Results 11 to 20 of 22
Thread: Unable to find .ROD File after VCDS update
    Sep 2018
    Leonartown, MD, USA
    Eric,
    I don’t have second PC that i can get to garage. Ipad?
    Ill try installing 32 bit, and will try on the car tomorrow.
    The error shows when i run AutoScan or go to a module (it shows incorrect chassis)directly. No extra steps.
    Should i try on different car, I have mk7 golf? Is there possibility of casing any issues with the car?
    Tom
  2. #12
    Quote Originally Posted by tomekd77 View Post
    No. Needs a Windows x86 or x64 PC (or a MacBook running boot camp).
    Thank you.
    OK, just wanted to confirm a minimal sequence to reproduce. So Start VCDS, Connect to 17; or Start VCDS, AutoScan.
    This only seems to happen where VWAG reused a chassis code across different platforms (5N, AX, 1T). I don't think the Mk7 Golf fell victim to that outrageous scheme
    Yes, if you pick an incorrect ROD file from the yellow dialog for a given controller, the warning that coding/adaptation/output test/basic setting info might not apply to your car, is to be taken seriously. I wouldn't use any of those functions under those conditions. Reading data (measuring values, fault codes), by definition, does not change anything in the car and is safe.
  3. Likes Uwe, Dana liked this post
  4. #13
    Sep 2018
    Leonartown, MD, USA
    Sorry for long delay with response, had to wait till my wife gets back with the car.
    Is there a reason why AutoScan does not have manual option for 2018 Mk2 Tiguan NAR?
    Here are the scans:
    32bit
    Wednesday,24,October,2018,17:32:30:30494
    VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
    VIN: 3VV2B7AX3JM002106   License Plate:
    Chassis Type: AX-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 52 5F 69 6C
              6D 75 CA
    VIN: 3VV2B7AX3JM002106   Mileage: 17068km-10605miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H30 0004
       Revision: 1DH30000
       Coding: 012A00122476010FB4000000000000000000000000000000
       Shop #: WSC 00066 790 00291
       ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
       ROD: EV_ECM20TFS0115NA907115A.rod
       VCID: 3C34CD1FB71CB9AAC9-8068
    17158 - Databus
       Part No SW: 09G 927 158 Q    HW: 09G 927 158
       Component: AISIN AQ8     206 3379
       Coding: 0002000100000000000000000000000000000000
       Shop #: WSC 00066 790 00453
       ROD: EV_TCMAQ450031_VW32.rod
       VCID: 41CABCEBD0FED4429A-8014
       Revision: 00000000    Serial number: 50987000000137
       Coding: 0BFA6BA454201B6EC5780300A2C949D0D62AD8A3C045927C18415058C28A4200002864121A1C230935351919323200
       Shop #: WSC 01383 790 50316
       VCID: 77BE1233CEBA5AF2E4-8022
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0434760327
       Coding: 032C0C070F
       Part No SW: 5NN 907 044 A    HW: 5NN 907 044 A
       Component: AC Automat    H35 4301
       Revision: 20K08000    Serial number: 00000D00004849
       Coding: 0002002410011800100501401211140E
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 4AD89BC7EDC8171A4B-801E
       Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
       Component: BCM PQ37BOSCH 034 0243
       Revision: --------    Serial number: C864120417023U
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0C545DDFA73C492AB9-8058
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 170308  034 0373
       Serial number: 17030521051340
       Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
       Serial number: 71808607
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 3200008950FF8728749C8145304097
       Shop #: WSC 00066 790 00274
       VCID: 3E30C717A100ABBAE7-806A
    0836 - Databus
              [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                        Reset counter: 85
                        Mileage: 16708 km
                        Date: 2018.10.14
                        Time: 08:43:57
                        Voltage terminal 15: 14.4 V
                        Control Module temperature: 30 °C
                        Longitudinal_acceleration_vehicle_reference: 0.03 m/s²
       Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
       Component: AirbagVW21    004 0336
       Serial number: 003NUM057U6/
       Coding: 8CCCFC00000000005000001AC20800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 054268FB84563862E6-8050
       Occupant Detection:
       Serial number: IBH0000000000073RU0R
       Coding: 303351
       Subsystem 2 - Part No SW: -----------    HW: 480 001 503 17
       Serial number: 357000000000D3191223
       Subsystem 3 - Part No SW: -----------    HW: 480 001 503 17
       Serial number: 358000000003D3191227
       Subsystem 4 - Part No SW: -----------    HW: 480 402 503 17
       Serial number: 3510001A32527B23351L
       Subsystem 5 - Part No SW: -----------    HW: 480 401 901 17
       Serial number: 3520001B922A9B34353/
       Subsystem 6 - Part No SW: -----------    HW: 480 402 103 17
       Serial number: 3550001C724CDB2395AI
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 103 17
       Component: FrontSensor_P  000 6149
       Serial number: 3560001C724CDB2392BH
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 07041708491719
       Coding: 0410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 075E62F3BE5A2A7294-8052
       Part No SW: 5NA 920 850 A    HW: 5NA 920 850 A
       Component: KOMBI         361 8311
       Coding: 0BA4001AA788CF0502887B095400000020000000
       VCID: 3D32C01BAC06B0A2FE-8068
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Reset counter: 71
                        Mileage: 16323 km
                        Date: 2018.10.06
                        Time: 08:22:09
       Component: GW MQB High   518 5286
       Serial number: 08051700840113
       Coding: 030500347F085900FB0322581E0F00010001050000000000000000000000
       Shop #: WSC 00066 790 00064
       ROD: EV_GatewNF_VW37.rod
       VCID: 2F2EEA53766A52327C-807A
       Subsystem 2 - Part No SW: 5NN 959 442 A    HW: 5NN 959 442 A
       Serial number: 0201700020200003BL2B
       Coding: 2C0000
       Serial number: 0475402904
       Serial number: HA1-00003.11.16
       Coding: 0101
       Serial number: 17000075290009
       Coding: 0800000000000000
       Shop #: WSC 00066 790 00440
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71AA2C2BA0DE04C22A-8024
       Component: HRE_Master    H12 0080
       Serial number: 0431834720
       Coding: 01012103
       ROD: EV_HREntryHella_VW37.rod
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0080
       Serial number: 0434370916
       Coding: 010121
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Component: TSG FS        010 0032
       Serial number: 7028702000146
       Coding: 00301B200000028000000000
       VCID: 45C2A8FBC4D6F862A6-8010
       Serial number: 00000000000005973918
       Coding: 011000
       Revision: 00000000    Serial number: 0001620982
       Coding: 01000010004001
       ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
       VCID: 40CCB9EFDBF4DD4A95-8014
       Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
       Component: TSG BFS       010 0032
       Serial number: 8028712700422
       Coding: 003013200000028000000000
       VCID: 44C4B5FFCFECC16AB1-8010
       Serial number: 00000000000006065356
       Coding: 091000
       Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
       Component: MU-S-NS-US    840 0755
       Coding: 02730602BE00000051220001001808001F0500C401200105C6
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 3228E32765587FDA13-8066
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H50 8120
       Serial number: VWZ6ZHT1300503
       Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
       Component: NAR 2017  --- 0525
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0447480187
       Coding: 0200000200000000
       Shop #: WSC 03099 444 12345
       VCID: 42C8B3E7D5F8CF5A83-8016
       Coding: 0123060121002017300040
       VCID: 393AD40BB82E8C82D2-806C
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: ’’’’’’’’’’’’’’
       Coding: 0A88
       Component: OCULowMQBUS   007 0570
       Coding: 02230602C2823A017F1E06020000
       ROD: EV_OCULowMQB.rod
       VCID: 43C6B6E3CAE2C65288-8016
       Component: SAD_STG_1     013 0005
       Coding: 00804073260C
    End----------(Elapsed Time: 01:46, VBatt start/end: 12.4V/12.4V)-----------
    64-bit
    Wednesday,24,October,2018,17:36:16:30494
    VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
    Chassis Type: AX-VW36 (3Q0)
              6D 75 CA
       Revision: 1DH30000
    17158 - Databus
       ROD: EV_Brake1UDSContiMK100IPB_032.rod
    Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
       Coding: 032C0C070F
       ROD: EV_ACClimaPrehVW37X_001.rod
    0836 - Databus
                        Reset counter: 85
                        Mileage: 16708 km
                        Date: 2018.10.14
                        Time: 08:43:57
       Occupant Detection:
       Coding: 303351
       Coding: 0410
       ROD: EV_SMLSKLOMQB_008.rod
    Address 17: Instruments (J285)       Labels:. 5G0-920-XXX-17.clb
       ROD: N/A
    No ASAM data for: "EV_DashBoardVDDMQBAB" (VW36)
    16777020 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 71
                        Mileage: 16323 km
                        Date: 2018.10.06
                        Time: 08:22:09
    Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
       ROD: N/A
       Coding: 2C0000
    No ASAM data for: "EV_GatewNF" (VW36)
       Coding: 0101
       Coding: 01012103
       ROD: EV_HREntryHella_VW32.rod
       Coding: 010121
       Coding: 011000
       ROD: EV_SteerAssisVWBSMQBA_008.rod
       Coding: 091000
    Address 69: Trailer (J345)       Labels:. 5Q0-907-383.clb
       ROD: N/A
    No ASAM data for: "EV_TrailFunctGener2Hella" (VW36)
       ROD: EV_CamSysRVRVCPANAMQBAB_004.rod
    Address 6D: Trunk Elect. (J605)       Labels:. 5Q0-959-107.clb
       Coding: 0A88
       ROD: N/A
    No ASAM data for: "EV_DeckLidCONTIAU736" (VW36)
    End----------(Elapsed Time: 01:46, VBatt start/end: 12.3V/12.3V)-----------
    tom
  5. Likes Uwe, Eric liked this post
  6. #14
    Given the nature of the vehicle, a manual option should not be required.
  7. #15
    Sep 2018
    Leonartown, MD, USA
    Isn’t that the problem 64bit is having issue recognizing proper chassis? Would manual selection force that?
  8. #16
    It would seem so, but it shouldn't be that way.
    I suppose so, but that's not the right way to fix this.
    Stand by; we'll have a possible fix for you to try later today.
  9. Likes tomekd77 liked this post
  10. #17
    Tartu, Estonia
    As manual option automarically redirects to Gateway identification.... my answer would be "No".
    The world is my oyster...
  11. Likes tomekd77 liked this post
  12. #18
    Sep 2018
    Leonartown, MD, USA
    Uwe/Eric
    I installed executable (per provided link) 64-bit over old version. Had to disable avast.
    Here is the scan
    Saturday,27,October,2018,05:05:13:30494
    VCDS Version: 18.9.0.4 (x64)  HEX-NET CB: 0.4436.4
              6D 75 CA
    VIN: 3VV2B7AX3JM002106   Mileage: 17106km-10629miles
       Revision: 1DH30000
       VCID: 3C34CD1FB71CB9AAC7-8068
    17158 - Databus
       VCID: 41CABCEBD0FED44294-8014
       VCID: 77BE1233CEBA5AF2EA-8022
       Coding: 032C0C070F
       VCID: 4AD89BC7EDC8171A45-801E
       VCID: 0C545DDFA73C492AB7-8058
       VCID: 3E30C717A100ABBAE9-806A
    0836 - Databus
                        Reset counter: 85
                        Mileage: 16708 km
                        Date: 2018.10.14
                        Time: 08:43:57
       VCID: 054268FB84563862E8-8050
       Occupant Detection:
       Coding: 303351
       Coding: 0410
       VCID: 075E62F3BE5A2A729A-8052
       VCID: 3D32C01BAC06B0A2F0-8068
              U1110 00 [008] - -
                        Reset counter: 71
                        Mileage: 16323 km
                        Date: 2018.10.06
                        Time: 08:22:09
       VCID: 2F2EEA53766A523272-807A
       Coding: 2C0000
       Coding: 0101
       VCID: 71AA2C2BA0DE04C224-8024
       Coding: 01012103
       Coding: 010121
       VCID: 45C2A8FBC4D6F862A8-8010
       Coding: 011000
       VCID: 40CCB9EFDBF4DD4A9B-8014
       VCID: 44C4B5FFCFECC16ABF-8010
       Coding: 091000
       VCID: 3228E32765587FDA1D-8066
       VCID: 42C8B3E7D5F8CF5A8D-8016
       VCID: 393AD40BB82E8C82DC-806C
       Coding: 0A88
       VCID: 43C6B6E3CAE2C65286-8016
    End----------(Elapsed Time: 01:47, VBatt start/end: 12.4V/12.4V)-----------
    Let me know if you need anything else.
    Tom
  13. Likes Uwe liked this post
  14. #19
    Uwe/Eric
    Was it quarantining the .exe, or messing with the chassis detection?
  15. #20
    Sep 2018
    Leonartown, MD, USA
    It was not allowing me to execute install file - kept aborting installation with massage that I have not privileges to the file. First, I though maybe file was password protected. I disabled avast for 10minutes, installed sw, after that all works fine with avast running.
    I run auto scan twice, restarted vcds few times and loaded modules right after starting the software, no issue detecting the chassis.
    Chassis detection appears to be fine on my pc.
  16. Likes Uwe, Eric liked this post
