- Joined
- Jul 26, 2018
- Messages
- 11
- Reaction score
- 0
- Location
- Netherlands
- VCDS Serial number
- C?ID=325927
Hello Friends,
I have some problems with my Golf 7 1.4 TDI fom 2013. The start/stop doesn't work well and now for the last 3 a 4 weeks when i switch ignition on the "EPC" light goes on with a warning "Start/Stop malfunction" waring.
When switching ignition off, take key and try again it goes fine, no warning en light.
On the scan it show some error in turbo too, hope somebody can help me whats causes this problems.
Wednesday,17,October,2018,17:07:11:39305
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4438.4
VIN: WVWZZZAUZDW140278 License Plate: 25102018
Mileage: 45738km-28420mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDW140278 Mileage: 45738km-28420miles
Address 01: Engine (J623-CMBA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 CN HW: 04E 907 309 A
Component: 1.4l R4 TSI X08 5551
Revision: WAX08---
Coding: 01250032232405082000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM14TFS01104E906016CN 002004
ROD: EV_ECM14TFS01104E906016CN.rod
VCID: 70B820F7EA2A8B176E5-8024
19404 - Turbo/Super Charger Boost System
P2263 00 [032] - Performance
Mileage: 45675 km
Date: 2018.10.16
Time: 06:09:10
Engine speed: 1128.50 /min
Normed load value: 13.7 %
Coolant temperature: 24 °C
Intake air temperature: 27 °C
Voltage terminal 30: 11.709 V
Charge pressure actuator: specified position: 140.00 %
Bypass valve f high press turboch turbine inlet: actual value: 102.75 %
Charge pressure actuator: adaptation for lower stop: 4410.4 mV
Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 55
Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 0
Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 66
Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 2
Bypass valve for high press turboch turbine inlet: uncond volt: 4506.6 mV
Charge air pressure: actual value: 1017.34 hPa
Part No SW: 0CW 300 044 T HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5244
Revision: 00043014 Serial number: CU501304065139
ROD: EV_TCMDQ200021_VW31.rod
VCID: 49CEAD13A9309ADF09B-801C
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 01FA6AA12024126C0379060701CB2980560448C0608094F3002A502AC1
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 7DA609C3AD78F67FF53-8028
Part No SW: 5G0 907 044 R HW: 5G0 907 044 R
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00020004200100011005000000101000
ROD: EV_ACClimaBHBVW37X_002_VW37.rod
VCID: 3634D6EFC8CEE527749-8062
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011309402662
Coding: 00001846C24102FB4FE44000001C07081000000000000000000000000000
ROD: EV_BCMBOSCH_010.rod
VCID: 46D4A62FB82E75A7E49-8012
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130329 042 0551
Serial number: 130402151201
Coding: 0E4DD5
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M04D09H17M38S44S1
Coding: 00A8DD
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Fault Frequency: 7
Reset counter: 107
Time: 00:00:00
539925 - Databus
[Kombi_02 Datenbus fehlende Botschaft]
Reset counter: 147
Mileage: 45734 km
Date: 2018.10.17
Time: 16:05:50
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 B HW: 5Q0 919 298
Component: PARKHILFE PLA H11 0033
Revision: -------- Serial number: 61131308200250
Coding: 0031061051
ASAM Dataset: EV_EPHVA2CAU3700000 003015
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 3E24CECFE0FE2D67AC9-806A
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R0441V4
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 40D8B0379A0A5B97DE5-8014
Subsystem 1 - Part No SW: ----------- HW: 480 002 803 13
Serial number: 3576700000061688EC0/
Subsystem 2 - Part No SW: ----------- HW: 480 002 803 13
Serial number: 3586700000074B919C0$
Subsystem 3 - Part No SW: ----------- HW: 480 400 304 13
Serial number: 3516502C50FBDE3411DS
Subsystem 4 - Part No SW: ----------- HW: 480 402 703 13
Serial number: 35265029F0FBDE44E351
Subsystem 5 - Part No SW: ----------- HW: 480 402 603 13
Serial number: 3556502A50FBDE4521EY
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 03041304221092
Coding: 0410
Shop #: WSC 50414 002 1048576
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 79AE1DD3B950CA5FD9B-802C
Part No SW: 5G0 920 860 HW: 5G0 920 860
Component: KOMBI 236 0580
Coding: 07A501082390000800086A00040000
VCID: 659641A325E85EBF0D3-8030
Part No SW: 5Q0 907 530 E HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1109
Revision: -------- Serial number: 0000479391
Coding: 030100042B086400EF0006481C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_006.rod
VCID: 3332EFFBDBBCF00F537-8066
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 29160000123600096045
Coding: 280000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 6934410203
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 29031306070422
Coding: 00310320D000040000001000
VCID: 3FDAB3CBE7F4246FA7F-806A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001129589
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 03
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D26C9C3EDF8367FB53-8068
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 21031306070725
Coding: 00310120DE00040000801000
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001118469
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 HW: 5G0 035 846
Component: MU-S-N-ER 039 0170
Serial number: V1F02503131053
Coding: 02730001FF00000011110001000800001F0100840100010045
ASAM Dataset: EV_MUStd4CPASE 002036
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 669446AFD8EE55A7049-8032
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H44 0020
Serial number: VWZ8Z9N3401H6C
Subsystem 2 - Part No SW: 5G0 919 866 AH HW: -----------
Component: ECE 2018/201 --- 0075
End----------(Elapsed Time: 01:06, VBatt start/end: 12.1V/12.1V)-----------
