Tuesday,25,February,2020,10:53:55:64160
VCDS Version: 19.6.2.2 (x64)
VIN: 3VW4T7AU4FM036473 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AU4FM036473 Mileage: 50839km-31589miles
Address 01: Engine (J623-CXCA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0005
Revision: --H13---
Coding: 091D00124424002F0000
Shop #: WSC 00066 790 00221
ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C79FEF947F1972F29-8078
Part No SW: 0D9 300 041 T HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4511
Revision: 03253104 Serial number: TFK01407160154
ROD: EV_TCMDQ250021.rod
VCID: 297707ED48038207D2-807C
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 52324000000257
Coding: 01FA6BA134230972007B020781C62980D62C9000408194B400430050C009
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
VCID: 44A9B659CF617F6FC1-8010
Part No SW: 5G0 907 426 R HW: 5G0 907 426 R
Component: AC Manuell H02 0907
Revision: 00001K06
Coding: 00020004200100000000000012000000
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 3A55C8A1BDA5399FAB-806E
Part No SW: 5Q0 937 087 N HW: 5Q0 937 087 N
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86580909140633
Coding: 000018464041804969E44000001407201000000000000000000000000000
Shop #: WSC 00066 790 00074
ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
ROD: EV_BCMBOSCH_013.rod
VCID: 46ADAC51F95D4D7FDF-8012
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140720 043 0581
Serial number: 140930225756
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Fault Frequency: 73
Reset counter: 185
Mileage: 49733 km
Date: 2020.02.05
Time: 11:48:58
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM0112ZH
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 51878F0D00139AC77A-8004
Occupant Detection:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J140001D3KF0-
Coding: 30325A
Subsystem 2 - Part No SW: ----------- HW: 480 000 708 14
Serial number: 3570000000053685C01C
Subsystem 3 - Part No SW: ----------- HW: 480 000 508 14
Serial number: 35800000000B52A0A01C
Subsystem 4 - Part No SW: ----------- HW: 480 401 108 14
Serial number: 3510002B516DB811C22+
Subsystem 5 - Part No SW: ----------- HW: 480 401 108 14
Serial number: 3520002B516DB813106Z
Subsystem 6 - Part No SW: ----------- HW: 480 402 107 14
Serial number: 3550002C515F3C325181
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 107 14
Serial number: 3560002C715F3C30D315
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20140804500089
Coding: 0410
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 3FA3B9B5A6871CB79C-806A
617752 - Selector Lever Park Position Lock Switch
B1162 29 [008] - Signal Implausible
Reset counter: 166
Mileage: 50482 km
Date: 2020.02.17
Time: 08:57:38
Ubat 30 Voltage: 14.30 V
Ignition State: On
Terminal 15: 13.50 V
A/D #1: 0.00 %
A/D #2: 0.00 %
A/D #3: 0.00 %
Part No SW: 5G1 920 856 HW: 5G1 920 856
Component: KOMBI 342 4270
Coding: 0BBD090A2180CF0502087A001000000000000000
VCID: 6BFB3DE5827F501760-803E
Part No SW: 5Q0 907 530 S HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2186
Revision: -------- Serial number: 22081410001813
Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07026
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
VCID: 41A7BF4DD0736A47EA-8014
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0101
Serial number: 29140001587730094323
Coding: 29FFFF
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 100914060500QK
Coding: 003E03200000040000000000
VCID: 40A1BA49DB79634FE5-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003513103
Coding: 011000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
ROD: EV_SteerAssisMQB_010.rod
VCID: 354FDB9D94BBD6E746-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 100914060502LY
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003615340
Coding: 191000
65588 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Reset counter: 148
Mileage: 50024 km
Date: 2020.02.08
Time: 16:30:08
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B01608141195
Coding: 02730000FF00000021220001001800001F0203040100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 64E956D96FA11F6F21-8030
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS500L03
Part No SW: 5QE 035 285 HW: 5QE 035 285
Component: OCULowMQBUS 006 0528
Coding: 02730002C2821A017F1E06000000
Shop #: WSC 00066 790 00123
ROD: EV_OCULowMQB.rod
VCID: 0225704195F5B15FB3-8056
2103041 - Control Module
Fault Priority: 8
Reset counter: 146
Time: 00:00:00
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 140724201680
End-------------------------(Elapsed Time: 03:20)--------------------------
