3 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY1313529MY
Serial number: 00000000000056922016
Subsystem 5 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20401466
267030 - Siren / Alarm Horn for Anti-Theft Alarm System
U1137 00 [008] - Implausible Message
Reset counter: 50
Mileage: 1048574 km
Time: 00:00:00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831315901380
Coding: 0000050001
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_002_AU37.rod
VCID: 387F46BE837E0784DF-806C
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Serial number: 003M2R01VTVH
VCID: 4B950972E2E89C1C82-801E
Subsystem 1 - Part No SW: ----------- HW: 480 002 905 13
Serial number: 3576700000005D813D0S
Subsystem 2 - Part No SW: ----------- HW: 480 002 905 13
Serial number: 3586700000024D813D0U
Subsystem 3 - Part No SW: ----------- HW: 480 400 806 13
Serial number: 3516502AD10CBDF2131I
Subsystem 4 - Part No SW: ----------- HW: 480 400 806 13
Serial number: 3526502AB10CBDF2510I
Subsystem 5 - Part No SW: ----------- HW: 480 402 404 13
Serial number: 3556502A50FEADA3924Z
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 506 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A110CBDF271BN
Subsystem 7 - Part No SW: ----------- HW: 480 400 506 13
Component: PedP_Sensor_P 001 6149
Serial number: 22965029F10CBDF5438-
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 400 506 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502AB10CBDF152DQ
Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
Revision: -------- Serial number: 10061304400191
Coding: 8418
ROD: EV_SMLSKLOMQB_013_AU37.rod
Part No SW: 8V0 920 970 N HW: 8V0 920 970 N
Component: KOMBI H03 2210
Coding: 278509002A8046000100EA00000000
VCID: 479D3542FE80787CA6-8012
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000684275
Coding: 030100040B0876005B000248080B00000001000000000000000000000000
ROD: EV_GatewLear_009_VW37.rod
VCID: 3B7559B2B2482C9C32-806E
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Serial number: 02 06 2013 B0199807
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004050393708
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 25051306070500
Coding: 00108E204001040000001002
VCID: 3F8D2DA2A65030BC1E-806A
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D7157AAAC5C22AC0C-8068
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 24051303110882
Coding: 001086204001040000001002
VCID: 3E7350A6A15A39B415-806A
65578 - Motors for Central Locking
B122B 12 [008] - Short to Plus
Fault Frequency: 142
Reset counter: 57
Mileage: 38963 km
Date: 2018.04.25
Time: 10:28:43
65579 - Motors for Central Locking
B122B 11 [009] - Short to Ground
Fault Frequency: 46
Reset counter: 17
Mileage: 38923 km
Date: 2018.04.24
Time: 11:51:52
65593 - Switch for Central Locking
B122D 29 [009] - Signal Implausible
Fault Frequency: 62
Reset counter: 16
Mileage: 38949 km
Date: 2018.04.25
Time: 10:08:15
Component: LWR-ECU 005 0070
Coding: 019C000001000000
VCID: 75E18F8AD4ECBAEC04-8020
Part No SW: 8V0 035 874 A HW: 8V0 035 874
Component: MU-S-ND-ER 040 0370
Serial number: A7F00206131660
Coding: 01730301FF00000021111101000A00002F0004460100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3A7B5CB6BD72159429-806E
Subsystem 1 - Part No SW: 8V0 919 866 A HW: -----------
Component: ECE 2013 --- 0021
Subsystem 2 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9DG6014A3
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000017041300010679
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 30051304080693
Coding: 000086204001040000001002
VCID: 41892B5AD0A4464C68-8014
Component: TSG HBFS 010 0006
Serial number: 30051301100696
End-------------------------(Elapsed Time: 03:56)--------------------------
