Steering Wheel module coding (2017 Golf Sportwagen)
delbert
C?ID=11691
I have a 2017 Golf Sportwagen with adaptive cruise control. The clock spring broke and was replaced by the dealership. Part number on the new clock spring is 5Q0-953-569-A. We continue to have the error "button for driver assistance systems is faulty".
The question is if I have a coding problem on the new module or if the button really is broken. The dealer doesn't seem to know anything about coding. The current coding is 6E10. I've done an auto scan and will post below per Uwe's sticky instructions.
Suggestions on how to determine proper coding and if this is an actual "hardware" button problem?
Thanks in advance-
David in Baltimore
Wednesday,24,October,2018,09:47:45:61370
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 18.9.0.2 (x64)
VIN: 3VWC17AU6Hxxxxx   License Plate: MD SARA
Mileage: 56023km-34811mi   Repair Order: 1
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 2B 3C 42 44 47 52 5F 75
VIN: 3VWC17AU6HMxxxxx   Mileage: 56023km-34811miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 K    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 091A00122464002F1000
   Shop #: WSC 00066 790 00149
   ASAM Dataset: EV_ECM18TFS0208V0906264K 001003
   ROD: EV_ECM18TFS0208V0906264K.rod
   VCID: 448DB3ACCF74656AB1-8011
17186 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 28
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:51:24
                    Coolant temperature: 30 ∞C
                    Intake air temperature: 30 ∞C
                    Voltage terminal 30: 12.070 V
                    ACC variants (coding): ACC with braking until at standstill/Stop & Go
                    CCS Switch: ACC operating unit
                    Cruise control switch actuation-Main switch hardware: operated
                    Cruise control switch actuation-Main switch CAN: not activated
                    ACC variants: ACC with braking until at standstill
                    Engine: operating status: ES
17176 - Databus
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 18:18:08
                    Engine speed: 1301.00 /min
                    Normed load value: 18.8 %
                    Coolant temperature: 69 ∞C
                    Intake air temperature: 54 ∞C
                    Voltage terminal 30: 12.187 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
18876 - Cruise Control Switch (E45)
          P0568 00 [047] - Implausible Signal
                    Fault Frequency: 23
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:51:22
                    Engine speed: 1363.50 /min
                    Vehicle speed: 43 km/h
                    Coolant temperature: 84 ∞C
                    Voltage terminal 30: 14.023 V
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Control component verified: No
                    Engine: operating status: PU
17187 - Cruise Control Switch (E45)
          P0568 00 [040] - Implausible Signal
                    Fault Frequency: 24
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:51:24
19853 - Implausible Data Received from Steering Column Control Module
          U0429 00 [046] - -
                    Fault Frequency: 165
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:30
                    Engine speed: 1329.50 /min
                    Normed load value: 17.3 %
                    Coolant temperature: 83 ∞C
                    Intake air temperature: 23 ∞C
                    Voltage terminal 30: 12.421 V
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    Engine oil temperature: 45.0 ∞C
                    Time since engine start: 0.4 s
                    T_ES: 0 min
                    T_AST_SAE: 0 s
Readiness: 0000 0100
   Part No SW: 09G 927 749 AP    HW: 09G 927 749
   Component: AISIN AG6 G3  129 3134
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 071764A0BEC28E7294-8053
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61756000001341
   Coding: 04FA6AA124200971407B020881C82920562490024081943416405050C08203
   Shop #: WSC 01383 790 50316
   VCID: 7BFF0850F20ADA9280-802F
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Revision: 00021000    Serial number: 0404706163
   Coding: 032C0C
   VCID: 3B7FC850B28A1A92C0-806F
   Part No SW: 5GM 907 044 C    HW: 5GM 907 044 C
   Revision: 00001K03
   Coding: 02020024200100000005000012111402
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 865824071600RB
   Coding: 00511846404182E969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 00206
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AF10D54FD30E39A9B-802F
   Component: WWS    160804  043 0581
   Serial number:         160812045533
   Component: RLHS  042 0105
   Serial number: S4Y16M06D29H13M26S14
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST000WQHAD00000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST000WQH7A00000
   Coding: 191800
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 94
                    Mileage: 55912 km
                    Date: 2018.10.21
                    Time: 14:48:20
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 3500000141FFC428949C8045000016
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
7 Faults Found:
2165 - Steering Column Control Module
          B105D 00 [009] -  -
                    Reset counter: 56
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Control Module temperature: 32 ∞C
                    Voltage terminal 15: 11.9 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
                    Status_ACC_System: ACC_irreversible error
2060 - Databus
          U1122 00 [009] - Implausible Message
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
2062 - Databus
                    Reset counter: 87
                    Mileage: 55799 km
                    Date: 2018.10.20
                    Time: 12:02:33
                    Control Module temperature: 29 ∞C
                    Voltage terminal 15: 13.8 V
2064 - Databus
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 16:02:28
                    Control Module temperature: 20 ∞C
                    Voltage terminal 15: 11.8 V
                    Status_ACC_System: ACC_Init
2127 - Databus
                    Reset counter: 96
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:57
1116 - Databus
                    Fault Frequency: 21
                    Reset counter: 96
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:55:27
                    Control Module temperature: 36 ∞C
                    Voltage terminal 15: 13.9 V
2068 - Databus
                    Reset counter: 56
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
   Serial number: 003GCR055ATL
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4797A4A0FE424E7254-8013
   Occupant Detection:
   Serial number: IBH000000000005LPM1Y
   Coding: 303137
   Subsystem 2 - Part No SW: -----------    HW: 480 001 606 16
   Serial number: 3570000000071C19FB1T
   Subsystem 3 - Part No SW: -----------    HW: 480 001 606 16
   Serial number: 35800000000B1C45DB1V
   Subsystem 4 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 35100029F20EDB66129D
   Subsystem 5 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 3520002C5209E9E531AA
   Subsystem 6 - Part No SW: -----------    HW: 480 401 706 16
   Serial number: 3550002C921160C1B12U
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 3560002BD20EDB60A11C
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20180211400293
   Coding: 6E10
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C7DCB4CB7841DAAC9-8069
226843 - Turn Signal Switch
          B1144 13 [009] - Open Circuit
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Ubat 30 Voltage: 12.20 V
                    Ignition State: On
                    Terminal 15: 11.40 V
                    A/D #1: 97.25 %
                    A/D #2: 97.25 %
                    A/D #3: 0.00 %
          B1149 13 [009] - Open Circuit
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Ignition State: On
                    A/D #1: 97.25 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
229131 - Cruise Control Switch
          B1154 13 [009] - Open Circuit
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Ignition State: On
                    A/D #1: 97.65 %
                    A/D #2: 97.25 %
                    A/D #3: 0.00 %
229147 - Cruise Control Switch
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Ignition State: On
                    A/D #1: 97.65 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
229160 - Cruise Control Switch
          B1154 29 [009] - Signal Implausible
                    Fault Frequency: 39
                    Reset counter: 56
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Ignition State: On
                    A/D #1: 97.65 %
                    A/D #2: 100.00 %
                    A/D #3: 0.00 %
   Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
   Component: KOMBI         244 8311
   Coding: 0BA4111AA588CF0502886A095000000000000000
   VCID: 264909245908B77A8F-8073
   Revision: --------    Serial number: 21051610801106
   Coding: 0901000830085900FB0002181C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CFD0B4CF704DDAA89-8029
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Serial number: 29160000709030096142
   Coding: 35FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0137235
   Revision: 00000000    Serial number: 16000110582003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346DE36C9FD4D5EA01-8061
   Component: HRE_Master    H12 0071
   Serial number: 0407573659
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0071
   Serial number: 0407465141
   Coding: 010111
   Serial number: 150716060500PD
   Coding: 003A13200000020000000000
   VCID: 438FB0B0CA7A625288-8017
   Serial number: 00000000000013257163
   Coding: 011000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 0102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 458BAEA8C44E5C62A6-8011
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA020GP7
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6DDB3608BC7E44220E-8039
   Serial number: 190716060508OR
   VCID: 4281B5B4D5606B5A83-8017
   Serial number: 00000000000013255387
   Coding: 091000
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0755
   Coding: 027302020000000051220002001808009F0100F401200105C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3261E57465C0DBDA13-8067
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJX0079V
   Subsystem 2 - Part No SW: 3G0 919 866 AC    HW: -----------
   Component: NAR 2016/17  --- 0445
          B11CF 53 [009] - Deactivated
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:30
                    Voltage terminal 30: 12.0 V
                    SDARS_tuner_status_2-Antenna current: 134 mA
                    SDARS_tuner_status_2-Reception quality: weak_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
   Component: OCULowMQBUS   007 0568
   Coding: 02730202C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 04:53)--------------------------
Address 16,5Q0 953 569 A,recoded (Long Coding),from,6E10,to,6E10,(01286/386/08256),
                Address 16: Steering wheel       Labels: 5Q0-953-549.clb
Control Module Part Number: 5Q0 953 569 A    HW: 5Q0 953 569 A
  Component and/or Version: Lenks.Modul   075 0235
           Software Coding: 6E10
            Work Shop Code: WSC 01286 386 08256
              ASAM Dataset: EV_SMLSVALEOMQB 001016 (VW37)
                      VCID: 3C7DCB4CAF841DAAC9-8069
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Ignition State: On
                    A/D #1: 97.25 %
                    A/D #2: 97.25 %
                    A/D #3: 0.00 %
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Ignition State: On
                    A/D #1: 97.25 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Ignition State: On
                    A/D #1: 97.65 %
                    A/D #2: 97.25 %
                    A/D #3: 0.00 %
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Ignition State: On
                    A/D #1: 97.65 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
                    Fault Frequency: 41
                    Reset counter: 56
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
                    Ignition State: On
                    A/D #1: 97.65 %
                    A/D #2: 100.00 %
                    A/D #3: 0.00 %
Address 16: DTCs cleared
Address 01: DTCs cleared
Address 01: DTCs clearedWednesday,24,October,2018,10:24:26:61370
VIN: 3VWC17AU6HMxxxxx   License Plate: MD SARA
   Revision: --H13---
17186 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 56023 km
                    Date: 2018.10.24
                    Time: 10:19:23
                    Engine speed: 696.25 /min
                    Normed load value: 23.5 %
                    Coolant temperature: 102 ∞C
                    Intake air temperature: 70 ∞C
                    Voltage terminal 30: 14.531 V
          P0568 00 [039] - Implausible Signal
                    Mileage: 56023 km
                    Date: 2018.10.24
                    Time: 10:20:19
                    Engine speed: 694.50 /min
                    Normed load value: 22.7 %
                    Intake air temperature: 72 ∞C
                    Mileage: 56023 km
                    Date: 2018.10.24
                    Time: 10:19:23
                    Engine speed: 698.25 /min
                    Normed load value: 23.9 %
                    Voltage terminal 30: 14.472 V
          U0429 00 [047] - -
                    Mileage: 56023 km
                    Date: 2018.10.24
                    Time: 10:18:37
                    Engine speed: 694.00 /min
                    Coolant temperature: 104 ∞C
                    Intake air temperature: 71 ∞C
                    Voltage terminal 30: 14.550 V
                    Engine oil temperature: 100.0 ∞C
                    Time since engine start: 514.3 s
                    T_ES: 0 min
                    T_AST_SAE: 0 s
Readiness: 1010 1101
   Coding: 032C0C
   Revision: 00001K03
   Coding: 00A8DD
   Sun Roof:
   Coding: 191800
   Roof Blind:
   Coding: 191800
544533 - Databus
                    Reset counter: 96
                    Mileage: 56023 km
                    Date: 2018.10.24
                    Time: 10:17:47
                    Reset counter: 94
                    Mileage: 55912 km
                    Date: 2018.10.21
                    Time: 14:48:20
7 Faults Found:
          B105D 00 [009] -  -
                    Fault Frequency: 10
                    Reset counter: 56
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
2060 - Databus
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
2062 - Databus
                    Reset counter: 96
                    Mileage: 55799 km
                    Date: 2018.10.20
                    Time: 12:02:33
2064 - Databus
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 16:02:28
2127 - Databus
                    Reset counter: 96
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:57
1116 - Databus
                    Fault Frequency: 23
                    Reset counter: 96
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:55:27
2068 - Databus
                    Reset counter: 56
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:36
   Occupant Detection:
   Coding: 303137
   Coding: 6E10
                    Reset counter: 56
                    Mileage: 56023 km
                    Date: 2018.10.24
                    Time: 10:18:07
                    Ubat 30 Voltage: 14.60 V
                    Ignition State: On
                    Terminal 15: 13.80 V
                    A/D #1: 97.25 %
                    A/D #2: 97.65 %
                    A/D #3: 0.00 %
                    Reset counter: 56
                    Mileage: 56023 km
                    Date: 2018.10.24
                    Time: 10:18:07
                    Ignition State: On
                    A/D #1: 97.25 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
                    Reset counter: 56
                    Mileage: 56023 km
                    Date: 2018.10.24
                    Time: 10:18:07
                    Ignition State: On
                    A/D #1: 97.25 %
                    A/D #2: 97.25 %
                    A/D #3: 0.00 %
                    Reset counter: 56
                    Mileage: 56023 km
                    Date: 2018.10.24
                    Time: 10:18:07
                    Ignition State: On
                    A/D #1: 98.04 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
                    Reset counter: 56
                    Mileage: 56023 km
                    Date: 2018.10.24
                    Time: 10:18:07
                    Ignition State: On
                    A/D #1: 97.65 %
                    A/D #2: 100.00 %
                    A/D #3: 0.00 %
   Coding: 35FFFF
   Coding: 01011103
   Coding: 010111
   Coding: 011000
   Coding: 0102
   Coding: 091000
                    Reset counter: 46
                    Mileage: 55797 km
                    Date: 2018.10.19
                    Time: 14:50:30
End-------------------------(Elapsed Time: 04:48)--------------------------
Fabia3
Poland
C?ID=300418
Is this car after crash?
iichel
Netherlands, eastern part
C?ID=284912
I suppose the best way is to ask the dealer to do an SVM for address 17, this way they can retreive the factory coding.
Or just have a look in the long coding that VCDS offers for your module, it does seem to have a label.
Dana
Western PA, USA
The 16 coding doesn't looks right to me. My previous 2017 Alltrack SEL with driver assist (Headlights, ACC, etc.) was coded to: 0C10
https://forums.ross-tech.com/showthread.php?8917-2017-NAR-Golf-Alltrack
You don't want to copy/paste any of my other coding values into your car but I would try changing 16 to 0C10 to see what faults return after clearing them.
delbert
C?ID=11691
Thanks Dana. I'll try that and see how it goes. It's easy enough to change back if it doesn't work. I'm traveling for a few days and away from the car, but will provide feedback on Sunday night or Monday.
1975 Kombi
Acton, Ontario, Canada
C?ID=211204
Did you ever find an answer for this? My friend has the same issue I believe. Although he has never had the clock spring replaced.
