First, i have to say sorry for my bad english... I am french. I will try my best.
I have a Tiguan Oct 2015 2.0 TDI 150CV Lounge Model.
I changed some parameters with no problems until now.(Like check needles, auto rabattable mirror, comfort turn signal, etc...)
I tried to pass the level 4 (back) and 5 (front) to level 1 (both) my volume park assist.
=> Here are the steps :
Park assist module / ...back then front volume sensor and change level...
VCDS accept the change, i confirm with "OK".(I test it with an obstacle in front and back of my car and the volume is weaker, its ok)
Then I turn off my car.
But when I turn on my car, the volume park assist parameters are again at their original level, 4 and 5 like I did nothing. (I check it in VCDS).
I did all change with doors closed and contact ON (but motor off... I tried with motor on too).
I tried to type the secured access code for this module (though maybe that was the problem) but VCDS answer "wrong code". (tried 71679 and 20103).But maybe its not the problem cause VCDS accepted my change each times.
(I have the last updated VCDS and HEX-V2 USB Cable (updated firmware too.))
What is wrong ? Some ideas ?...
Thanks to all help I could find.
There is my scan :
There is my scan :
Type chassis: 5N-VW36 (7N0)
Scanner: 01 03 05 08 09 10 15 16 17 19 25 2B 42 44 46 4C 4F 52 53 5F
61 62 6C 72
VIN: WVGZZZ5NZGW032487 Kilométrage: 27140km
01-Moteur -- Etat: OK 0000
03-Freins ABS -- Etat: OK 0000
04-Angle de direction -- Etat: OK 0000
05-Autor. démarrage -- Etat: OK 0000
08-Climatronic -- Etat: OK 0000
09-Centrale Elec. -- Etat: OK 0000
10-Assistance stationnt -- Etat: OK 0000
15-Airbags -- Etat: OK 0000
16-Volant multifonct. -- Etat: OK 0000
17-Instruments -- Etat: OK 0000
19-Gateway CAN -- Etat: OK 0000
25-Anti-démarrage -- Etat: OK 0000
2B-Verr. Col. Direct. -- Etat: OK 0000
42-Porte conducteur -- Etat: OK 0000
44-Direction assistée -- Etat: OK 0000
46-Module confort -- Etat: OK 0000
4C-Pression pneus II -- Etat: OK 0000
4F-Centrale Elect. II -- Etat: OK 0000
52-Porte passager -- Etat: OK 0000
53-Frein de stationnt -- Etat: OK 0000
5F-Electr. d'informat. -- Etat: OK 0000
61-Régul. batterie -- Etat: OK 0000
62-Porte AR gauche -- Etat: OK 0000
6C-Caméra recul -- Etat: OK 0000
72-Porte AR droite -- Etat: OK 0000
Adresse 01: Moteur (J623-CUVC) Labels:. 04L-907-309-V1.clb
No. pièce Log: 04L 906 016 CL Mat: 04L 907 309 K
Pièce: R4 2,0L EDC H20 1841
Révision: 8AH20---
Codage: 01190032042401083000
No. Atelier: WSC 01357 011 00200
Jeu de données ASAM: EV_ECM20TDI01104L906016CL 001004
ROD: EV_ECM20TDI01104L906016CL_001.rod
VCID: 75B71DD1254E810F4B3-8020
1 Code défaut trouvé:
4531 - Activation du ventilateur de radiateur 1 c.c. Ã* la masse
P0691 00 [032] - -
Intermittent - Non Confirmé - Testé depuis RÃ*Z mémoire
Tests passés: 0 0 0 0 0
Adresse 03: Freins ABS Labels: 5N0-614-109-C6.clb
No. pièce Log: 5N0 614 109 BN Mat: 5N0 614 109 BN
Pièce: J104 C6 450M VDD6 0021
Révision: --H07--- No. de série: 00000008950474
Codage: 0038203
VCID: 78A914E53EDCFC67505-802C
Aucun code défaut trouvé.
Adresse 05: Autor. démarrage (J518) Labels:| 5K0-959-434.clb
No. pièce Log: 5K0 959 434 E Mat: 5K0 959 434
Pièce: VWKESSYPQ35GP 092 1202
Révision: 00092000 No. de série: 0375467428
Codage: 030C0C
Jeu de données ASAM: EV_KESSYPQ35G A02717
VCID: 372BD7D97FC2331F99F-8062
Adresse 08: Climatronic (J255) Labels:| 5K0-907-044.clb
No. pièce Log: 1K8 907 044 AB Mat: 1K8 907 044 AB
Pièce: Climatronic H05 0304
Révision: 00001K03
Codage: 001000C003
Jeu de données ASAM: EV_Climatronic A01010
VCID: 6FBB2FB94712BBDF81F-803A
Adresse 09: Centrale Elec. (J519) Labels:. 1K0-937-08x-09.clb
No. pièce Log: 5K0 937 086 T Mat: 5K0 937 086 T
Pièce: BCM PQ35 M 122 0183
Révision: BC122001
Codage: 60180A3B88250AC4408800C0340081644ED13E88476D81B06480C700A041
VCID: 45D7AD1135AE518F1B3-8010
Sous-système 1 - No. pièce Log: 5N1 955 119 B Mat: 5N1 955 119 B Labels: 1KX-955-119.CLB
Pièce: WWS316 020715 24 0664
Codage: 009795
Sous-système 2 - No. pièce: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Pièce: RLS 030815 05 54 0403
Codage: 02304D
Adresse 10: Assistance stationnt (J791) Labels:| 5Q0-919-298.clb
No. pièce Log: 1K8 919 475 B Mat: 5Q0 919 298
Pièce: PARKHILFE PLA H12 0479
Révision: -------- No. de série: 39431521102041
Codage: 0031160041
Jeu de données ASAM: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00_VW36.rod
VCID: 392FD1E149D6256F6FB-806C
Adresse 15: Airbags Labels: 5N0-959-655.lbl
No. pièce Log: 5N0 959 655 AA Mat: 5N0 959 655 AA
Pièce: J234__20J VW10 HI 2518
Révision: 30021000 No. de série: 003L7PG1S3N+
Codage: 0012362
VCID: 7CA108F50AE4D04734D-8028
Sous-système 1 - No. de série: 6332MTS618592105
Sous-système 2 - No. de série: 6342MTS609382095
Sous-système 3 - No. de série: 6351HTS6VH8HQDKR
Sous-système 4 - No. de série: 6361HTS6RP7HQDKR
Sous-système 5 - No. de série: 00000000000000000
Sous-système 6 - No. de série: 00000000000000000
Adresse 16: Volant multifonct. (J527) Labels:| 5K0-953-569.clb
No. pièce Log: 5K0 953 501 DM Mat: 5K0 953 569 AP
Pièce: LENKS.MODUL 016 0180
Révision: FF010042 No. de série: 20150812200987
Codage: 110A140000
Jeu de données ASAM: EV_VW360SteerWheelUDS A03004
VCID: 78A914E5325CFC67505-802C
Calculateur de volant de direction multifonction:
Sous-système 1 - No. pièce Log: 5K0 959 542 C Mat: 5K0 959 542 C Labels: 3C8-959-537.CLB
Pièce: E221__MFL-TAS H31 0037
No. de série: 0860993
Codage: 820000
Adresse 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
No. pièce Log: 5N0 920 883 G Mat: 5N0 920 883 G
Pièce: KOMBI H04 1008
Codage: 111F010000
Jeu de données ASAM: EV_Kombi_UDS_VDD_RM09 A05730
VCID: 3829D4E572DC3C67905-806C
Adresse 19: Gateway CAN (J533) Labels:. 7N0-907-530-V2.clb
No. pièce Log: 7N0 907 530 BB Mat: 7N0 907 530 AM
Pièce: J533 Gateway H55 1663
Révision: H55 No. de série: 110715F1000022
Codage: 356032
VCID: 71BF29C151A6AD2F97B-8024
Adresse 25: Anti-démarrage (J334) Labels:| 5K0-920-xxx-25.clb
No. pièce Log: 5K0 953 234 Mat: 5K0 953 234
Pièce: IMMO H04 1008
Codage: 000007
Jeu de données ASAM: EV_Immo_UDS_VDD_RM09 A03710
VCID: 6A8D3EAD7CF05EF7D61-803E
Adresse 2B: Verr. Col. Direct. (J764) Labels:| 5K0-905-861.clb
No. pièce Log: 5K0 905 861 C Mat: 5K0 905 861 C
Pièce: ELV-PQ35 H21 0240
Révision: 00000000 No. de série: 15000185772006
Codage: 4100000000000000
Jeu de données ASAM: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3039ECC59AACE427D85-8064
Adresse 42: Porte conducteur (J386) Labels:| 3C0-959-70X-GEN4.clb
No. pièce Log: 5N0 959 701 G Mat: 3C0 959 793 C
Pièce: TUER-SG FT 002 0503
Révision: 12110009 No. de série: 0009937008
Codage: 0214BE
Jeu de données ASAM: EV_TSGFPQ35BRFVW46X A04001
Slave Driver:
Sous-système 1 - No. pièce Log: 5N0 959 703 F Mat: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Pièce: J388__TSG-HL 009 1504
No. de série: 00000009481958
Codage: 000490
Adresse 44: Direction assistée Labels: 5N1-909-144.clb
No. pièce Log: 5N1 909 144 R Mat: 5N1 909 148 J
Pièce: J500__APA-BS KL.286 1401
Révision: 1BH04841 No. de série: 00151940172901
Codage: 0000258
VCID: 41DFB9012D867DAF27B-8014
Adresse 4F: Centrale Elect. II (J520) Labels:. 1K0-907-532.clb
No. pièce Log: 7N0 907 532 Mat: 7N0 907 530 AM
Pièce: EZE_2 H55 1663
Codage: 050B0500
VCID: 6FBB2FB94792BBDF81F-803A
Sous-système 1 - No. pièce Log: 7N0 959 591 B Mat: 7N0 959 591 B
Pièce: J245EE04SKB03 H04 0090
No. de série: 0123456789ABCDEFGHIJ
Sous-système 2 - No. pièce Log: 7N0 959 591 B Mat: 7N0 959 591 B
Pièce: J394EE04SKB03 H04 0090
Adresse 52: Porte passager (J387) Labels:| 3C0-959-70X-GEN4.clb
No. pièce Log: 5N0 959 702 G Mat: 3C0 959 792 C
Pièce: TUER-SG BT 002 0503
Révision: 14110009 No. de série: 0009940950
Codage: 0215BE
Jeu de données ASAM: EV_TSGBPQ35BRFVW46X A04001
VCID: 3A2DCEED4CD02E77661-806E
Slave Passenger:
Sous-système 1 - No. pièce Log: 5N0 959 704 F Mat: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Pièce: J389__TSG-HR 009 1504
No. de série: 00000009487825
Codage: 000490
Adresse 53: Frein de stationnt Labels: 3AA-907-801.clb
No. pièce Log: 3AA 907 801 J Mat: 3AA 907 801 J
Pièce: J540 EPB4 VW-63206 0012
Révision: H19 No. de série: 00000000815907
Codage: 0026167
VCID: 3829D4E57E5C3C67905-806C
Adresse 5F: Electr. d'informat. (J794) Labels:| 5G0-035-MIB-STD2.clb
No. pièce Log: 5C0 035 680 B Mat: 5C0 035 680 B
Pièce: MU-S-N-ER H20 0241
No. de série: VWZAZ2R8771013
Codage: 02130601FF00000011110001000808001F01008400200100CF
Jeu de données ASAM: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 20191C85CA4C54A7485-8074
Support de données:
Sous-système 1 - No. pièce Log: 3G0 919 866 AQ Mat: -----------
Pièce: ECE1 2017 --- 0730
No. de série: --------------------
Adresse 61: Régul. batterie (J840) Labels:. 1K0-907-534.clb
No. pièce Log: 7N0 907 534 Mat: 7N0 907 530 AM
Pièce: Batt.regelung H55 1663
Codage: 030F1873
Sous-système 1 - No. pièce Log: 1K0 915 181 H Mat: 1K0 915 181 A
Pièce: J367-BDM H07 0180
No. de série: 42203408391491414838
Adresse 6C: Caméra recul (J772) Labels:| 5Q0-907-441.clb
No. pièce Log: 7N0 907 441 B Mat: 7N0 907 441 B
Pièce: VW428 RVC Mid H04 0040
Codage: 011306010201000700
Jeu de données ASAM: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
Fin----(Temps écoulé: 01:29, VBatt début/fin: 11.6V/11.6V. VIgn 11.7V)-----
Mardi,01,Mai,2018,17:26:57:64378
VCDS -- Logiciel d'émulation de VAG/VAS sous Windows 10 x64
Version VCDS: FRM 18.1.0.2 HEX-V2 CB: 0.4411.4
Version données: 20180122 DS285.1
www.vcds.fr
VIN: WVGZZZ5NZGW032487 Plaque d'immat.:
Kilométrage: 27140km Ordre réparation::
61 62 6C 72
Révision: 8AH20---
P0691 00 [032] - -
Codage: 0038203
Codage: 030C0C
Révision: 00001K03
Codage: 001000C003
Révision: BC122001
Codage: 64180A3B88250AC4408800C0340081644FD13E88476D81B06480C700A041
Codage: 009795
Codage: 02304D
Codage: 0031160041
Codage: 0012362
Codage: 110A140000
Codage: 820000
Codage: 111F010000
Codage: 356032
Codage: 000007
Codage: 0214BE
Slave Driver:
Codage: 000490
Codage: 0000258
Codage: 050B0500
Codage: 0215BE
Slave Passenger:
Codage: 000490
Codage: 0026167
Support de données:
Codage: 030F1873
Fin----(Temps écoulé: 01:28, VBatt début/fin: 11.4V/11.4V. VIgn 11.5V)-----
