Auto scan supplied.
dnesday,24,October,2018,12:20:06:39082
VCDS Version: 18.9.0.2 HEX-V2 CB: 0.4436.4
VIN: WAUZZZ8P5AB014031 License Plate: PY59NRN
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 61 62 72
37-Navigation -- Status: Not registered 0011
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 M HW: 03L 906 023 L
Component: 1,6l R4 CR td H23 8790
Revision: --H23--- Serial number: AUX7Z0IDFN403M
Coding: 00114016030501080000
Shop #: WSC 02069 000 90108
ASAM Dataset: EV_ECM16TDI02103L906023M 003009
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 3039ED12BAAAD9272E5-8064
6260 - Engine Start Blocked by Immobilizer
P1570 00 [165] - -
Mileage: 295521 km
Date: 2000.01.05
Time: 02:13:06
Coolant temperature: 12 °C
Intake air temperature: 13 °C
Voltage terminal 30: 11.746 V
Immobilizer snapshot A: 2B
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [101] - -
Mileage: 295521 km
Date: 2000.01.05
Time: 02:13:07
Engine speed: 0 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 11.1 V
Readiness: 0010 1000
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Shop #: WSC 00046 412 00000
VCID: 7AAD0F3A2CD6D377D01-802E
Reset counter: 203
Count: 3
Count: 20992
Count: 195
Count: 43264
Fault Status: 01100101
Reset counter: 203
Mileage: 999999 km
Count: 3
Count: 2
Count: 20992
Count: 279
Count: 43264
Reset counter: 203
Mileage: 999999 km
Count: 3
Count: 2
Count: 20992
Count: 295
Count: 43264
Reset counter: 203
Mileage: 999999 km
Count: 3
Count: 2
Count: 20992
Count: 270
Count: 43264
Part No SW: 8P0 820 043 BK HW: 8P0 820 043 BK
Component: KlimavollautomatH09 0140
Revision: 000714 Serial number: 8P0820043BK
VCID: 76B51B0A14CEB717B49-8022
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 0E000A2FB005F0C0207041E00000015C431A29AA004DC12AE4008F800041
VCID: 323DE71AB426EB37581-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K8 951 605
Component: LIN BACKUP HO H10 9003
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Fault Status: 01100111
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 07:32:21
Term 15 Off
Voltage: 11.85 V
Term 50 Off
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB004D0X-
Coding: 30314238303830303037554A305238503053
ROD: EV_Airba10AURB4.rod
VCID: 4FFB8EEEC754A6DF57F-801A
Serial number: 3572DRB40000A2110ADN
Serial number: 3582DRB40000A09C815W
Serial number: 35128RB40000528371DE
Serial number: 35228RB4000051C0CB4L
Serial number: 35547RB4000052ECD96+
Serial number: 35647RB4000052ECD95+
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0002012
VCID: 46D5ABCA24AE6797E49-8012
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 J HW: 8P0 920 982 J
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 224DI005013615
Coding: 0004428
Shop #: WSC 12345 123 12345
VCID: 40D9BDD2068A49A7DE5-8014
00003 - Control Module
014 - Defective
Fault Status: 01101110
Mileage: 240832 km
Date: 2016.08.31
Time: 00:00:23
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0231
Revision: H17 Serial number: 1321J09B1701A3
Coding: E9807F06100202042103
VCID: 6B833A7E5F8C7AFF5B7-803E
Fault Status: 01101011
Fault Frequency: 13
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 07:09:00
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 07:09:03
Address 25: Immobilizer
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8J0 035 193 D HW: 8J0 035 193 D
Component: RNS-E PU EU H07 0220
Revision: 0000013S Serial number: AUZBZ7ND403353
Coding: 0619725
Shop #: WSC 01236 785 00200
VCID: 2B03FA7E9F0CBAFF1B7-807E
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 06:58:48
Mileage: 655350 km
Count: 401
Clock: 06:58
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 06:58:40
02005 - Coding Pin
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 06:58:46
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 06:58:29
Bin. Bits: 00000000 00000000
Bin. Bits: 10000000 00000000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0131764
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
VCID: 313FE816BD20D02F21B-8064
Fault Status: 11100101
Mileage: 999999 km
Date: 2000.01.04
Time: 06:58:40
Battery Volts: 12.1 V
DD
Temperature: 18.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158954817326
VCID: 3635DB0A544EF717749-8062
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0131764
VCID: 47CBA6CE23A47E9F1FF-8012
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0619725
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 06:58:48
Mileage: 655350 km
Count: 401
Clock: 06:58
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 06:58:40
02005 - Coding Pin
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 06:58:46
Reset counter: 203
Mileage: 999999 km
Date: 2000.01.04
Time: 06:58:29
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0231
Revision: -------- Serial number: 1321J09B1701A3
Coding: 0303085A
VCID: 68894572427A51E7365-803C
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790842086
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131216
Shop #: WSC 00046 412 1012544
VCID: 42DDB7DA08865BB7C81-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131216
VCID: 43D3B2DE179C52BFC37-8016
End----(Elapsed Time: 01:19, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
