First post and already a question to those way more knowledgeable than I.
So, my car is an 2007 Audi S5 V8.
I have retro fitted the later style face lift climate panel, so I have the white on black display. I had component protection removed and I have coded the unit so the blower all works as it should.
However I want to know if it is possible to change some coding somewhere so
a) the errors go and
b) I can get the display working as originally was back on the screen in the dashboard.
I have ran the scan after everything was installed and the codings changed that I could find.....
Any one able to help please?
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
52 53 55 56 77
Address 01: Engine (J623-CAUA) Labels:. 079-907-560-CAU.clb
Part No SW: 8T0 907 560 HW: 8T0 907 560
Component: 4.2l V8/4V H10 0007
Revision: 76H10---
Coding: 01140003180F0120
Shop #: WSC 00402 210 92240
VCID: 77F66A3BC68D27F2E4-8022
Part No SW: 8K0 907 379 J HW: 8K0 907 379 J
Component: ESP8 quattro H03 0190
Coding: 110500
Shop #: WSC 06325 000 00000
VCID: 4084C1E7D3C3A04A95-8014
Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
Component: BCM2.01 H37 0253
Coding: 031000
VCID: 3972AC03B019F182D2-806C
Subsystem 1 - Part No SW: 8T0 959 754 Q HW: 8T0 959 754 Q
Component: FBSAUDIB8 IDG H32 0047
Serial number: 0107000030903001
Subsystem 2 - Part No SW: 8K0 905 852 A HW: 8K0 905 852 A
Component: ELVAUDIB8 H34 0039
Serial number: 0207000000136002
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 HW: 8T0 959 760
Component: MEM-BFS H08 0027
Revision: AA000000 Serial number: 00001001010854
Coding: 00217025002C44440000
VCID: 55AA00B33C4135E2D6-8000
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 T HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 329FU077512394
Coding: 0015002
VCID: 4A90E3CF25FF6A1A4B-801E
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH07 0100
Subsystem 2 - Serial number: 00000000007791
Subsystem 3 - Serial number: 0104.06.070000000100010033ÿ
Subsystem 4 - Serial number: 010033ÿ
00003 - Control Module
Fault Status: 01100101
Reset counter: 54
Mileage: 133367 km
Date: 2018.10.21
Time: 15:13:51
01043 - Control Module; Incorrect Software Version
Reset counter: 54
Mileage: 133367 km
Date: 2018.10.21
Time: 15:14:00
Bin. Bits: 00000000 00000010
Bin. Bits: 00000000 00000000
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Revision: D1000000 Serial number: 01090320151271
Coding: 4806000000
VCID: 78F46907CB93288AED-802C
Reset counter: 54
Mileage: 133367 km
Date: 2018.10.21
Time: 15:09:10
Part No SW: 8K0 907 063 D HW: 8K0 907 279 D
Component: BCM1 1.0 H19 0253
Revision: 05019001 Serial number: 00000000021528
Coding: 2600D0910014AF011709000300005D5D4F9D03C800010141000000
Shop #: WSC 00164 210 82222
VCID: 30649127636330CA65-8064
Subsystem 1 - Part No SW: 8T2 955 119 B HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 060607 H11 0040
Serial number: SWFBIE 0000032
Coding: 00FD11
Subsystem 2 - Part No SW: 8T0 955 559 HW: 4E0 955 559 B
Component: RLS H12 0001
Serial number: 10007422
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000000106070451
Part No SW: 8T2 035 110 C HW: 8T2 035 110 A
Component: MP3-Changer H42 0390
Revision: 00042001 Serial number: AUZ5ZBG4511019
VCID: 2B5E864B8A45531250-807E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276V7201080
Coding: 0000001
VCID: 244C6D77E79B9C6A91-8070
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 HW: 8K0 919 475
Component: PARKHILFE 4K H06 0003
Revision: 11001001 Serial number: 46130716301713
Coding: 100002
VCID: 76E8673FC1875EFAFF-8022
Part No SW: 8K0 959 655 HW: 8K0 959 655
Component: AirbagVW-AU10 H21 0334
Serial number: 0038GD0823HR
Coding: 30323232333030303030554A305238543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
VCID: 7AF0730FFD9F3A9A9B-802E
Serial number: 6334LSME1A4D653BP
Serial number: 6344LSME18565917F
Serial number: 6352QSME2D47794BY
Serial number: 6362QSME2D4B3A5D$
Serial number: 63734SME2F305319$
Serial number: 63834SME2F241723
Revision: 00000000 Serial number: 20120703001132
Coding: 000036
VCID: 4FA6F2DB1E9D4F321C-801A
Part No SW: 8T0 920 980 N HW: 8T0 920 980 N
Component: KOMBIINSTR. H20 0136
Revision: 00200000 Serial number: 6C3113467
Coding: 2F9F010002002600010001
VCID: 4688D7FFF1E78E7AAF-8012
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E0760181C0
Coding: 000003
Shop #: WSC 00353 210 91474
VCID: 448CCDF7C7DBBC6AB1-8010
Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
Component: J367-BDM H06 0120
Serial number: 17001FC5250507
Reset counter: 94
Mileage: 133367 km
Date: 2018.10.21
Time: 15:12:42
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 A
Component: SG ext.Player H09 0850
Revision: 00000000
VCID: 2B5E864B4A45531250-FFFE
Component: MEM-FS H08 0027
Revision: AA000000 Serial number: 00001001011134
Coding: 00397325002C44440000
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H49 1060
Revision: 00000000 Serial number: 333EQ077511487
VCID: 3B7EB60B7A25C392C0-806E
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: 0F5`
Coding: 011C02225E012201
VCID: 7DFA7813E4B10DA2BE-8028
Revision: 00002001 Serial number: 0104283408
Coding: 011F0682003904C0033000
Component: DWA-Sensor H02 0030
Part No SW: 8T0 035 223 T HW: 8T0 035 223 C
Component: DSP Prem H11 0400
Revision: 00H11003 Serial number: 34812000432300
Coding: 020101
Shop #: WSC 12336 024 394758
VCID: 3F86C21BAE3DDFB2EC-806A
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0149
Revision: Serial number: 0… `
VCID: 7CFC7517FFAB04AA89-8028
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0030
Revision: 00000001 Serial number: 00000000007404
VCID: 2F66925B7E5D2F327C-807A
Part No: 8K0 907 357
VCID: 72E05B2F6DEF42DAD3-8026
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336FI077510035
Coding: 0000001
VCID: 2E588F5FB957263A77-807A
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 D HW: 4F1 862 335
Component: BTA H09 1120
Revision: 00H09000 Serial number: 00000007535623
Coding: 0010021
VCID: 254A7073ECA1656286-8070
End-------------------------(Elapsed Time: 03:33)
