Results 11 to 20 of 22
Thread: Forced OBD readiness with VCDS
    Got it, out to the garage I go
  2. #12
    Well right you are again, the only thing left is the Evap system but I do have a full tank of gas and I believe that has to be between 1/3 to 3/4 full for that to reset itself, so i will do some driving. Fantastic support, thanks so much and I will post later!
    Tuesday,09,July,2019,18:29:56:30397
    VIN: WAURNAF48HN070849   License Plate: TEST SYSTEMS
    Readiness Status: 0000 0100
    Exhaust Gas Recirculation: Passed
    Oxygen Sensor Heating: Passed
    Oxygen Sensor(s): Passed
    Air Conditioning: Passed
    Secondary Air Injection: Passed
    Evaporative Emissions: Failed or Incomplete
    Catalyst Heating: Passed
    Catalytic Converter(s): Passed
  3. Likes Uwe, jyoung8607 liked this post
  4. #13
    Done and done
    Thanks to the software and advice emission inspection was no problem.
    Quote Originally Posted by Moxnix View Post
  5. Likes jyoung8607, Uwe liked this post
  6. #14
    May 2016
    I need to get my 2015 Gti smog check done in California. All of the tests are ready except the fuel system. Is there anyway to get the fuel system monitor “ready”? I’ve driven through several tanks of gas but the fuel system stays “not ready”. Car is stock except for the intercooler. ECU was reset at the 30k service.
  7. #15
    Quote Originally Posted by spelk3 View Post
    So this car has an aftermarket intercooler, but it isn't chipped?
    Please post an Auto-Scan and also the OBD-II Mode 9 data.
  8. #16
    May 2016
    Car was custom tuned, ECU and TCU using Accessport. Accessport was completely uninstalled and car returned to stock before the 30k service. Sold the car to a friend straight from the mechanic. He’s been driving it since mid December and the only monitor that is not ready is the fuel system.
    I should have access to the car tomorrow and I’ll get the scans.
  9. #17
    What are modes in VCDS OBD2 0x33?
    Modes 01-01, 03, 07, 09
    Please post ALL data.
  10. #18
    May 2016
    Tuesday,25,February,2020,10:53:55:64160
    VCDS Version: 19.6.2.2 (x64)
    VIN: 3VW4T7AU4FM036473   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
    VIN: 3VW4T7AU4FM036473   Mileage: 50839km-31589miles
    Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0005
       Revision: --H13---
       Coding: 091D00124424002F0000
       Shop #: WSC 00066 790 00221
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
       ROD: EV_ECM20TFS0205G0906259A.rod
       VCID: 2C79FEF947F1972F29-8078
       Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4511
       Revision: 03253104    Serial number: TFK01407160154
       ROD: EV_TCMDQ250021.rod
       VCID: 297707ED48038207D2-807C
              P1734 00 [002] - -
       Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
       Component: ESC           H31 0371
       Revision: 00000000    Serial number: 52324000000257
       Coding: 01FA6BA134230972007B020781C62980D62C9000408194B400430050C009
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
       VCID: 44A9B659CF617F6FC1-8010
       Part No SW: 5G0 907 426 R    HW: 5G0 907 426 R
       Component: AC Manuell    H02 0907
       Revision: 00001K06
       Coding: 00020004200100000000000012000000
       VCID: 3A55C8A1BDA5399FAB-806E
       Part No SW: 5Q0 937 087 N    HW: 5Q0 937 087 N
       Component: BCM PQ37BOSCH 028 0106
       Revision: --------    Serial number: 86580909140633
       Coding: 000018464041804969E44000001407201000000000000000000000000000
       Shop #: WSC 00066 790 00074
       ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
       ROD: EV_BCMBOSCH_013.rod
       VCID: 46ADAC51F95D4D7FDF-8012
       Component: WWS    140720  043 0581
       Serial number:         140930225756
                        Fault Frequency: 73
                        Reset counter: 185
                        Mileage: 49733 km
                        Date: 2020.02.05
                        Time: 11:48:58
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM0112ZH
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 51878F0D00139AC77A-8004
       Occupant Detection:
       Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
       Component: BF-Gewichtss.  H05 0016
       Serial number: IBH0000J140001D3KF0-
       Coding: 30325A
       Subsystem 2 - Part No SW: -----------    HW: 480 000 708 14
       Serial number: 3570000000053685C01C
       Subsystem 3 - Part No SW: -----------    HW: 480 000 508 14
       Serial number: 35800000000B52A0A01C
       Subsystem 4 - Part No SW: -----------    HW: 480 401 108 14
       Serial number: 3510002B516DB811C22+
       Subsystem 5 - Part No SW: -----------    HW: 480 401 108 14
       Serial number: 3520002B516DB813106Z
       Subsystem 6 - Part No SW: -----------    HW: 480 402 107 14
       Serial number: 3550002C515F3C325181
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 107 14
       Serial number: 3560002C715F3C30D315
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20140804500089
       Coding: 0410
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3FA3B9B5A6871CB79C-806A
    617752 - Selector Lever Park Position Lock Switch
              B1162 29 [008] - Signal Implausible
                        Reset counter: 166
                        Mileage: 50482 km
                        Date: 2020.02.17
                        Time: 08:57:38
                        Ubat 30 Voltage: 14.30 V
                        Ignition State: On
                        Terminal 15: 13.50 V
                        A/D #1: 0.00 %
                        A/D #2: 0.00 %
                        A/D #3: 0.00 %
       Part No SW: 5G1 920 856     HW: 5G1 920 856
       Component: KOMBI         342 4270
       Coding: 0BBD090A2180CF0502087A001000000000000000
       VCID: 6BFB3DE5827F501760-803E
       Part No SW: 5Q0 907 530 S    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2186
       Revision: --------    Serial number: 22081410001813
       Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07026
       ROD: EV_GatewConti_011.rod
       VCID: 41A7BF4DD0736A47EA-8014
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29140001587730094323
       Coding: 29FFFF
       Serial number: 100914060500QK
       Coding: 003E03200000040000000000
       VCID: 40A1BA49DB79634FE5-8014
       Serial number: 00000000000003513103
       Coding: 011000
       Coding: 8102
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 354FDB9D94BBD6E746-8060
       Serial number: 100914060502LY
       Serial number: 00000000000003615340
       Coding: 191000
              B1487 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 148
                        Mileage: 50024 km
                        Date: 2020.02.08
                        Time: 16:30:08
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0645
       Serial number: V7B01608141195
       Coding: 02730000FF00000021220001001800001F0203040100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 64E956D96FA11F6F21-8030
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS500L03
       Part No SW: 5QE 035 285     HW: 5QE 035 285
       Component: OCULowMQBUS   006 0528
       Shop #: WSC 00066 790 00123
       ROD: EV_OCULowMQB.rod
       VCID: 0225704195F5B15FB3-8056
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 146
                        Time: 00:00:00
       Serial number: 140724201680
    End-------------------------(Elapsed Time: 03:20)--------------------------
    mode 9
    Tuesday,25,February,2020,11:07:28:64160
    VCDS Release 19.6.2 (x64):  Generic OBD2
    Mode 9 : Calibration Identification
    Type 02 - VIN : 3VW4T7AU4FM036473 (Address E8)
    Type 04 - Calibration ID : 5G0259A 0005AXAJ (Address E8)
    Type 04 - Calibration ID : 0D9300041T  4511 (Address E9)
    Type 06 - Calibration Verification Number : AC61822F (Address E8)
    Type 06 - Calibration Verification Number : 0000D6C1 (Address E9)
    Type 08 - In-use performance tracking :
        OBD Monitoring Conditions Encountered count : 143
        Ignition cycle count : 464
        Conditions completion count / Specified conditions encountered count
             Catalyst monitor bank 1 : 103 / 137
             Catalyst monitor bank 2 : 0 / 0
             O2 Sensor monitor bank 1 : 174 / 137
             O2 Sensor monitor bank 2 : 0 / 0
             EGR-VVT monitor : 82 / 119
             AIR monitor : 73 / 31
             EVAP monitor : 18 / 30
             Secondary O2 Sensor monitor bank 1 : 93 / 137
             Secondary O2 Sensor monitor bank 2 : 0 / 0
    Type 0A - Controller Name : ECM- (Address E8)
    Type 0A - Controller Name : TCM- (Address E9)
    mode 1-01
    Tuesday,25,February,2020,10:59:17:64160
    Mode 01 - PID 01 : Readiness  --  Address 7E8
    Number of DTCs stored: 0  --  MIL Status: MIL OFF
    Misfire monitoring:  Passed
    Fuel System:  Failed or Incomplete
    Comprehensive Components:  Passed
    Catalyst monitoring:  Passed
    Heated catalyst monitoring: Not installed.
    Evaporative system monitoring:  Passed
    Secondary air system monitoring:  Passed
    A/C system refrigerant monitoring: Not installed.
    Oxygen sensor monitoring:  Passed
    Oxygen sensor heater monitoring:  Passed
  11. Likes Uwe liked this post
  12. #19
    May 2016
    mode 3
    Thursday,27,February,2020,11:01:41:64160
    Mode 03: Emission related fault codes
    Address 7E8: No fault code found.
    Address 7E9: No fault code found.
    mode 7
    Thursday,27,February,2020,11:02:45:64160
    Mode 07: Pending emission related fault codes
    mode 9
    Thursday,27,February,2020,11:08:59:64160
        OBD Monitoring Conditions Encountered count : 148
        Ignition cycle count : 480
             Catalyst monitor bank 1 : 107 / 142
             O2 Sensor monitor bank 1 : 180 / 142
             EGR-VVT monitor : 84 / 122
             AIR monitor : 75 / 33
             EVAP monitor : 20 / 32
             Secondary O2 Sensor monitor bank 1 : 97 / 142
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
  13. Likes Uwe liked this post
  14. #20
    May 2016
    Still have the fuel system monitor “not ready”. Any ideas?
