Dual climate control - temperature not moving
kpm
C?ID=342561
Hi all
I have a 2014 A3, UK so right hand drive. The passenger side is cold. No fault codes. Coolant is a solid 91 degrees according to VCDS value.
I checked values with both sides set at 22:
Left front temperature = 15
Right front temperature = 22
Last customer setting - left specified temperature = 22
Last customer setting - right specified temperature = 15
Two questions:
How is it that the left vent corresponds to the right dial and vice versa?
Why is the right specified temperature stuck at 15 - do these dials have potentiometers?
Thanks, Kristian
kpm
C?ID=342561
Monday,15,October,2018,11:27:52:42375
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
VIN: WAUZZZ8V5FA   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V5FA   Mileage: 188373km-117049miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 7539
   Revision: 81H22---
   Coding: 02190012032501082000
   Shop #: WSC 29392 003 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
   ROD: EV_ECM20TDI01104L906021AE.rod
   VCID: 77ABE8D7FF471CCF40E-8022
   Revision: 00000000    Serial number: 62004000002468
   Coding: 12F18AA234230A74017E060241CB2948512C5080608294F4026100788608
   ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
   VCID: 45D7521FF52BBE5F022-8010
   Revision: 20026000    Serial number: 00000000387850
   Coding: 03100104002000011000000000001100
   Shop #: WSC 06314 790 00021
   VCID: 33331CC7ABBF30EFBC6-8066
   Serial number: 0319CD37000000000001
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011419804312
   Coding: 07040A46C24322FD03844004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 0059830BAA895B77714-8054
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140713  041 0580
   Serial number:         140716220904
   Coding: 0A47F7
   Serial number: 63282863
   Coding: 02006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
   Serial number: 26 01 2016  00001031
   Serial number: 000000000ZY141681KG4
   Serial number: 00000000000030264090
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39231420400990
   Coding: 0000050001
   ROD: EV_EPHVA14AU3700000_002_AU37.rod
   VCID: 3B2334E783EFF8AF646-806E
   Serial number: 003M2R07T4KS
   VCID: 4BC36427D34F482FD46-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 607 14
   Serial number: 357670000003EAD0001Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 607 14
   Serial number: 35867000000DDAD0001-
   Subsystem 3 - Part No SW: -----------    HW: 480 402 107 14
   Serial number: 3516502C515F3C34B23C
   Subsystem 4 - Part No SW: -----------    HW: 480 402 107 14
   Serial number: 3526502C515F3C324166
   Subsystem 5 - Part No SW: -----------    HW: 480 401 706 14
   Serial number: 35565029D1697520A136
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 807 14
   Serial number: 2286502C11656B83C307
   Subsystem 7 - Part No SW: -----------    HW: 480 400 807 14
   Serial number: 2296502C11656B8393CH
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 807 14
   Serial number: 23065029B1656B853287
   Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 17071408490481
   Coding: A408
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 0655951388AD75474B8-8052
   Part No SW: 8V0 920 971 E    HW: 8V0 920 971 E
   Component: KOMBI         H02 4291
   Coding: 27A409002B8026000100E8001000000000000000
   VCID: 3FDB40F797F7E48F48E-806A
1048578 - No Basic Setting
          B2010 00 [009] -  -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 152
                    Mileage: 188236 km
                    Date: 2018.10.14
                    Time: 00:24:01
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002290549
   Coding: 030100040F0876005B000248080B00000001010000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011_VW37.rod
   VCID: 42DD4903E4058967270-8016
   Serial number: 12 07 2014  D0038904
   Serial number: 3110563903
   Serial number: 14071403110089
   Coding: 00108E204001040000001002
   VCID: 40D9430BEA099B77314-8014
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF460FE103927F3EA-8014
   Serial number: 12071404080092
   Coding: 001086204001040000001002
   Coding: 019C000001000000
   VCID: 75B7E2DFE54B6EDF522-8020
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    041 0420
   Serial number: A7F01907140514
   Coding: 01730301FF0A000021111101000A00002F0004460100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 8V0 919 866 B    HW: -----------
   Component:  ECE 2014  --- 0036
   Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY304V8J
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Serial number: C1000007061400020173
1590 - invalid data record
          B2005 00 [008] -  -
          [Control module (data record download) - invalid data record for sound audio parameters]
                    Reset counter: 192
                    Mileage: 188236 km
                    Date: 2018.10.14
                    Time: 00:35:30
                    Voltage terminal 30: 12.5 V
0532 - Loudspeaker Channel 5
          B13A4 01 [009] - Electrical Failure
                    Reset counter: 152
                    Mileage: 188236 km
                    Date: 2018.10.14
                    Time: 00:35:47
0537 - Loudspeaker Channel 6
          B13A5 01 [009] - Electrical Failure
                    Reset counter: 152
                    Mileage: 188236 km
                    Date: 2018.10.14
                    Time: 00:35:47
   Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0025
   Serial number: 11071401100167
   Coding: 000086204001040000001002
   Component: TSG HBFS      020 0025
   Serial number: 11071402090166
End----------(Elapsed Time: 01:30, VBatt start/end: 12.2V/12.2V)-----------
Mari
C?ID=150535
If you turn the dials, values must go up or down... check also the value of the flaps (they should change also)... When heater is set to max. and coolant is at 90 degrees, there should be coming hot air from the vents and values must go up... if not, and flaps work prefect, the heater radiator is full of stuff that shouldn't be there!
kpm
C?ID=342561
Hi Mari
The left/right dial/vent issue seems to have sorted itself out, but I’m still left with the problem of the passenger side giving cold air even when it’s set to 28. The driver side works normal hot and cold. I guess as the driver side can go hot then the heater matrix is ok.
I will check again the flap values for the passenger side and report back.
kpm
C?ID=342561
I did some more diagnostics today. With the engine running I logged the below info. Looks a bit messy but you can see right vent got upto 34 and left vent upto 17. The right hand side is quite warm no?
With the engine off the left side could get warmer - upto 24 but no further when the right side carried onto 36 with climate on HI. I did notice the flaps were delayed on the left side.
I did the adapation thing and with glovebox out I could see the mixer arm moving back and forth.
The heater matrix was hot, I measured the in and out pipe with an infrared thermometer and with coolant at 70 degrees, the top hose was 65 and bottom hose was 55. 10 degrees cooler coming out than going in, but hot enough to provide hot air into the cabin.
I am unsure of the make-up of the heater matrix/ core - is it possible something has partially blocked passenger side feed without affecting driver side?
I also wondered about the mixer flap inside the heater system not being tight on the motor, but it does switch between cold and warm air with engine off so it must be moving. I don't know how flap values are measured - at the flap or the motor?
The third alternative is an air lock. I sometimes get coolant leaking out of the hole under the expansion tank. It's minimal and random, though I suspect it happens under heavy load. System has been pressure tested - twice - and no leaks, so no air getting in.
Air lock, mixer flap, blocked core..... what is most likely?
kpm
C?ID=342561
To close this out, I had the heater matrix replaced which fixed the problem
