Results 1 to 10 of 16
Thread: New user in need of assistance - VW Tiguan 5N 1.4 tsi 4wd manual transmission
    Verified VCDS User NikosP's Avatar
    Oct 2018
    Greece
    I got a VCDS and Hex Can interface in order to help me identify faults and trouble shoot on a used Tiguan I recently bought.
    I tried ordering from States but had to go through Uk dealer and managed to get it. Gendan UK are great professionals.
    As you can find on the Autoscan copied bellow , there were plenty of issues some real and some just registered , and not sure how to fix since the car is a runner and all works fine ( I think?).
    Please if you can identify some significant faults given and point me into the right direction on how to solve, since were I live ( Greece Corfu island) there are no dealers of VW or Car engineers dealing with VW ( I am an engineer but on the marine industry myself so pretty switched on technically ) to trust change me a wheel off my skate if I had to...
    The main issues I need to sort out are the following 2 :
    A/ I am equipped with an Off-road Button but doesn't work . The odd is that the car when feels a steep slope activates on its own the off-road aids and you can see the light on dial turned on with the off-road aid sign.
    Nothing wrong to that , but sometimes the off-road aids activate, when you are just driving on flat tarmac road and when stopped on a traffic light been annoying.
    The off-road button is been like dead and doing nothing as to activate or disactivate when that happens and defiantly wont activate on demand.
    Please I would be grateful if you can assist me to that cause sometimes is a bit scary trying to start from traffic light and been restricted from abs as the off-road functions are activated.
    B/ I installed a 9w2 Bluetooth unit on to my RNS510 and follow the wiring as per instructions , but the RNS doesn't sees the Bluetooth ( if I press phone button on wheel or RNS does only mute the audio and nothing else). Also when I try coding 19 and set 77 , but the 77 channel cannot be reached.
    All commands from steering wheel goes right on RNS510 except the phone command that mutes volume.
    Again I will be grateful into your assistance.
    I have done some reset of ecu 9 pulling power cable and sort negative to discharge) The car learns all abs etc again. But no luck.
    tried clear fault codes on central electronic (channel 19) but keep coming up.
    I attach autoscan for help.
    thank you volumes
    nikosP
    Sunday,21,October,2018,13:58:45:37191
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVGZZZ5NZAW054863   License Plate: IOO
    Mileage: 111650km-69376mi   Repair Order:
    Chassis Type: 5N-VW36 (1K0)
    Scan: 01 03 08 09 0D 0F 10 14 15 16 17 18 19 1C 20 22 25 26 2B 2E
              32 37 3D 42 44 46 47 4F 52 53 55 56 5D 61 62 6C 72 73 75 76
              77 78 A6
    VIN: WVGZZZ5NZAW054863   Mileage: 111650km-69376miles
    0D-Slide Door, Left -- Status: Cannot be reached 1100
    0F-Digital Radio -- Status: Cannot be reached 1100
    18-Aux. Heat -- Status: Cannot be reached 1100
    1C-Position Sensing -- Status: Cannot be reached 1100
    20-High Beam Assist. -- Status: Cannot be reached 1100
    26-Auto Roof -- Status: Cannot be reached 1100
    2B-Steer. Col. Lock -- Status: Cannot be reached 1100
    2E-Media Player 3 -- Status: Cannot be reached 1100
    32-Differential Locks -- Status: Cannot be reached 1100
    3D-Special Function -- Status: Cannot be reached 1100
    5D-Operations -- Status: Cannot be reached 1100
    61-Battery Regul. -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Cannot be reached 1100
    73-Entry Assist, P -- Status: Cannot be reached 1100
    75-Telematics -- Status: Cannot be reached 1100
    76-Park Assist -- Status: Cannot be reached 1100
    78-Slide Door, Right -- Status: Cannot be reached 1100
    A6-Microphone -- Status: Cannot be reached 1100
    Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
       Part No SW: 03C 906 027 BL    HW: 03C 906 027 F
       Component: MED17.5.5       G   8011
       Revision: LAH08---    Serial number:
       Coding: 0000172
       Shop #: WSC 00050 207 90732
       VCID: 6C81C7DE3A82E31752D-8038
    Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
       Part No SW: 5N0 614 109 M    HW: 5N0 614 109 M
       Component: J104    C4 450 V220 0003
       Revision: --H28---    Serial number: 00000002372359
       Coding: 0011525
       Shop #: WSC 01324 020 00200
       VCID: 353722BA294862DF7D3-8060
       Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
       Revision: 00003001
       Coding: 0000000002
       VCID: 7DA7FA9A5D787A9FF53-8028
    13701520 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Tόrsteuergerδt hinten links - kein Signal/Kommunikation]
                        Fault Frequency: 17
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2018.10.20
                        Time: 20:24:58
       Part No SW: 5K0 937 087 D    HW: 5K0 937 087 D
       Component: BCM PQ35 H    011 0028
       Revision: BE011001
       Coding: 4C180A3B9825F3C0400800803400092443553088736D89605C8000000000
       VCID: 363525B6384E69C7749-8062
       Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 03110  012 0203
       Serial number: N1955119   203!
       Coding: 009795
       Component: RLS 091109 05  54  0402
       Coding: 07304D
    6 Faults Found:
    00380 - Special Vehicle Control Module (J608)
                        Reset counter: 26
                        Mileage: 111585 km
                        Date: 2013.03.10
                        Time: 16:54:06
                        Voltage: 12.45 V
    00830 - Convertible Top Control Module (J256)
                        Reset counter: 26
                        Mileage: 111585 km
                        Date: 2013.03.10
                        Time: 16:54:06
                        Voltage: 12.45 V
    01207 - Control Module for Auxiliary Heater (J364)
                        Reset counter: 26
                        Mileage: 111585 km
                        Date: 2013.03.10
                        Time: 16:54:08
                        Voltage: 12.45 V
    01259 - Fuel Pump Relay (J17)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 00:00:05
                            Term 15 Off
                        Voltage: 12.90 V
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.12
                        Time: 20:24:60
                        Voltage: 13.75 V
                        Fault Status: 00101010
                        Reset counter: 70
                        Mileage: 111645 km
                        Date: 2013.03.12
                        Time: 16:57:54
                        Voltage: 12.05 V
    Address 0D: Slide Door, Left
    Address 0F: Digital Radio
    Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
       Part No SW: 1T0 919 475 H    HW: 1T0 919 475
       Component: PARKHILFE PLA H07 0110
       Revision: --------    Serial number: 88520930900609
       Coding: 300002
       VCID: 40D9436E6A8AD777DE5-8014
       Component: DAEMPFUNGS-SG H07 0070
       Revision: 00000000    Serial number: 04110903300001
       Coding: 010180
       Shop #: WSC 00000 785 00200
       VCID: 270BF8F2EFE4004FFFF-8072
       Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Component: J234__200 VW10 HI   1916
       Revision: 20013000    Serial number: 003E2PNYUQTE
       Coding: 0012336
       VCID: 44D14F7E7292CB57FAD-8010
       Subsystem 1 - Serial number: 6332MTS619253039
       Subsystem 2 - Serial number: 6342MTS670013039
       Subsystem 3 - Serial number: 6351HTS6S7HE66KJ
       Subsystem 4 - Serial number: 6361HTS6PKOE66KR
       Part No SW: 1K0 953 549 CK    HW: 1K0 953 549 CK
       Component: J0527           056 0111
       Coding: 0000332
       VCID: 7DA7FA9A51F87A9FF53-8028
       Component: E0221           002 0030
       Part No SW: 5N0 920 871 A    HW: 5N0 920 871 A
       Component: KOMBI         H05 0305
       Coding: 110F00
       VCID: 2F3B10D2C794580F37F-807A
    12715520 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerδt fόr Verdeck: keine Kommunikation]
                        Fault Frequency: 218
                        Reset counter: 32
                        Mileage: 110492 km
                        Date: 2018.09.16
                        Time: 13:54:31
    13635328 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerδt fόr Sonderfahrzeuge: keine Kommunikation]
                        Reset counter: 32
                        Mileage: 110492 km
                        Date: 2018.09.16
                        Time: 13:54:31
    Address 18: Aux. Heat
       Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
       Component: J533  Gateway   H20 0592
       Revision:   H20       Serial number: 261009F2000316
       Coding: F9EB7F2E797FF30D6002
       VCID: 6B83C4C23F8CE42F5B7-803E
    20 Faults Found:
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:18
    01327 - Control Module for Parking Aid (J446)
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:22
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:19
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:18
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:18
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:22
    01302 - Control Module for Telematic (J499)
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:22
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:22
    02649 - Digital Radio Tuner
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:22
    00484 - Vehicle Position Recognition Control Module (J603)
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:22
    02749 - Control Module / Control Head for Telephone (J738)
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:19
    02011 - Right Entry Assistance Control Module (J573)
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:18
    02054 - Control Module for Differential Locks (J647)
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:18
    03272 - Control Module for Audio Interface
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:22
    03604 - Control Module Auomatic Sliding Door, Rear Left
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:18
    03395 - Control Module for High Beam Assistant
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:22
    03605 - Control Module Auomatic Sliding Door, Rear Right
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:18
    02811 - Control Module for Electronic Steering Column Lock (J764)
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:22
    03753 - Control Module for Microphone
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:16:22
    03406 - Control Module for Battery Monitoring
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:17:17
    Address 1C: Position Sensing
    Address 20: High Beam Assist.
       Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
       Component: Haldex 4Motion      0041
       Coding: 0000005
       VCID: 4BC364425FCC042F3B7-801E
       Component: IMMO          H05 0305
       VCID: 6A8DC1C63CF6FD27201-803E
    9456681 - Key
              B104C 29 [008] - Implausible Signal
                        Mileage: 110364 km
                        Date: 2018.09.13
                        Time: 18:48:56
    Address 26: Auto Roof
    Address 2B: Steer. Col. Lock
    Address 2E: Media Player 3
    Address 32: Differential Locks
       Part No SW: 1T0 035 680 P    HW: 1T0 035 680 P
       Component: RNS-MID       H10 5274
       Revision: AB001001    Serial number: VWZ6Z7L8092131
       Coding: 0606044204000081000C
       Shop #: WSC 00028 028 00001
       VCID: 3B233482036CB4AF8B7-806E
       Subsystem 1 - Part No: 1T0 919 859 B
       Component: EU West V15  8515
    00857 - CD Changer Unit (R41)
                        Fault Frequency: 12
                        Reset counter: 32
                        Mileage: 111656 km
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:23:09
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:23:09
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:47:38
    Address 3D: Special Function
       Part No SW: 5N0 959 701 E    HW: 5N0 959 701 E
       Component: Tuer-SG         009 2101
       Coding: 0004096
       VCID: 372B28B2334490CF6FF-8062
    01706 - Switch for Mirror-Adjust (E43)
       Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.162 0703
       Revision: 1AH03273    Serial number: 00092530082202
       Coding: 0000258
       VCID: 3A2D318600568DA7901-806E
    Address 47: Sound System
       Part No SW: 1K0 907 532     HW: 1K0 907 951
       Component: EZE_2         H20 0592
       Coding: 050B0500
       VCID: 6695B5F6286ED947049-8032
       Component: J245EE20SKB13  H01 0220
       Component: J394EE20SKB13  H01 0220
    02071 - Local Databus
                        Fault Status: 00101100
                        Reset counter: 72
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 11:50:02
       Part No SW: 5N0 959 702 E    HW: 5N0 959 702 E
       Coding: 0004542
       VCID: 38292B8E3E5A9FB7665-806C
       Part No SW: 3AA 907 801 B    HW: 3AA 907 801 B
       Component: J540 EPB4  VW-49878 0004
       Revision:   H17       Serial number: 00000000001620
       Coding: 0023057
       VCID: 303913AED62A47F72E5-8064
    03200 - Switch for Electric Parking Brake (E538)
                        Reset counter: 69
                        Mileage: 111638 km
                        Date: 2013.03.12
                        Time: 13:20:45
                        Voltage: 13.60 V
                        Count: 10
                        Hex Value: 0x12EB
                        Hex Value: 0x8001
                        Hex Value: 0x1010
                        Fault Status: 00101101
                        Reset counter: 70
                        Mileage: 111641 km
                        Date: 2013.03.12
                        Time: 13:54:51
                        Voltage: 9.60 V
                        Count: 141
                        Hex Value: 0x12E3
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Component: AFS-Steuergeraet    0142
       Coding: 1363142
       VCID: 34311FBE22327BD74AD-8060
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000020
       Coding: 00000020
                        Fault Frequency: 13
                        Reset counter: 32
                        Mileage: 111656 km
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:23:09
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:23:09
                        Reset counter: 32
                        Mileage: 111657 km
                        Date: 2013.03.13
                        Time: 13:47:38
    Address 5D: Operations
       Part No SW: 1K0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H20 0592
       Coding: F000085A
       VCID: 6889BBCE227ACF37365-803C
    Address 62: Door, Rear Left
       Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
       Component: J772__Rearview      0020
       Revision: 00H07000    Serial number: 525PA8-J9X1263
       Coding: 0020010
       Shop #: WSC 01324 785 00200
       VCID: 2D070ADAC1182A1F053-8078
       Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
       Coding: 0000144
       Shop #: WSC 01324 020 1012552
       VCID: 392F2E8A055086BF99B-806C
    Address 73: Entry Assist, P
    Address 75: Telematics
    Address 76: Park Assist
    Address 77: Telephone
    Address 78: Slide Door, Right        Labels: None
       Coding: 0000144
    Address A6: Microphone
    End----------(Elapsed Time: 02:22, VBatt start/end: 12.5V/12.4V)-----------
    Jul 2014
    Tallinn, Estonia
    You have so many modules that cannot be reached. It might be a good start to remove the modules not in the car from the CAN gateway installation list. Except leave 77 for Bluetooth. Rear right door should be on address 62, not 78.
  3. Likes Uwe, myounus, downtime, NikosP liked this post
    May 2017
    I have to state this again. The modules not existing in the car physically, won't magically appear there even they are enabled in the gateway installation list.
    Now if you look even the very recent support requests on this forum and the attached autoscans there, you notice in 90% of the cases they have some module that cannot be reached. The reason for that being it's enabled in the gateway for god knows what reasons.
    Thumb of rule, DO NOT MESS WITH THE GATEWAY INSTALLATION LIST UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING!!! The modules added to the list don't appear on the car no matter how much it is wished. They need to be installed physically first.
  5. Likes Fredrick Awuor, NikosP liked this post
  6. #4
    Oct 2018
    Greece
    Thank you for your help, can I relocate address like you suggest? On rear door? I will try identifying modules and remove. 77 is dead and cannot reach even when Bluetooth module is connected. Any tips on how to get it on? Rns510 connected with 9w2. Thank you volumes
    Oct 2018
    Greece
    Thank you guys, I will try by trial and error to identify keeping original settings.
    Oct 2018
    Greece
    Guys any directions over the off road button issue I got will be greatly appreciated. The system works automatically but the button is not working by pressing to engage or disable. Thank you
    Oct 2018
    Greece
    Hi Downtime,
    The list is as appeared on my first autoscan , haven't added any new. So you think safe to remove the ones cannot reach?
  10. #8
    May 2017
    Yes, remove at least these :
    Then clear all dtc's run a new autoscan and paste the contents here. Then we'll see what are actual errors and whatnot.
    What comes to the offroad function, probably needs coding to ABS, maybe? Haven't done that myself ever so I'm not sure about it.
  11. Likes Uwe, NikosP, Dana liked this post
  12. #9
    May 2017
    Hmmm.. looks like the offroad button is not just adding the button, you need to pull one wire to ABS unit as well. Look here, very good instructions how-to :
    https://www.mytiguan.com/index.php?/...n-button-how2/
  13. Likes Dana liked this post
  14. #10
    Oct 2018
    Greece
    done what suggested stilll no bluetooth module recognised st wheel button only mutes
    Tuesday,23,October,2018,20:18:29:37191
    VIN: WVGZZZ5NZAW054863   License Plate: IOO231018C
    Mileage: 111720km-69419mi   Repair Order:
    Scan: 01 03 08 09 10 14 15 16 17 19 22 25 37 42 44 46 4F 52 53 55
              56 61 62 6C 72
    VIN: WVGZZZ5NZAW054863   Mileage: 111720km-69419miles
    56-Radio -- Status: Not registered 0011
       Coding: 0000172
    Readiness: 1110 0101
       Component: J104    C4 450 V227 0003
       Coding: 0011525
       Revision: 00003001
       Coding: 0000000002
              U1111 00 [009] - -
                        Fault Frequency: 30
                        Reset counter: 38
                        Mileage: 111657 km
                        Date: 2018.10.20
                        Time: 20:24:58
       Revision: BE011001
       Coding: 009795
       Coding: 07304D
                        Reset counter: 39
                        Mileage: 111721 km
                        Date: 2013.03.15
                        Time: 20:15:06
                        Voltage: 12.60 V
       Coding: 300002
       Coding: 010180
       Coding: 0012336
       Coding: 0000332
       Coding: 110F00
       Coding: F9AB7F06404003046002
                        Reset counter: 39
                        Mileage: 111721 km
                        Date: 2013.03.15
                        Time: 20:15:06
                        Mileage: 111721 km
                        Date: 2013.03.15
                        Time: 20:15:05
       Coding: 0000005
    9456681 - Key
                        Mileage: 110364 km
                        Date: 2018.09.13
                        Time: 18:48:56
       Coding: 0601044204000081000C
                        Reset counter: 38
                        Mileage: 111720 km
       Coding: 0004096
       Coding: 0000258
       Coding: 050B0500
       Coding: 0004542
       Coding: 0023057
       Coding: 1363142
       Coding: 00000020
       Coding: 00000020
                        Reset counter: 38
                        Mileage: 111720 km
       Coding: F000085A
       Coding: 0020010
       Coding: 0000144
    End----------(Elapsed Time: 01:53, VBatt start/end: 12.6V/12.6V)-----------
