Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Blank page
    You still haven't explained exactly what you mean by "blank page", there are a number of things that could be. Is your phone screen completely white? Is it pale blue? Do you still see the IOS notification bar and buttons? Do you see a network error? Do you see the measuring value page, with turbo and go back buttons, but the data part is blank? Do you see a go back button of any kind?
  2. #12
    Oct 2018
    just blank browser page wit hex-net ip # in the header that's all, I can email you video or screen shot if you like
  3. #13
    Yes please do.
  4. #14
    Thanks for the email. Lets try to eliminate some things this could be. I put your interface onto the beta update channel, you should have two updates available now, a new codeblock and a new dataset. Please check for updates in VCDS-Mobile and download those two updates, and then see if you are still having the issue.
    If it's still there, please describe the state of the leds on the interface at the moment the blank page first comes up.
  5. Likes Uwe liked this post
  6. #15
    Oct 2018
    I did the updates you provided, then run a test but the same thing had happened again. I've emailed you new video with controller lights in view. Hope it helps you to narrow the issue.
  7. Likes Dana liked this post
  8. #16
    United States
    Thanks for the additional info. You should have a reply to that email from the main Support address.
    Edit: Internal ref to pre-programmed Micro SD Card order O?ID=393101
