Hi, I recently changed my front seats in my 2009 Audi S5. I placed in a pair of Recaro Sportster CS manual seats. I did the passenger seat first and there did not seem to be any functionality problems (I transferred the occupancy sensor system and used a airbag resistor, so no airbag warning lights on dash display) . All HVAC functions seemed to be working - A/C in particular. I then changed the drivers seat and I then noticed that a few days later when I tried the A/C it did not function. At that time both seat modules where unplugged from the floor of the car.
I auto scanned the system and numerous codes appeared (as predicted, since the seat modules are unplugged). A few codes caught my attention and I'm now concerned that the component protection may be preventing the A/C from working.
auto scan 1. : seats changed , no modules plugged in
auto scan 2. : seats changed, some codes deleted to see if they would return .
auto scan 3. : seats changed, Only drivers side module plugged back in.
My main concern is that I would like to get the A/C working again. Will plugging in both seat modules to plugs on floor reset the CP ? It apperas that I have triggered the CP and now the A/C is not functioning ?
I sure would appreciate any advice you may have. (and my apologies for the LONG string of scans! ) Thank you! Stefan
Address 09: DTCs cleared
Saturday,13,October,2018,13:54:07:19210
VCDS Version: 18.9.0.2 (x64) HEX-NET CB: 0.4436.4
Dealer/Shop Name: Stefan Czechorski DDS
Workshop Code: 123 12345 123456
VIN: WAURV78T99A015469 License Plate: SFN463
Mileage: Repair Order: 10-13-2018
Address 09: Cent. Elect. Labels: 8K0-907-063.clb
Control Module Part Number: 8K0 907 063 D HW: 8K0 907 063 D
Component and/or Version: BCM1 1.0 H22 0253
Software Coding: 26001091063CAF010000000300003D3D0F1C138800010161000000
Work Shop Code: WSC 12345 123 123456
VCID: B02C6F02E368D9CAE5-80E4
03124 - Terminal 30 - 3
Fault Status: 00101011
Reset counter: 54
Mileage: 167563 km
Date: 2018.10.04
Time: 19:00:00
Fault Frequency: 7
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 19:41:00
00576 - Terminal 15
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 204
Mileage: 165056 km
Date: 2008.05.27
Time: 16:45:00
00256 - A/C Pressure/Temperature Sensor (G395)
Reset counter: 8
Mileage: 167372 km
Date: 2018.10.01
Time: 20:20:00
02258 - Door Opener Transmitter
Reset counter: 58
Mileage: 167813 km
Date: 2018.10.10
Time: 10:05:00
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 52
53 55 56 65 67 77
VIN: WAURV78T99A015469 Mileage: 168090km-104446miles
06-Seat Mem. Pass -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAUB) Labels: None
Part No SW: 8T0 907 560 UM HW: 8T0 907 560
Component: V.6 JHM H10 0003
Revision: 76H10---
Coding: 01140009180F0120
Shop #: WSC 02621 444 176472
VCID: 997AB2A690D23882B2-80CC
Readiness: 0100 0000
Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
Component: ESP8 quattro H04 0060
Coding: 110500
Shop #: WSC 06325 000 00000
VCID: F9BA92267092D88212-80AC
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H80 0141
Coding: 0B0000
VCID: B326600E127EE2D298-80E6
Subsystem 1 - Part No SW: 8T0 959 754 M HW: 8T0 959 754 M
Component: FBSAUDIB8 IDG H34 0050
Serial number: 0107000112192005
Component: ELVAUDIB8 H36 0041
Serial number: 0208000043444011
Fault Status: 00101101
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Address 06: Seat Mem. Pass
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 L HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 339HT087504055
Coding: 0025003
VCID: C2C835CA9DC45B5A03-8096
Subsystem 1 - Part No: 8T0 919 609 A
Subsystem 2 - Serial number: 00000000128574
Subsystem 3 - Serial number: 0106.08.080000000100010063ÿ
Subsystem 4 - Serial number: 010063ÿ
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:52
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000001
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0109.08.080922
Coding: 48022000
VCID: F2A8A50A2DE4ABDA53-80A6
Reset counter: 8
Mileage: 167372 km
Date: 2018.10.01
Time: 20:20:03
Temperature: 18.0°C
Fault Status: 01101101
Reset counter: 8
Mileage: 167372 km
Date: 2018.10.01
Time: 20:20:03
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000205657
Shop #: WSC 12345 123 123456
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110808 H13 0040
Serial number: SWFBIE 0000094
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10224813
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 BA HW: 8K0 941 531 BA
Component: E1 - LDS H03 0031
Serial number: 00000000002210113891
Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
Component: UGDO HL US H04 0060
00576 - Terminal 15
Reset counter: 25
Mileage: 168090 km
Date: 2018.10.13
Time: 13:55:00
Reset counter: 25
Mileage: 168090 km
Date: 2018.10.13
Time: 13:55:00
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043003 Serial number: AUZ5ZBH8547276
VCID: AA187D6A05B4A31A2B-80FE
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0383037
Coding: 0000100
VCID: B12A6A062862D0C2EA-80E4
Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
Serial number: 0039KD1410Y%
Coding: 303333334330303030304A55304C38543053
VCID: C0CC3FC25BC8494A15-8094
Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
Component: BF-Gewichtss. H01 0050
Serial number: 5810000R08000018BT
Serial number: 6334MSME35006D79G
Serial number: 6344MSME3F20417CI
Serial number: 6352QSME540033361
Serial number: 6362QSME53000B3AA
Serial number: 63732SME4B043F30$
Serial number: 63832SME61002F0AY
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372RBQ00047
Coding: 000016
VCID: C4C433D247D0556A31-8090
Part No SW: 8T0 920 981 E HW: 8T0 920 981 E
Component: KOMBIINSTR. H30 0224
Revision: 00000000 Serial number: 9D9622A88
Coding: 831501000300D705020000
VCID: BE30413A293C3FBA67-80EA
Part No SW: 8T0 907 468 K HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0092
Revision: EB302042 Serial number: 4200E088048079
Coding: 000303
VCID: C9DA22E660F28802C2-809C
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 1803724F010808
01964 - Control Module for Seat & Steering Column Memory (J136)
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:44
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 61
Mileage: 167851 km
Date: 2018.10.10
Time: 20:03:00
00461 - Control Module for Seat Memory; Passenger (J521)
Reset counter: 230
Mileage: 166137 km
Date: 2018.08.31
Time: 12:54:35
Reset counter: 61
Mileage: 167851 km
Date: 2018.10.11
Time: 00:03:00
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 020000
VCID: AB16786ECA4EBA12D0-80FE
Address 36: Seat Mem. Drvr
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 341HO087511923
Shop #: WSC 06342 000 00000
VCID: B83C5722CB18018AAD-80EC
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: AX
Coding: 011C03225E002201
VCID: FDB2863664BAE4A23E-80A8
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:48
Revision: 00002001 Serial number: 0113745169
Coding: 0102069A007AC4C400B000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Serial number: 00000000000000055750
Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
00198 - Automatic Day/Night Interior Mirror (Y7)
Reset counter: 204
Mileage: 165056 km
Date: 2008.05.27
Time: 16:45:25
03123 - Terminal 30 - 2
Reset counter: 65
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
00926 - Terminal 30
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 AD HW: 8T0 035 223 G
Component: DSP STD H08 0300
Revision: S2600000
Coding: 020101
VCID: F0ACAF0223E899CAA5-80A4
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0149
Revision: Serial number: eU
VCID: FCB48B327FA0EDAA09-80A8
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:48
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 10000000078316
VCID: B12A6A06E862D0C2EA-80E4
Reset counter: 29
Mileage: 166137 km
Date: 2018.09.02
Time: 12:05:43
Voltage: 12.30 V
Count: 80
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Shop #: WSC 06324 000 00000
VCID: B4246312D770E5EA81-80E0
Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
Revision: 00000000 Serial number: 357H 087507682
Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 13140781525422
Coding: 0CD154
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000807290057
Shop #: WSC 12336 024 394758
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005054612
Coding: 0010900
VCID: A81C87621BB8910A3D-80FC
End----------(Elapsed Time: 02:02, VBatt start/end: 12.3V/12.3V)-----------
53 55 56 65 67 77
Revision: 76H10---
Coding: 110500
Coding: 0B0000
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Coding: 0025003
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:52
Coding: 48022000
Reset counter: 8
Mileage: 167372 km
Date: 2018.10.01
Time: 20:20:03
Temperature: 18.0°C
Reset counter: 8
Mileage: 167372 km
Date: 2018.10.01
Time: 20:20:03
Coding: 00FD11
Coding: 02532C
00576 - Terminal 15
Reset counter: 25
Mileage: 168090 km
Date: 2018.10.13
Time: 13:55:00
Reset counter: 25
Mileage: 168090 km
Date: 2018.10.13
Time: 13:55:00
Coding: 0000100
Coding: 000016
Coding: 000303
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:44
Reset counter: 61
Mileage: 167851 km
Date: 2018.10.10
Time: 20:03:00
Reset counter: 230
Mileage: 166137 km
Date: 2018.08.31
Time: 12:54:35
Reset counter: 61
Mileage: 167851 km
Date: 2018.10.11
Time: 00:03:00
Revision: 00000000
Coding: 020000
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:48
Reset counter: 204
Mileage: 165056 km
Date: 2008.05.27
Time: 16:45:25
Reset counter: 65
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
00926 - Terminal 30
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Revision: S2600000
Coding: 020101
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:48
Reset counter: 29
Mileage: 166137 km
Date: 2018.09.02
Time: 12:05:43
Voltage: 12.30 V
Count: 80
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Coding: 0CD154
Coding: 0010900
End----------(Elapsed Time: 01:58, VBatt start/end: 12.2V/12.2V)-----------
Sunday,14,October,2018,09:59:09:19210
Mileage: 168090km-104446mi Repair Order: 10-14-2018 AC scan
53 55 56 65 67 77
Revision: 76H10---
Coding: 110500
Coding: 0B0000
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Coding: 0025003
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:52
Coding: 48022000
Reset counter: 8
Mileage: 167372 km
Date: 2018.10.01
Time: 20:20:03
Temperature: 18.0°C
Reset counter: 8
Mileage: 167372 km
Date: 2018.10.01
Time: 20:20:03
Coding: 00FD11
Coding: 02532C
00576 - Terminal 15
Reset counter: 25
Mileage: 168090 km
Date: 2018.10.13
Time: 13:55:00
Reset counter: 25
Mileage: 168090 km
Date: 2018.10.13
Time: 13:55:00
Coding: 0000100
Coding: 000016
Coding: 000303
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:44
Reset counter: 61
Mileage: 167851 km
Date: 2018.10.10
Time: 20:03:00
Reset counter: 230
Mileage: 166137 km
Date: 2018.08.31
Time: 12:54:35
Reset counter: 61
Mileage: 167851 km
Date: 2018.10.11
Time: 00:03:00
Revision: 00000000
Coding: 020000
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:48
Reset counter: 204
Mileage: 165056 km
Date: 2008.05.27
Time: 16:45:25
Reset counter: 65
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
00926 - Terminal 30
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Revision: S2600000
Coding: 020101
Reset counter: 8
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:48
Reset counter: 29
Mileage: 166137 km
Date: 2018.09.02
Time: 12:05:43
Voltage: 12.30 V
Count: 80
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Coding: 0CD154
Coding: 0010900
End----------(Elapsed Time: 01:59, VBatt start/end: 12.3V/12.3V)-----------
Mileage: 168090km-104446mi Repair Order: 10-15-2018 drs. seat module plugged in
53 55 56 65 67 77
36-Seat Mem. Drvr -- Status: Malfunction 1010
Revision: 76H10---
Coding: 110500
Coding: 0B0000
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Coding: 0025003
Coding: 48022000
Reset counter: 25
Mileage: 168090 km
Date: 2018.10.15
Time: 19:22:03
Reset counter: 25
Mileage: 168090 km
Date: 2018.10.15
Time: 19:22:03
Temperature: 15.0°C
Coding: 00FD11
Coding: 02532C
00576 - Terminal 15
Reset counter: 25
Mileage: 168090 km
Date: 2018.10.15
Time: 19:21:00
Reset counter: 25
Mileage: 168090 km
Date: 2018.10.15
Time: 19:21:00
Coding: 0000100
Coding: 000016
Coding: 000303
Reset counter: 65
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:44
Reset counter: 61
Mileage: 167851 km
Date: 2018.10.10
Time: 20:03:00
Reset counter: 230
Mileage: 166137 km
Date: 2018.08.31
Time: 12:54:35
Reset counter: 61
Mileage: 167851 km
Date: 2018.10.11
Time: 00:03:00
Revision: 00000000
Coding: 020000
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001129050
Coding: 00197325002C00000000
VCID: C2C835CA5DC45B5A03-8096
Reset counter: 230
Mileage: 166137 km
Date: 2018.08.31
Time: 12:54:36
03337 - Switch for Back Rest Locking
Reset counter: 8
Reset counter: 65
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:48
Reset counter: 204
Mileage: 165056 km
Date: 2008.05.27
Time: 16:45:25
Reset counter: 65
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
00926 - Terminal 30
Reset counter: 48
Mileage: 167372 km
Date: 2018.10.01
Time: 20:13:42
Revision: S2600000
Coding: 020101
Reset counter: 65
Mileage: 167371 km
Date: 2018.09.29
Time: 10:39:48
Reset counter: 29
Mileage: 166137 km
Date: 2018.09.02
Time: 12:05:43
Voltage: 12.30 V
Count: 80
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Coding: 0CD154
Coding: 0010900
End----------(Elapsed Time: 02:09, VBatt start/end: 12.1V/12.1V)-----------
