Results 1 to 8 of 8
Thread: Electronic Parking Brake (EPB) service mode - 2017 Skoda Superb 3
    Oct 2018
    Norway
    Hello.
    I just bought my ross tech cable to perform my own brake pad and rotor change on my 2017 Skoda Superb.
    This is the first car from Skoda that is using the electronic parking brake, and because it was only first available in 2015 there is not that many good guides for that specific car out there.
    I tried to use the general guide here, but module 53 is not installed in the Skoda Superb, and I just get the error "Can't connect to module" if I try to open it anyway (it is not listed under Installed modules, only under Chassis). After looking through all the available options in the different modules I found out that 03 ABS Brakes has the option to test the electronic parking brake, and I can get all the necessary information about the parking brake from that module (if the motors are active or not, and if the light is on etc)
    After checking some more on the internet I found this guide for the Golf VII, and I found the same options under 03 ABS Brakes (Start/End lining change mode).
    What I want to ask is if it is the lining change mode I'm supposed to be using on the Skoda, as I really don't know what is meant by "lining change mode". If I can I would like to avoid the need of a tow truck just because I tested something in VCDS.
    If anyone else has done this on the Skoda Superb 3, please let me know if I'm on the right track or not.
    I'm reasonably confident that Start and End Change Lining Mode in the ABS are what you want, but please post an Auto-Scan so we can see exactly what control modules your car has.
  3. Likes downtime, Jack@European_Parts liked this post
    Oct 2018
    Norway
    Thanks for the reply Uwe. I've attached the result of the auto scan of the modules here:
    Chassis Type: NP-SK48 (3Q0)
    Scan: 01 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42 44 47
              4B 52 5F 69 6C 6D A5 BB BC
    VIN: TMBLH9NP7H7519985   Mileage: 36801km-22867miles
    Address 01: Engine (J623-DFEA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 NA    HW: 04L 907 309 M
       Component: R4 2.0l TDI   X24 3075
       Revision: B4X24---
       Coding: 0119003A045605087000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01104L906026NA 004001
       ROD: EV_ECM20TDI01104L906026FQ_004.rod
       VCID: 76B5E51178491017B49-8022
    Readiness: 0 0 0 0 X
       Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
       Component: ESC           H62 0643
       Revision: 00000000    Serial number: 63536000003347
       Coding: 1E076A9C34210B754780070840C84978562CD0E2E0029275346350F8C0A9420000000012121212B835351919323200
       Shop #: WSC 33361 790 00157
       VCID: 78A9EB29725D6667A65-802C
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0425519372
       Coding: 032C0C0E03
       VCID: 3C21373906E58A4782D-8068
       Subsystem 1 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
       Component: GEB.F.Heckoef  H16 0903
       Serial number: 84497054
       Part No SW: 3V0 907 044 EC    HW: 3V0 907 044 EC
       Component: AC Automat    H34 4101
       Revision: 20K07000    Serial number: 00000E00338338
       Coding: 1201010400441101100510010010110A
       ASAM Dataset: EV_ACClimaPrehVW37X 002019
       ROD: EV_ACClimaPrehVW37X_SK37.rod
       VCID: 79AFEE2D49577F6FD9B-802C
       Subsystem 2 - Part No SW: 3V0 907 049 E    HW: 3V0 907 049 E
       Component: E265KlimaHeck  H02 0101
       Serial number:       06051501850797
       Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H34 0236
       Serial number: 02001634800661
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7F5B00355773515FE7F-802A
       Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: 48x LL 161128  032 0121
       Serial number: 00000001611250401251
       Coding: 165DDD
       Component: RLHS  042 0105
       Serial number: S6Y16M12D14H05M46S15
       Coding: 0088DF
       Serial number: 000000000ZY163161NTC
       Serial number: 00000000000067886508
       Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Component: SysNameFanLin  014 0101
       Serial number: ESE0228496
       Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0227814
       Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0227945
       Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0227815
       Part No SW: 5QA 919 298 B    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0038
       Serial number: 000308417616349
       Coding: 0271167141
       ASAM Dataset: EV_EPHVA2CAU3700000 009032
       ROD: EV_EPHVA2CAU3700000_009_VW37.rod
       VCID: 4FFB70F5A75301DF57F-801A
       Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
       Component: ACC BOSCH MQB H04 0195
       Coding: 2A0060CB51FFC428949C8045
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3537221D25CF5B0F7D3-8060
       Serial number: 27111641350605
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 38292B2932DDA667665-806C
       Part No SW: 5Q0 959 655 AS    HW: 5Q0 959 655 AS
       Component: AirbagVW21    003 0317
       Serial number: 003TMR2E13M.
       Coding: 98FCC0C0000000005C5400CF000800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 117FB68D71E7572F01B-8044
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3V0857701C0344Q00523
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3V0857702C0343Q01798
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 001 212 16
       Serial number: 35700000000D70191025
       Subsystem 4 - Part No SW: -----------    HW: 480 001 012 16
       Serial number: 35800000000F5638EF1/
       Subsystem 5 - Part No SW: -----------    HW: 480 401 012 16
       Serial number: 3510001C522CA566070Y
       Subsystem 6 - Part No SW: -----------    HW: 480 401 012 16
       Serial number: 3520001C122CA56265F3
       Subsystem 7 - Part No SW: -----------    HW: 480 401 312 16
       Serial number: 3550001AD22CA56506CB
       Part No SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
       Revision: FF035035    Serial number: 20161209400990
       Coding: 6404
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 7BA3F425436B4D7FCB7-802E
       Part No SW: 3V0 920 711 A    HW: 3V0 920 711 A
       Component: KOMBI         305 8311
       Coding: 07A50812FF840008018B6B0B5001000000000000
       Shop #: WSC 73430 031 00157
       VCID: 2E050D71C09968D73C9-807A
       Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
       Component: STH-MQB       008 0075
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       VCID: 3A2D31210CD1B477901-806E
       Component: R64 D208L  004 0401
       Serial number: 00000000000000158847
       Component: GW MQB High   515 5286
       Serial number: 14121610520545
       Coding: 0B0100345F087300EB00025E880F00010001070000000000000000000000
       Shop #: WSC 33361 790 00132
       ROD: EV_GatewNF_VW37.rod
       VCID: 2F3B1075C79361DF37F-807A
       Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000C0768191016
       Serial number: 7081442404
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
       Component: U13DCAC  H25 0780
       Serial number: 0000592
       Serial number: HA1-00016.11.16
       Coding: 0301
       VCID: 4ACD61E15C3124F7001-801E
       Serial number: 16000329247018
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD60D1127372F61B-8024
       Component: Sitzmemory    H08 0021
       Serial number: Y0006PL914406
       Coding: 0010000000000500018280808080000000008181000000D400
       Component: HRE_Master    H12 0071
       Serial number: 0413490111
       Coding: 02012103
       ROD: EV_HREntryHella_VW37.rod
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0071
       Serial number: 0423355307
       Coding: 020121
       Component: TSG FS        010 0032
       Serial number: 0000233290814
       Coding: 001D0820DE00048000001100
       VCID: 47CB58D54F23D99F1FF-8012
       Revision: 00000000    Serial number: 0001264566
       Coding: 01010011004001
       ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
       VCID: 40D943C96A0DEEA7DE5-8014
       Part No SW: 81A 035 223     HW: 81A 035 223
       Component: MIB2_amp_P_SK H10 0410
       Revision: 00000001    Serial number: SKZ8Z1GJE00XUBZ
       Coding: 0384020000AA002FAA0000000000
       ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
       ROD: EV_AMPMst16C5Gen2ALPI.rod
       VCID: 59EF8EADE9975F6FB9B-800C
       Component: FCM MQB Low   001 0285
       Serial number: 15121610520064
       Coding: 000000020100067206007F01000000000000000000000000000000000000
       VCID: 72BDD90114210C37981-8026
       Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329
       Component: Leimo links  H02 0013
       Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329
       Component: Leimo rechts  H02 0013
       Component: TSG BFS       010 0032
       Serial number: 0000232482717
       Coding: 001D0220DE00048000001100
       VCID: 46D555D14829C097E49-8012
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
       Part No SW: 3V0 035 020 D    HW: 3V0 035 020
       Component: MU-H-ND-EU    H50 0942
       Serial number: A676L0GB022543
       Coding: 038402010000000051111202008808002F0103E4012081009E
       VCID: 270BF855EF63399FFFF-8072
       Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
       Component: ABT_High-2  H47 1031
       Serial number: SKZ8Z9SLU00ZK1
       Subsystem 2 - Part No SW: V03 959 801 JP    HW: -----------
       Component: ECE 2018  --- 0166
       Component: Gracenote2---  --- 1013
       Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
       Component: Anhaenger     H21 0204
       Revision: 8B001003    Serial number: 0424990691
       Coding: 0100000202000000
       Coding: 048402018700201F000040
       ROD: EV_CamSysRVRVCPANAMQBAB_006_SK37.rod
       VCID: 392F2E2D09D7BF6F99B-806C
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: 31103458200000
       Coding: 0D88
       ROD: EV_DeckLidCONTIAU736_VW41.rod
       VCID: 41DF46CD6107E7AFD1B-8014
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 17121612P10417
       Coding: 020408020000040100262355C050A90094000E100040
       VCID: 3B23342503EB8D7F8B7-806E
       Part No SW: 5Q4 959 395 E    HW: 5Q4 959 395 B
       Component: TSG HFS       011 0032
       Serial number: 0000232674542
       Coding: 001C00208000048000001100
       ASAM Dataset: EV_DCURearDriveMAXCONT 006001
       Component: TSG HBFS      011 0032
       Serial number: 0000233236355
       ASAM Dataset: EV_DCURearPasseMAXCONT 006001
    End----------(Elapsed Time: 02:24, VBatt start/end: 14.6V/14.7V)-----------
  5. Likes Uwe liked this post
  6. #4
    HQ
    Thank you for posting a full Auto-Scan!
    Details for this are on our wiki:
    http://wiki.ross-tech.com/wiki/index...AU)_ABS_Brakes
    Remember, the rear caliper pistons are pushed in AFTER you get the EPB mechanism opened up. I just use a screw driver or small pry bar to get the pistons pushed back in, then remove the caliper. Once you get the brakes back together, be sure to pump up the brake pedal prior to doing the closing procedure.
    Wanna hang out with the cool kids? Make some channel maps of your car and post in the Reference Scans and Maps of Non-Broken Car section.
    Jef
    Oct 2018
    Norway
    Thanks Jef. Now I know I'm on the right track.
    Mar 2019
    Sweden
    Hello all!
    I just got helped by this thread to fix my own 2016 Skoda Superb (III).
    I would like to add some details that could be helpful for others:
    * The rear brake-system seem to be equal to that of a Golf VII. It is easy to find instructions for this on YouTube and elsewere
    * The pistions do not need to be rotated as they are pushed in. Just pushing is ok
    * It is possible to loosen the caliper carrier when using a "normal" jack and a ratchet with a joint, but it will require significant arm strength
    A detail worth noting is that my vehicle is a 4x4 and with adjustable suspension. It might look/be different with other options.
    I would like to attach pictures of the work, but it does not seem to be supported by the forum (only adding links). Is is possible to attach pictures to a message?
    Edit: pictures below
  9. Likes Uwe liked this post
  10. #7
    Near Philadelphia, PA, USA
    Thanks for your additional info. You asked how to post pictures. Please read:
    How To Post Pictures
  11. Likes Jack@European_Parts liked this post
  12. #8
    Mar 2019
    Sweden
    When you get a link from imgur.com it looks like
    https://imgur.com/Vac4XqL
    That wont work.
    https://i.imgur.com/Vac4XqL.jpg will work
