Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Tiguan oct 2015 : Level volume park assist sensors
  1. #21
    May 2017
    I'm honestly also quite amazed that there's no effect and the fact that there's no PDC menu visible in infotainment system.
    That what PetrolDave wrote, might be true. Maybe there's a minimum level which is applied first and then it goes down to set level after few seconds. That's how OP described it's working.
  2. #22
    Oct 2018
    France
    Maybe the volume is reset to default levels (read from the configuration in EEPROM?) when the car is turned on
    Ok maybe... How can I have this information ?
    How can I read it ?
    In a second point, I know i can type the securise access code for this module (Maybe it's the reason why... ?), i dont remember if I already did it but now when i try, VCDS said "wrong code".
    I tryed 71679 and 20103, is it right ?
  3. #23
    Quote Originally Posted by Kronos View Post
    How can I read it ?
    I have no idea, it was just a guess based on what you have said about the changes not being permanent and how the comfort blink function works (where it is only read from non-volatile storage when the 5F is restarted).
  4. #24
    New User
    Apr 2020
    absolutly no visible in the car/setup like you said.... honestly I really searched in every menu cause i though my eyes played with my brain
    Perhaps i have to activate this menu with VCDS ?...
    Or perhaps someone have an other idea to help my changes to be saved.
    Seriously, I dont understand : if the options to decrease or increase the volume sensors exist in VCDS, why the changes doesnt works when turn off/turn on the car... its not logical !!??
    Hi Kronos,
    Did you ever solve this volume problem? I am having the exact same issue that my changes get overwritten once the car gets turned off and on again.
    Thanks
  5. #25
    May 2014
    ^^^Jettatdi: Hi - this is an absolute long-shot and nothing more than a guess, but for some tweaks on MQB platform build vehicles (not sure what build platform your car has) it's necessary to engage the factory reset facility in the vehicle to enable the changes to take-effect.
    If your car has such a facility - perhaps try this?
  6. Likes downtime, PetrolDave liked this post
  7. #26
    New User
    Apr 2020
    Hi Don,
    Thanks for the reply. My car is a 2012 mk6 jetta 1.6tdi. I don't see an option for factory reset facility anywhere. All I have found is "Resetting of all adaptions" in 10 park/steer assist basic settings. And clicking this made no difference when I tried to change the volume afterwards.
  8. #27
    Quote Originally Posted by jettatdi View Post
    Since the title of this thread is Tiguan oct 2015 - hijacking this thread is causing confusion as we all thought you had a Tiguan
  9. Likes downtime, Uwe, DV52 liked this post
