Tuesday,23,October,2018,08:24:46:13308
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 72 77
VIN: WAUBFAFL2BN003631 Mileage: 139390km-86612miles
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AD HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H17 0002
Revision: E1H17---
Coding: 0104010A290F0160
ASAM Dataset: EV_ECM20TFS0118K2907115AD 001005
ROD: EV_ECM20TFS0118K2907115AD.rod
VCID: 71BFD67EF12A254F61B-8024
4054 - Cylinder 1
P0301 00 [096] - Misfire Detected
Mileage: 139077 km
Date: 2018.10.16
Time: 16:22:00
Engine speed: 1208.50 /min
Normed load value: 12.5 %
Coolant temperature: 41 °C
Intake air temperature: 26 °C
Ambient air pressure: 930 mbar
Voltage terminal 30: 12.910 V
Unlearning counter according OBD: 24
4060 - Cylinder 3
P0303 00 [096] - Misfire Detected
Mileage: 139077 km
Date: 2018.10.16
Time: 16:22:00
4063 - Cylinder 4
P0304 00 [096] - Misfire Detected
Mileage: 139077 km
Date: 2018.10.16
Time: 16:22:00
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Mileage: 139077 km
Date: 2018.10.16
Time: 16:21:15
Engine speed: 783.50 /min
Normed load value: 9.8 %
Coolant temperature: 31 °C
Intake air temperature: 27 °C
Voltage terminal 30: 11.897 V
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8K0 927 158 K HW: 0BK 927 156 N
Component: 0BK 20TFSIUSA H08 1014
Revision: --H08---
Coding: 001102
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMAL551211 001013
ROD: EV_TCMAL551211_001.rod
VCID: 3E253D42F0F48A37AC9-806A
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0050
Coding: 1D0D10
Shop #: WSC 02391 823 56573
VCID: 025D89B2C40C2ED7881-8056
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H04 0430
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 76B5E56298C40277B49-8022
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0815000146611018
Component: J764 ELV MLB H37 0042
Serial number: 0210000087940014
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 99
Mileage: 138778 km
Date: 2018.10.11
Time: 14:49:12
Part No SW: 8T1 820 043 AN HW: 8T1 820 043 AN
Component: KLIMA 1 ZONE H08 0180
Revision: A1000000 Serial number: 01220520100327
Coding: 64182000
VCID: 7DA7FA4EBDF2512FF53-8028
01207 - Control Module for Auxiliary Heater (J364)
Reset counter: 106
Mileage: 139057 km
Date: 2018.10.15
Time: 17:49:46
03023 - Running-in Requirement
Fault Status: 01100101
Reset counter: 120
Mileage: 139319 km
Date: 2018.10.21
Time: 10:24:17
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H29 0392
Revision: 10029001 Serial number: 00000000552995
Coding: 69080031003CBE010001010300007F5F4F14520802000021000000
VCID: 3C21374AE668982782D-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 010610 H06 0070
Serial number: SWF10060010851
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AK HW: 8K0 941 531 AK
Component: E1 - LDS H08 0090
Serial number: 00000000001905100711
02258 - Door Opener Transmitter
Reset counter: 98
Mileage: 138778 km
Date: 2018.10.11
Time: 14:46:00
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H41 0610
Serial number: 003GLD0G3UL.
Coding: 303837354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
VCID: 45D752AE9522D9EFED3-8010
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1000000602
Serial number: 6334MSME540417734
Serial number: 6344MSME54050631+
Serial number: 6352QSME4C633808L
Serial number: 6362QSME2F5F0C22V
Serial number: 63732SME39631E181
Serial number: 63832SME0A621508W
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304JES0006X
Coding: 000014
VCID: 3D273A4EFD72912FB53-8068
Component: E221 - MFL H02 0010
Part No SW: 8K0 920 950 H HW: 8K0 920 950 H
Component: KOMBIINSTR. H20 0258
Revision: 00100000 Serial number: EIL21KJ5A
Coding: 8337090003005705820001
VCID: 34311F6ACE3850674AD-8060
Reset counter: 138
Mileage: 138778 km
Date: 2018.10.11
Time: 14:14:08
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1051883EC
Coding: 00C303
VCID: 015F86BEC10A35CF91B-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1001C077200510
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
VCID: 392F2E5EE95AAD0F99B-806C
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C03204000410001
VCID: 53F37CF66BF6775F737-8006
Revision: 00002001 Serial number: 0131033247
Coding: 0126163A00FA40048030013200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000264255
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS039 H06 0041
01403 - Glass-Break Sensors; Rear
Reset counter: 98
Mileage: 138778 km
Date: 2018.10.11
Time: 14:46:37
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010102
VCID: 74B1DF6A8EB810678AD-8020
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
VCID: 52FD79F254EC7E57781-8006
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000532403
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000009 Serial number: AUZ5Z6J1413356
Coding: 0402000201018503DD198F0803
VCID: 46D555A2A8A4D2F7E49-8012
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Reset counter: 98
Mileage: 138778 km
Date: 2018.10.11
Time: 14:46:47
Fault Frequency: 42
Reset counter: 125
Mileage: 138934 km
Date: 2018.10.12
Time: 14:41:05
Bin. Bits: 00100000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
01043 - Control Module; Incorrect Software Version
Reset counter: 106
Mileage: 139057 km
Date: 2018.10.15
Time: 17:49:47
Bin. Bits: 00000010
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010C03204000210001
VCID: 56F585E278046277949-8002
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H06 1401
Part No SW: 8T0 862 336 E HW: 8T0 862 336 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005083289
Coding: 0010370
Shop #: WSC 02335 785 00200
VCID: 3D273A4EF172912FB53-8068
End----------(Elapsed Time: 01:37, VBatt start/end: 12.4V/12.4V)-----------
