Results 1 to 2 of 2
Thread: Q2 - Visual Parking
    Oct 2018
    Q2 - Visual Parking
    Hi All,
    I have a Q2 that has the rear parking sensors fitted.
    On the A3's you had the option used coding to turn on the visual parking onto the screen.
    I do the same process but cant seem to do this on the Q2, has anyone managed to figure out the coding?
    Many thanks!!
    Scan is below
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V8EA015023   Mileage: 40326km-25057miles
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 5514
       Revision: 83H22---
       Coding: 02190012030501082000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
       ROD: EV_ECM20TDI01104L906021DS_002.rod
       VCID: 79F983BAF8F4DE8C60-802C
    18115 - Oxygen (Lambda) Sensor B1 S1
              P0132 00 [032] - Signal too High
    21125 - Invalid Data Received from Airbag Control Module
              U0452 00 [032] - -
       Revision: 00000000    Serial number: 61603000000176
       Coding: 12F18AA224210A710177060241C6294851245080608294F2006100040508
       ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
       VCID: 7BF599B2F2C8EC9C72-802E
       Part No SW: 8V0 820 043     HW: 8V0 820 043
       Component: AC Automat    H13 0031
       Revision: 20021000    Serial number: 00000000098454
       Coding: 03100104002000011000000000001100
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
       VCID: 6FEDBDE2B6B0803CCE-803A
       Serial number: 9D19CFA6000000000001
    329988 - Motor for Defroster Flap
              B1090 71 [008] - Actuator stuck
                        Reset counter: 25
                        Mileage: 39465 km
                        Date: 2018.05.26
                        Time: 11:10:13
                        Voltage terminal 30: 14.5 V
                        Interior temperature: 16.0 °C
                        Outside air temperature: 16 °C
                        Defroster flap: specified value: 70
                        Defroster flap: actual value: 0
                        Defroster flap: actual value: 0.0 %
       Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
       Component: BCM MQBAB H   H14 0112
       Serial number: 00011316201669
       Coding: 07000A42C24120DD03844004B31C07A80000000000000000000000000000
       ROD: EV_BCMBOSCH_011.rod
       VCID: 77FD8582CEE0C8FC16-8022
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 130521  041 0580
       Serial number:         130601090809
       Coding: 0A47F7
       Light switch:
       Subsystem 2 - Part No SW: 8V0 941 531 J    HW: 8V0 941 531 J
       Serial number: 13 04 2013  00000986
       Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY1313529MY
       Serial number: 00000000000056922016
       Subsystem 5 - Part No SW: 8U0 955 559     HW: 8U0 955 559
       Serial number: 20401466
    267030 - Siren / Alarm Horn for Anti-Theft Alarm System
              U1137 00 [008] - Implausible Message
                        Reset counter: 50
                        Mileage: 1048574 km
                        Time: 00:00:00
       Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H09 0033
       Revision: --------    Serial number: 60831315901380
       Coding: 0000050001
       ASAM Dataset: EV_EPHVA14AU3700000 002018
       ROD: EV_EPHVA14AU3700000_002_AU37.rod
       VCID: 387F46BE837E0784DF-806C
       Serial number: 003M2R01VTVH
       VCID: 4B950972E2E89C1C82-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 002 905 13
       Serial number: 3576700000005D813D0S
       Subsystem 2 - Part No SW: -----------    HW: 480 002 905 13
       Serial number: 3586700000024D813D0U
       Subsystem 3 - Part No SW: -----------    HW: 480 400 806 13
       Serial number: 3516502AD10CBDF2131I
       Subsystem 4 - Part No SW: -----------    HW: 480 400 806 13
       Serial number: 3526502AB10CBDF2510I
       Subsystem 5 - Part No SW: -----------    HW: 480 402 404 13
       Serial number: 3556502A50FEADA3924Z
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 506 13
       Serial number: 2286502A110CBDF271BN
       Subsystem 7 - Part No SW: -----------    HW: 480 400 506 13
       Serial number: 22965029F10CBDF5438-
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 506 13
       Serial number: 2306502AB10CBDF152DQ
       Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
       Revision: --------    Serial number: 10061304400191
       Coding: 8418
       ROD: EV_SMLSKLOMQB_013_AU37.rod
       Part No SW: 8V0 920 970 N    HW: 8V0 920 970 N
       Component: KOMBI         H03 2210
       Coding: 278509002A8046000100EA00000000
       VCID: 479D3542FE80787CA6-8012
       Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1144
       Revision: --------    Serial number: 0000684275
       Coding: 030100040B0876005B000248080B00000001000000000000000000000000
       ASAM Dataset: EV_GatewLear 009013
       ROD: EV_GatewLear_009_VW37.rod
       VCID: 3B7559B2B2482C9C32-806E
       Serial number: 02 06 2013  B0199807
       Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
       Component: J367-BDM  H08 0192
       Serial number: 00000000004050393708
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 25051306070500
       Coding: 00108E204001040000001002
       VCID: 3F8D2DA2A65030BC1E-806A
       Coding: 81
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D7157AAAC5C22AC0C-8068
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 24051303110882
       Coding: 001086204001040000001002
       VCID: 3E7350A6A15A39B415-806A
    65578 - Motors for Central Locking
              B122B 12 [008] - Short to Plus
                        Fault Frequency: 142
                        Reset counter: 57
                        Mileage: 38963 km
                        Date: 2018.04.25
                        Time: 10:28:43
    65579 - Motors for Central Locking
              B122B 11 [009] - Short to Ground
                        Fault Frequency: 46
                        Reset counter: 17
                        Mileage: 38923 km
                        Date: 2018.04.24
                        Time: 11:51:52
              B122D 29 [009] - Signal Implausible
                        Fault Frequency: 62
                        Reset counter: 16
                        Mileage: 38949 km
                        Date: 2018.04.25
                        Time: 10:08:15
       Component: LWR-ECU       005 0070
       Coding: 019C000001000000
       VCID: 75E18F8AD4ECBAEC04-8020
       Part No SW: 8V0 035 874 A    HW: 8V0 035 874
       Component: MU-S-ND-ER    040 0370
       Serial number: A7F00206131660
       Coding: 01730301FF00000021111101000A00002F0004460100010006
       ASAM Dataset: EV_MUStd4CPASE 002018
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 3A7B5CB6BD72159429-806E
       Subsystem 1 - Part No SW: 8V0 919 866 A    HW: -----------
       Component:  ECE 2013  --- 0021
       Subsystem 2 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
       Component: DU Std  H47 0013
       Serial number: AUZ8Z9DG6014A3
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
       Component: ControlUnit_B  H33 0037
       Serial number: C1000017041300010679
       Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
       Component: TSG HFS       010 0006
       Serial number: 30051304080693
       Coding: 000086204001040000001002
       VCID: 41892B5AD0A4464C68-8014
       Component: TSG HBFS      010 0006
       Serial number: 30051301100696
    End-------------------------(Elapsed Time: 03:56)--------------------------
    Jun 2017
    Since 2016 respectively since the introduction of MIB2 this is not possible anymore in the Audi world.
    Don't ask why, I don't know
    Your scan seems to be from an A3 8V.
  3. Likes Dana liked this post
