Front seat(s) Change: OEM to Recaro Sportster CS (aftermarket)
Hi, I recently changed my front seats in my 2009 Audi S5. I placed in a pair of Recaro Sportster CS manual seats. I did the passenger seat first and there did not seem to be any functionality problems (I transferred the occupancy sensor system and used a airbag resistor, so no airbag warning lights on dash display) . All HVAC functions seemed to be working - A/C in particular. I then changed the drivers seat and I then noticed that a few days later when I tried the A/C it did not function. At that time both seat modules where unplugged from the floor of the car.
I auto scanned the system and numerous codes appeared (as predicted, since the seat modules are unplugged). A few codes caught my attention and I'm now concerned that the component protection may be preventing the A/C from working.
auto scan 1. : seats changed , no modules plugged in
auto scan 2. : seats changed, some codes deleted to see if they would return .
auto scan 3. : seats changed, Only drivers side module plugged back in.
My main concern is that I would like to get the A/C working again. Will plugging in both seat modules to plugs on floor reset the CP ? It apperas that I have triggered the CP and now the A/C is not functioning ?
I sure would appreciate any advice you may have. (and my apologies for the LONG string of scans! ) Thank you! Stefan
Saturday,13,October,2018,13:54:07:19210
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
Dealer/Shop Name: Stefan Czechorski DDS
Workshop Code: 123 12345 123456
VIN: WAURV78T99A015469   License Plate: SFN463
Mileage:    Repair Order: 10-13-2018
                Address 09: Cent. Elect.       Labels: 8K0-907-063.clb
Control Module Part Number: 8K0 907 063 D    HW: 8K0 907 063 D
  Component and/or Version: BCM1 1.0      H22 0253
           Software Coding: 26001091063CAF010000000300003D3D0F1C138800010161000000
            Work Shop Code: WSC 12345 123 123456
                      VCID: B02C6F02E368D9CAE5-80E4
03124 - Terminal 30 - 3
                    Fault Status: 00101011
                    Reset counter: 54
                    Mileage: 167563 km
                    Date: 2018.10.04
                    Time: 19:00:00
            000 -  -  - Intermittent
                    Fault Frequency: 7
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 19:41:00
00576 - Terminal 15
                    Reset counter: 204
                    Mileage: 165056 km
                    Date: 2008.05.27
                    Time: 16:45:00
                    Reset counter: 8
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:20:00
02258 - Door Opener Transmitter
                    Reset counter: 58
                    Mileage: 167813 km
                    Date: 2018.10.10
                    Time: 10:05:00
Address 09: DTCs cleared
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 52
          53 55 56 65 67 77
VIN: WAURV78T99A015469   Mileage: 168090km-104446miles
06-Seat Mem. Pass -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAUB)       Labels: None
   Part No SW: 8T0 907 560 UM    HW: 8T0 907 560
   Component: V.6  JHM      H10 0003
   Revision: 76H10---
   Coding: 01140009180F0120
   Shop #: WSC 02621 444 176472
   VCID: 997AB2A690D23882B2-80CC
Readiness: 0100 0000
   Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
   Component: ESP8 quattro  H04 0060
   Coding: 110500
   Shop #: WSC 06325 000 00000
   VCID: F9BA92267092D88212-80AC
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H80 0141
   Coding: 0B0000
   VCID: B326600E127EE2D298-80E6
   Subsystem 1 - Part No SW: 8T0 959 754 M    HW: 8T0 959 754 M
   Component: FBSAUDIB8 IDG  H34 0050
   Serial number: 0107000112192005
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000043444011
                    Fault Status: 00101101
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
Address 06: Seat Mem. Pass
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 L    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 339HT087504055
   Coding: 0025003
   VCID: C2C835CA9DC45B5A03-8096
   Subsystem 1 - Part No: 8T0 919 609 A
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000128574
   Subsystem 3 - Serial number: 0106.08.080000000100010063ÿ
   Subsystem 4 - Serial number: 010063ÿ
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:52
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000001
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C1000000    Serial number: 0109.08.080922
   Coding: 48022000
   VCID: F2A8A50A2DE4ABDA53-80A6
                    Reset counter: 8
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:20:03
                    Temperature: 18.0°C
                    Fault Status: 01101101
                    Reset counter: 8
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:20:03
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000205657
   Shop #: WSC 12345 123 123456
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 110808  H13 0040
   Serial number: SWFBIE 0000094
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10224813
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 BA    HW: 8K0 941 531 BA
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002210113891
   Subsystem 4 - Part No SW: 8K0 907 410 A    HW: 8K0 907 410 A
   Component: UGDO HL US  H04 0060
00576 - Terminal 15
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.13
                    Time: 13:55:00
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.13
                    Time: 13:55:00
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBH8547276
   VCID: AA187D6A05B4A31A2B-80FE
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7H0383037
   Coding: 0000100
   VCID: B12A6A062862D0C2EA-80E4
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD1410Y%
   Coding: 303333334330303030304A55304C38543053
   VCID: C0CC3FC25BC8494A15-8094
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R08000018BT
   Serial number: 6334MSME35006D79G
   Serial number: 6344MSME3F20417CI
   Serial number: 6352QSME540033361
   Serial number: 6362QSME53000B3AA
   Serial number: 63732SME4B043F30$
   Serial number: 63832SME61002F0AY
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372RBQ00047
   Coding: 000016
   VCID: C4C433D247D0556A31-8090
   Part No SW: 8T0 920 981 E    HW: 8T0 920 981 E
   Component: KOMBIINSTR.   H30 0224
   Revision: 00000000    Serial number: 9D9622A88
   Coding: 831501000300D705020000
   VCID: BE30413A293C3FBA67-80EA
   Part No SW: 8T0 907 468 K    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0092
   Revision: EB302042    Serial number: 4200E088048079
   Coding: 000303
   VCID: C9DA22E660F28802C2-809C
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 1803724F010808
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:44
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 61
                    Mileage: 167851 km
                    Date: 2018.10.10
                    Time: 20:03:00
00461 - Control Module for Seat Memory; Passenger (J521)
                    Reset counter: 230
                    Mileage: 166137 km
                    Date: 2018.08.31
                    Time: 12:54:35
                    Reset counter: 61
                    Mileage: 167851 km
                    Date: 2018.10.11
                    Time: 00:03:00
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   Coding: 020000
   VCID: AB16786ECA4EBA12D0-80FE
Address 36: Seat Mem. Drvr
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H51 1100
   Revision: 00000000    Serial number: 341HO087511923
   Shop #: WSC 06342 000 00000
   VCID: B83C5722CB18018AAD-80EC
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: AX
   Coding: 011C03225E002201
   VCID: FDB2863664BAE4A23E-80A8
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:48
   Revision: 00002001    Serial number: 0113745169
   Coding: 0102069A007AC4C400B000
   Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
   Component: GTO BF  H06 0040
   Serial number: 00000000000000055750
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
00198 - Automatic Day/Night Interior Mirror (Y7)
                    Reset counter: 204
                    Mileage: 165056 km
                    Date: 2008.05.27
                    Time: 16:45:25
03123 - Terminal 30 - 2
                    Reset counter: 65
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
00926 - Terminal 30
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
   Part No SW: 8T0 035 223 AD    HW: 8T0 035 223 G
   Component: DSP STD       H08 0300
   Revision: S2600000
   Coding: 020101
   VCID: F0ACAF0223E899CAA5-80A4
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: eU
   VCID: FCB48B327FA0EDAA09-80A8
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:48
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 10000000078316
   VCID: B12A6A06E862D0C2EA-80E4
                    Reset counter: 29
                    Mileage: 166137 km
                    Date: 2018.09.02
                    Time: 12:05:43
                    Voltage: 12.30 V
                    Count: 80
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Shop #: WSC 06324 000 00000
   VCID: B4246312D770E5EA81-80E0
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
   Revision: 00000000    Serial number: 357H 087507682
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140781525422
   Coding: 0CD154
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000807290057
   Shop #: WSC 12336 024 394758
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005054612
   Coding: 0010900
   VCID: A81C87621BB8910A3D-80FC
End----------(Elapsed Time: 02:02, VBatt start/end: 12.3V/12.3V)-----------
          53 55 56 65 67 77
   Revision: 76H10---
   Coding: 110500
   Coding: 0B0000
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
   Coding: 0025003
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:52
   Coding: 48022000
                    Reset counter: 8
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:20:03
                    Temperature: 18.0°C
                    Reset counter: 8
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:20:03
   Coding: 00FD11
   Coding: 02532C
00576 - Terminal 15
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.13
                    Time: 13:55:00
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.13
                    Time: 13:55:00
   Coding: 0000100
   Coding: 000016
   Coding: 000303
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:44
                    Reset counter: 61
                    Mileage: 167851 km
                    Date: 2018.10.10
                    Time: 20:03:00
                    Reset counter: 230
                    Mileage: 166137 km
                    Date: 2018.08.31
                    Time: 12:54:35
                    Reset counter: 61
                    Mileage: 167851 km
                    Date: 2018.10.11
                    Time: 00:03:00
   Revision: 00000000
   Coding: 020000
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:48
                    Reset counter: 204
                    Mileage: 165056 km
                    Date: 2008.05.27
                    Time: 16:45:25
                    Reset counter: 65
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
00926 - Terminal 30
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
   Revision: S2600000
   Coding: 020101
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:48
                    Reset counter: 29
                    Mileage: 166137 km
                    Date: 2018.09.02
                    Time: 12:05:43
                    Voltage: 12.30 V
                    Count: 80
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 0CD154
   Coding: 0010900
End----------(Elapsed Time: 01:58, VBatt start/end: 12.2V/12.2V)-----------
Sunday,14,October,2018,09:59:09:19210
Mileage: 168090km-104446mi   Repair Order: 10-14-2018 AC scan
          53 55 56 65 67 77
   Revision: 76H10---
   Coding: 110500
   Coding: 0B0000
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
   Coding: 0025003
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:52
   Coding: 48022000
                    Reset counter: 8
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:20:03
                    Temperature: 18.0°C
                    Reset counter: 8
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:20:03
   Coding: 00FD11
   Coding: 02532C
00576 - Terminal 15
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.13
                    Time: 13:55:00
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.13
                    Time: 13:55:00
   Coding: 0000100
   Coding: 000016
   Coding: 000303
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:44
                    Reset counter: 61
                    Mileage: 167851 km
                    Date: 2018.10.10
                    Time: 20:03:00
                    Reset counter: 230
                    Mileage: 166137 km
                    Date: 2018.08.31
                    Time: 12:54:35
                    Reset counter: 61
                    Mileage: 167851 km
                    Date: 2018.10.11
                    Time: 00:03:00
   Revision: 00000000
   Coding: 020000
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:48
                    Reset counter: 204
                    Mileage: 165056 km
                    Date: 2008.05.27
                    Time: 16:45:25
                    Reset counter: 65
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
00926 - Terminal 30
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
   Revision: S2600000
   Coding: 020101
                    Reset counter: 8
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:48
                    Reset counter: 29
                    Mileage: 166137 km
                    Date: 2018.09.02
                    Time: 12:05:43
                    Voltage: 12.30 V
                    Count: 80
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 0CD154
   Coding: 0010900
End----------(Elapsed Time: 01:59, VBatt start/end: 12.3V/12.3V)-----------
Mileage: 168090km-104446mi   Repair Order: 10-15-2018 drs. seat module plugged in
          53 55 56 65 67 77
36-Seat Mem. Drvr -- Status: Malfunction 1010
   Revision: 76H10---
   Coding: 110500
   Coding: 0B0000
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
   Coding: 0025003
   Coding: 48022000
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.15
                    Time: 19:22:03
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.15
                    Time: 19:22:03
                    Temperature: 15.0°C
   Coding: 00FD11
   Coding: 02532C
00576 - Terminal 15
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.15
                    Time: 19:21:00
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.15
                    Time: 19:21:00
   Coding: 0000100
   Coding: 000016
   Coding: 000303
                    Reset counter: 65
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:44
                    Reset counter: 61
                    Mileage: 167851 km
                    Date: 2018.10.10
                    Time: 20:03:00
                    Reset counter: 230
                    Mileage: 166137 km
                    Date: 2018.08.31
                    Time: 12:54:35
                    Reset counter: 61
                    Mileage: 167851 km
                    Date: 2018.10.11
                    Time: 00:03:00
   Revision: 00000000
   Coding: 020000
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001129050
   Coding: 00197325002C00000000
   VCID: C2C835CA5DC45B5A03-8096
                    Reset counter: 230
                    Mileage: 166137 km
                    Date: 2018.08.31
                    Time: 12:54:36
03337 - Switch for Back Rest Locking
                    Reset counter: 8
                    Reset counter: 65
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:48
                    Reset counter: 204
                    Mileage: 165056 km
                    Date: 2008.05.27
                    Time: 16:45:25
                    Reset counter: 65
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
00926 - Terminal 30
                    Reset counter: 48
                    Mileage: 167372 km
                    Date: 2018.10.01
                    Time: 20:13:42
   Revision: S2600000
   Coding: 020101
                    Reset counter: 65
                    Mileage: 167371 km
                    Date: 2018.09.29
                    Time: 10:39:48
                    Reset counter: 29
                    Mileage: 166137 km
                    Date: 2018.09.02
                    Time: 12:05:43
                    Voltage: 12.30 V
                    Count: 80
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 0CD154
   Coding: 0010900
End----------(Elapsed Time: 02:09, VBatt start/end: 12.1V/12.1V)-----------
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I do see that CP was active at one point, but it was flagged Intermittent, and you've managed to clear it. So I don't think it's your current problem. Here's what you do have:
A/C is going nowhere without G395. You'll see that code in both 08 and 09. From having talked someone through a similar issue, I believe G395 is a LIN bus device connected up via 09-Central Electronics, which then passes the reading over to 08-Auto HVAC via CAN.
Absent an amazing coincidence, or something you haven't shared, the first thing I'd check is if you have (or had) LIN bus devices in the seats, that might have been on the same LIN bus as G395. Sometimes stuff like seat heating and ventilation can be driven through 09-Central Electronics rather than 36/06-Seat Mem Driver/Passenger. You may need a wiring diagram to check.
Even if you didn't damage the wiring itself, LIN (just like CAN) needs a termination resistor at the end of any wire, which you may have taken away as part of your work. They're generally built into the control modules. If this turns out to be your problem, you may be able to rig a substitute termination resistor.
More data is always good, please always feel free to share or over-share. :) If you'd like to make it more readable, use CODE tags as shown here:
https://forums.ross-tech.com/showthread.php?101-How-to-post-an-Auto-Scan
Edit: Looks like Uwe just put CODE tags in on your behalf..
OK, thank you JYoung and Uwe both very much! I did plug back in the drivers side seat module (minus the heating harness as the pad is deep in the seat). I know what you mean JY, coincidence ? I'm not really surprised though. I do have a wiring diagram. Right now the drivers seat module is plugging in with only the seat switch / control harness, so you may be on to the LIN Bus being part of the seat heating etc.
I did test the plug at G395 (A/C pressure sensor switch) for power and ground and there was none.
I will definitely share, and I will continue to Auto Scan as I plug "items" back in .
Thanks again for the insight JY; and the platform Uwe. Stefan
I did scroll through the wiring diagram for both front seats , the heating, the ventilation and anything else associated with the LIN Bus B-549 .
It is associated with ventilation Fans (which I do Not have in ether seat).
There was nothing under heating.
It is connected to G-657 Humidity sender in fresh air duct , but all worked fine before seat change. (coincidence???)
I will try to place back in the Passenger module (without the heating harness) and see what occurs. (auto scan)
I'll also try to get those wire diagrams up (once I get them to post).
Also JYoung, I read all 18 pages of the post you recommended! Wow, talk about anti-climactic! "HVAC in Hell" . What a journey only to find out it was all in the PN "A" . That alone was worth the read..... no offense to all the great help she received.
The modules and the harness that I'm plugging back in also have a "twisted pair" within the harness . I'm almost certain that I do not have a broken or pinched wire as I'm very careful - but I will check some of the usual areas (as per that TSB). All fuses test ok, but I will double check.
Like many of you, I refuse to take it to any Audi dealer as ........ well...... fill in the blank. Although the parts person (in that thread) who gives advice may mean well and in their case , for that car, with those unique options, something unplugged may not matter one can not go on that method.
[/IMG]
[/IMG]
My apologies , as the WD's above are quite "soft" ; B549 Lin Bus is the focus here ( left side of WD , yellow and grey lines , one short and one long) ; G238 and G395 ; brown trace is at the bottom of WD is ground and above G's is Lin Bus connecting the two ; as the yellow and grey trace wire travels up to J519. Note: always verify the colors of your actual wires..... some of these manuals have multiple listings for all the variants involved so always check. The very top WD is color accurate for my car.
[/IMG]
[/IMG]
That should help. I'll update as I / "we" make progress!
UPDATE:
UPDATE: I plugged in the Pass. side seat module (the only item not connected is the seat heating and the seat switches and as far as the WD showed they are not assoc. with the LIN B-549). With all the codes cleared, here is the most recent auto scan. Also, note that there is a interior auto dimming mirror code and that has been there for some time and the A/C functioned just fine.
    Friday,19,October,2018,18:06:42:19210
          53 55 56 65 67 77
VIN: WAURV78T99A015469   Mileage: 168400km-104638miles
   Revision: 76H10---
   Coding: 110500
   Coding: 0B0000
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001124746
   Coding: 00017025002C00000000
                    Reset counter: 32
                    Mileage: 168404 km
                    Date: 2018.10.19
                    Time: 17:57:01
   Coding: 0025003
   Coding: 48022000
                    Reset counter: 32
                    Mileage: 168404 km
                    Date: 2018.10.19
                    Time: 18:01:11
                    Reset counter: 32
                    Mileage: 168404 km
                    Date: 2018.10.19
                    Time: 18:01:11
                    Temperature: 37.0°C
   Coding: 00FD11
   Coding: 02532C
00576 - Terminal 15
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.15
                    Time: 19:21:00
                    Reset counter: 25
                    Mileage: 168090 km
                    Date: 2018.10.15
                    Time: 19:21:00
                    Reset counter: 32
                    Mileage: 168125 km
                    Date: 2018.10.16
                    Time: 13:35:00
   Coding: 0000100
   Coding: 000016
   Coding: 000303
   Revision: 00000000
   Coding: 020000
                    Reset counter: 72
                    Mileage: 166137 km
                    Date: 2018.08.31
                    Time: 12:54:36
                    Reset counter: 8
                    Reset counter: 32
                    Mileage: 168404 km
                    Date: 2018.10.19
                    Time: 17:59:12
   Revision: S2600000
   Coding: 020101
   Coding: 0CD154
   Coding: 0010900
End----(Elapsed Time: 01:54, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
Its looking like the A/C faults are coincidence , but I'm not certain. Here is a rather interesting observation: In Address 09: Cent. Elect. (J519) , there is a no-com. for the garage door opener, yet it works just fine. I will check once again for power and ground at the G395 and also check that G238 - Air quality sensor as it is tied in with G395 (B-549) Lin Bus.
Is J-519 component protected ? (should it need to be changed). But as of right now, the A/C is not activating.
Good Evening, I was trying to sort out my A/C problem as noted above. I plugged in the seat switches on both pass. and drs. side. The scan was showing comm. with the modules now, but the A/C fault codes were still showing. So, I thought I would clear the HVAC module codes and try to re- auto scan just in case a clear code was necessary to get the A/C system live again. Observation: when I tried to clear the codes in the HVAC address / module I noticed that it would return almost immediately ; I mean the blink of a eye return!
This I recall from other vehicle faults (like a emissions code on my WRX) was usually something "gross" like a unconnected wire or blown fuse. So, I went looking for any connections that I made with the new seats (they are heated, so you need to hook up 12v pos. and ground) , and that looked fine. I went on to the drivers side fuse dash panel and started looking at fuses..... all looked ok and tested ok. I then started looking at fuse position numbers and counting there positions (why I don't know) . A/C on the drivers side is in the black column #12 , 5A fuse - according to the cover panel on the dash. (this is where it gets embarrassing :facepalm:) ; position 12 was vacant! I looked into the socket and there were female clips on each side of the socket (as other positions may be vacant and only have one connecting clip present) . I must have pulled that fuse and plugged it into space #11 when I was placing the fuse tap for the heated seat. Spot 11 is heated h-light wash jets (?) , which does have two connections present.
I then anxiously found a 5A fuse and plugged it into space #12 A/C........ and wha-la cold air!
As I did the pass. side first and did use a fuse tap on that side the AC still worked, but when I did the drivers side I must have pulled a fuse and placed it into the incorrect spot when I was looking for a spot for the tap.
So, in summary...... disconnecting your oem seat modules and switches will throw a bunch of codes , so best to plug back in the modules to avoid "CP active". BUT, it does not cause your a/c to go down and become nonfunctional. (unless you don't plug back in the A/C fuse :banghead:)
Thank you all who read and posted , it really helped.
Final Auto Scan : seat modulles in ; no seat switches attached
     Monday,22,October,2018,19:17:52:19210
Mileage: 168400km-104638mi   Repair Order: 10-22-2018 seat modules plugged into floor - codes cleared - no seat switches or heater harness
NOTE: address 46, central conv. mirror day/night  mirror auto dimming  may be faulting because of Rear window tint and sun screen shade !!
          53 55 56 65 67 77
   Revision: 76H10---
   Coding: 110500
   Coding: 0B0000
                    Reset counter: 32
                    Mileage: 168404 km
                    Date: 2018.10.21
                    Time: 14:25:05
   Coding: 0025003
   Coding: 48022000
   Coding: 00FD11
   Coding: 02532C
00576 - Terminal 15
                    Reset counter: 32
                    Mileage: 168404 km
                    Date: 2018.10.22
                    Time: 08:01:00
   Coding: 0000100
   Coding: 000016
   Coding: 000303
   Revision: 00000000
   Coding: 020000
                    Reset counter: 32
                    Mileage: 168404 km
                    Date: 2018.10.21
                    Time: 14:26:08
03331 - Motor for Backrest Angle Adjustment
                    Reset counter: 32
                    Mileage: 1048574 km
                    Reset counter: 32
                    Mileage: 168404 km
                    Date: 2018.10.19
                    Time: 17:59:12
   Revision: S2600000
   Coding: 020101
   Coding: 0CD154
   Coding: 0010900
End----------(Elapsed Time: 01:57, VBatt start/end: 12.1V/12.0V)-----------
Thank you once again!
[/IMG]
Recaro Sportster CS ; 2009 Audi S5
[/IMG]
[/IMG]
I also wanted to mention, in case you ended up here and have these seats or plan to get them (Recaro Sprotster CS, synthetic leather, heated) that Recaro does Not sell upholstery for these seats and the support is very minimal. I managed to find a Recaro Dealer who also does custom seat covers ; any material and any pattern / combination you can dream up! He's in Poland! I've done business with him and he is legitimate. Below is a link to the post I made on a Audi Forum , Audizine. Once you read the post, you'll realize the benefit of having access to his services. (!)
https://www.audizine.com/forum/show...-Original-seat-covers?p=13360819#post13360819
